Results 1 to 10 of 19
Thread: OpenPilot
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    OpenPilot
    A thing is happening:
    As of this morning, we have a fork of Comma AI OpenPilot that can steer my 2018 Golf R. We're doing it by filtering the HCA_01 (Heading Control Assist) CAN messages from the A5 camera and inserting our own, and transparently passing the rest of its traffic. We're filtering Extended CAN right at the CAN gateway, so all the wiring and hardware bits are tucked away safe and invisible, plus it lets us integrate and enhance the ACC radar later on.
    This could be used, in combination with VCDS coding, to provide Active Lane Guidance functionality for vehicles that don't even have cameras from the factory. No windshield replacements, no CP, no FEC. Same may go for ACC. OpenPilot will use feedback from the factory radar, if present, but it can do purely vision-based ACC as well, and those CAN messages could be simulated.
    The PID feedback loops aren't dialed in yet, so it wants to pingpong between the lane markers, but now that we know it's feasible the rest will come together quickly. That's the theory anyway. Maybe I'll end up upside-down in a ditch. If I disappear off the Internet forever after posting this, Ross-Tech, please update my interface registrations to my wife and children.
    In other news, I accidentally found out a MQB vehicle can go ignition-on with the CAN gateway entirely unplugged. It would really prefer not to, but it will. 3,502 line Auto-Scan.
    Wednesday,30,January,2019,10:29:27:21122
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4451.4
    Dealer/Shop Name: Southwest Ohio Luxobarge Rescue
    Workshop Code: 444 08607 000005
    VIN: WVWVF7AU2JW177386   License Plate: 2018GOLFR
    Mileage: 22407km-13923mi   Repair Order: REL1891-HNIF-WHOOPS
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
              47 4B 52 5F 75 A5 A9 D6 D7
    VIN: WVWVF7AU2JW177386   Mileage: 22407km-13923miles
    29-Left Light -- Status: Malfunction 0010
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    4B-Multifunc. Module -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 0A2500122466010E3004
       ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
       ROD: EV_ECM20TFS0208V0906259P_VW37.rod
       VCID: CDD2285C9C831C22E6-8098
    9 Faults Found:
    21630 - No Communications with HVAC Control Module (J301)
              U0164 00 [032] - -
                        Mileage: 22283 km
                        Time: 00:00:00
                        Vehicle speed: 255 km/h
                        Coolant temperature: 9 °C
                        Intake air temperature: 9 °C
                        Voltage terminal 30: 12.753 V
                        Unlearning counter according OBD: 32
                        Engine: operating status: ES
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 9.0 °C
                        Time since engine start: 0.0 s
                        T_ES: 578 min
                        Cruise control switch actuation-Main switch: not activated
                        Cruise control switch actuation-Setting: not activated
                        Cruise control switch actuation-Activation: not activated
                        Cruise control switch actuation-Status: OK
                        Cruise control switch actuation-Accelerate: not activated
                        Cruise control switch actuation-Decelerate: not activated
                        Cruise control switch actuation-Cancel: not activated
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Coding: plausible
                        Cruise control switch actuation-Limit function: not selected
                        Cruise control switch actuation-Limit button: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        Cruise control switch actuation-Large increment: not activated
                        Cruise control switch actuation-Control component verified: No
                        T_AST_SAE: 0 s
    19854 - Steering Column Control Module
              U0212 00 [032] - No Communications
                        Mileage: 22283 km
                        Time: 00:00:00
                        Intake air temperature: 8 °C
                        Voltage terminal 30: 12.773 V
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    22008 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [040] - -
                        Mileage: 22283 km
                        Time: 00:00:00
                        Unlearning counter according OBD: 37
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    19311 - Door Control Module - Driver's Door
              U0199 00 [032] - No Communications
                        Mileage: 22283 km
                        Time: 00:00:00
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    22055 - No Communications with Power Steering Control Module
              U0131 00 [032] - -
                        Mileage: 22283 km
                        Time: 00:00:00
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    19868 - No Communication with Instrument Cluster
              U0155 00 [032] - -
                        Mileage: 22283 km
                        Time: 00:00:00
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    19870 - No Communication with Diagnostic Gateway
              U0146 00 [032] - -
                        Mileage: 22283 km
                        Time: 00:00:00
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    19875 - No Communication with ABS Brake Control Module
              U0121 00 [032] - -
                        Mileage: 22283 km
                        Time: 00:00:00
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    19879 - Body Control Module (Central Electric)
              U0140 00 [032] - No Communications
                        Mileage: 22283 km
                        Time: 00:00:00
                        ECU_STATE: ENG_STOP
                        T_ES: 578 min
                        T_AST_SAE: 0 s
    Readiness: 0000 0100
       Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 1403
       Revision: 00H06V07
       ROD: EV_TCMDQ381061.rod
       VCID: A10AA4ECB09BE84272-80F4
       Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
       Component: ESC           H25 0523
       Revision: 00000000    Serial number: 63627000001098
       Coding: 01FA6BA154272173457A030860C96980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
       VCID: 8346CE640A471A5240-80D6
    25 Faults Found:
    8192 - Databus
              [FCAN: ACC_07 message is not received]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
    8196 - Databus
              [FCAN : ACC_10 message is not received]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
    8206 - Databus
              [FCAN: Airbag_03 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8214 - Databus
              [FCAN: Diagnose_01 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8222 - Databus
              [FCAN : Getriebe_11 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8226 - Databus
              [FCAN : Getriebe_14 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8232 - Databus
              [FCAN: Kombi_02 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8234 - Databus
              [FCAN: Kombi_03 messag is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8246 - Databus
              [FCAN: Motor_Code_01 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8250 - Databus
              [FCAN: Motor_07 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8252 - Databus
              [FCAN: Motor_11 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8254 - Databus
              [FCAN: Motor_12 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8256 - Databus
              [FCAN: Motor_14 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8258 - Databus
              [FCAN: Motor_20 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8268 - Databus
              [FCAN: VIN_01 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8343 - Databus
              [FCAN : Gateway_79 message is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8362 - Databus
              [FCAN: RCTA_01 is not received]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
    8366 - Databus
              [FCAN: Charisma_01 is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8368 - Databus
              [FCAN: Charisma_07 is not received]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8382 - Databus
              [FCAN: HCA_01 not received]
                        Fault Frequency: 8
                        Reset counter: 129
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    8384 - Databus
              [FCAN: HCA_01 received with invalid checksum]
                        Reset counter: 129
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:09
    16409 - Display for Tire Pressure Monitoring
              C1146 02 [008] - Signal Failure
                        Reset counter: 121
                        Mileage: 22283 km
    16410 - Display for Tire Pressure Monitoring
                        Reset counter: 121
                        Mileage: 22283 km
    16411 - Display for Tire Pressure Monitoring
                        Reset counter: 121
                        Mileage: 22283 km
    16416 - Display for Tire Pressure Monitoring
                        Reset counter: 121
                        Mileage: 22283 km
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0464858592
       Coding: 032C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: BC3475983739A5AA41-80E8
    12715780 - Databus
              [Ausfall BEM_02-Botschaft - kein Signal/Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    12716548 - Databus
              [Ausfall Systeminfo - Botschaft -  kein Signal/Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    12716804 - Databus
              [Ausfall Motor_14 - Botschaft -  kein Signal/Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    12717060 - Databus
              [Ausfall Gateway_73 - Botschaft - kein Signal/Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    12717316 - Databus
              [Ausfall Gateway_71 - Botschaft - kein Signal/Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    12718084 - Databus
              [Ausfall Airbag_02 - Botschaft - kein Signal/Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0002000420010201110501401211142A
       Shop #: WSC 08607 444 00001
       VCID: ED9288DC3CC3FC2286-80B8
       Air quality sensor:
    459009 - Databus
              [Airbagsteuergerät - kein Signal/Kommunikation]
                        Reset counter: 121
    459024 - Databus
              [Frontsensorik - kein Signal/Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:12
    459013 - Databus
              [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                        Reset counter: 121
       Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H36 0253
       Serial number: 01001735200577
       Coding: 000000000000080000000000000000000000000000000000000000000000
       ROD: EV_BCMBOSCH_018.rod
       VCID: 8640D77039752F7A67-80D2
       Component: WWS    171209  043 0551
       Serial number:         171213061443
       Component: RLHS  047 0105
       Serial number: S4Y18M01D10H22M47S41
       Coding: 00A8DD
    19 Faults Found:
    204546 - Remote key 2
                        Reset counter: 81
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:42:51
    528405 - Databus
              [Airbag_01 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    528917 - Databus
              [ESP_21 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    529941 - Databus
              [BEM_02 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    531221 - Databus
              [Diagnose_01 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    531477 - Databus
              [Charisma_03 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    533269 - Databus
              [ESP_20 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    533781 - Databus
