Kreativ, thanks a lot, the Coding that you have proposed it's work, but only after I unplug the PLA modul, I don't know if it's this or not
Actually I have some smoler problems I think it's the adaptation problem in abs or something like that
Thanks very much
12F162A224280A75017C060641C72548462450806082A4F23441F0080008
Thanks very much
Wednesday,17,June,2020,23:18:46:64015
VCDS Version: 20.4.0.1 HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8V1EA189564 License Plate:
Mileage: 70036km-43518mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F A5 BB BC
VIN: WAUZZZ8V1EA189564 Mileage: 70036km-43518miles
Address 01: Engine (J623-CRKB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FD HW: 04L 907 309 E
Component: R4 1,6L EDC H22 6544
Revision: 86H22---
Coding: 02190032034411092000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ECM16TDI01104L906021FD 002004
ROD: EV_ECM16TDI01104L906021FD.rod
VCID: 6C81C6C97604579B9FA-8038
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61895000000844
Coding: 12F162A224280A75017C060641C72548462450806082A4F21441F0080608
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7AADF0910C50F92B1D6-802E
0143 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[valve calibrating data missing]
Reset counter: 168
Mileage: 70036 km
Date: 2020.06.17
Time: 23:10:03
0338 - ABS/ESP Control Module
[inlet valve calibration data missing]
Reset counter: 168
Mileage: 70036 km
Date: 2020.06.17
Time: 23:10:03
4255 - Internal Fault
B200F F0 [137] - Unknown Error Elaboration
[Hecu_mismatch_final]
Reset counter: 168
Mileage: 70036 km
Date: 2020.06.17
Time: 23:10:03
32821 - Hydraulic Assistance Not Possible
C1100 F0 [009] - Unknown Error Elaboration
Reset counter: 168
Mileage: 70036 km
Date: 2020.06.17
Time: 23:10:47
32830 - Parking Brake Motors
C10E1 29 [008] - Signal Implausible
[IPB-Actuator: Actuator state UNKNOWN]
Reset counter: 208
Mileage: 70036 km
Date: 2020.06.17
Time: 23:10:03
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000306869
Coding: 03000104002000001000000000001000
Shop #: WSC 06314 790 00021
VCID: 33331DB56BBAC8639E0-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: A6988527000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 BR HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0138
Serial number: 01011415301252
Coding: 04040D46C24106FD43844004001407080000000000000000000000000000
Shop #: WSC 06745 128 28888
ROD: EV_BCMBOSCH_013.rod
VCID: 094F9F5D59B6E2B304C-805C
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140412 042 0580
Serial number: 140416135254
Coding: 0647F7
Component: G397_RLFS H06 0002
Serial number: 22535822
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H05 0032
Serial number: 19 04 2016 00001226
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616148
Coding: 0271061841
Shop #: WSC 05311 115 00082
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000_009_AU37.rod
VCID: 0D47AB4D2DDEFE93284-8058
13637426 - Databus
Reset counter: 168
Mileage: 70036 km
Date: 2020.06.17
Time: 23:08:14
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 H HW: 5Q0 907 567 G
Component: ACC3 H08 0096
Serial number: 14031376110147
Coding: 00200501FE0309
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 40D942792A0C63FB132-8014
1043 - Automatic Distance Control
B10E7 F0 [047] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 168
Mileage: 70036 km
Date: 2020.06.17
Time: 23:08:14
Control Module temperature: 25 °C
Voltage terminal 15: 13.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1056 - Databus
U1123 00 [047] - Received Error Message
[FAULT_CIS_ECD_FAIL]
Reset counter: 169
Mileage: 70036 km
Date: 2020.06.17
Time: 23:08:14
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 169
Mileage: 70036 km
Date: 2020.06.17
Time: 23:08:17
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 168
Mileage: 70036 km
Date: 2020.06.17
Time: 23:08:17
1061 - Databus
U1123 00 [046] - Received Error Message
[FAULT_CIS_EPB_ACTUATOR_FAIL]
Reset counter: 209
Mileage: 70036 km
Date: 2020.06.17
Time: 23:08:17
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R06D5XP
Coding: 98CCC0000C0000005C540000004800000065
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4BC36555134AB0A3F60-801E
Subsystem 1 - Part No SW: ----------- HW: 480 001 504 14
Serial number: 357670000006D2993F0%
Subsystem 2 - Part No SW: ----------- HW: 480 001 504 14
