Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Skoda 1.8 Tsi low oil pressure
    Ecuador
    hi I have a skoda super b 1.8tsi in my workshop, the car say low oil pressure rpm limit 4000 rpm, I unassabled a engine, I change a ballance shafts, oil pump, the camshafts are perfects but I have a problem, somebody have this problem?
    the vag com say only oil oressure switch, this switch are not a problem, because I install a oil gauge and I dont have more tham 25 psi in wot, and about 5 psi on ible.
    thanks
    Post an auto-scan please Alvaro.........
    May 2016
    What is the mileage and condition of crank bearing?, guess scan would answer some of that.
    Larimore
    Wanna check oil PSI controlled regulation volume as per the RTFB too by doing the JPPSG.
    Is a oil bypass stuck open slightly?
    thanks
    These tests don't cut the mustard for the Bavarian pretzel.
    May 2016
    As stated all my experience is VW TDI, other than some friends cars but know the 1.8 from classes is a historic sludge motor along with numerous others, Toyota and Chrysler come to mind.
    Know the 1,8 as you stated plugs screens which you say remove.
    Again, are these and others full of sludge from poor maint, as know lots of folks with the 1.8 that don't have the issue.
    LARIMORE
    LARIMORE
    Would you remove screens at oil fed adjusters or tensioners that are post oil filter or pickup screen in sump & that would prevent an engine from running proper & isn't it a known fact that in the TSI engines, the screens themselves break down and become vicarious FOD to damage an engine cylinder head etc. regardless of oil change history & all on its own proving me even more right since the 1.8T days & not for oil pump pickup's and stated again for clarity?
  7. #7
    Jul 2014
    Tallinn, Estonia
    OP should clarify what particular 1.8 TSI engine model this car has - BZB or the infamous CDAA?
  8. #8
    Ecuador
    Hi, I cant because the engine is unassambled now, thanks
  9. #9
    Ecuador
    the car has 62k kilometers, I unassambled the engine and all is perfect, all is ok, crankshaft bearings, rod bearings, ballance shafts, camshafts, and cylinder head cover , thanks
  10. #10
    Ecuador
    Larry, I unassambled a engine, all is perfect,
