Jacks Professional Problem Solver Guide. ""
Make / Model / Year / Edition.
Skoda Super B / Year 2014 / 1.8TSI
Step 1 Tag of PR-Build data picture posted ( Last 6 of VIN can be omitted for privacy )
TMBAB63T7E9006212
Step 2 Status of car stock or modified in any way? If so list!
All is Stock
Step 3 ""
COMPLETE Auto-Scan in code tags!
I cant start a autoscan because the engine is uninstall to the car
Step 4 Describe recent repairs or services, problem at hand, & attempts at repair.
Low oil pressure, I install a oil pressure meter in the oil pressure switch and dont have more than 20 psi with oil hot and wot
Step 5 Are parts or AFT? If so, "what", and what origin?
All engine is , I check all parts and all is perfect, I install a new oil pump, but the problem exist
Step 6 Identify specific issues to be addressed/concerned about, or say ALL.
Low oil pressure, I have a message, RMP limit to 4000 RPM
Step 7 Now that you jumped through the first few hoops of fire, did you check the FUSES/Battery connections?
yes I check all
Good Information Guideline.
1 Focus discussion on symptom description!
2 Ask questions that clarify what, when, where, & frequency.
All time with oil over 90 degrees
3 Summarize your understanding & get agreement in forum or from colleagues.
I work with vw engines for 10 years, and theTSI engines have hard problems with oil pressure, .
4 Explain what you will do to proceed, & get forum acknowledgement.
I think that the problem may be in the oil pump second phase, I dont understand how can I test this.
5 Do you have a proper repair manual? If not get one!
http://forums.ross-tech.com/showthre...Wiring-Diagram
6 Do you know how to read a schematic? If not see "How to read section" or link to Jef.
http://forums.ross-tech.com/showthre...(final-version)
7 Check part numbers are accurate, & firmware versions of + respective controllers are of latest release.
8 Did you check CHARGING SYSTEM HEALTH, BATTERY & FUSES "YET"?
Diagnosing, Brain storming, & the Final Solution!
1 Describe problem ( List known symptoms ) Nix opinions or disguised solutions
2 Verify & Analyze ( Duplicate if possible, & list possible causes...... ! the trouble tree, 's & for )
Further..... of hardware, & or electronically modified firmware/software/emissions defeat/delete devices is essential now...... do not negate this! Look for any discrepancies in codification when compared to other modules. Actually review Time Stamps Miles and the information made available in a , such as a G or N destinations and use as a search in .
3 Locate the problem ( Prioritize and identify work times + safety limits, the use of chemicals or tool requirements )
4 Repair the Problem ( Determine the cause & not just treat an effect )
5 Conduct a quality Check of your work and verify you fixed it!
Always follow up reporting back to the Forum to help the next guy.
IF ANY OF THE ABOVE IS TOO MUCH TO COMPLY WITH, YOU SHOULD CONSIDER SEEKING A PROFESSIONAL SHOP VISIT.
