Results 1 to 6 of 6
Thread: Jetta 6 ABS coding lost?
    Apr 2015
    South Africa
    Jetta was towed in and an engine swop was done.
    For some reason the ABS coding is zero and we would like to do basic settings etc but when logged in it throws an error.
    Any suggestions please?
    Client does not know if ABS pump was replaced?!
    Thursday,24,January,2019,13:15:30:48706
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: RyMar Auto
    Workshop Code: 000 00000 001753
    VIN: WVWZZZ16ZDM026497   License Plate: DZR145L
    Mileage: 185920km-115525mi   Repair Order:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN: WVWZZZ16ZDM026497   Mileage: 185920km-115525miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 MP    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 9564
       Revision: --H43---    Serial number: 00000000000000
       Coding: 10254014032500080000
       Shop #: WSC 00066 790 00186
       ASAM Dataset: EV_ECM16TDI02103L906023MP 003007
       ROD: EV_ECM16TDI02103L906023ML_003.rod
       VCID: 004C65ED9BBD414AD5-8054
       Part No SW: 0AM 300 054 D    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 3640
       Revision: 00043014    Serial number: CU501207256451
       VCID: 2E10EB55B9A9073A77-807A
       Revision: 00H31001
       VCID: 7DB21C19E44F2CA2BE-8028
                        Reset counter: 130
                        Date: 2013.06.16
                        Time: 00:43:44
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 43008
                        Fault Status: 01100101
                        Reset counter: 130
                        Mileage: 185928 km
                        Date: 2013.06.16
                        Time: 00:42:42
                        Count: 3
                        Count: 14
                        Count: 20992
                        Count: 279
                        Count: 43008
                        Count: 256
                        Reset counter: 130
                        Mileage: 185928 km
                        Date: 2013.06.16
                        Time: 00:42:42
                        Count: 3
                        Count: 14
                        Count: 20992
                        Count: 295
                        Count: 43008
                        Count: 256
                        Reset counter: 130
                        Mileage: 185928 km
                        Date: 2013.06.16
                        Time: 00:42:42
                        Count: 3
                        Count: 14
                        Count: 20992
                        Count: 270
                        Count: 43008
                        Count: 256
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010002002
       Shop #: WSC 00066 000 00120
       VCID: 7BB61201F25B229280-802E
              B10AB F0 [008] - Too Low
                        Reset counter: 170
                        Mileage: 185895 km
                        Date: 2019.01.22
                        Time: 16:43:40
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0068
       Revision: BC021001
       Coding: 00000A3A802DE1C040880080140081640170008850A085605C8000000040
       VCID: 3E30DB15A9C9F7BAE7-806A
       Component: RLS 310712 05  54  0403
       Coding: 02300A
       Subsystem 2 - Part No: 1K8 951 171
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 130
                        Mileage: 185928 km
                        Date: 2013.06.15
                        Time: 03:21:16
                        Voltage: 13.70 V
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6M0617W7
       Coding: 00003241
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3228FF25659123DA13-8066
       Serial number: 3572MSME1A46436FZZZ%
       Serial number: 3582MSME7D47436FZZZA
       Serial number: 3516KSME6B18771DZZZ0
       Serial number: 3526KSME4D51121EZZZV
       Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90440LH2000NS
       Coding: 0892140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 42C8AFE5D531935A83-8016
       Component: E221__MFL-TAS  H08 0010
       Serial number: 0301953
       Coding: 830000
       Part No SW: 5C6 920 872 A    HW: 5C6 920 872 A
       Component: KOMBI         H07 0705
       Coding: 171B01
       VCID: 2B16E24142BB721250-807E
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 20091203271511
       Coding: 351003
       VCID: 3FCEA611AEC3FEB2EC-806A
    01304 - Radio
                        Reset counter: 130
                        Mileage: 185928 km
                        Date: 2013.06.16
                        Time: 00:44:28
       Component: IMMO          H07 0705
       VCID: 6A9827458DC1AB1A6B-803E
       Revision: 13110009    Serial number: 0005468859
       Coding: 0002B5
       Shop #: WSC 01383 790 50316
       VCID: 5BF67281529BC292E0-800E
       Slave Driver:
       Component: J389__TSG-HR  008 1508
       Serial number: 00000007112710
       Coding: 000290
    131072 - Rear Door Control Module
              B11ED 04 [009] - Internal System Fault
                        Mileage: 109084 km
                        Date: 2017.01.06
                        Time: 02:33:52
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       VCID: 373ECE3146F3C6F224-8062
                        Fault Status: 11100101
                        Mileage: 185928 km
                        Date: 2013.06.15
