2013 Audi A6 Transmission (8-speed CVT)
bruceaa
C?ID=296302
> I own a registered device purchased direct from RT: S/N
> *****-000001-eebf71-84e949-tqiahh-****
> Lately, though there are no warning lights, the transmission is acting
> with some hesitation into
> 1st gear and I may have "lost" the top (8th) on my 2013 A6 2.0TFSI
> Premium Plus. No warnings lights. No diagnostic codes. I drive the same route
5x/week. HWY mileage dropped from 33 to 29. Weather not a factor.
> I 've used the tool several times for other issues (saved me over $5K
> so far!!!), but never noticed there
> are no transmission report modules. Is there some tool or add-on?
> I'm doing my best to avoid dealership rip-offs - and frankly would not
> trust anyone but VAG authorized.
Is there a tool for transmission eval?
bruceaa
C?ID=296302
Chassis Type: 4G0
 Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 72 82 84 85 8B 8E 8F 90
 VIN: WAUBGAFC5CN015352
 82-Heads Up Display -- Status: Malfunction 0010
 84-Night Vision -- Status: Malfunction 0010
 8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Saturday,26,January,2019,12:13:00:49009
VIN: WAUDFAFC7DN011669   License Plate:
Mileage: 142834km-88752mi   Repair Order:
S/N # hv20248-000001-eebf71-84e949-tqiahh-5714
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 52 53 55
          56 5F 62 6C 72 8F 90
VIN: WAUDFAFC7DN011669   Mileage: 142834km-88752miles
Address 01: Engine (0MTEX-CAEB)       Labels:. 06H-907-115-CAB.clb
   Part No SW: 4G0 907 115 F    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0004
   Revision: ECH09---
   Coding: 4A030013242400062000
   Shop #: WSC 56379 002 1048576
   ASAM Dataset: EV_ECM20TFS0114G0907115F 001007
   ROD: EV_ECM20TFS0114G0907115F.rod
   VCID: 280AF2252278EC57F6D-807C
18062 - Coolant Pump 2
          P261A 00 [047] - Open circuit
                    Mileage: 140988 km
                    Date: 2018.12.17
                    Time: 11:22:34
                    Engine speed: 1267.50 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 39 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 12.604 V
                    Median injection timing: 2.333 ms
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G1 927 155 G    HW: 0AW 927 156 K
   Component: 0AW 20TAVSUSA H04 0003
   Revision: --H04---    Serial number: 0000000802
   Coding: 000001
   ASAM Dataset: EV_TCMVL381 A02431
   ROD: EV_TCMVL381.rod
   VCID: 303A1A451AA8A4972ED-8064
   Coding: 01A10F018085F0805B00
   VCID: 36362C5DF8CC8AA7741-8062
   Part No SW: 4H0 907 064 FD    HW: 4H0 907 064 ED
   Component: BCM2 2.0      H36 0551
   Coding: 0D882006000000000000
   Shop #: WSC 04348 001 1048576
   VCID: 70BADA45DAA8E4976ED-8024
   Serial number: 2312000099573002
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 72
                    Mileage: 140997 km
                    Date: 2018.12.18
                    Time: 07:16:18
   Part No SW: 4G0 820 043 AH    HW: 4G0 820 043 AH
   Component: KLIMA 2 ZONEN H11 0070
   Serial number: 31051200111082
   Coding: 64812018C9
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   VCID: 6594BB1115EA313F0DB-8030
0019 - Motor for Fresh Air / Recirculated Air Flap
          B11AF 07 [008] - Mechanical Failure
                    Fault Frequency: 18
                    Reset counter: 175
                    Mileage: 141073 km
                    Date: 2018.12.18
                    Time: 14:08:39
                    Voltage terminal 30: 13.91 V
                    Outside air temperature: 18.0 °C
                    Interior temperature: 25.46 °C
                    Fresh air door motor-Act.val.: 11002
                    Fresh air door motor-Specified value: 10600
                    Fresh air door motor-Stop open: 11411
                    Fresh air door motor-Stop closed: 10000
   Revision: 11012002    Serial number: 00000001509150
   Coding: 06002091063C9FE08100088380003908CF9CD208A2090221000004406000
   VCID: 6FB8D939C796FB6F777-803A
   Component: WWS57X 120424  H35 0080
   Serial number:         120508045830
   Coding: 0045F7
   Serial number: 20302843
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 24 05 2012  00000168
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1SKR02
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Serial number: 6B08CC26000000000001
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061214301109
   Coding: A8C105
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   VCID: 77A8E159BF46B3AFAF7-8022
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D80024G14
   Coding: 303234373130303030314A55304C34473053
   VCID: 33301549EBBE9F8F53F-8066
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H11 0045
   Serial number: 6940000Y120000EHD20G
   Serial number: 3575HRB404T1BEPU98HC
   Serial number: 3585HRB405T1BBH448LJ
   Serial number: 3515JRB405D18AICBPCI
   Serial number: 3525JRB406319KD2COF9
   Serial number: 3554VRB401E4UE205H27
   Serial number: 3564VRB401E4UE20E2BB
   Revision: --------    Serial number: 90372LER000FM
   Coding: 000434
   VCID: 382A2265F2587CD766D-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 18 04 2012  D0111317
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460207    Serial number: 658250512596051
   Coding: 0BE609040B41D705020000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   VCID: 37282159FFC673AF6F7-8062
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000544924
   Coding: 00C1032900
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 70BADA45DA28E4976ED-8024
