Page 1 of 7 123 ... LastLast
Results 1 to 10 of 66
Thread: Retrofit 3Q0 ABS Pump
    Oct 2017
    Northwest UK
    Greetings
    Please ignore all errors as the car has a flat battery and was involved in an accident and is being charged up. I'll post a proper scan when I've finished the body repairs.
    It is a 2014 Golf MK7 that has Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H ABS pump which I'm pretty sure is not compatible with blind spot assist, unless someone can advise otherwise.
    I think it'll need to be changed to a 3Q0 one. If so would there be any recommendations someone could make or wold any 3Q0 part number suffice? Would it be possible to recode a second hand ABS module or am I better avoiding this altogether??
    VCDS Version: 18.9.1.0 (x64)
    Dealer/Shop Name: VW UK
    VIN: WVWZZZAUZEP074956   License Plate: BLUE
    Mileage: 52284km-32487mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEP074956   Mileage: 52284km-32487miles
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5520
       Revision: 83H22---
       Coding: 011D0012036505082000
       Shop #: WSC 00028 028 00072
       ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
       ROD: EV_ECM20TDI01104L906021DT_002.rod
       VCID: 7AFC4FC4FDD1809A93-802E
    21605 - Sensor for Ambient Air Temperature (G17)
              P0070 00 [175] - Malfunction
                        Fault Frequency: 8
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 14:05:53
                        Coolant temperature: 35 °C
                        Intake air temperature: 40 °C
                        Voltage terminal 30: 12.540 V
                        Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 184.6 °C
                        Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: -0.0 °C
                        Particle filt.inlet temp.sens.1 bank 1: raw value: 38.9 °C
                        Particle filter outlet temp.sens.1 bank 1: raw value: 25.3 °C
                        Shut-off timer: last engine shut-off time: 5 s
              U0428 00 [032] - -
                        Mileage: 52284 km
                        Date: 2018.12.04
                        Time: 00:00:12
                        Coolant temperature: 6 °C
                        Intake air temperature: 5 °C
                        Voltage terminal 30: 11.640 V
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [047] - -
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:23
                        Engine speed: 2397.50 /min
                        Normed load value: 100.0 %
                        Vehicle speed: 56 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 105 °C
                        Voltage terminal 30: 14.540 V
                        Limitation: accelerator pedal: 418.9 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 0
                        selected gear-Bits 0-7: 3
    Readiness: 1 1 0 0 0
       Part No SW: 0D9 300 040 N    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H52 4305
       Revision: 03252204    Serial number: TFK01401250588
       Shop #: WSC 00028 028 00066
       ROD: EV_TCMDQ250021.rod
       VCID: 224C57A435C1285AEB-8076
    21159 - Gear R
    10906 - Cooling Oil Valve
       Component: ESC           H31 0557
       Revision: 00000000    Serial number: 6054400000042F
       Coding: 01FA8AA1242709700380060541C92980512490C0608294F3F8625078C202
       Shop #: WSC 00028 028 00241
       VCID: 7CF049DCF7E5BEAA81-8028
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Reset counter: 250
                        Mileage: 52284 km
                        Date: 2018.12.04
                        Time: 00:01:03
    8192 - Databus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:23
    8196 - Databus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:23
    16390 - Display for Tire Pressure Monitoring
                        Reset counter: 210
                        Mileage: 52284 km
                        Date: 2018.12.04
                        Time: 00:01:03
       Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       ROD: EV_ACManueBHBVW37X_003_VW37.rod
       VCID: 35669CF8944FAFE23E-8060
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.29
                        Time: 08:55:58
                        Outside air temperature: 63.0 °C
                        Engine speed: 900 /min
                        Temperature after evaporator: 7.0 °C
                        System run time-Engine running time: 2 s
                        System run time-Terminal 15 on: 6 s
    459527 - Databus
                        Fault Frequency: 8
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 14:05:54
    1048834 - Functional Limitation due to Energy Management
              B10CD 00 [008] -  -
                        Fault Frequency: 20
                        Reset counter: 245
                        Mileage: 48603 km
                        Date: 2018.09.28
                        Time: 08:01:21
                        Voltage terminal 30: 11.4 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
                        Auxiliary heater: in stages-Act.val.: 1
                        Auxiliary heater: in stages-Specified value for control: 3
    1048835 - Functionality limited due to Engine Control Module
              P1719 00 [008] - -
                        Fault Frequency: 76
                        Reset counter: 248
                        Mileage: 48249 km
                        Date: 2018.09.24
                        Time: 04:20:09
                        Voltage terminal 30: 13.9 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                        Auxiliary heater: in stages-Act.val.: 3
              B10CD 00 [008] -  -
                        Reset counter: 250
                        Mileage: 52284 km
                        Date: 2018.12.04
                        Time: 01:14:56
                        Voltage terminal 30: 10.6 V
