Results 1 to 7 of 7
Thread: Audi A6 C5 Tiptronic doesn't work (P0702)
    New User
    Jan 2019
    Hello!
    My Audi A6 C5 Allroad 2.5 TDI AKE 2000 has run to some problems. During the weekend I was in the warm garage doing maintenance (changed CV joint and track rod end). After that I drove my car outside where was -25C, and noticed that my steering wheel wasn't straight. It was little bit to the left while driving straight. Next day after a very cold night, I did an test drive and everyhting was fine except that steering wheel was to the left. Until I noticed that the tiptronic didn't change gears at all.
    On the dashboard where is visible current selected gear, there was all lights "on" like I had every gear in. P,R,N,S,D were all "on". Car was powerless, and even that manual gear select +/- didn't work. So i drived back home. After that I checked with VCDS I noticed it had the 4th gear in all the time. I checked the faultcodes and got only one code from transmission:
    Sunday,27,January,2019,14:05:08:61411
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUZZZ4B42N026830   License Plate: ILT-788
    Mileage: 314660km-195520mi   Repair Order: Auto.Vaihteisto vika
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
              75 76 77
    VIN: WAUZZZ4B42N026830   Mileage: 314660km-195520miles
    Address 01: Engine        Labels: 059-907-401-AKE.clb
       Part No: 4Z7 907 401 B
       Component:  2.5l/4VTEDC G000AG D06
       Coding: 01016
       Shop #: WSC 02325
       VCID: 3C7CE7332C8444AAC1-4B00
       Subsystem 1 - Part No: 00015059
       Component: 130 106EC150_1.R75438336187
       WAUZZZ4B42N026830     AUZ7Z0A1903996
    Readiness: N/A
       Part No: 4Z7 927 156 H
       Component: AG5 01V 2.5lTDI RdW 2121
       Coding: 00001
       VCID: 4B9EB4EF792AF31278-513C
    17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
                P0702 - 35-00 -
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389
       Component: ABS/ESP allrad      D57
       Coding: 06357
       Shop #: WSC 02325
       VCID: 09124EE733D6A1028A-513C
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AD
       Component: A6-Klimavollautomat 0104
       Coding: 00003
       Shop #: WSC 02325
       VCID: 5CBC47B3CCC464AAE1-2578
                57-00 - Electric Circuit Failure
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 D
       Component: Airbag 8.4E         3000
       Coding: 0000106
       Shop #: WSC 02325 785 00200
       VCID: 50A4A383C00CD0CA0D-5120
       Part No: 4B0 920 933 M
       Component: KOMBI+WEGFAHRS. VDO D07
       Coding: 04160
       Shop #: WSC 00001
       VCID: 2D5ADA77E7FEDD2246-5120
    Address 34: Level Control        Labels: 4Z7-907-553.lbl
       Part No: 4Z7 907 553 E
       Component:  - 2C1A1          D040
       Coding: 25500
       Shop #: WSC 09999
       VCID: 479688DF654217725C-5120
    01772 - Signal from Level Control Pressure Sensor (G291)
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 K
       Component: Zentralverrieg.,DWA D35
       Coding: 06987
       Shop #: WSC 02325
       VCID: 3162C607FBC6B9C262-4ECA
    01560 - Passenger Door
                59-10 - Can't Unlock - Intermittent
    01561 - Rear left door
    01562 - Rear right door
                60-00 - Won't Safe
                61-10 - Won't De-Safe - Intermittent
                61-00 - Won't De-Safe
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0101
       Coding: 00001
       VCID: 2C5CD773DCE4D42A51-4B00
    Address 37: Navigation        Labels: 4B0-035-192-RNSD-37.lbl
       Part No: 4B0 035 192 M
       Component: RNS 4.1 H06    BNO 0017
       VCID: 2756285FC502F772BC-4ACE
                36-00 - Open Circuit
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00002
       Shop #: WSC 02325
       VCID: 60C47343E0AC404ABD-4B32
       Part No: 4Z7 907 357
       Component: dynamische LWR       D06
       Coding: 00030
       Shop #: WSC 02325
       VCID: 040C5FD314F4FC6AF9-4B7C
    Address 56: Radio        Labels: 4B0-035-192-RNSD-56.lbl
       Component: Radio          BNO 0001
       Coding: 00117
       Shop #: WSC 02325
       VCID: 2756285FC502F772BC-4AE6
    Address 57: TV Tuner        Labels: 4D0-919-146.clb
       Part No: 4D0 919 146 B
       Component: TV Tuner        H05 0704
       Coding: 0000160
       VCID: 28542B63981CF80AB5-5120
    Address 76: Park Assist        Labels: 8E0-919-283-8E2.lbl
       Part No: 8E0 919 283
       Component: Parkingsyst. A6 RDW D09
       Coding: 01186
       Shop #: WSC 02325
       VCID: 6DDA1A77277E1D2206-513C
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
                37-00 - Faulty
    End-------------------------(Elapsed Time: 04:44)--------------------------
    After that, I took TCU out and got it inside to warm up. I kept it in warm for 2 days, plugged it in again, heated car from inside, and deleted faultcodes. Fault gets back.
    I have no idea what should I do next. Do I need to buy new TCU, or is there something else I should check before that?
    Thanks for help!
    Jul 2014
    I think the first thing to do is retrace your steps of fitting the CV and track rod end, did you displace/disconnect/damage a TCM connector. Have you checked the fuses that power the TCM. You also need to get the wheel alignment done as the track rod end is not in the same place or has different dimensions from the original.
    Regards HMC
    New User
    Jan 2019
    Thanks for tips!
    What should I look for at wheel surrounding? Is there somewhere TCM connector or something? I have checked all the fuses on the drivers side inside car, but I have no idea where the TCM fuse is. Is it where is ECU, under the hood and on the drivers side?
    I will get the Wheel alignment done as soon as I get this sorted out, I dont want to drive with that car in case if that would brake the transmission completely… Getting pretty frustrated, should get the car working so I could go to work
    New User
    Jan 2019
    Quote Originally Posted by HMC View Post
    Regards HMC
    I checked all fuses, they are okay. Could wheel alignment differense cause this? Or some other minor thing? Is there any way to see/test my TCM condition?
    Jul 2014
    You need to make sure the TCM is powered and has a good earth. I cannot look at a wiring diagram until Monday. If you are sure it is powered, http://wiki.ross-tech.com/wiki/index...6/P0702/001794 does not look good.
    HMC
  6. #6
    New User
    Jan 2019
    HMC
    Yes, I found at ebay some used boxes for around 300€. Could you please provide me with an wiring diagram so I could check the wirings? I've been trying to look it myself, but havend found any diagrams.
  7. #7
    Please see: Where do I get a Wiring Diagram.
