Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Golf Mk7 - CCS trouble after upgrade to high gateway
    Nov 2017
    I upgraded the #19 Gateway from a mid to a high (required for headlight leveling retrofit) and I am facing a fault in the 01 Engine Control module.
    17149 - Check Coding of ECUs on Powertrain Data Bus
    P1647 00 [167] - -
    [Checking coding/versions of control modules in drive train]
    The glow plug light on the cluster flashes. When I turn on the cruise control (button on the MFSW) I get the cruise symbol with an exclamation point and it won't engage.
    When I select CCS not installed in #01 module coding the fault goes away, but CCS doesn't work either.
    The #19 gateway is the only part that changed other than adding the #55 leveling module.
    My BCM is still a mid version. I am wondering if that needs to be upgraded in tandem with the high gateway.
    The fault says coding/adaptation problem on the powertrain data bus. Which modules are on that bus?
    Here's an adaptation I made based on the ross-tech wiki.
    #19 Adaptations: ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Version - CCS
    Thanks for any clues.
    Saturday,26,January,2019,22:57:34:40467
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4436.4
    VIN: 3VWFA7AU8FM519186   License Plate:
    Mileage: 27740km-17240mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 69 75
    VIN: 3VWFA7AU8FM519186   Mileage: 27733km-17232miles
    Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 C    HW: 04L 907 309
       Component: R4 2.0l TDI   H23 9282
       Revision: 85H23---
       Coding: 01190012033410081000
       Shop #: WSC 43121 003 104857
       ASAM Dataset: EV_ECM20TDI01104L906021C 004014
       ROD: EV_ECM20TDI01104L906021C_004.rod
       VCID: 25170C6B2568E71FCDB-8070
              P1647 00 [167] - -
              [Checking coding/versions ofcontrol modules in drivetrain]
                        Mileage: 27733 km
                        Date: 2019.01.26
                        Time: 22:53:46
                        Coolant temperature: 15 °C
                        Intake air temperature: 15 °C
                        Ambient air pressure: 830 mbar
                        Voltage terminal 30: 11.700 V
                        ACC variants-Bits 0-7: 0
                        CCS Switch-Bits 0-7: 1
                        Cruise control switch actuation-Bits 0-7: 32
                        Cruise control switch actuation-Bits 0-7: 0
                        ACC variants (coding)-Bits 0-7: 1
                        Acceleration: 0.000 m/s²
    Readiness: 0 0 0 1 1
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 51385000000080
       Coding: 04FA6AA1242109750078020881C92520562490004081A4B200630050C002
       Shop #: WSC 43121 003 1048576
       VCID: 47CBA6E3FF24150F1F7-8012
       Revision: 00021000    Serial number: 0365852065
       Coding: 030C0C
       Shop #: WSC 01383 790 50316
       VCID: 3A2DCF17BCD678E7909-806E
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 02020104202100000000000000000000
       ROD: EV_ACManueBHBVW37X_003_VW37.rod
       VCID: 46D5ABE7F82E0C07E41-8012
       Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86582404150684
       Coding: 005308464041026969E44000001407001800000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 4ACD9FD7EC36E867009-801E
       Component: WWS    150411  043 0581
       Serial number:         150609124147
       Coding: 1F4DFD
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S2Y15M04D16H23M14S06
       Coding: 14A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS22.409  H03 0004
       Serial number: 0000FST0004CZM100000
       Coding: 191800
       Roof Blind:
       Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS22.409  H03 0004
       Serial number: 0000FST0004CZKZ00000
       Coding: 191800
                        Reset counter: 138
                        Mileage: 27733 km
                        Date: 2019.01.26
                        Time: 15:18:46
       Serial number: 003GCR01VAAO
       ROD: EV_AirbaVW20SMEVW37X.rod
       Occupant Detection:
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH0000J150002P5XA0H
       Coding: 303135
       Subsystem 2 - Part No SW: -----------    HW: 480 002 005 15
       Serial number: 3570000000090685941E
       Subsystem 3 - Part No SW: -----------    HW: 480 002 005 15
       Serial number: 3580000000035585941D
       Subsystem 4 - Part No SW: -----------    HW: 480 401 404 15
       Serial number: 3510002A91A87854010V
       Subsystem 5 - Part No SW: -----------    HW: 480 402 104 15
       Serial number: 3520002B519EFF53C3EX
       Subsystem 6 - Part No SW: -----------    HW: 480 401 404 15
       Serial number: 3550002BF19EFF50E13W
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 804 15
       Serial number: 3560002BF1A878553216
       Revision: FF032032    Serial number: 20150422500922
       Coding: 0400
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 045171EF8E92FE17BA5-8050
       Part No SW: 5G1 920 841     HW: 5G1 920 841
       Component: KOMBI         243 4270
       Coding: 0BA512122980CF0502086A001000000000000000
