Results 1 to 10 of 17
Thread: VW Eos 2007 -- Airbag module defective. Questions abound. Help pls!
    Verified VCDS-Lite User
    Jan 2019
    Hello RossTechies!
    I beg you for some insight and advice! I have a 2007 VW Eos and I suddenly got an airbag light that can’t be cleared. The car has not been in an accident. This appears to be a random failure. The fault code is:
    00003 - Control Module
    014 - Defective - MIL ON
    Apparently the module is toast. I called the VW dealer in Austin, Tx and they said there is no airbag module available for this VIN in US or Canada. He said it could be a year or more before a replacement is found or manufactured. I would have to pay $600 in advance and later a few hundred more for coding. Not cool.
    As I understand these modules have a Part Number but also a hidden index number (aka color code) with about a hundred variations. Thus, finding a used one with the right part number isn’t sufficient; it also must have the right index number. I read somewhere that this index number is written on the box when you buy a new module from the dealer. I also read on forums that a new or used airbag module must also be VIN coded by the dealer. I have a few questions and I really appreciate your thoughts:
    1. Given a new module isn’t available, if I buy a used module on Ebay and the index code doesn’t match the one on my module, but it did come off of another 2007 Eos is there any way to make it work on my car?
    2. My part number is 1Q0-959-655-A, but what is my index code? Autoscan attached.
    3. Can the index code be changed by a dealer or third party or is it tied to the hardware in permanent way?
    4. Is VIN coding the same as setting the index code, or are these completely separate things?
    5. Can VIN coding be performed in VCDS? Is it through the adaptation option?
    6. When I search VWPartsCenter.net there are a bunch of part numbers that supposedly replaced my part number 1Q0-959-655-A. Is that right? Will these replacements actually work? See screenshot below.
    Thank you all so so much for any assistance!
    Note: The driver's side igniter fault occasionally comes on calling out a resistance is too high. I would erase it and go on until it greeted me again. I know about the connector under the seat, but that's already been removed. It hadn't come on in a few months and then all of a sudden I got the hole module defective hard fault.
    Tuesday,29,January,2019,21:59:04:40464
    VCDS Version: 18.2.0.3 (x64)
    VIN: WVWAA71F97V018698   License Plate:
    Chassis Type: 1F (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 52 56 62 63
    65
              72
    VIN: WVWAA71F97V018698   Mileage: 131980km-82008miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    63-Entry Assist,D -- Status: OK 0000
       Part No SW: 1Q0 907 115 E    HW: 1Q0 907 115 B
       Revision: 5BH15---    Serial number: VWX7Z0F83NT8EB
       Coding: 041C010A18070160
       Shop #: WSC 03164 444 80806
       VCID: 2E7DE498B9895534BA-807A
       Revision: 00H11001
       Coding: 0021218
       Shop #: WSC 00020 000 00000
       VCID: 73CB35EC122B38DC15-8026
       Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
       Component: ClimatronicPQ35 093 0101
       Revision: 00093002    Serial number: 00000000000000
       VCID: 2B7BED8C8A9B201C9D-807E
       Revision: 00H46000    Serial number: 00000006127809
       Coding: 158C8F0340041500470000000F00000000285D035C0000
       VCID: 3753C1FC46D394FCE9-8062
       Component: Wischer 031006 020  0501
       Coding: 00038805
       Shop #: WSC 00020
    Address 0F: Digital Radio
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 13 Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B3000YEXC
       Coding: 0012595
       VCID: 3A55D8C875C1899416-806E
       Subsystem 1 - Part No: 1Q0 959 339 A
       Component: BF-Gewichtsens. 007 0003
       Subsystem 2 - Serial number: 3EW5L
       Subsystem 3 - Serial number: 0001.01.000000700000000000† 63
       Subsystem 4 - Serial number: 000000† 6332SRB403CC8BA3E† 63
       Subsystem 5 - Serial number: C8BA3E† 6342SRB403CDC6204† 63
       Subsystem 6 - Serial number: DC6204† 6372URB4017D453C6† 63
       Subsystem 7 - Serial number: D453C6† 6382URB4017D4041Z
       Subsystem 8 - Serial number: D4041Z
                        Fault Status: 11101110
                        Fault Frequency: 21
                        Mileage: 131743 km
                        Time: 06:48:28
    01217 - Side Airbag Igniter; Driver Side (N199)
                        Fault Status: 11100001
                        Mileage: 131849 km
                        Time: 00:16:12
                001 - Upper Limit Exceeded - Intermittent - MIL ON
                        Fault Status: 10100001
                        Mileage: 131870 km
                        Time: 00:55:25
       Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
       Component: J0527           036 0070
       Coding: 0000041
       VCID: 022560285D9101540E-8056
       Part No SW: 1Q0 920 973 BX    HW: 1Q0 920 973 BX
       Component: KOMBIINSTRUMENT VDD 1610
       Revision: V0003000    Serial number: VWX7Z0F83NT8EB
       Coding: 0023207
       Shop #: WSC 47865 001 1048576
       VCID: 0A35480865A1591446-805E
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 127713 km
                        Time: 11:57:07
       Part No SW: 1K0 907 530 H    HW: 1K0 907 951
       Component: J533__Gateway   H12 0150
       Revision:   H12       Serial number: 310010691780DF
       Coding: 3DBF23600F025000
       VCID: 2C79EE908F95272494-8078
    00469 - Infotainment Databus in Single Wire Operation
                        Reset counter: 50
