Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 66
Thread: Retrofit 3Q0 ABS Pump
    Oct 2017
    Northwest UK
    The ones I've got are fine, I don't get glare from them. The lights are the mirrors are yellow/orange are its quite cool how it works. They light up when a car is next to you in your blind spot and if you indicate the light starts to flash to warn you. If you then start to turn your steering the steering wheel shakes to warn you that you are likely to crash. The positioning of the lights are just perfect.
    Anyway does anyone have any suggestions about the BCM?
    I've also just come up with another problem, the dealers won't sell me the plug that goes into the glass, they're saying I have to purchase the entire mirror!! It's a really long and narrow section and I can't find it on ETKA either.
  2. #12
    May 2017
    Look here, I wrote a small description about my Leon BSM retrofit. I have the connectors and pins there.
    https://forums.ross-tech.com/showthread.php?12734-2013-Seat-Leon-5DR-1-2-TSI-DSG-Style-(MQB)&p=133971&viewfull=1#post133971
    Copy paste, auto url does not work
    The pins and connectors are JST, not VAG official components. You can find the parts easily from ebay.
  3. #13
    Oct 2017
    Northwest UK
    Thanks for that, great write up. I've just ordered the connectors and housing from RS Components here in the UK.
    02R-JWPF-VSLE-S - waterproof housing for the mirror
    SWPR-001T-P025 - female connectors.
    The only trouble is minimum order for the housing is 5 so got a few spare but the connectors is 100! At 4p each it's not much but what a waste.
  4. Likes downtime liked this post
  5. #14
    I think it's due to the acronym decoder having its way with "MQB" in the URL.
    I suspect it will work if we remove the "search engine friendly" text from the URL, like this:
    https://forums.ross-tech.com/showthr...l=1#post133971
  6. #15
    Apr 2018
    ITALY
    Quote Originally Posted by myounus View Post
    Thanks I'll try it tonight when I'm with the car. I think I'm going to swap the bcm also to a highline one to add in xenon and afs.
    It currently has Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
    Component: BCM MQBAB M H16 0124
    Would you say the best version for this car is 5Q0937084AJ?
    I have a BCM AJ if you need it.
  7. #16
    Apr 2018
    ITALY
    It checks the current at startup and if it deviates enough it will disable the BSM system. If you get the resistance correct it should work.
    do you think there is any chance to know the current involved?
  8. #17
    May 2017
    Trial and error?
    No seriously, there was a writeup somewhere (maybe here) in which a person measured the differences in Audi?
  9. #18
    Oct 2017
    Northwest UK
    Guys
    I'm almost done with the install but I have an ABS pump that is too old. Ive got 5Q0 H31 0557 and the min to make this work is H31 0571 or a 3Q0 pump. Is it possible to upgrade the software or does it need replacing?
    If replacing then will my ABS code still work??
  10. #19
    May 2017
    if you’re able to find a newer software upgrade should be possible. Otherwise pump upgrade.
    The 3Q0 AB pump though has everything. It’s the creme de la creme of abs pumpa
    If you’re current pump is IPB the code should be easier to create.
  11. #20
    Oct 2017
    Northwest UK
    The obvious next question is where would I locate a software upgrade? Dealership???
    I've never upgraded an ABS pump before.
