Hi all,
Im new to the forum and I've problem with my car audi a6 c6 2009 2.0tdi CAGB 140bhp.
I had gearbox replaced however the gearbox is out from 170bhp audi a6 c6 CAHA which has different ratios on the 4,5,6th gears. My problem is that the gear shift recommendation does't work on the gears 4,5,6th and its not displaying on the DIS on the cluster on these gears. Also cruise control is not working on these gears. Is there an option to code ecu or abs or cluster to match the values from the 170bhp gearbox instead of 140bhp? I will add that i've vcds and also gear box is 6speed manual. It used to be JWS gearbox standard for my a6 c6 CAGB 2.0 tdi 140bhp and now its HCK out of a6 c6 CAHA 2.0 tdi 170bhp. Car is facelift model.
Any help i would really appreciate it.
Thanks.
Thanks.