              [ESP_02 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    534549 - Databus
              [FLA_01 Datenbus fehlende Botschaft]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    535317 - Databus
              [Gateway_71 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    536085 - Databus
              [Gateway_73 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    540693 - Databus
              [LWR_AFS_01 Datenbus fehlende Botschaft]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    541973 - Databus
              [Motor_04 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    542229 - Databus
              [Motor_14 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    542485 - Databus
              [Motor_18 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    556309 - Databus
              [Systeminfo_01 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    558101 - Databus
              [Airbag_02 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    558613 - Databus
              [Gateway_78 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    559125 - Databus
              [Motor_07 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
       Part No SW: 5QA 919 294 B    HW: 5QA 919 294
       Serial number: 000308418918005
       Coding: 0471155811
       VCID: CBD6264462971212F8-809E
    13 Faults Found:
    12666384 - Databus
              [Diagnose-Interface für Datenbus-J533 - Diagnose_01 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    12665088 - Databus
              [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    12664864 - Databus
              [Steuergerät für BCM - Dimmung_01 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    12670210 - Databus
              [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    12648465 - Databus
              [Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    12648721 - Databus
              [Getriebesteuergerät - Getriebe_11 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    12666389 - Databus
              [Diagnose-Interface für Datenbus-J533 - Gateway_72 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    12727553 - Databus
              [Steuergerät für Abstandsregelung - Gateway_79.ACC_02_alt - kein Signal/keine Kommunikation]
                        Fault Frequency: 13
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
    12666390 - Databus
              [Diagnose-Interface für Datenbus-J533 - Gateway_79 - kein Signal/keine Kommunikation]
                        Reset counter: 121
    13637426 - Databus
                        Reset counter: 121
    13639168 - Databus
              [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                        Fault Frequency: 17
                        Reset counter: 128
    13688835 - Databus
              [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 20:26:21
    12648468 - Databus
              [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                        Reset counter: 121
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 331807E15DFFC728949C810580401600000000000000000000
       Shop #: WSC 08607 444 00005
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: BE307F902125B7BA6F-80EA
    10 Faults Found:
    2109 - Databus
              [FAULT_AWV_CONSISTENCY_FAIL]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 20:26:22
                        Control Module temperature: 34 °C
                        Voltage terminal 15: 14.5 V
    2111 - Databus
              [FAULT_ESP_CONS_ACC]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 20:26:22
    1799 - Internal Fault
              B200F F0 [008] - Unknown Error Elaboration
              [FAULT_TX_TIMEOUT_ACC_02]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
                        Control Module temperature: 11 °C
                        Voltage terminal 15: 12.7 V
    1798 - Internal Fault
              [FAULT_TX_TIMEOUT_ACC_04]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
    1797 - Internal Fault
              [FAULT_TX_TIMEOUT_ACC_06]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
    1796 - Internal Fault
              [FAULT_TX_TIMEOUT_ACC_07]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
    1795 - Internal Fault
              [FAULT_TX_TIMEOUT_ACC_10]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
    1800 - Internal Fault
              [FAULT_TX_TIMEOUT_ACC_13]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
    1801 - Internal Fault
              [FAULT_TX_TIMEOUT_ACC_15]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
    1794 - Internal Fault
              [FAULT_TX_TIMEOUT_KN_ACC]
                        Reset counter: 121
                        Mileage: 22283 km
                        Time: 00:00:00
       Serial number: 24111741350693
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: B83C69880301898AA5-80EC
    332548 - Databus
              [Gateway - kein Signal/Kommunikation]
                        Reset counter: 121
    336388 - Databus
              [Motor - kein Signal/Kommunikation]
                        Reset counter: 121
       Serial number: 003GCR09SK3W
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: C7DE1A747EFFF672DC-8092
       Occupant Detection:
       Serial number: IBH000000000008EZ3AU
       Coding: 303344
       Subsystem 2 - Part No SW: -----------    HW: 480 000 501 18
       Serial number: 35700000000198194A2G
       Subsystem 3 - Part No SW: -----------    HW: 480 000 201 18
       Serial number: 358000000007D82D1A2T
       Subsystem 4 - Part No SW: -----------    HW: 480 402 312 17
       Serial number: 3510001C9284E2D6869H
       Subsystem 5 - Part No SW: -----------    HW: 480 402 712 17
       Serial number: 3520001AB288D0F4E33G
       Subsystem 6 - Part No SW: -----------    HW: 480 402 212 17
       Serial number: 3550001C7284E2D3A79J
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 212 17
       Component: FrontSensor_P  000 6149
