Hey, so I'm kinda at my wits end with the heat problem I'm having with my '08 Avant. The issue is that there is no heat coming from the vents even at max heat and fans on full. No vents, either side, top or bottom. I CAN get SOME heat from the defrost but only when "Econ" is on. I believe the problem is with some temperature sensors, but I can't quite figure out how - hopefully I'm just being stupid.
Here's my JPPSG Info:
2008 Audi A4 B7 Avant. Don't have a photo of the build tag, but it's got the BWT engine and the transmission is a 09L. Car is stock except for an ECS catch can. I've also disabled the TPMS. Scan at the bottom of this message.
Recently (within 6 months) replaced the oil filter housing, fuel injectors, vacuum pump, coolant flange and coolant temperature sensor.
Here's what I've done so far with the current issue:
I have no codes in VCDS. I have replaced the heater core. I have ensured that there is no air in the system by using this tool to refill the system after I hooked everything back up again.
I think the thermostat is fine, as the temperature gauge is always rock-steady in the middle of the range when the car gets up to temp.
I ran through the adaptations in VCDS for the comfort system, and there were no issues.
Here's where it gets weird. When it was going through the tests, I DID get hot air out of all of the vents, which means the servos are all fine, and the flaps are all fine. I pulled measuring values on the temperature sensors, and it's very weird (to me, anyway):
Those values were pulled after the car got up to temp. I had the temp up to 91 F, fans at max. It seems logical to me that I'm not getting hot air because it thinks it's already in the 90's, but I don't think ALL 4 temp sensors could have gone bad at the same time...could they?
Also, the one code that is showing in the logs is probably because I stopped the adaptation sequence during the crash test sensor test.
Here's the log - any help or ideas would be appreciated!
Address 08: Auto HVAC (8E0 820 043 BM)
15:53:46
33.0°C Left Footwell Vent Temp. (G261)
31.2°C Right Footwell Vent Temp. (G262)
33.6°C Left Vent Temp. (G150)
30.6°C Right Vent Temp. (G151)
19.5°C Measured Ambient Temp. (G17)
22.4°C Temperature Actual (G59)
15.2°C Temperature Actual (G60)
Saturday,26,January,2019,16:10:10:30993
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
VIN: WAUKF78E18AXXXXXX License Plate: JENNA01262018
Mileage: 216130km-134296mi Repair Order:
67 69 75 76 77
VIN: WAUKF78E18AXXXXXX Mileage: 216130km-134296miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E1 910 115 G HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0010
Revision: 5EH15--- Serial number: XXXXXXXXXXXXXX
Coding: 010C010A190F0120
Shop #: WSC 06335 000 00000
VCID: 2615F57014E09C27C41-8072
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 K HW: 09L 927 156 B
Component: AG6 09L 2,0TFSI USA 0080
Revision: --H01--- Serial number: 4408371
VCID: 2F3B10543B1ADD6F377-807A
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004528
VCID: 2E050D503C10D4673C1-807A
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x0190
Hex Value: 0x0001
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
VCID: 6D87CA5CF4866F7F45B-5160
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 11023
Shop #: WSC 65536
VCID: 3D273A1CE4663FFFB5B-4B00
Part No SW: 8E0 035 593 N HW:
Component: SDAR SIRIUS
Revision: Serial number: AUZ4Z7G0209252
VCID: 34311F38D21CFEB74A5-5160
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 M HW: 8E0 959 655 M
Component: Airbag 9.41 H01 4240
Revision: 91H01424 Serial number: 003CS00053BJ
Coding: 0032607
VCID: 41DF46EC9D8E5B1FD13-8014
Subsystem 1 - Part No: 8E0 910 339 D
Component: BF-Gewichtsens. H03 0080
Subsystem 2 - Serial number: 01NJD
Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB4069AC91D0ÿ†63
Subsystem 5 - Serial number: AC91D0ÿ†6342DRB4067C8A29 ÿ†63
Subsystem 6 - Serial number: C8A29 ÿ†6352ARB40338314AEÿ†63
Subsystem 7 - Serial number: 8314AEÿ†6362ARB403383B45Kÿ†63
Subsystem 8 - Serial number: 83B45Kÿ†63729RB40309F6AF+ÿ†63
Subsystem 9 - Serial number: 9F6AF+ÿ†63829RB40309F6D1Vÿ
Subsystem 10 - Serial number: 9F6D1Vÿ
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 02142
Shop #: WSC 06335
VCID: 41DF46EC989E5B1FD13-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 E HW: 8E0 920 983 E
Component: KOMBI+WFS 4 H10 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0023008
Shop #: WSC 54321 444 13970
VCID: 313F162C2D3ECB9F213-5184
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023008
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 P HW: 8E0 035 192 P
Component: RNS-E US H74 0250
Revision: 04S Serial number: AUZBZ7G2407186
Coding: 0301137
VCID: 313F162C2D0ECB9F213-5160
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CP
Component: Komfortgerát T7B 4336
Coding: 11896
Shop #: WSC 06335
VCID: 015F86ECD81E9B1F913-4B00
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Component: Tõrsteuer.HL BRM 0606
Component: Tõrsteuer.HR BRM 0606
01366 - Opened Due to Crash Signal
35-00 - -
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
VCID: 290FFE4C05FEB35FE93-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0301137
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062121
Shop #: WSC 06435 000 00000
VCID: 2A0D014000D8B847E09-5160
Fault Status: 10100100
Fault Frequency: 62
Reset counter: 33
(no units): 91.0
Voltage: 13.90 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Fuel Consump.: 0.0 l/100km
End----------(Elapsed Time: 04:46, VBatt start/end: 12.3V/12.3V)-----------