                        CAN input signal(s) status-Back-up light: OFF
       Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
       Component: BCM MQBAB M   H16 0124
       Serial number: 00011405501740
       Coding: 03001842C241027B0BA44080B10403281000000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 012001
       ROD: EV_BCMBOSCH_012.rod
       VCID: 79FE50C8F8D78B829A-802C
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    140216  042 0551
       Serial number:         140218200751
       Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
       Component: RLS  024 0042
       Serial number: Y14M02D28H03M27S12S8
       Coding: 00A8DD
       Serial number: 000000000ZY140340CLY
       Serial number: 00000000000028780639
    7 Faults Found:
    5386 - Bulb for Front Right Turn Signal
              B11EA 15 [009] - Open or Short to Plus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:23
    6922 - Bulb for Low Beam Headlamp Right
              B1218 15 [009] - Open or Short to Plus
                        Reset counter: 210
                        Time: 00:00:00
    8714 - Bulb for Left Fog Lamp
              B121F 15 [009] - Open or Short to Plus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.29
                        Time: 09:04:32
    8970 - Bulb for Right Fog Lamp
              B1220 15 [009] - Open or Short to Plus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.29
                        Time: 09:04:25
    137217 - Outside temperature sensor
              B103F 1B [009] - Resistance Too High
                        Fault Frequency: 12
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 14:05:52
    204546 - Remote key 2
                        Reset counter: 14
                        Mileage: 43719 km
                        Date: 2018.07.31
                        Time: 09:04:02
    550420 - Databus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:23
       Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0142
       Revision: --------    Serial number: 39331403702212
       Coding: 0071151011
       VCID: 3E7483D4A1796CBAEF-806A
    7 Faults Found:
              B10FC 13 [008] - Open Circuit
                        Reset counter: 250
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:30
    1112596 - Front Right Parking Aid Sensor
              B10FA 14 [009] - Open or Short to Ground
                        Reset counter: 210
                        Mileage: 52284 km
                        Date: 2018.12.13
                        Time: 03:18:25
    1112084 - Front Left Center Parking Aid Sensor
              B10F8 14 [009] - Open or Short to Ground
                        Reset counter: 210
                        Mileage: 52284 km
                        Date: 2018.12.13
                        Time: 03:18:25
    1112340 - Front Right Center Parking Aid Sensor
              B10F9 14 [009] - Open or Short to Ground
                        Reset counter: 210
                        Mileage: 52284 km
                        Date: 2018.12.13
                        Time: 03:18:26
    1111826 - Front Left Parking Aid Sensor
              B10F7 12 [009] - Short to Plus
                        Reset counter: 210
                        Mileage: 52284 km
                        Date: 2018.12.13
                        Time: 03:18:52
    13637426 - Databus
                        Reset counter: 250
                        Mileage: 52284 km
                        Date: 2018.12.04
                        Time: 00:01:03
    13637888 - Databus
                        Fault Frequency: 9
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 14:05:52
    Address 13: Auto Dist. Reg
       Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
       Component: AirbagVW20    014 0386
       Serial number: 003MLR03W5K4
       Shop #: WSC 00028 028 00061
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F0ABED0E6F3A5B2A4-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169677B28021450347
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169676B27021450365
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 402 14
       Serial number: 35767000000705E00F0Q
       Subsystem 4 - Part No SW: -----------    HW: 480 002 702 14
       Serial number: 35867000000A4B251F0Y
       Subsystem 5 - Part No SW: -----------    HW: 480 402 502 14
       Serial number: 3516502BB142B1C08210
       Subsystem 6 - Part No SW: -----------    HW: 480 402 802 14
       Serial number: 3526502A312F6292D3FI
       Subsystem 7 - Part No SW: -----------    HW: 480 402 402 14
       Serial number: 3556502C112F62954096
    1054981 - Databus
                        Fault Frequency: 9
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 14:05:56
    1050117 - Databus
                        Reset counter: 250
                        Mileage: 52284 km
                        Date: 2018.12.04
                        Time: 00:01:03
       Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 03031404220519
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 7BF24AC0F2EBB99288-802E
       Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
       Component: KOMBI         252 2210
       Coding: 27A419082780260001886A01040000
       VCID: 2858458C53FDC20AB5-807C
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 250
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:26
    16776960 - Databus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:22
    16776961 - Databus
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:22
    13639936 - Databus
                        Fault Frequency: 13
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 14:05:52
       Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2163
       Revision: --------    Serial number: 04031410800267
       Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewConti 010015
       ROD: EV_GatewConti_010.rod
       VCID: 3F8AFED0A67365B2E4-806A