       Shop #: WSC 01787 210 12345
       VCID: 65974C6B65E8271F0DB-8030
       Revision: --------    Serial number: 01101410803011
       Coding: 090100000008640020000000000000000000000000000000000000000000
       Shop #: WSC 06385 790 00016
       ROD: EV_GatewConti_011_VW37.rod
       VCID: 72BD2737A426C0A7989-8026
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0101
       Serial number: 29140002498530065173
       Coding: 28FFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: WECHSELRICHTE  H53 0041
       Serial number: 0071685
       Revision: 00000000    Serial number: 15000105448003
       Coding: 5500000000000000
       Shop #: WSC 00066 790 07030
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E12F9EB28E974A5-8060
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 21051506050FWV
       Coding: 003013200000040000000000
       VCID: 3E25C307A0FE54C7AC1-806A
       Serial number: 00000000000001282438
       Coding: 011000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: 43D3B2F3CB1C392FC3F-8016
    Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H40 0070
       Serial number: VWZ8Z1FC402PGHI
       Coding: 22000000AAAAAA0000
       ASAM Dataset: EV_AMPMst12C1ALPI 001007
       ROD: EV_AMPMst12C1ALPI.rod
       VCID: 639352736BDC592FE3F-8036
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 280515060506FW
       VCID: 3D27C40BADF84FDFB5B-8068
       Serial number: 00000000000001235066
       Coding: 091000
       Coding: 010A000101000000
       VCID: 75B71C2BD548D79FBDB-8020
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0655
       Serial number: V7B00405150080
       Coding: 027302000000000021220002001800001F0100340100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 6491516F6ED25E171A5-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9RS501W29
              B11CF 53 [009] - Deactivated
                        Reset counter: 98
                        Mileage: 27733 km
                        Date: 2019.01.26
                        Time: 14:11:37
                        Voltage terminal 30: 12.2 V
       Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
       Component: Anhaenger     H21 0204
       Revision: 8C001003    Serial number: 0410657900
       Coding: 0100000000000000
       Component: OCULowMQBUS   007 0564
       Coding: 02730202C2823A017F1E06000000
       Shop #: WSC 00066 790 00322
       ROD: EV_OCULowMQB.rod
    End----(Elapsed Time: 01:35, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    May 2017
    When the dealer removed the component protection from the gateway, did they return also the FeC codes to it? If not that is the reason your CCS is not working. It’s a SWaP function and requires proper feature enable codes to be activated in gateway to work.
  3. Likes Uwe liked this post
    Nov 2017
    The car had CCS from the factory. Are you saying it needs to be re-enabled in the new gateway despite that?
    The dealer had absolutely no clue. When I approach them with SWaP that will be way over their heads.
    Thanks.
    May 2017
    Yes, it needs to be returned to the new gateway. Gateway acts as the master.
    The activation codes are returned to the gateway by using a guided function to return activation codes. I can’t remember what was the exact item name. I’m sure there’s someone here who can verify what it is. Just tell the workshop the exact item name and they will do it.
  6. Likes Uwe liked this post
    Nov 2018
    Germany, Erfurt
    Correct,
    tell your dealer to go to the function, I have marked for you in the picture. After that, he will have the choice to *re-enable* the function by VIN identification.
    2017 Ford Mustang Shelby GT350 (FUN), 2019 VW Passat 2.0 TDI 4Motion (Daily-Company-Car), 2018 VW Tiguan SE (Wife)
    VCDS, ETKA, Erwin, ODIS with FAZIT Online Access
    Prior cars:
    Fiat Bravo 1.6, Fiat Marea 1.6, Audi 80 2.6, Audi A4 2.6, Audi A4 2.4, Audi A6 2.8, Audi V8 3.6 & 4.2, Fiat Marea 1.6, Passat 2.0TDI, Mustang 3.7, Ford Taurus SHO, Mustang 5.0, Lincoln MKS
  8. Likes Uwe, downtime liked this post
  9. #6
    Tartu, Estonia
    Actually You need to use the "clearing" option, and then manually enter 19 as the module.
    Status just tells the status.
    The world is my oyster...
  10. Likes downtime liked this post
  11. #7
    Nov 2018
    Germany, Erfurt
    I didnt execute it as I had nothing to exchange but trying the status one gave the option to re-enable as well - but they can hopefully try one of them
    Prior cars:
  12. #8
    Nov 2017
    Thanks, guys. I'll put them to the task and will report back on the results.
    Cheers!
  13. #9
    Nov 2017
    We did just that (clearing) and are getting a technical error when submitting the signature. Anyone have an idea?
    "When attempting the signature service, a technical error occurred."
  14. #10
    Nov 2017
    One thing I noticed and was told that it was strange:
    I have had 3 #19 gateways at my disposal. The original MID, and 2 HIGH versions. We removed CP from the two high versions, and now I can swap back and forth without CP coming back. Is that normal?
