Results 1 to 4 of 4
Thread: 2014 Audi A3 - Multiple Intermittent Fault Codes - Failure to Start Car
    New User
    Jan 2019
    Good evening ladies and gents, in the interim of my VCDS cable being verified by the forum admin, please see my issue below relating to a 2014 Audi A3.
    periods of hours in-between repeat faults, and in some instances week before the next occurrence. Please see below for the Scan.
    Any help would be greatly appreciated.
    Regards. Tom
     Wednesday,23,January,2019,19:58:37:47856
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 18.9.0.4
    VIN: WAUZZZ8V6EA11XXXX   License Plate:
    Mileage: 187533km-116527mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F BB BC
    VIN: WAUZZZ8V6EA11XXXX   Mileage: 187533km-116527miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 7544
       Revision: 83H22---
       Coding: 02190012030501082000
       Shop #: WSC 45330 002 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79F90334F863A2829C-802C
    5273 - Output for Starter Relay
              P0616 00 [038] - Short to Ground
                        Mileage: 187533 km
                        Time: 00:00:00
                        Coolant temperature: 11 °C
                        Intake air temperature: 11 °C
                        Voltage terminal 30: 12.140 V
                        Starter control: terminal 50 acknowledgment-Bits 0-7: 1
                        Status of starter activation relay-Bits 0-7: 0
                        Starter control: release conditions-Bits 0-7: 11
                        Starter control: release conditions-Bits 0-7: 86
                        Starter control: shut-off conditions 1-Bits 0-7: 0
                        Starter control: shut-off conditions 1-Bits 0-7: 32
                        Number of manual engine starts-Bits 0-7: 0
                        Number of automatic engine starts-Bits 0-7: 0
                        Number of automatic engine starts-Bits 0-7: 57
    5459 - Control Circuit for Starter Relay 2
              P3048 00 [038] - Short to Ground
                        Mileage: 187533 km
                        Time: 00:00:00
    4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
              U1010 00 [038] - -
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
                        Accelerator pedal travel: raw value: 0.00 %
                        Accelerator pedal: sensor voltage 1: 752.4 mV
                        Accelerator pedal: sensor voltage 2: 371.2 mV
                        Accelerator pedal: switch positions-Bits 0-7: 64
                        Starter control: Interlock- or P/N-signal-Bits 0-7: 65
                        Limitation: torque: 0.0 Nm
                        Control Module temperature: 11.3 °C
    4710 - No Communications with Airbag Control Module
              U0151 00 [038] - -
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
                        Voltage terminal 30: 12.100 V
                        Limitation: accelerator pedal: 126.7 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 0
                        selected gear-Bits 0-7: 0
       Revision: 00000000    Serial number: 63393000000B84
       Coding: 12F18AA224210A740178060141CA294851245080608294F2006100080608
       Shop #: WSC 06314 790 00021
       ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
       VCID: 7BF5193CF25F90928E-802E
    6 Faults Found:
    8200 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:28
    8204 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:29
    8206 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.23
                        Time: 19:51:42
    32869 - Databus
              U1123 00 [136] - Received Error Message
                        Reset counter: 157
                        Mileage: 132126 km
                        Date: 2016.06.13
                        Time: 07:38:17
    32995 - Clutch Position Sensor
              C10BF 01 [137] - Electrical Failure
                        Reset counter: 117
                        Date: 2017.06.19
                        Time: 18:29:49
    32997 - Clutch Position Sensor
              C10BF 15 [137] - Open or Short to Plus
                        Reset counter: 117
                        Date: 2017.06.19
                        Time: 18:29:49
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Revision: 20026000    Serial number: 00000000205763
       Coding: 03100104002000011000000000001100
       VCID: 326BF418659591DA1D-8066
       Serial number: 5ED8CED6000000000001
    262658 - High Pressure Sensor
              B10AE 31 [008] - No Signal
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
                        Outside air temperature: 6.5 °C
                        Temperature after evaporator: 6.9 °C
                        System run time-Terminal 15 on: 1 s
    459009 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
    263682 - Exterior Air Quality/Humidity Sensor
              B137A 31 [008] - No Signal
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:30
                        Voltage terminal 30: 11.9 V
                        System run time-Terminal 15 on: 4 s
       Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
       Component: BCM MQBAB M   H16 0124
       Serial number: 00011334301747
