I upgraded the #19 Gateway from a mid to a high (required for headlight leveling retrofit) and I am facing a fault in the 01 Engine Control module.
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
[Checking coding/versions of control modules in drive train]
The glow plug light on the cluster flashes. When I turn on the cruise control (button on the MFSW) I get the cruise symbol with an exclamation point and it won't engage.
When I select CCS not installed in #01 module coding the fault goes away, but CCS doesn't work either.
The #19 gateway is the only part that changed other than adding the #55 leveling module.
My BCM is still a mid version. I am wondering if that needs to be upgraded in tandem with the high gateway.
The fault says coding/adaptation problem on the powertrain data bus. Which modules are on that bus?
Here's an adaptation I made based on the ross-tech wiki.
#19 Adaptations: ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Version - CCS
Thanks for any clues.
P1647 00 [167] - -
Saturday,26,January,2019,22:57:34:40467
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4436.4
VIN: 3VWFA7AU8FM519186 License Plate:
Mileage: 27740km-17240mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 69 75
VIN: 3VWFA7AU8FM519186 Mileage: 27733km-17232miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 C HW: 04L 907 309
Component: R4 2.0l TDI H23 9282
Revision: 85H23---
Coding: 01190012033410081000
Shop #: WSC 43121 003 104857
ASAM Dataset: EV_ECM20TDI01104L906021C 004014
ROD: EV_ECM20TDI01104L906021C_004.rod
VCID: 25170C6B2568E71FCDB-8070
P1647 00 [167] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Mileage: 27733 km
Date: 2019.01.26
Time: 22:53:46
Coolant temperature: 15 °C
Intake air temperature: 15 °C
Ambient air pressure: 830 mbar
Voltage terminal 30: 11.700 V
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 1
Cruise control switch actuation-Bits 0-7: 32
Cruise control switch actuation-Bits 0-7: 0
ACC variants (coding)-Bits 0-7: 1
Acceleration: 0.000 m/s²
Readiness: 0 0 0 1 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51385000000080
Coding: 04FA6AA1242109750078020881C92520562490004081A4B200630050C002
Shop #: WSC 43121 003 1048576
VCID: 47CBA6E3FF24150F1F7-8012
Revision: 00021000 Serial number: 0365852065
Coding: 030C0C
Shop #: WSC 01383 790 50316
VCID: 3A2DCF17BCD678E7909-806E
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104202100000000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 46D5ABE7F82E0C07E41-8012
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582404150684
Coding: 005308464041026969E44000001407001800000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 4ACD9FD7EC36E867009-801E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150411 043 0581
Serial number: 150609124147
Coding: 1F4DFD
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M04D16H23M14S06
Coding: 14A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST0004CZM100000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST0004CZKZ00000
Coding: 191800
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Reset counter: 138
Mileage: 27733 km
Date: 2019.01.26
Time: 15:18:46
Component: AirbagVW20 009 0825
Serial number: 003GCR01VAAO
ROD: EV_AirbaVW20SMEVW37X.rod
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150002P5XA0H
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 002 005 15
Serial number: 3570000000090685941E
Subsystem 3 - Part No SW: ----------- HW: 480 002 005 15
Serial number: 3580000000035585941D
Subsystem 4 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3510002A91A87854010V
Subsystem 5 - Part No SW: ----------- HW: 480 402 104 15
Serial number: 3520002B519EFF53C3EX
Subsystem 6 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3550002BF19EFF50E13W
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 804 15
Serial number: 3560002BF1A878553216
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150422500922
Coding: 0400
ROD: EV_SMLSVALEOMQB.rod
VCID: 045171EF8E92FE17BA5-8050
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA512122980CF0502086A001000000000000000
Shop #: WSC 01787 210 12345
VCID: 65974C6B65E8271F0DB-8030
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 01101410803011
Coding: 090100000008640020000000000000000000000000000000000000000000
Shop #: WSC 06385 790 00016
VCID: 72BD2737A426C0A7989-8026
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29140002498530065173
Coding: 28FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0071685
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000105448003
Coding: 5500000000000000
Shop #: WSC 00066 790 07030
ROD: EV_ELVMarquMQB.rod
VCID: 3431E12F9EB28E974A5-8060
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 21051506050FWV
Coding: 003013200000040000000000
VCID: 3E25C307A0FE54C7AC1-806A
Serial number: 00000000000001282438
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
VCID: 43D3B2F3CB1C392FC3F-8016
Address 47: Sound System (J525) Labels:| 5G0-035-456.clb
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0070
Serial number: VWZ8Z1FC402PGHI
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst12C1ALPI 001007
ROD: EV_AMPMst12C1ALPI.rod
VCID: 639352736BDC592FE3F-8036
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 280515060506FW
VCID: 3D27C40BADF84FDFB5B-8068
Serial number: 00000000000001235066
Coding: 091000
Component: LWR-ECU 005 0080
Coding: 010A000101000000
VCID: 75B71C2BD548D79FBDB-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0655
Serial number: V7B00405150080
Coding: 027302000000000021220002001800001F0100340100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 6491516F6ED25E171A5-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9RS501W29
B11CF 53 [009] - Deactivated
Reset counter: 98
Mileage: 27733 km
Date: 2019.01.26
Time: 14:11:37
Voltage terminal 30: 12.2 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 J HW: 5Q0 907 383 B
Component: Anhaenger H21 0204
Revision: 8C001003 Serial number: 0410657900
Coding: 0100000000000000
Shop #: WSC 12345 123 12345
Component: OCULowMQBUS 007 0564
Coding: 02730202C2823A017F1E06000000
Shop #: WSC 00066 790 00322
ROD: EV_OCULowMQB.rod
End----(Elapsed Time: 01:35, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
