Results 1 to 10 of 12
Thread: Text wrapping between fields
    Jan 2019
    Posting here in addition to sending an email to Ross Tech support with more info.
    I'm not new to vcds but am a new customer. I used my buddy's to check DTCs a couple of times over the years.
    I have two problems trying to code a rebuilt ABS module on my 2004 A6 / 3.0L / CVT
    I tried setting the coding with two different computers - win 7 and win 10 with almost exactly the same results.
    Downloaded the latest version 18.9.1 on each computer.
    Double checked my Login and Coding values against an auto scan from before the module failed.
    New module is the same PN as the old Bosch 5.7 module.
    One problem is the Login and Coding info doesn't seem to take and the Component description field wraps down to the Coding field. The letter "t" from "front" and "3428" start out in the Component field but after entering Login and Coding, they move to the Coding field. This happened with both computers I ran the software on.
    During one attempt I continued with steering sensor calibration but the DTC codes didn't clear: 00778 Steering Sensor and 01044 Module incorrectly coded. I get the same codes when scanning with my non-vcds scanner with ABS.
    The other problem is VCDS doesn't ask me to confirm locking 1 of my 3 VINs when setting the Coding. Makes me wonder if the software is acting up.
    To elimiate the new ABS module as the problem, I put the old one back in and saw the same field-wrapping issue from the scanner plus the two codes that required me to get a new module:
    01420 High Pressure Switch Valve1 N227
    01421 High Pressure Switch Valve2 N228
    Also, when I hover over the Login-11 box I don't get the full list of tips I've seen in examples. Instead I get only something about code 40168 - even when I haven't entered any Login / Coding info yet.
    I haven't figured out how to add images but I have screen shots before and after entering the Login and Coding.
    Thanks for any ideas.
    I see your screen-shots in the support inbox. I'll can post 'em in this thread for you if you want me to.
    I'm not sure what's up with that. It could indeed be a bug in the current version of VCDS, or the interface firmware (and since you didn't include an Auto-Scan, I can't see what firmware is in your HEX-V2), or it could be your ABS module acting screwy.
    Let's do this: Go to [Options], set Debug Level to 1024, then click [Apply]. Now (without exiting VCDS), do whatever is necessary to reproduce them. When done, exit VCDS gracefully, then look in the Debug sub-folder and e-mail us the file named DEBUG-03.DLM.
    Oh, and please run a complete Auto-Scan and send (or post) that too.
    Jan 2019
    Yes please post the pics from the support email. It won't hurt.
    I emailed the debug file. One thing: after I entered debug mode and clicked on 3 - ABS brakes, a window popped up asking if I wanted to register the VIN. I clicked Yes and instantly got a Windows message: VCDS has stopped working. The only option was to close the program. That's the debug file I'm sending. I'll try it again before end of the day.
    Here's the auto scan:
    Sunday,27,January,2019,16:14:14:31656
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
    VIN: WAUJT64B74N038258   License Plate:
              75 76 77
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 R    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0020
       Coding: 0016582
       Shop #: WSC 02334 785 00200
       VCID: 44D14E83C28C65A7FA5-5184
    8 Faults Found:
    18057 - Powertrain Data Bus
                P1649 - 008 - Missing Message from ABS Controller - Intermittent
    16955 - Brake Switch (F)
                P0571 - 008 - Implausible Signal - Intermittent
                P0300 - 001 -  - MIL ON
    16690 - Cylinder 6
                P0306 - 001 - Misfire Detected - MIL ON
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1
                P1116 - 004 - Open Circuit - MIL ON
    17548 - Oxygen (Lambda) Sensor; B2 S2
                P1140 - 008 - Internal Resistance too High - MIL ON
    16544 - Oxygen (Lambda) Sensor B2 S2
                P0160 - 004 - No Activity - MIL ON
    17887 - Brake Boost Vacuum System
                P1479 - 008 - Mechanical Failure - Intermittent
    Readiness: 0110 1001
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4B0 910 155 E    HW: 01J 927 156 JK
