Results 1 to 6 of 6
Thread: Cable not working
    Dec 2016
    Cable not working
    My ross cable does work anymore
    Is there any warranty after 3 years that i bought it ?
    Warranty is one year.
    However, we have out-of-warranty repair and upgrade options. Please e-mail Support@Ross-Tech.com and describe exactly what's wrong with it.
    Dec 2016
    Thanks i will email you guys
    A diacount would be nice for a new one
    Nov 2017
    Latvia
    If you own hex-can or older interface, open it up, and check at least for visual damage, "black smoke" , maybe fried voltage regulator, usb cable wires torn off the pcb, check continuity for the cable itself.
    Dead ftdi chip could be harder to diagnose.
    I have seen some topics in here when users tries to fix it themselves.
    Quote Originally Posted by _Val View Post
    As well as my HEX-NET I still have my old HEX-CAN cable, but that appears to be glued together, not screwed, so opening it up won't be easy
    Jun 2014
    Swansea, UK
    The casings are screwed together, but there is usually a generous helping of hot glue on the board too - presumably to make them more resilient.
    You'll often find the PCB is stuck to one side of the casing by the glue, so you have to be careful pulling it open if so, to avoid ripping components off the board.
    A soldering heat gun helps to soften the glue.
    Apparently I should put something witty or profound in here...
  7. Likes Eric, Uwe liked this post