       Coding: 07040842C24100DD03844004B31407A80000000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 131202  041 0580
       Serial number:         131204030406
       Coding: 0A47F7
       Light switch:
       Subsystem 2 - Part No SW: 8V0 941 531 N    HW: 8V0 941 531 N
       Serial number: 29 08 2013  00000791
       Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY1330200JC
       Serial number: 00000000000058306870
       Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20584735
    136458 - Terminal 15
              B1148 15 [008] - Open or Short to Plus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:25
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                        Reset counter: 117
                        Time: 00:00:00
    204546 - Remote key 2
                        Reset counter: 112
                        Mileage: 187341 km
                        Date: 2019.01.18
                        Time: 08:41:00
    528405 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:28
    558101 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:29
       Serial number: 003M2R04CXW6
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4B9589FCE27FE0127E-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 000 612 13
       Serial number: 35767000000DC0F4BD0A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 612 13
       Serial number: 35867000000880F4BD02
       Subsystem 3 - Part No SW: -----------    HW: 480 400 712 13
       Serial number: 3516502C51220761C06X
       Subsystem 4 - Part No SW: -----------    HW: 480 400 612 13
       Serial number: 3526502AF1220563733.
       Subsystem 5 - Part No SW: -----------    HW: 480 401 211 13
       Serial number: 3556502C51088B01220X
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 403 011 13
       Serial number: 2286502A71220561521O
       Subsystem 7 - Part No SW: -----------    HW: 480 402 811 13
       Serial number: 2296502AF122076320D1
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 403 011 13
       Serial number: 2306502C1122076252ET
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 08121304401509
       Coding: 8408
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 060378C8B99DDD7AE1-8052
       Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
       Component: KOMBI         H03 2220
       Coding: 27850900228046000101A800100000
       VCID: 479DB5CCFE1704725A-8012
    16776962 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1164
       Revision: --------    Serial number: 0001312706
       Coding: 030100040B0876005B000248080B00000001000000000000000000000000
       ROD: EV_GatewLear_010.rod
       VCID: 3E73D028A1CD45BAE9-806A
       Serial number: 13 11 2013  A0171888
       Serial number: 4572931903
    131605 - No Communications with Airbag Control Module
              U0151 00 [008] - -
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:29
                        Terminal 15: On
       Serial number: 24111303110840
       Coding: 00108E204001040000001002
       VCID: 408FAED0DB39334A9B-8014
    458752 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
    458857 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 4189ABD4D0333A4294-8014
       Serial number: 28111304080156
       Coding: 001086204001040000001002
       VCID: 3F8DAD2CA6C74CB2E2-806A
    458752 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
    458857 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.20
                        Time: 11:06:21
       Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
       Component: MU-S-ND-ER    040 0420
       Serial number: A7F00912130185
       Coding: 01730301FF00000021111101000A00002F0001460100010006
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 3B75D93CB2DF5092CE-806E
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H48 0013
       Serial number: AUZ8Z9DY30092G
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
       Component: ControlUnit_B  H33 0037
       Serial number: C1000011111300010433
    6697 - Databus
                        Reset counter: 157
                        Mileage: 187533 km
                        Date: 2019.01.23
                        Time: 19:51:37
                        Voltage terminal 30: 11.2 V
       Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0025
       Serial number: 06121306070761
       Coding: 000086204001040000001002
       VCID: 428BA4D8D535215A8D-8016
       Component: TSG HBFS      020 0025
       Serial number: 06121301100768
    End-------------------------(Elapsed Time: 03:27)-------------------------->
    You're going to have to get wiring diagrams and take a look at how the starter relay(s) work. "Short to Ground" can sometimes mean a missing +12V on the high side of a low-side switched actuator.
    New User
    Jan 2019
    Thank you for the response.
    Would this ultimately lead to the multiple failures? As they all appear together or not at all.
    I was thinking something along the lines of a shared earth or live to the Start/Stop relay, starter relay, parking break module, and clutch position sensor.
    Well, I haven't exactly pointed my finger at any specific "this" yet, but sure, a dodgy voltage supply (or ground) could set lots of fault codes in in different modules.