       Component: V30 01J 3.0l 5V USA 3220
       Revision: 00000008    Serial number: 00000002022045
       Coding: 0001001
       VCID: 2019E21336D45987BED-5184
    18259 - Powertrain Data Bus
                P1851 - 000 - Missing Message from ABS Controller - Intermittent
                        RPM: 96 /min
                        (no units): 1.0
                        Torque: 268.0 Nm
                        Temperature: 19.0C
                        T.B. Angle: 0.0
                        Bin. Bits: 0101 0 0
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       3428
       Coding: 00000
       VCID: 2517F3072CF6BCAFCDB-51F2
                66-10 - Not Matched - Intermittent
                35-00 -  -
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AR
       Component: A6-Klimavollautomat 0208
       Coding: 00110
       VCID: 6A8DC03B855853D7209-2586
                30-00 - Open or Short to Plus
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        3001
       Coding: 0000607
       VCID: 3E253C6BAC600F77AC1-5184
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01002
       Shop #: WSC 02334
       VCID: 2F3B112F7E3AF6FF377-5184
    01304 - Radio
                49-00 - No Communications
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 N
       Component: KOMBI+WEGFAHRS. VDO D14
       Coding: 02262
       Shop #: WSC 07117
       VCID: 313F1757683EE00F213-5184
       WAUJT64B74N038258     AUZ7Z0C2456870
    01304 - Radio
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       Shop #: WSC 02334
       VCID: 33331D5F9212D21F53F-4F2E
    6 Faults Found:
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
    01561 - Rear left door
                59-00 - Can't Unlock
    01574 - Alarm triggered by Door Contact Switch; Rear Right
                35-00 -  -
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0204
       Coding: 00001
       VCID: 2C0106234F2C8DE7125-4B3C
    End----(Elapsed Time: 05:18, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
  4. Likes jyoung8607, Dana liked this post
    Jan 2019
    Debug mode worked this time. It let me enter the Login and Coding, and the Coding stayed in the box. I wasn't sure about the process after entering code 40168 - left my notes in the house. I emailed the debug file.
    Something I just noticed - when not in debug mode the LEDs on the scanner quickly flash green and red. Not sure if it means anything. Also, it's still not working when not in debug mode.
    Thanks for the help.
    -Dave
  6. Likes jyoung8607 liked this post
    DetroitDave's Screen shots:
    I can confirm we have debug files. I'm confident this will get looked at in the near future.
    Oh, and FWIW, your Login and Coding look correct to me.
  8. Likes jyoung8607, Dana liked this post
  9. #6
    I have recently seen this also, guess there is an bug.
    But I was able to do the coding.
    Have you tried to do the login > Coding > Basic setting in a row, quit VCDS and ignition OFF ?
  10. Likes Uwe, jyoung8607, _Val, Dana liked this post
  11. #7
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    I've seen someone hit this recently on Bosch 5.3 as well: https://forums.ross-tech.com/showthr...l=1#post135119
    I didn't notice this nuance at the time, but reading the thread again today, I see...
    Quote Originally Posted by rubirock View Post
    When I login & attempt to set the coding/wsc, I will get a message in the coding field reading "ad D56". The D56 part i recognize from the ABS module (also on both ABS module stickers) but I haven't found an explanation yet, made a little harder b/c both "ad" & "D56" are too short a term to be used in the search.
    ... the Bosch 5.3 owner's issue ALSO happened post-login/coding attempt, which might explain why more people haven't noticed, and it isn't popping up in Auto-Scans.
    Silence gives consent.
  12. Likes Uwe, Eric, PetrolDave, _Val, Dana liked this post
  13. #8
    Jan 2019
    I tried but with no success. The text wrapping didn't happen this time but the coding didn't stay. After turning the key back on the same codes 00778 Steering Sensor and 01044 Module incorrectly coded were still there.
  14. #9
    And you did this basic setting, right after Coding and before Ignition OFF ?
  15. Likes Uwe, Dana liked this post
  16. #10
    HQ
    Where did that ABS module come from?
    Jef