                        Time: 02:59:48
                        Battery Volts: 13.8 V
                            DU
                        Temperature: 53.0°C
                        Count: 3
                        Steering Angle: 0.00°
                        Count: 1
                            SteerAng n.Init
       Revision: 15110009    Serial number: 0005468436
       Coding: 0002B4
       VCID: 5CF4719D5795C5AAE9-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1508
       Serial number: 00000007120847
       Coding: 000290
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 169
                        Mileage: 185895 km
                        Date: 2019.01.22
                        Time: 16:43:40
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 167
                        Mileage: 185895 km
                        Date: 2019.01.22
                        Time: 16:43:40
    Address 56: Radio
       Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
       Revision: 1B001001    Serial number: 00007663110232
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 393AC809B8E7D082D2-806C
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 127
                        Mileage: 185895 km
                        Date: 2019.01.22
                        Time: 16:43:40
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 127
                        Mileage: 185895 km
                        Date: 2019.01.22
                        Time: 16:43:40
    0022 - Radio
              U1066 00 [009] - No Communication
              [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                        Fault Frequency: 14
                        Reset counter: 130
                        Mileage: 185899 km
                        Date: 2019.01.22
                        Time: 22:01:18
    End----(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
    Nov 2016
    Often the modules lose coding if they lose communication with the engine ecu
    Try this coding, then you should be able to perform basic settings
    133B200D092300FDC81004EB90200081310000
    Someone wasn't done hiding a nefarious act?
    Are VIN's consistent in VCDS "advanced ID" in 0x01 and 0x25?
  4. Likes Fredrick Awuor liked this post
    Apr 2015
    South Africa
    Advanced id`s are the same.
    Code rejected, Error31, Request of range for coding supplied.
    Vehicle Identification No. WVWZZZ16ZDM026497
    Model Jetta 1.6
    JEM
    Date of production 28.09.2012
    Year 2013
    Sales type 162325
    Engine Code CAYC
    Transmission Code NTS
    Revision: 00H31001
    Coding: 0000000009240000000F00ED90200000000000 LHD VIN STRIP
    Coding: 114B200D09240000880F04ED90200041310000
    Coding: 133B200D09240000880F04ED90200041310000 TRY these two Please HH LHD 280/253 1K Chassis
    Coding: A13B200D09240000850F04ED90200041210000 16 Chassis
    Coding: 133B200D092300FDC81004EB90200081310000 ( RHINOPOWER ) RHD Nein! 280/253 HH, 1K chassis
    Thread not complete will be back in a bit.......
    SCANS OF THE NET SHOW A MATCH.
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Revision: 00H31001
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 7KK Vehicle class differentiation -160-
    drive-off assistance UG1 Hill hold control
    Emission standard 7MQ Emissions standard, EU5 mod
    Trailer hitch 1D0 without trailer towing
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Storage compartment 7N2 Sunglass holder
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    Alternative drive system 0K0 Without alternative drive system
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8C Comfort equipment
    Brake type in rear 1KS Disc brakes in rear (Geomet D)
    batteries J0N Battery 330 A (61 Ah)
    Brake type, front 1ZM Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Beverage holders 4M2 Beverage holder in center console in front and in storage compartment in rear
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B2E Component parts set, complying with vehicle type for South Africa, various parts
    floor covering 3MH Dilours floor covering without scuff guard
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ1 Chrome package
    General operating permit, alterations C11 Operating permit, alteration
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G56 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
    Installation differentiation for components 0EG Installation differentiation for twin-clutch gearbox DQ 200 Vehicle components
    Theft protection system 7AS Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5MB Decorative inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K3 Daytime headlights with automatic headlight control and coming home function
    Fresh air intake for passenger compartment (with particulate filter) 2V1 dust-pollen filter
    Antifreeze 1C2 Antifreeze up to -35 degree celsius tolerance up to -40 degree C
    Vehicle tracing system 7G0 Without preparation for VTS (Vehicle Tracing System)
    Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YE Weight range 5 installation control only, no requirement forecast
    Weight category front axle L13 Suspension range 13 installation control only, no requirement forecast
    Base engine TF3 4-cylinder diesel engine 1.6 l unit 03L.1
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T2 Electronic cruise control system (CCS)
