Results 1 to 5 of 5
Thread: How do I activate the rear fog lights? (2010 A3 8PA)
    Jan 2019
    Dear All,
    I own a 2010 Audi A3 2.0T Premium Plus. My car has Xenon, DRL but no Auto sensor or come home. I moved the car to Europe and in order to pass the local inspection I need to activate the rear fog lights. I would like to avoid changing the light fixtures.
    After reading around I got the necessary switch (8P1941531BQ) and now I will have to do the necessary coding. I tried what is written here ( https://oooo-a3.blogspot.com/2005/11...og-lights.html ) but the information refers to an older A3 and does not seem to apply to mine.
    Has anyone done this? Could you please share the right procedure for changing the coding? If it helps the current coding of the central electronics module from VCDS is:
    2E000A3FB83336E4287241E000100D4D411E62AA104DD929E4 0008840040
    Thanks in advance
    Dimitris
    A full Auto-Scan would be more helpful.
  3. Likes Uwe liked this post
    Jan 2019
    Here it goes:
    Sunday,27,January,2019,12:30:26:16569
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUKFBFM6AA101369   License Plate:
    Mileage: 58830km-36555mi   Repair Order:
    Chassis Type: FM (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 55 56 62 65
              72 77
    VIN: WAUKFBFM6AA101369   Mileage: 58830km-36555miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 8P0 907 115 AM    HW: 8P0 907 115 Q
       Revision: AAH11---    Serial number: AUX7Z0INFNO0E8
       Coding: 0103010A1C070160
       Shop #: WSC 06314 000 00000
       VCID: 7DDF21B024B1D7A2B6-8028
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 19.0C
                        Temperature: 18.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 8.636 V
    Readiness: 0110 0101
       Part No SW: 02E 300 053 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2235
       Revision: 05151112    Serial number: 00000911200907
       VCID: 206138C4F3835A4AFD-8074
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Coding: 1150600F492200FB880E06EA92220041390800
       VCID: 7AD52AACF59FE09A93-802E
       Part No SW: 8P0 820 043 BK    HW: 8P0 820 043 BK
       Component: KlimavollautomatH09 0140
       Revision: 000066      Serial number: 8P0820043BK
       VCID: 76CD3E9C018784FAF7-8022
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 D    HW: 8P0 907 063 D
       Component: BCM PQ35  M   105 0573
       Revision: 00105 AJ
       Coding: 2E000A3FB83336E4287241E000100D4D411E62AA104DD929E40008840040
       VCID: 354FF9909C01CFE23E-8060
       Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
                000 -  -  - Intermittent
                        Reset counter: 55
                        Mileage: 58824 km
                        Date: 2019.01.25
                        Time: 16:19:53
                        Voltage: 10.95 V
                            Term 50 Off
    01134 - Alarm Horn (H12)
                        Reset counter: 55
                        Mileage: 58824 km
                        Date: 2019.01.25
                        Time: 16:35:29
                        Voltage: 8.90 V
                            Term 50 Off
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7J0560347
       Coding: 0000100
       VCID: 364DFE9C4107C4FA37-8062
    Address 15: Airbags
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0014142
       VCID: 46AD8E5C31E7547AA7-8012
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 N    HW: 8P0 920 982 N
       Component: KOMBIINSTR. VDO H03 0990
       Revision: D0H03004    Serial number: 224NI004001384
       Coding: 0016288
       Shop #: WSC 63411 001 1048576
       VCID: 44A9945407DB666AB9-8010
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0231
       Revision:   H16       Serial number: 4320K09B2300F5
       Coding: ED817F07100702000102
       Shop #: WSC 00237 211 99201
       VCID: 69F765E040395B026A-803C
       Revision: D0H03004    Serial number: AUX7Z0INFNO0E8
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
       Component: Tuer-SG         H04 0100
       Coding: 0001181
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 233    3001
       Revision: 00H17000
       VCID: 3147CD80A869E3C262-8064
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158954802964
       Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
       Coding: 0001181
       VCID: 47B3835836ED4D725C-8012
       Part No: 8P3 907 357
       Coding: 0000013
       VCID: 7AD52AAC359FE09A93-802E
       Part No SW: 8P0 035 186 T    HW: 8P0 035 186 T
       Component: R Concert2+     H03 0280
       Revision: 00H03000    Serial number: AUZ1Z3I5338123
       Coding: 0750112
       VCID: 43AB974802D5615280-8016
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0001176
       Shop #: WSC 06314 000 1012544
       VCID: 42A5924C1DCF685A8B-8016
    Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
       Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
       Component: J502-RDK        H03 0370
       Revision: --H03-H0    Serial number: 13373791702325
       Coding: 0860021
       Shop #: WSC 06435 000 00000
       VCID: 2F43CBF8BE5DF53274-807A
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0001176
       Part No SW: 8P0 862 335 AB    HW: 8P0 862 335 T
       Component: FSE_256x BT     H38 0600
       Revision: 00000000    Serial number: 00000005030037
       Coding: 0001277
    End-------------------------(Elapsed Time: 01:37)--------------------------
    United States
    Since this vehicle uses a (Mk6 Golf based) PQ35 BCM you will need to change Byte 18 and I suspect you will need to add the trigger wire from the headlight switch to the BCM.
    Switching:
    Although you would want to compare the instructions to your factory wiring diagram I believe this will help:
    https://forums.vwvortex.com/showthre...thout-Rear-Fog.
    That thread, in addition to similar taillight specific (2012 Golf R and Non-LED Rear Fog Light) links, can be found in post #1 of this old VW Vortex thread:
    https://forums.vwvortex.com/showthre...-Coding-tweaks
    Coding:
    Byte 18 can be nasty when the original value was covered (hidden) by zeros. As long as you haven't modified the codng already it woudl appear as if your original value was not masked:
    62: Audi A3 Sportback (8PA) with Xenon & LED DRLs (Front) North American Region (NAR)
    Based on the description I believe this RoW option would enable rear fog after swapping any needed tail light components, wiring and adding the RFL switch:
    2B: Audi A3 Sportback (8PA) with Xenon & LED DRLs (Front) Rest of World (RoW)
  6. Likes Uwe liked this post
    Jan 2019
    Dear All,
    It has been some time, but, in case anyone is interested, the right solution was to change Byte 18 from 62 to 2C and of course swap the light switch. No wiring was necessary. An experienced mechanic in The Hague (https://www.cartronic.nl/) fixed it in ~10min at minimal cost. The resulting coding of Cent. Elec.:
    2E000A3FB83336E4287241E000100D4D411E2CAA104DD929E4 0008840040
    Regards
    Dimitris
  8. Likes Uwe liked this post