       Component: E221__MFL-DC1  H15 0038
       Serial number: 29140000230530104075
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 5289432703
    131671 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
                        Fault Frequency: 21
                        Reset counter: 210
                        Mileage: 52284 km
                        Date: 2018.12.04
                        Time: 00:01:04
                        Supply voltage: Terminal 30: 11.5 V
                        Terminal 15: On
    66054 - Extended CAN Bus (SAE Bus C)
              U0047 00 [008] - Performance
                        Fault Frequency: 17
                        Reset counter: 250
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:25
                        Supply voltage: Terminal 30: 14.6 V
                        Terminal 15: On
    65798 - Extended CAN in One-Wire Mode
              U0054 00 [008] - -
                        Fault Frequency: 8
                        Reset counter: 250
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:27
                        Terminal 15: On
       Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
       Component: TSG FS        009 0014
       Serial number: 0000093468588
       Coding: 003B0220D001048000001000
       VCID: 4480F13CCF95066AB9-8010
       Serial number: 00000000000004375448
       Coding: 0D0000
    65558 - Heated Exterior Mirror
              B11F8 14 [009] - Open or Short to Ground
                        Fault Frequency: 21
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:37
    65650 - Turn Signal in Exterior Mirror
              B11FD 13 [009] - Open Circuit
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:23
    65654 - Motor for mirror fold-in
              B11F6 13 [009] - Open Circuit
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 14:16:14
       Component: EPS_MQB_ZFLS  122 1043
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 418EF828D087134292-8014
       Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0014
       Serial number: 0000093350543
       Coding: 003B0020DE01048000801000
       VCID: 4382F220CA9B015280-8016
       Serial number: 00000000000004391698
       Coding: 050000
       Part No SW: 5G0 035 874     HW: 5G0 035 874
       Component: MU-S-ND-ER    040 0430
       Serial number: V7F02202142644
       Coding: 02730001FF00000021111201002800001F0100160100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 67DA06B09E630D727C-8032
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9NJ9037N4
       Subsystem 2 - Part No SW: 5G0 919 866 F    HW: -----------
       Component:  ECE 2014  --- 0036
    6917 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 250
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:27
                        Voltage terminal 30: 14.4 V
    6939 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 250
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:26
    7173 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:30
                        Voltage terminal 30: 14.5 V
                        BAP-BAP_Function_ID: 02
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 210
                        Mileage: 52285 km
                        Date: 2018.11.24
                        Time: 13:46:29
    May 2017
    You ABS block should be fine for blind spot assist. It already has ACC installed so BSM should be good to go as well. You have 30 byte block already. Byte 29 has Rear cross traffic alert coding which is the only thing you need to code to ABS block for BSM.
    Oct 2017
    Northwest UK
    That's good news then! I'll get on wiring it in (not looking forward to the mirrors wiring).
    Thanks downtime
    May 2017
    Quote Originally Posted by myounus View Post
    Thanks downtime
    Good luck Mirror wiring is not that bad as it seems. There's not much room to play with the door connector on car side and pulling the wiring through the rubber protecting the wires to the door is not that nice, but it's not that bad.
    RCTA bit is the only change required in ABS block. If that is not accepted, then no probs. You'll just don't enable it.
    If you want to do the coding already, here's a new coding for your ABS block with RCTA bit enabled :
    01FA8AA1242709700380060541C92980512490C0608294F3F8625078C282
    Oct 2017
    Northwest UK
    Thanks I'll try it tonight when I'm with the car. I think I'm going to swap the bcm also to a highline one to add in xenon and afs.
    It currently has Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
    Would you say the best version for this car is 5Q0937084AJ?
  6. #6
    Apr 2018
    ITALY
    the mirror thing is the only thing which is holding me back from the BSM retrofit. I don't want to replace the mirrors' glasses because I already replaced them with aftermarket antiglare version, and I am totally in love.
    then I thought: the BSM mirror LED must not be much different from a regular LED, so what if I installed just a round LED on the car doors?
  7. #7
    May 2017
    It checks the current at startup and if it deviates enough it will disable the BSM system. If you get the resistance correct it should work.
    There are videos in youtube where Leon owners have retrofitted BSM system and used leds in A pillars as indicators. Leon uses same 5Q0 modules.
    Isn’t there anti-glare BSM mirror glasses available?
  8. #8
    Apr 2018
    ITALY
    that's exactly what I would like, do you maybe have any Leon forum links?
    I was not able to find ANY antiglare glass for Golf, which is strange because Octavia has them.
  9. #9
    May 2017
    This one is really good. Spanish but Google translator does it's magic
    https://www.clubseatleon.net/viewtop...21713#p1961160
  10. #10
    Apr 2018
    ITALY
    being italian I need little help to read spanish. thanks.
    it looks like they used a stupid 12V LED, I will have to look into it.