    Exterior noise suppression measures 2B0 without additional exterior noise insulation
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G1C Seven-speed automatic transmission
    glove box 4Z3 Lockable glove compartment door, with light
    Brackets 3P1 Bracket for first aid kit and warning triangle
    handle for hand brake lever 6PE handbrake lever grip (leather)
    Rear spoiler 5J0 Without rear spoiler
    Rear axle 0N4 4-link rear suspension
    Rear seats 3KB Unsplit rear seat bench, split folding backrest, with center armrest
    Heating and air-conditioning system KH6 Air conditioning system with electronic control
    Headlamps 8ID Halogen twin headlamps
    Customized installation FC0 Without individual installation
    Instrument clusters U5A Instrument insert, km/h speedometer
    Instrument panel 4N3 Comfort dashboard
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8B Notchback
    Luggage compartment floor covering 6SF Standard trunk floor covering
    coolbox 1W2 Glove compartment cooling system
    Electronic map cooling system QS0 Without electronic map cooling system
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    headrest for seat, rear 3T2 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 0F3 Fuel system for diesel engine
    Body measures 5C0 Without special body measures
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Camera systems/accident sensors KA0 without camera systems/environment sensors
    Radiator grille 6KE Radiator grille
    License plate lighting KL0 Standard license plate lighting
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K5 Transport protection film with additional transport protection measures
    Steering system arrangement L0R Right-hand drive
    Reading lamp 8S1 Reading light in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Light control systems 8G0 Without Light Assist
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2FQ Leather-wrapped multi-function sports steering wheel with tiptronic
    Driving on the left/on the right AV0 left-hand traffic
    Speaker installation 8RM 8 speakers (passive)
    Steering column systems 2C5 Steering column, adjusted axially and vertically
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Front center armrest
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z6 Hot country
    Engine specifications D38 4-cyl. turbo dies. eng. 1.6 l/77 kW (4V) TDI common rail Base engine is TF3/TN1/TJ1
    Market-specific vehicle version AW1 Version (high)
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WB Front fog lamps
    Rear of platform module base 4P1 Rear floor panel module, type 2
    Platform group class 7PA Platform group class 1
    Panic switch KP2 With additional switch
    Hubcaps 1NL Trims for alloy wheels
    Wheels C1W Alloy wheels 6.5J x 16
    Radios 8DD Radio "RCD510 World Variant"
    Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and rear
    Tire pressure monitoring system 7K9 Tire pressure monitoring system
    tire HH7 Tires 205/55 R16 91V
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G2 Spare wheel with full tyre, steel
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PH3 Air conditioning Climatic
    PJ7 "Sedona" - 4 alloy wheels 6.5J x 16 - tires 205/55 R16
    PLA "Lights & Vision" package
    PU3 Multi-function leather steering wheel with control of gear shift
    RKZ "RCD 510" special markets
    WD4 Anti-theft alarm system "Plus"
    WLB Leather trim "Vienna" with sports seats front
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Service indicator QI6 Service indicator 30 000 km or 2 years ( variable )
    Front seat, left 3TG Sports comfort seat in front, left
    Front seat, right 3SG Sports comfort seat, front, right
    Nameplates for sales name QD3 Nameplates for sales name
    Seat belt check 9P3 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZU 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    seat covers N4M Seat trim covers in part leather
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A3 seat heating for front seats separat controlable
    Side lights 7R3 Side turn signal lights (white)
    Start-stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
    Horns 8Y1 Two-tone horn
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JG bumper in color of vehicle
    Rear stabilizer 0BG Rear stabilizer
    Front stabilizer bar 0AG Front stabilizer bar
    Drawers under front seats QN3 Drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Nameplate set 1RQ Nameplate set "TDI"
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B53 Type approval country South Africa
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Front underbody guard 1SL Underbody stone guard
    Identification plates 1EY Special identification label with weight data, but without general operating permit (ROW)
    First aid kit / warning triangle 1T2 warning triangle
    Telephone / telematics 9ZB Mobile phone interface High
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W0 without washer water level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZA Standard decorative trims
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung 0RB Ignition/starter switch locking system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  7. Likes Fredrick Awuor liked this post
    RYMAR
    Tried to PM you but not active.
    Please report results above, thank you
