Results 1 to 3 of 3
Thread: 2011 Audi A4 CAEB 2.0t Injection Volume
    Jan 2019
    I'm taking a current baseline of key VCDS measurements for my 2011 Audi A4 with the CAEB 2.0t engine with an 8-speed automatic transmission. No modifications. 88k miles.
    I came across a potential anomaly when measuring IDE01932, High pressure pump injection volume mm3. Logging was performed at WOT in 3rd gear with numerous runs.
    Per the graph below, the injection volume as observed today is significantly lower than when I logged the same ID three years ago.
    A few questions:
    What is the expected range for Injection Volume values?
    Is this a command/expectation or observation/result value?
    Which sensor monitors Injection Volume?
    All other measurements I took (fuel pressure, boost, timing, AFR, Load, wastegate, etc.) look as expected and I'm trying to confirm whether my fueling works as expected or do I have a HPFP or injectors issue.
    Any insights or comparison logs would be greatly appreciated.
    16.4905 S, 151.7375 W
    - If there is no "specified value" listed in the Advanced Measuring Values, it would appear it is not possible to know.
    - I would speculate the "High pressure pump injection volume (mm3)" is a calculated value, since there is no sensor for fuel volume, only pressure pressure.
    Question:
    - Where the conditions the exactly the same three years ago as they were during the last baseline tests?
    I am thinking that normal powertrain wear, fuel formulas, ECM strategies and other conditions (atmospheric and others) could be the cause of the "potential anomaly".
    Is there anything wrong with the vehicle? It would be helpful to post up an Auto-Scan of the vehicle in question when asking such questions.
    This question would be best answered by the people who designed the system.
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
    Jan 2019
    Thank you for the response, drpeter.
    Recent Autoscan:
    Sunday,10,February,2019,12:52:54:17532
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUWFAFL0BA084802   License Plate:
    Mileage: 143160km-88955mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
              77
    VIN: WAUWFAFL0BA084802   Mileage: 143160km-88955miles
    Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0002
       Revision: E1H19---
       Coding: 010C010A290F0160
       Shop #: WSC 51072 001 1048576
       ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
       ROD: EV_ECM20TFS0118K2907115AG.rod
       VCID: 74EC30F4DFFF53EAC9-8020
    Readiness: 1110 0101
       Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
       Component: 0BK 20TFSIUSA H08 0010
       Revision: --H08---
       Coding: 001112
       Shop #: WSC 06342 000 00000
       ASAM Dataset: EV_TCMAL551211 001013
       ROD: EV_TCMAL551211_001.rod
       VCID: 3E78D2DCA133C9BAEF-806A
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0060
       Coding: 1D0D18
       VCID: 0200662C9D4B6D5ACB-8056
       Part No SW: 8K0 907 064 CG    HW: 8K0 907 064 CG
       Component: BCM2 2.0      H05 0434
       Coding: 090200
       VCID: 77F607F8C68938F2EC-8022
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Component: FBSAUDIB8 IDG  H50 0071
       Serial number: 0810000115895004
       Serial number: 2310000054180016
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01161120102291
       Coding: 64002000
       VCID: 00046C2493477F4ADD-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000856880
       Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000
       Shop #: WSC 06342 123 12345
       VCID: 3C7CD8D4BF2FDBAAC1-8068
       Component: WWS 181110  H06 0070
       Serial number: SWF10110180017
       Coding: 00F511
       Component: RLS  H04 0003
       Serial number: 11154499
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000911100513
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0GV1Z7
       Coding: 303837354230303030304A55304C384B3053
       Shop #: WSC 06335 000 00000
       VCID: 458ABD30C4E59A62AE-8010
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1000001YUA
       Serial number: 6334MSME57542635A
       Serial number: 6344MSME590037356
       Serial number: 6352QSME786A4B1E
       Serial number: 6362QSME086B3232D
       Serial number: 63732SME1B780E00/
       Serial number: 63832SME6C7731362
       Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
       Component: Lenks.Modul   H07 0156
       Revision: 00000000    Serial number: 20101124000028
       Coding: 000037
       VCID: 4992B100E0FD7E024A-801C
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 950 H    HW: 8K0 920 950 H
       Component: KOMBIINSTR.   H20 0258
       Revision: 00200000    Serial number: EIL74AHCA
       Coding: 831F11000300D705020000
       VCID: 346CF0F4977F13EA09-8060
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G10B0281FB
       Coding: 00C303
       VCID: 01026920984D7642D2-8054
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 10006E66151110
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020302
       VCID: 3972C1C0B01DEE82DA-806C
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000011704541
       Coding: 011C03204000410001
       VCID: 4A908E0CE5FB751A43-801E
       Revision: 00002001    Serial number: 0137830379
       Coding: 0126063A20BA441480B0023200000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000328830
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS150  H08 0043
       Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J394 PS229  H07 0041
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
       Component: DSP Prem      H19 0320
       Revision: 00019001    Serial number: 34803000451301
       Coding: 0203010302
       Shop #: WSC 20205 444 13906
       VCID: 7EF812DCE9B309BAAF-802A
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000110556150
       Revision: 00000003    Serial number: 00000000798706
       Part No: 8K5 907 357 B
       Coding: 0000004
       VCID: 3972C1C0701DEE82DA-806C
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H06 0351
       Revision: 00000009    Serial number: AUZ5Z6J1498045
       Coding: 04030002010285004359070800
       VCID: 4688BA3CF1E3917AA7-8012
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
                        Reset counter: 229
                        Mileage: 142877 km
                        Date: 2019.01.30
                        Time: 20:59:06
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000110509120
       Coding: 010C03204000210001
       VCID: 458ABD30CCE59A62AE-8010
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000110509185
       Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005100014
       Coding: 0010370
       VCID: 3D7AD5D06435D2A2F6-8068
    End-------------------------(Elapsed Time: 03:28)--------------------------
    Regarding test conditions, I kept all variables as consistent as possible: same stretch of highway, same gear, etc.
    Over the years, major work was performed to the car, including oil consumption stage 1 and 2 fix (PCV, pistons and rings), timing chain and tensioner replacement.
    Car still has original HPFP and injectors.
    I'm at 5000ft altitude which affects charge pressure and air flow readings.
    I inspected the intake valves via borescope and see a good amount of carbon build-up.
    The car doesn't throw any codes, but I dug a little deeper into the fuel trim values. LTFT hovers around 13%. Screenshot at idle with warmed up engine:
    Already did an intake pressure test to check for air leaks which passed. I still need to inspect for any exhaust leaks.
    Car is at 90k miles and a carbon cleanup of the intake is on the horizon and I'm contemplating replacing the fuel injectors at the same time.
    Bottom line, I'm trying to gauge whether the car operates within expected ranges and learn more about ECU management in the process.
  5. Likes Uwe liked this post