       Serial number: 3560001C7284E2D20755
    11 Faults Found:
    9482752 - Seat Occupied Recognition
              B10B2 00 [008] - Function Restriction due to Missing Message(s)
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
              B13BC F2 [008] - No function
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1054976 - Databus
              [NWD: 0x6B7 Kombi_02 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1051904 - Databus
              [NWD: 0x30B Kombi_01Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1052928 - Databus
              [NWD: 0x0FD ESP_21 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1051136 - Databus
              [NWD: 0x6B4 VIN_01 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1051392 - Databus
              [NWD: 0x6B2 Diagnose_01 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1048576 - Databus
              [NWD: 0x5F0 Dimmung_01 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1052672 - Databus
              [NWD: 0x392 ESP_07 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1053696 - Databus
              [CAN: 0x3DB Gateway_72 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
    1054208 - Databus
              [NWD: 0x3C0 Klemmen_Status_01 Timeout]
                        Reset counter: 167
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:14
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 28121704221561
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 895ADC4C286B40020A-80DC
    131108 - Databus
              U1121 00 [024] - Missing Message
              [Time-Out Gateway_71: Time-Out BSG]
                        Reset counter: 123
                        Time: 00:00:00
                        Operating time: 26267 min
                        Supply voltage: Terminal 30: 12.9 V
                        Voltage at switch: 4.98 V
                        Terminal 15 status: active
                        System status: 30
       Part No SW: 5G1 920 891 A    HW: 5G1 920 891 A
       Component: KOMBI         408 3195
       Coding: 03AD301A7F88CF0502886B0B54010000A0000000
       VCID: AB1646C4C2573212D8-80FE
    20 Faults Found:
    16777008 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_SWA_0x1A keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:17
    16777010 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_LDW_0x19 keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:17
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_AWV_0x1B keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:17
    16776960 - Databus
              [ACC_02 keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776961 - Databus
              [ACC_04 keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776962 - Databus
              [Airbag_01 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776965 - Databus
              [BEM_02 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776966 - Databus
              [Daempfer_01 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776967 - Databus
              [EPB_02 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776968 - Databus
              [ESP_24 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776969 - Databus
              [LDW_02 keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776970 - Databus
              [LWR_AFS_01 keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776971 - Databus
              [Motor_04 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776973 - Databus
              [RKA_01 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776978 - Databus
              [LH_EPS_01 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776982 - Databus
              [SWA_01 keine Kommunikation]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776980 - Databus
              [PLA_Status_01 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776983 - Databus
              [WBA_03 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776988 - Databus
              [TSK_07 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    16776993 - Databus
              [ESP_21 keine Kommunikation]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
       Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007198325
       Coding: 030100047F085902FB00827A9C0F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW37.rod
       Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0040
       Serial number: 29170002448880057427
       Coding: 35FFFF
       Serial number: 3640416404
    131593 - Unknown Error Code
              U1301 00 [008] - -
              [Time_out_node_0x09_multifunction_module_on_second_bus]
                        Reset counter: 124
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
                        Supply voltage: Terminal 30: 12.0 V
                        Terminal 15: On
    131662 - Lane change assistant control module
              U1045 00 [008] - No communication
              [Timeout Knoten 0x4E / 3C - Steuergerät für Spurwechselassistent]
                        Reset counter: 124
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
                        Terminal 15: On
    131663 - No Communications with Front Sensor Package for Driver Assist. Systems
              U10E0 00 [008] - -
              [Timeout Knoten 0x4F / A5 - Frontsensorik für Fahrerassistenzsysteme]
                        Reset counter: 124
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
                        Terminal 15: On
    131671 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [008] - -
              [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                        Reset counter: 124
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:11
                        Terminal 15: On
    66054 - Extended CAN Bus (SAE Bus C)
              U0047 00 [008] - Performance
              [Globaler Timeout CAN-Extended]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:35
                        Supply voltage: Terminal 30: 14.2 V
                        Terminal 15: On
       Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00003.11.17
       Coding: 0001
       VCID: CCD425586799152AF1-8098
    9 Faults Found:
    16652 - Databus
              [Getriebe - TO -- Get_11]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    16654 - Databus
              [Kombi - TO -- Kombi_01]
                        Fault Priority: 8
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    17466 - Databus
              [Kombi - TO -- Kombi_02]
                        Fault Priority: 8
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    17473 - Databus
              [Motorsteuergerät - TO -- Mot_11]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    16657 - Databus
              [Motorsteuergerät - TO -- Mot_12]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    17474 - Databus
              [Motorsteuergerät - TO -- Mot_14]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    16727 - Databus
              [Motorsteuergerät - TO -- Mot_20]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    17475 - Databus
              [Motorsteuergerät - TO -- Mot_Code]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    16659 - Databus
              [Gateway - TO -- Sys_01]
                        Fault Priority: 8
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:18
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
    0279 - Databus
              [databus - message missing]
                        Fault Frequency: 10
                        Reset counter: 128
                        Mileage: 22283 km
    0281 - ROD - Unknown Error Code
              - 00 [008]
                        Fault Frequency: 10
                        Reset counter: 128
                        Mileage: 22283 km
       Revision: 00000000    Serial number: 17000376691003
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: B4245DB81F696DEA89-80E0
    7 Faults Found:
    12666368 - Databus
              [Timeout Message Gateway_71]
                        Reset counter: 123
                        ELV State: 04
                        Information Clamps: 77 68
                        CoCo State: E0 01
                        WFS State: 17 0E
                        Vehicle speed: 0.00 km/h
                        Voltage: 6F
                        AD-Value H-bridge: 36
                        Clamp15 flip flop: SSTx: button contacts: 06
                        CAN signals: 0A
    12666369 - Databus
              [Timeout Message Motor_14]
                        Reset counter: 121
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 17 0E
                        Voltage: 6F
                        CAN signals: 0A
    12666370 - Databus
              [Timeout Message ESP_10]
                        Reset counter: 121
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 17 0E
                        Voltage: 6F
                        CAN signals: 0A
    12666372 - Databus
              [Timeout Message Gateway_73]
                        Reset counter: 123
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 17 0E
                        Voltage: 6F
                        CAN signals: 0A
    12666375 - Databus
              [Timeout Message BEM_02]
                        Reset counter: 121
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 17 0E
                        Voltage: 6F
                        CAN signals: 0A
    12666376 - Databus
              [Timeout Message Airbag_02]
                        Reset counter: 121
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 17 0E
                        Voltage: 6F
                        CAN signals: 0A
    12666381 - Databus
              [Timeout Message Motor_09]
                        Reset counter: 121
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 17 0E
                        Voltage: 6F
                        CAN signals: 0A
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
    0033 - Supply voltage
              [Supply voltage - lower limit exceeded]
                        Reset counter: 123
                        Mileage: 22312 km
                        Date: 2019.01.29
                        Time: 13:36:06
    0279 - Databus
                        Fault Frequency: 10
                        Reset counter: 128
                        Mileage: 22283 km
              - 00 [008]
                        Fault Frequency: 10
                        Reset counter: 128
                        Mileage: 22283 km
       Component: HRE_Master    H12 0080
       Serial number: 0464678659
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: BD32789C2C23ACA276-80E8
       Component: HRE_Slave  H12 0080
       Serial number: 0465504023
       Coding: 020111
    9 Faults Found:
    123396 - Databus
              [Airbag ECU Airbag_01 - no signal/no communication]
                        Reset counter: 127
    332549 - Databus
              [Gateway ECU Gateway_72 - no signal/no communication]
                        Reset counter: 127
    336901 - Databus
              [Braking ECU ESP_33 - no signal/no communication]
                        Reset counter: 127
    337156 - Databus
              [Kombi ECU Kombi_01 - no signal/no communication]
                        Reset counter: 127
    337184 - Databus
              [BCM ECU Blinkmodi_02 - no signal/no communication]
                        Reset counter: 128
    337280 - Databus
              [EPS ECU LWI_01 - no signal/no communication]
                        Reset counter: 127
    337312 - Databus
              [Parkhilfe ECU Parkhilfe_01 - no signal/no communication]
                        Reset counter: 127
    338032 - Databus
              [ESP_33:: ESC_Konsistenz_RCTA- nicht_konsistent]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
    512260 - Extended CAN Bus (SAE Bus C)
       Serial number: 021217EL138903
       Coding: 003E13208000040000000000
       VCID: C3C60E644AC7DA5200-8096
       Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000018361075
       Coding: 111000
