Hello RossTechies!
I beg you for some insight and advice! I have a 2007 VW Eos and I suddenly got an airbag light that can’t be cleared. The car has not been in an accident. This appears to be a random failure. The fault code is:
00003 - Control Module
014 - Defective - MIL ON
Apparently the module is toast. I called the VW dealer in Austin, Tx and they said there is no airbag module available for this VIN in US or Canada. He said it could be a year or more before a replacement is found or manufactured. I would have to pay $600 in advance and later a few hundred more for coding. Not cool.
As I understand these modules have a Part Number but also a hidden index number (aka color code) with about a hundred variations. Thus, finding a used one with the right part number isn’t sufficient; it also must have the right index number. I read somewhere that this index number is written on the box when you buy a new module from the dealer. I also read on forums that a new or used airbag module must also be VIN coded by the dealer. I have a few questions and I really appreciate your thoughts:
1. Given a new module isn’t available, if I buy a used module on Ebay and the index code doesn’t match the one on my module, but it did come off of another 2007 Eos is there any way to make it work on my car?
2. My part number is 1Q0-959-655-A, but what is my index code? Autoscan attached.
3. Can the index code be changed by a dealer or third party or is it tied to the hardware in permanent way?
4. Is VIN coding the same as setting the index code, or are these completely separate things?
5. Can VIN coding be performed in VCDS? Is it through the adaptation option?
6. When I search VWPartsCenter.net there are a bunch of part numbers that supposedly replaced my part number 1Q0-959-655-A. Is that right? Will these replacements actually work? See screenshot below.
Thank you all so so much for any assistance!
Note: The driver's side igniter fault occasionally comes on calling out a resistance is too high. I would erase it and go on until it greeted me again. I know about the connector under the seat, but that's already been removed. It hadn't come on in a few months and then all of a sudden I got the hole module defective hard fault.
Tuesday,29,January,2019,21:59:04:40464
VCDS Version: 18.2.0.3 (x64)
VIN: WVWAA71F97V018698 License Plate:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 52 56 62 63
65
72
VIN: WVWAA71F97V018698 Mileage: 131980km-82008miles
0F-Digital Radio -- Status: Cannot be reached 1100
63-Entry Assist,D -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1Q0 907 115 E HW: 1Q0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH15--- Serial number: VWX7Z0F83NT8EB
Coding: 041C010A18070160
Shop #: WSC 03164 444 80806
VCID: 2E7DE498B9895534BA-807A
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021218
Shop #: WSC 00020 000 00000
VCID: 73CB35EC122B38DC15-8026
Part No SW: 1Q0 907 044 A HW: 1Q0 907 044 A
Component: ClimatronicPQ35 093 0101
Revision: 00093002 Serial number: 00000000000000
VCID: 2B7BED8C8A9B201C9D-807E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000006127809
Coding: 158C8F0340041500470000000F00000000285D035C0000
VCID: 3753C1FC46D394FCE9-8062
Component: Wischer 031006 020 0501
Coding: 00038805
Shop #: WSC 00020
Address 0F: Digital Radio
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 13 Airbag VW8C 0180
Revision: 92009018 Serial number: 003B3000YEXC
Coding: 0012595
VCID: 3A55D8C875C1899416-806E
Subsystem 1 - Part No: 1Q0 959 339 A
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 3EW5L
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ† 63
Subsystem 4 - Serial number: 000000ÿ† 6332SRB403CC8BA3Eÿ† 63
Subsystem 5 - Serial number: C8BA3Eÿ† 6342SRB403CDC6204ÿ† 63
Subsystem 6 - Serial number: DC6204ÿ† 6372URB4017D453C6ÿ† 63
Subsystem 7 - Serial number: D453C6ÿ† 6382URB4017D4041Zÿ
Subsystem 8 - Serial number: D4041Zÿ
Fault Status: 11101110
Fault Frequency: 21
Mileage: 131743 km
Time: 06:48:28
01217 - Side Airbag Igniter; Driver Side (N199)
Fault Status: 11100001
Mileage: 131849 km
Time: 00:16:12
001 - Upper Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100001
Mileage: 131870 km
Time: 00:55:25
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 036 0070
Coding: 0000041
VCID: 022560285D9101540E-8056
Part No SW: 1Q0 920 973 BX HW: 1Q0 920 973 BX
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWX7Z0F83NT8EB
Coding: 0023207
Shop #: WSC 47865 001 1048576
VCID: 0A35480865A1591446-805E
014 - Defective
Fault Status: 01101110
Mileage: 127713 km
Time: 11:57:07
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 310010691780DF
Coding: 3DBF23600F025000
VCID: 2C79EE908F95272494-8078
00469 - Infotainment Databus in Single Wire Operation
Reset counter: 50
Mileage: 127713 km
Time: 14:44:44
02649 - Digital Radio Tuner
Reset counter: 50
Mileage: 127713 km
Time: 14:44:48
Part No SW: 1Q0 919 965 HW: 1Q0 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 1350208TK4FS02
VCID: 79D707C43047428C5F-802C
Component: IMMO VDD 1610
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 B HW: 1Q0 959 255 B
Component: Verdecksteuergeraet 0622
Revision: 0032000K Serial number: 062630578
Coding: 0655360
Address 42: Door Elect, Driver Labels: 1K0-959-701-
MAX2.lbl
Part No: 1Q0 959 701 B
Component: Tuer-SG 024 2729
Coding: 0001207
VCID: 334BF5EC52AB78DCD5-8066
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
VCID: 3449F6F057A57FE4CC-8060
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CL
Component: KSG PQ35 RDK 051 0218
Revision: 00051000 Serial number: 00000000000000
Coding: 93908A800186281B0804040FB0080E04889C00
Shop #: WSC 01814 444 59532
VCID: 0429663047850F643C-8050
00849 - S-contact at Ignition/Starter Switch (D)
Reset counter: 191
Mileage: 131683 km
Time: 00:55:39
Address 52: Door Elect, Pass. Labels: 1K0-959-702-
MAX2.lbl
Part No: 1Q0 959 702 B
Coding: 0001206
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 017 0037
Revision: 00017000 Serial number: VWZ5Z7G2142892
Coding: 0040401
Shop #: WSC 39612 828 149130
VCID: 246906B0E745EF645C-8070
02218 - Satellite Radio (R146)
Fault Status: 01110100
Reset counter: 124
Mileage: 129077 km
Time: 00:00:40
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1Q0 959 703
Component: Tuer-SG 021 2705
Coding: 0000128
Address 63: Entry Assist,D Labels: 1Q0-959-790.lbl
Part No SW: 1Q0 959 790 A HW: 1Q0 959 790 A
Component: J572 EASYENTRY FS 0603
Revision: 00H02000 Serial number: 5DS008646-01--
Component: RDK 0440
Coding: 0100101
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 01:24)--------------------------