                        Mileage: 127713 km
                        Time: 14:44:44
    02649 - Digital Radio Tuner
                        Reset counter: 50
                        Mileage: 127713 km
                        Time: 14:44:48
       Part No SW: 1Q0 919 965     HW: 1Q0 919 965
       Component: Kompass         002 0001
       Revision: 00002000    Serial number: 1350208TK4FS02
       VCID: 79D707C43047428C5F-802C
       Component: IMMO            VDD 1610
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
       Component: Verdecksteuergeraet 0622
       Revision: 0032000K    Serial number: 062630578
       Coding: 0655360
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-
    MAX2.lbl
       Part No: 1Q0 959 701 B
       Component: Tuer-SG         024 2729
       Coding: 0001207
       VCID: 334BF5EC52AB78DCD5-8066
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       VCID: 3449F6F057A57FE4CC-8060
       Part No SW: 1K0 959 433 CT    HW: 1K0 959 433 CL
       Component:    KSG PQ35 RDK 051 0218
       Revision: 00051000    Serial number: 00000000000000
       Coding: 93908A800186281B0804040FB0080E04889C00
       Shop #: WSC 01814 444 59532
       VCID: 0429663047850F643C-8050
    00849 - S-contact at Ignition/Starter Switch (D)
                        Reset counter: 191
                        Mileage: 131683 km
                        Time: 00:55:39
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-
    MAX2.lbl
       Part No: 1Q0 959 702 B
       Coding: 0001206
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       017 0037
       Revision: 00017000    Serial number: VWZ5Z7G2142892
       Coding: 0040401
       Shop #: WSC 39612 828 149130
       VCID: 246906B0E745EF645C-8070
    02218 - Satellite Radio (R146)
                        Fault Status: 01110100
                        Reset counter: 124
                        Mileage: 129077 km
                        Time: 00:00:40
       Part No: 1Q0 959 703
       Component: Tuer-SG         021 2705
       Coding: 0000128
    Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
       Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
       Component: J572  EASYENTRY FS  0603
       Revision: 00H02000    Serial number: 5DS008646-01--
       Component:    RDK              0440
       Coding: 0100101
    Address 72: Door, Rear Right
    End-------------------------(Elapsed Time: 01:24)--------------------------
    1) Not terribly practical. For a different index, you'd have to replace other airbag system components to match your new index.
    2) Your index is 013
    3) Neither the dealers' tool nor VCDS can change the index.
    4) I do not think there is any VIN coding needed on this car.
    5) See 4.
    6) I see no screenshot anywhere.
    PS: Moving this to Car Repair Support
  3. Likes kenovo liked this post
    Jan 2019
    Thanks Uwe. That's very helpful and I very much appreciate your responses.
    1. Just curious, how did you determine the index code?
    That code doesn't appear in the auto-scan readout.
    With the index code I found this part number that claims to replace my part number and index. It appears to be my best bet.
    https://cdn1.imggmi.com/uploads/2019...0a624-full.jpg
    https://www.vwpartscenter.net/?year=...&search_in=all
    Quote Originally Posted by kenovo View Post
    Sure it does. You just have to know where to look for it:
       Coding: 0012595
    Note that it will generally not appear there in a brand-new module until after it has been coded.
  6. Likes PetrolDave liked this post
    PS: What's with the side airbag faults on both sides?
    Jan 2019
    Hey Uwe,
    Two follow-up questions:
    1. Please comment on the part number (1Q0-959-655-B-01B) as a replacement for (1Q0-959-655-A-013) in the above link from vwpartscenter.net? Does it make sense that there would be a different replacement part number for an airbag control module? Have you seen this before? Will it work with the other airbag components?
    2. Specify what kind of coding you refer to in your reply "Note that it will generally not appear there in a brand-new module until after it has been coded"? You previously said that no VIN coding was needed, so what kind of coding *is* needed? I'm looking for the type or name of the coding so I can then search for how to do it.
    Many thanks again for sharing your knowledge.
    Jan 2019
    I was hoping that this was caused by the failing control module. These codes have come up every few months from time to time. It's a well known fault that's often associated with the wiring harness connector under the seat. VW had a tech bulletin on this and the dealer would cut out the original connector and put in butt connectors. This was already done on this car, so I'm not sure why this is happening.
  10. #8
    I don't know whether that's correct or not. I don't personally have access to an official parts catalog.
    It is not terribly unusual for control module part numbers to get superseded. Sometimes they're fully compatible, but we've also seen cases where the replacements are not compatible with other stuff in the car and require upgrading of other components as well. With airbag modules, it has often been side crash sensors, and with front door control modules, the rears sometimes need to get upgraded when the fronts are replaced.
  11. #9
    Just this:
       Coding: 0012595
    You may find this article in our Wiki helpful:
    http://wiki.ross-tech.com/wiki/index.php/Airbag_Coding
  12. Likes kenovo liked this post
  13. #10
    Jan 2019
    Do you think the side airbag faults could be or could have been related to the failed control module? Likely or unlikely?