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790315366
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 42
                    Reset counter: 178
                    Mileage: 141070 km
                    Date: 2018.12.18
                    Time: 12:22:19
                    Voltage terminal 30: 12.4 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 13 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 17
                    Reset counter: 178
                    Mileage: 141143 km
                    Date: 2018.12.18
                    Time: 22:20:14
                    Control Module temperature: 18 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Revision: AA000000    Serial number: 00000030297440
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77A8E159BFC6B3AFAF7-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA4205437J0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 2D0403310D9AC97F05B-8078
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 010 287-03
   VCID: 303A1A451628A4972ED-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F31.05.1200H010003CF24333ÿ
   Subsystem 4 - Serial number: F24333ÿ
   Component: TSG FA        H03 0506
   Coding: 011F17005E00628002000012
   VCID: 47C851998FA6032F1F7-8012
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0018589627
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323E104D14A49687589-8066
   Revision: 00002001    Serial number: 0346903163
   Coding: 0106023A00FA408580B00800020703000000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000087573
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1645423%
   Coding: 101F00
   Subsystem 4 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84258092
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 72
                    Mileage: 140989 km
                    Date: 2018.12.17
                    Time: 12:52:08
02615 - Fuel Tank Cap; Lock
                    Reset counter: 73
                    Mileage: 141070 km
                    Date: 2018.12.18
                    Time: 08:48:37
   Component: TSG BF        H03 0506
   Coding: 011F17005E00628002000002
   VCID: 46D65C9D88AC1A27E41-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000356032
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B000D29338EC74F1BF-807E
   Serial number: 120530-0001-006
   Coding: 122196101002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C020E353680C077125-8078
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156ET0C7600272
   Coding: 020007020100000001
   VCID: 2412E6155ED00837DA5-8070
   Part No SW: 4G0 035 746 E    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0735
   Revision: --------    Serial number: 194F 0C7502196
   Coding: 050200000003E0EF55128B1E00000003100001000000000000
   VCID: 290CF72139F2D55FE93-807C
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Serial number: AUZ8ZDC9401S0S+
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Serial number: 90349LEU000RB
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Component: TSG HL        H03 0506
   VCID: 49CC57A199B2F55F093-801C
   Revision: --H06---    Serial number: 525 PA8J25G0TD
   Coding: 1080004
   VCID: 2616FC1D24ECFA27C41-8072
   Component: TSG HR        H03 0506
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313C1F4111A2AD9F213-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:13, VBatt start/end: 14.5V/14.7V)-----------
bruceaa
C?ID=296302
Thank you -
I followed the link to try and embed the CODE. If it does not work, let me know.
B
Hmm, I wonder if the engine is asking the trans to keep the RPMs up a bit due to that Coolant Pump fault?
bruceaa
C?ID=296302
Thanks, Uwe -
The coolant pump was disconnected under USDOT Safety Recall campaign. THAT is likely the cause of the other associated faults.
However, since the HEX-CAN tool I have does not report any transmission data; I can only assume that (and this seems inherent on engines with fewer cylinders)
that RPMs are both higher and fluctuate significantly especially in very cool to cold temps, even after engine warm-up to operating temp.
Bruce
I believe that Uwe would be correct here........
Huh?
   Coding: 000001
That's transmission data. However, your Transmission Control Module is not reporting any fault codes. It can also show you lots and lots of live data, but since it doesn't report any faults, I'm not sure what would be interesting to look at.
bruceaa
C?ID=296302
Thanks, Jack -
I got an email that you posted here, but I can't find it. Your request was about coolant pump disconnect, yes?
There is no special instruction, I think its covered in the Audi Shop Manual. You have a copy of that?
bruceaa
C?ID=296302
Thanks again, Uwe. I think the only way to know for sure is put it on a dyno and read the live data to look at the shift points
and make sure it is going into 8th gear, I suppose I could try and put it in manual (paddle shift) mode and try it on
the freeway.
Yeah I found what I was looking for, because I missed something and realized I had it, so I modified the post pretty quick, so people weren't looking for me or you.
Thank you though for being so considerable with such conscientious.... :thanks:
the freeway.
Uhm... A CVT has no gears to go into. It is Continuously Variable -- by definition. The discreet gear ratios that it makes available are simulated.
You know what's not simulated in a CVT, is the fact a car can lose control on a slick surface, just so you can feel the gears or sides?
Simulated shift points are dumb!