Serial number: 35867000000082993F0W
Subsystem 3 - Part No SW: ----------- HW: 480 401 604 14
Serial number: 3516502AF1529DF1A10I
Subsystem 4 - Part No SW: ----------- HW: 480 401 604 14
Serial number: 3526502AF1529DF2504I
Subsystem 5 - Part No SW: ----------- HW: 480 401 103 14
Serial number: 35565029B14476B1B17D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 408 15
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A71CF1D33126D
Subsystem 7 - Part No SW: ----------- HW: 480 400 402 15
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A7198E15340EG
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 408 15
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A51CF1D32F2AL
Part No SW: 8V0 953 521 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 16041408490098
Coding: EC08
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 7F5B01851772DC032A8-802A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 A HW: 8V0 920 790 A
Component: FBenRDW H16 0066
Coding: 04A309026E9000080304ED001C00001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3A2D30914CD0392B5D6-806E
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005688384
Coding: 030100040B0876005B000258080B00000001000000000000000000000000
ROD: EV_GatewNF_AU37.rod
VCID: 2F3B11C58792EC83FA8-807A
Subsystem 2 - Part No SW: 8W0 951 523 E HW: 8W0 951 523 E
Component: J453 MFL H04 0002
Serial number: 20180118180523 01315
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3046833103
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 18041404080212
Coding: 001C0E205C00040000001003
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 1302
Shop #: WSC 00200 935 01530
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF477D21066AF31CC-8014
Address 47: Sound System (J525) Labels:* None
Part No SW: 8V0 035 465 HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0270
Serial number: AUZ8ZAC09001PJM
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004023
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: 75B7E3AD254E9653704-8020
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 22041403110367
Coding: 001C06205E00040000001003
VCID: 3FDB418557F21C036A8-806A
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 019A00003E230200
Shop #: WSC 06756 128 28888
ROD: EV_HeadlRegulAFSMQBMLB.rod
Subsystem 1 - Part No SW: 7PP 941 472 B HW: 7PP 941 472 B Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H06 6000
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 B HW: 7PP 941 472 B Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H06 6000
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 035 D HW: 8V1 035 035
Component: MU-P-LND-EU 054 1168
Serial number: A698I0H2532540
Coding: 01736301FF0A000011110102000A00002F0028E571700100DE
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
Subsystem 1 - Part No SW: V03 959 801 PR HW: -----------
Component: ECE 2018 --- 0166
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0FNKV
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL106031700010606
Component: Gracenote2 --- 1016
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H05 0052
Serial number: 10000065146
Coding: 0100010000010304000000000100000100
ROD: EV_MFKBoschAU370.rod
VCID: 3B23359543EA0023460-806E
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 12041404080068
Coding: 000C06204000040000001002
Component: TSG HBFS 020 0025
Serial number: 12041401100073
End----------(Elapsed Time: 01:21, VBatt start/end: 13.9V/14.0V)-----------
Basic settings do a lot off times and don't work, it's seams that the 3q0 abs module doesn't work with 5q0 abs pump
Can you post an updated scan. It might be coding on 17 instrumentsPump change, and yes this it's the problem
New everything works but not the PLA
When I touch the first time the pla button nothing happens and if I touch again I have one message that told my that the PLA assistant stopped
Thursday,18,June,2020,23:21:04:64015
VIN: WAUZZZ8V1EA189564 Mileage: 70044km-43523miles
Revision: 86H22---
Coding: 12F162A224280A75037C060641C72548462450C06082A4F73443F0080008
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 170
Date: 2020.06.18
Time: 22:41:56
Coding: 0647F7
Coding: 00006C
Light switch:
Coding: 0271061841
Coding: EC08
Coding: 1302
Coding: E00100
Coding: E00100
Coding: E00100
Coding: E00100
End----------(Elapsed Time: 01:20, VBatt start/end: 12.2V/12.2V)-----------
