Results 1 to 4 of 4
Thread: 2009 AUDI A6 3.0T Engine light
    Aug 2014
    Now permanent in Maryland, USA.
    Hi Folks,
    I have this A6 with CEL on. I have tried to look out for air leaks but none. I also cannot seem to believe both banks secondary injection system have failed. Visual inspection shows all hose connections are ok. All fuses tested ok.Also I could not use VCDS to carry out actuator diagnosis on the secondary air pump to run, the sequence goes through but Sec air did not come up on VCDS screen as part of the test during the actuator diagnosis, like as it is in most cases for other audi/vw models.
    Is there any measured value blocks I could use to check the fuel trim codes logged? I heard the secondary air ports block sometimes but wondering if all 2 banks ports could block same time or what to look out for?
    Any inputs appreciated!
    Thanks guys.
    Friday,23,November,2018,13:32:40:46890
    VCDS Version: 18.9.0.2 (x64)
    VIN:    License Plate: AsiaT
                    Address 01: Engine       Labels: 06E-907-551-CAJ.clb
    Control Module Part Number: 4F1 910 551 A    HW: 4F1 907 551
      Component and/or Version: 3.0l V6 TFSI        0080
               Software Coding: 0105000A190F0120
                Work Shop Code: WSC 40864 444 84539
                          VCID: 21422C9DF87EC042FA-8074
                   U1017 - 000 -  - Intermittent
                        Mileage: 217274 km
                        Date: 2008.06.07
                        Time: 20:49:20
                        RPM: 896 /min
                        Mass Air / Rev.: 87.2 mg/str
                        Temperature: 49.5°C
                        Bin. Bits: 00000010
                        Load: 8.6 %
    001170 - Secondary Air Injection System: Bank 2
                   P0492 - 000 - Insufficient Flow - MIL ON
                        Fault Status: 11100010
                        Mileage: 217310 km
                        Date: 2018.11.22
                        Time: 10:52:50
                        RPM: 864 /min
                        Mass Air / Rev.: 256.2 mg/str
                        Temperature: 27.0°C
                        Bin. Bits: 00000010
                        Voltage: 13.67 V
                        Bin. Bits: 00000010
    001169 - Secondary Air Injection System: Bank 1
                   P0491 - 000 - Insufficient Flow - MIL ON
                        Mileage: 217310 km
                        Date: 2018.11.22
                        Time: 10:52:40
                        RPM: 896 /min
                        Mass Air / Rev.: 305.2 mg/str
                        Temperature: 24.0°C
                        Bin. Bits: 00000010
                        Voltage: 13.46 V
                        Bin. Bits: 00000010
    Address 01: DTCs cleared
    Address 03: DTCs clearedMonday,28,January,2019,16:33:25:46890
    VCDS Version: 18.9.1.0 (x64)
    VIN:    License Plate: ASIATU
                          VCID: 21422C9DF87EC042F2-8074
                        Mileage: 217352 km
                        Date: 2018.11.23
                        Time: 09:40:55
                        RPM: 1280 /min
                        Mass Air / Rev.: 185.3 mg/str
                        Temperature: 16.5°C
                        Bin. Bits: 00000010
                        Voltage: 13.46 V
                        Bin. Bits: 00000010
                        Mileage: 217352 km
                        Date: 2018.11.23
                        Time: 09:40:45
                        RPM: 1280 /min
                        Mass Air / Rev.: 234.4 mg/str
                        Temperature: 15.0°C
                        Bin. Bits: 00000010
                        Voltage: 13.57 V
                        Bin. Bits: 00000010
    004408 - Fuel Trim: Bank 2 (Add)
                   P1138 - 000 - System too Lean - Intermittent
                        Fault Status: 00100001
                        Mileage: 219142 km
                        Date: 2019.01.05
                        Time: 00:46:05
                        RPM: 672 /min
                        Mass Air / Rev.: 158.1 mg/str
                        Temperature: 84.0°C
                        Bin. Bits: 00000010
                        Time: 204.8 s
                        Bin. Bits: 00000010
    Chassis Type: 4F-AU56 (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4C