    458752 - Databus
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    458809 - Databus
                        Reset counter: 123
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    458803 - Databus
                        Reset counter: 123
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    458857 - Databus
              [RGS_VL_01 Datenbus fehlende Botschaft]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    458851 - Databus
              [Mem_FS_01 Datenbus fehlende Botschaft]
                        Reset counter: 81
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:27:09
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 911F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: BB3676843237A29248-80EE
    24320 - Steering
              C10AC 07 [009] - Mechanical Failure
              [Belastungszähler hat 99% überschritten Belastungszähler hat 100% erreicht]
                        Reset counter: 89
                        Mileage: 22347 km
                        Date: 2019.01.30
                        Time: 04:08:50
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 11.00 V
                        Temperature: 12.0 °C
                        KFC: 5F
                        KFA: 00 00
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 11.20 V
                        uAdSensI_SwitchedKl30_xdu16: 11.09 V
                        NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
                        NoInitCause_RackPos_Rohwert: 00 00
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_KMN_RACKPOS_SET: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_WHLSPDPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
       Component: MIB2_lite_amp H40 0200
       Revision: 00000001    Serial number: VWZ8Z1HMD01KBFQ
       VCID: AE104FD0F145473AFF-80FA
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338     HW: 3Q0 907 338
       Component: FCM MQB Low   002 0286
       Serial number: 21121710521279
       Coding: 000000050100165207713F07020000000000000000000000000000000000
       VCID: F2A89BA025FD23DA5B-80A6
    7 Faults Found:
    13705488 - Databus
              [Diagnose_01 data bus missing message]
                        Reset counter: 121
    13705480 - Databus
              [Systeminfo_01 data bus missing message]
                        Reset counter: 121
    12601088 - Extended CAN Bus (SAE Bus C)
              [Databus extended no communication]
                        Reset counter: 128
    13706046 - Databus
              [LV_Abblendlicht_li_def received error value]
                        Fault Frequency: 16
                        Reset counter: 128
    13706047 - Databus
              [LV_Abblendlicht_re_def received error value]
                        Fault Frequency: 16
                        Reset counter: 128
    13705988 - Databus
              [FA_Hoehenwert_VL_00 received error value]
                        Fault Frequency: 7
                        Reset counter: 124
    13705989 - Databus
              [FA_Hoehenwert_HL_00 received error value]
                        Fault Frequency: 7
                        Reset counter: 124
       Serial number: 101217ELA06139
       Coding: 003E13208000040000800000
       VCID: C2C80B6055DDD35A0B-8096
       Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000018233831
       Coding: 091000
    458752 - Databus
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    458809 - Databus
                        Reset counter: 123
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    458803 - Databus
                        Reset counter: 123
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    458857 - Databus
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    851 0867
       Coding: 027310020000000051220002001808009F0507F401200405C6
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: B3265EA41A676AD290-80E6
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZJT3480215
       Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
       Component: NAR 2018  --- 0715
    9 Faults Found:
    6917 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ACC (0x05) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:37
                        Voltage terminal 30: 14.8 V
    6937 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:38
    6938 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Side assist (0x1A) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:37
    6939 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Brake assist system (0x1B) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 128
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:37
    7173 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:34
                        Voltage terminal 30: 12.3 V
                        BAP-BAP_Function_ID: 02
    7184 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Seat adjustment/seat memory (0x10) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 81
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:27:12
                        Voltage terminal 30: 12.4 V
    7193 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:34
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:34
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 128
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:43:34
       Component: OCULowMQBUS   009 0570
       Coding: 02730002C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
    7 Faults Found:
    12670464 - Databus
              [CAN TO brake]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    0022 - Databus
              [CAN TO radio]
                        Reset counter: 40
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    0035 - Databus
              [CAN TO Airbag]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    0036 - Databus
              [CAN TO GPS data]
                        Reset counter: 123
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    0041 - Databus
              [CAN TO Motor ECU]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    13633792 - Databus