              4F 52 53 55 56 62 72 77
    VIN: WAUSG74FX9N014545   Mileage: 219370km-136310miles
    4C-Tire Pressure II -- Status: Malfunction 0010
    Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
       Part No SW: 4F1 910 551 A    HW: 4F1 907 551
       Component: 3.0l V6 TFSI        0080
       Revision: --H02---    Serial number:
       Shop #: WSC 40864 444 84539
                        Mileage: 217352 km
                        Date: 2018.11.23
                        Time: 09:40:55
                        RPM: 1280 /min
                        Temperature: 16.5°C
                        Bin. Bits: 00000010
                        Voltage: 13.46 V
                        Bin. Bits: 00000010
                        Mileage: 217352 km
                        Date: 2018.11.23
                        Time: 09:40:45
                        RPM: 1280 /min
                        Temperature: 15.0°C
                        Bin. Bits: 00000010
                        Voltage: 13.57 V
                        Bin. Bits: 00000010
                        Mileage: 219142 km
                        Date: 2019.01.05
                        Time: 00:46:05
                        RPM: 672 /min
                        Temperature: 84.0°C
                        Bin. Bits: 00000010
                        Time: 204.8 s
                        Bin. Bits: 00000010
       Part No SW: 4F1 910 156 K    HW: 09L 927 156 C
       Component: AG6 09L 3,0TFSI USA 0020
       Revision: --H04---    Serial number:        4488831
       Shop #: WSC 02325 785 00200
       VCID: 2C5CCDA98FBC1D2A51-8078
       Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
       Component: ESP8 quattro    H01 0060
       Coding: 0020921
       VCID: 6ED807A179202F3A3F-803A
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601208775
       Coding: 0000003
       Shop #: WSC 02323 785 00200
       VCID: 254A388DEC562C628E-8070
       Subsystem 1 - Part No: 4F0 910 132 J
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 303IY087564962
       Coding: 0000003
       Shop #: WSC 02335 785 00200
       VCID: 3162DCDDA89E70C262-8064
       Subsystem 2 - Serial number: 00000001194191
       Subsystem 3 - Serial number: 0107.10.080000000100011120˙
       Subsystem 4 - Serial number: 011120˙
       Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000054    Serial number: 00000000575467
       Coding: 0524326
       VCID: 1C3C1D69DF1CEDAA21-8048
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H22 0320
       Coding: 0013123
       VCID: 346CD5C9578C45EA09-8060
       Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       VCID: 2B5ECEB54AB21A1258-807E
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7H0421462
       Coding: 0000100
    Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 M    HW: 4F0 959 655 F
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003000000000
       Coding: 303142373034303030314A55304C34463053
       ROD: EV_Airba10AURB4.rod
       VCID: 3162DCDD609E70C262-8064
       Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
       Component: BF-Gewichtss.  H03  0060
       Serial number: 5810000R0000002TSL
       Serial number: 3574SRB4000081E0625$
       Serial number: 3584SRB4000081E4A8CI
       Serial number: 35152RB402V7EMTB4KM5
       Serial number: 35252RB402P7EMTASSOX
       Serial number: 3554NRB40000458B4C63
       Serial number: 3564NRB40000458CA98A
       Revision: 00H03000    Serial number: 90026082700132
       Coding: 0002041
       VCID: 27563285965A3E72BC-8072
    Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 951 D    HW: 4F0 920 951 D
       Component: KOMBIINSTR.   H06 0133
       Revision: 00200000    Serial number: 9IW441AA8
       Coding: 8B960A050300CF05020201
       Shop #: WSC 02391 823 56573
       VCID: 285431B95B44310AB5-807C
       Part No SW: 4F0 907 468 F    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0024
       Revision: 4LA70021    Serial number: 2100L08A050004
       Coding: 000303
       VCID: 3260D3D16D984BDA1B-8066
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0100
       Serial number: 00000000002730027267
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
       Component: MP3-Changer     H47 0390
       Revision: 00047003    Serial number: AUZ5ZBH8619501
       VCID: 1A301B71D528939A33-804E
       Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
       Component: MEM-FS        H08 0062
       Revision: AA000000    Serial number: 00001001160747
       Coding: 00581300004011110000
       VCID: 3162DCDD689E70C262-8064
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
       Component: MNS US          H52 1100
       Revision: 00000000    Serial number: 341JS097816101
       Shop #: WSC 08201 444 85739
       VCID: 3874E1F94BE4A18A25-806C
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000100349455
       Coding: 011F07204E40410001
       VCID: 46889F01F110C77AA7-8012
                        Fault Frequency: 9
                        Reset counter: 91
                        Mileage: 215411 km
                        Date: 2018.09.26
                        Time: 15:53:12
       Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Component: Komfortgeraet   H28 0240
       Revision: 02400028    Serial number: 01151969620000
       Coding: 4618269
       VCID: 356AE8CD5CF65CE23E-8060
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 M    HW: 4F0 035 223 N
       Component: Amp.-ASK-RD   H07 0270
       Revision: S1400000
       Coding: 060000
                000 -  -  - Intermittent
                        Reset counter: 31
                        Mileage: 217213 km
                        Date: 2018.11.11
                        Time: 17:39:53
                        Voltage: 11.10 V
                        Temperature: 20.0°C
                        Bin. Bits: 00000011
                        Fault Status: 00101011
                        Reset counter: 144
                        Mileage: 218927 km
                        Date: 2019.01.02
                        Time: 15:04:59
                        Voltage: 12.40 V
                        Temperature: 30.0°C
                        Bin. Bits: 00000011
       Part No SW: 4F0 910 274 A    HW: 4F0 907 274
       Component: J793  RKA+      H02 0100
       Revision: 00000000    Serial number: 00008390032710
       Coding: 0623301
       Shop #: WSC 00477 128 42026
       VCID: 22402391FD78DB5AEB-8076
    02214 - Tire Pressure Warning
                        Reset counter: 162
                        Mileage: 219282 km
                        Date: 2019.01.25
                        Time: 19:49:50
                        Hex Value: 0x0004
                        Hex Value: 0x0000
                        Hex Value: 0x0007
                        Voltage: 14.30 V
                        Temperature: 2.0°C
                        (no units): 53.0
       Part No SW: 4F0 910 280     HW: 4F0 907 280 C
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000247969
       Coding: 0002014
       VCID: 5EB857618980BFBA8F-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000100351239
       VCID: 458A980DCC16CC62AE-8010
                        Reset counter: 144
                        Mileage: 215370 km
                        Date: 2018.09.25
                        Time: 11:46:47
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000222
       Shop #: WSC 02145 785 00200
       Part No: 8P0 907 357 H
       Coding: 0000003
       VCID: 3F868AE56ECA96B2E4-806A
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
       Revision: 00000000    Serial number: 379J3087539076
       Revision:             Serial number: 0000100345865
       Coding: 010E07204040220001
       VCID: 438E8615C222F25280-8016
       Revision:             Serial number: 0000100365817
       Component: Handyvorb2      H20 1130
       Revision: 00000000    Serial number: 00000005064905
       Coding: 0010900
       VCID: 285431B99B44310AB5-807C
    End-------------------------(Elapsed Time: 03:54)--------------------------
    Please clear codes and post a fresh auto-scan and with Mode 9 of OBD2 please.
    Thank you
    HQ
    Under certain driving conditions, the secondary air ports in the cylinder head can accumulate carbon over time, causing a restriction.
    - Technical Service Bulletin 2033001
    This is a very common issue for older V6 engines in the Audi fleet. The fix is to drop the exhaust, expose the front end of the engine and with special adapters pressure wash the ports in the cylinder heads. Then, X miles later, it will do it again.
    Jef
  4. Likes Jack@European_Parts, Uwe liked this post
  6. Likes Uwe liked this post