              [CAN TO gateway]
                        Reset counter: 123
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
    12718848 - Databus
              [CAN TO Steering angle module]
                        Reset counter: 121
                        Mileage: 22283 km
                        Date: 2019.01.29
                        Time: 01:31:29
       Component: MQB_B_MFK     H07 0272
       Serial number: 22121712P20035
       Coding: 0003070000000201002213548156890088000E200120
    10 Faults Found:
    1122563 - Databus
              [Timeout_Airbag_01]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        Control Module temperature: 18 °C
                        Outside air temperature: -7.5 °C
                        System run time: 285.3 s
                        Voltage terminal 15: 14.3 V
                        mid: 01 A5
                        Status of camera: limited
                        Engine_Running_Info: 1
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122593 - Databus
              [TIMEOUT_ESP_21]
                        Reset counter: 40
                        Control Module temperature: -258 °C
                        Outside air temperature: 77.5 °C
                        Vehicle speed: 655.35 km/h
                        System run time: 0.0 s
                        Voltage terminal 15: 11.2 V
                        mid: 01 BF
                        Status of camera: Initializing
                        Engine_Running_Info: 255
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1135155 - Databus
              [Timeout_Gateway_73]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        mid: 01 CC
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122612 - Databus
              [TIMEOUT_Kombi_01]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        mid: 01 CF
                        Status of camera: operational
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1123606 - Databus
              [TIMEOUT_Licht_Anf_01]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        System run time: 285.8 s
                        mid: 01 B3
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122625 - Databus
              [TIMEOUT_LWI_01]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        mid: 01 D9
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122628 - Databus
              [Timeout_Motor_14]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        mid: 01 E5
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122629 - Databus
              [TIMEOUT_Motor_20]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        mid: 01 E9
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122679 - Databus
              [Timeout_TSK_06]
                        Reset counter: 40
                        Mileage: 22341 km
                        Date: 2019.01.29
                        Time: 19:57:33
                        mid: 02 12
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    0659 - Steering
              C10AC F2 [008] - Lane-Holding Assistance Not Coded
              [HC_interface_at_the_steering_not_activated]
                        Reset counter: 40
                        Time: 00:00:00
                        Control Module temperature: 8 °C
                        Outside air temperature: 77.0 °C
                        Vehicle speed: 655.34 km/h
                        System run time: 3.4 s
                        Voltage terminal 15: 12.1 V
                        mid: 02 A6
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 171206201656
       VCID: AF2E52D4F64F4E32F4-80FA
    0014 - Databus
              [Keine Funktion durch CAN FehlerESPsteuergerätebotschaft fehlt--> keine Klangerzeugung]
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: B93A6C8C380B90825A-80EC
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----(Elapsed Time: 02:45, VBatt start/end: 11.5V/11.4V. VIgn 11.4V)-----
    Silence gives consent.
  2. Likes Uwe, NZDubNurd, NEtech, downtime, D-Dub, dafrazi liked this post
  3. #2
    Video. We need video.
    PS:
    One of our distributors has a 2016 Passat in Germany with this kind of functionality from the factory and he says it's unusable due to behavior much like that.
  4. Likes PetrolDave, jyoung8607 liked this post
  5. #3
    Cincinnati, OH
    I'm going to need a few days for that...
    The lane centering feedback loop is substantially useless right now except to validate we can indeed command steering torque, you can't really go hands-off for a meaningful amount of time yet. And, it all needs to be refactored from the current jumble of copypasta we used for discovery and testing. I'm working on that. While that's happening, I've got a camera mount on the way that I wanted for WITW anyway.
    Hrm... not sure what you're referring to here. Something besides the usual A5 camera?
  6. Likes Uwe liked this post
  7. #4
    No, I'm pretty sure it's got the usual A5 camera.
  8. #5
    Jul 2014
    Tallinn, Estonia
    This normally shouldn't be the case with the 3Q0980654 A5 camera, which the Passat B8 and many other MQB cars use. It should definetly keep the car in the center of the lane. Perhaps have the dealer do a SW level update?
  9. #6
    Võru, Estonia
    Setting of lane assist needs to be tweaked higher for Autonomous driving feeling. When set in center or lower position, it does feel like drunk driver.
    The world is my oyster...
  10. Likes PetrolDave liked this post
  11. #7
    It ok, Jesus is taking the wheel!
  12. Likes Uwe, jyoung8607 liked this post
  13. #8
    Lansdale, PA
    Quote Originally Posted by DGMotors View Post
  14. #9
    I always wanted to do something like that for my volt to add ACC.
    I have the camera behind the mirror for emergency braking collision warning, but no blindspot detectors.
    looks like comma.ai supports some of the newer volts, but not the old ones. /sigh
  15. #10
    Cincinnati, OH
    Port DONE. Totally acceptable performance. Just need dramamine.
