Results 1 to 10 of 11
Thread: A4 engine temperature problem 8K-AU48
    Jan 2019
    Friday,04,January,2019,07:25:47:27957
    VCDS Version: 18.9.0.4 (x64)
    VIN: WAUZZZ8K6DA187362   License Plate:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72
    VIN: WAUZZZ8K6DA187362   Mileage: 129450km-80436miles
    Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 HT    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 12034012242401080000
       Shop #: WSC 62232 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018HT 003009
       ROD: EV_ECM20TDI01103L906018HT.rod
       VCID: 0304046C8A782D52C6-8056
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 8K9 927 155 A    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000001097
       Coding: 000002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMVL381 A02432
       ROD: EV_TCMVL381.rod
       VCID: 3A7AB988BD32AC9AD5-806E
       Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
       Component: ESP8 front    H09 0100
       Coding: 171544
       VCID: 000E0B60936E364ADB-8054
       Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
       Component: BCM2 2.0      H12 0633
       Coding: 01B24040000000000000
       VCID: 79F86684F0B467829C-802C
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0512000084046021
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 2312000276032008
       Part No SW: 8K2 820 043 AJ    HW: 8K2 820 043 AJ
       Revision: D1000000    Serial number: 01030120130321
       Coding: 342402E000
       VCID: 71E85EA4A8C42FC224-8024
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000535965802
       Coding: 260000108034AFC00081400300001D0D0F1D470827090201000008004400000200020024000000
       VCID: 7AFA7988F5B26C9A95-802E
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 030113  H06 0080
       Serial number: SWF13010035406
       Coding: 00FD11
       Serial number: 20840144
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001412120387
       Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Serial number: 59984166000000000001
       Serial number: 003KFD97C722
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 47074 001 1048576
       VCID: 489ED340F3DECE0A53-801C
       Serial number: 6334MSME757105659
       Serial number: 6344MSME7551467BK
       Serial number: 6352QSME10265052+
       Serial number: 6362QSME432722503
       Serial number: 63732SME01270B50P
       Serial number: 63832SME7E26347EE
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20130109001213
       Coding: 000037
       VCID: 4FACF85C1EB0193212-801A
       Part No SW: 8K0 920 982 E    HW: 8K0 920 982 E
       Component: KOMBIINSTR.   H35 0556
       Revision: 00200000    Serial number: UVR56M21E
       Coding: 33AE10000A012600010000
       Shop #: WSC 06335 123 12345
       VCID: 3662ADB8812A48FA31-8062
       Component: GW-BEM 4CAN-M H11 0055
       Revision: 1Y060027    Serial number: 2741Y12C19005B
       Coding: 80CF07FF00
       VCID: 4A9AE948E5D23C1A45-801E
       Serial number: 7346138901
       Serial number: 12346003044021200410
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000047922395
       Coding: 011C02204001410001
       Revision: 00001000    Serial number: 0012137180
       Coding: 100000000001
       Shop #: WSC 06334 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 346697B09F565AEA0F-8060
       Revision: 00002001    Serial number: 0300021274
       Coding: 013B062220B90000802002368000000F
       Revision: 00005001    Serial number: 94813009185702
       VCID: 2D5082D4747C0B2240-8078
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000046817524
       VCID: 4E92E55819BA103A19-801A
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000154539
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 387EA380833EBE8A23-806C
       Part No SW: 4G0 035 061 J    HW: 4G0 035 061
       Component: Radio U DAB   H60 0123
       Revision: AB001007    Serial number: 109LX0C7605032
       Coding: 010103010000000001
       VCID: 244667F027B6CA6A9F-8070
       Part No SW: 8R2 035 666 B    HW: 8R2 035 666 C
       Component: H-BN-EU       H45 0639
       Revision: --------    Serial number: 206AM0D7512243
       Coding: 0F010101000681ED01808B5E00000403E40000020000000000
       VCID: 387EA3808B3EBE8A23-806C
       Subsystem 1 - Part No: 8R0 060 884 AR
       Component: ECE 2013  1505
       Component: DU7 High  H41 0104
       Serial number: A130L-0C2609870
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000001366495
       Component: CD-Database  4949
       Revision:             Serial number: 0000047254715
       Coding: 010C02204001210001
       VCID: 4682DD78F1CAD87AA1-8012
       Revision:             Serial number: 0000047254778
    End-------------------------(Elapsed Time: 03:27)--------------------------]
                    Address 01: Engine  (03L 906 018 HT)
    07:49:47
      IDE00025   Coolant temperature 69 °C
      IDE00196   Engine oil temperature 70.8 °C
      IDE00556   Outside air temperature 7 °C
      IDE03582   Temperature sensor for engine temperature management 69.0 °C
      IDE04637   Engine temperature management actuator 99.74 %
      IDE04666   Heat delivery temperature in cooling system -273.1 °C
      IDE04937   Sensor for engine block temperature: raw value 69.6 °C
      IDE06258   Charge air temperature at the turbocharger outlet: calculated -0.7 °C
      IDE06391   Oil temperature sensor 2 -0.0 °C
      IDE06392   Oil temperature sensor 2: raw value 0.0 mV
    The engine is slow to get warm in the winter and cools down quickly when not under load. I've changed the thermostat which had no effect.
    Also "G381 Loc. IDE04637 Engine temperature management actuator 99.74%" this value never changes.
    Any help welcome.
    Thanks.
    The car is new enough that I'm fairly confident that the ECU monitors the temperatures (and their rate of change) fairly closely. Given that it's not throwing any fault codes, I would suppose that it's all within the expected parameters for this engine?
    Did you try to block air dams with quick removable cardboard in front of radiator to increase heat efficiency & does your car support a heater core bifurcated inline thermostat?
    Sep 2015
    Would not take this for granted. Although a different engine, but in my A3 8V 1.8TFSI CJSB I had a leaking thermostat. Could not get engine to normal operating temperature no matter what, but ECU was still happy with it. No fault codes whatsoever.
  5. Likes Jack@European_Parts liked this post
    Jan 2019
    I've had the thermostat replaced which made no difference. Can anyone shed any light on the Engine temperature management actuator, this is always showing 99.74%. I have recorded the various levels and it looks to be just really poor temperature control. Sometimes after a short journey the cooling fan will switch on. I'm wondering if it could be sensor that's not faulty but just giving the wrong temperature.
    The thermostat is a 3 port not the actuated 4 port but there is an actuator on the cabin heater line.
    May 2016
    Quote Originally Posted by Steve_bury View Post
       Revision: 45H25---
       Coding: 000002
       Coding: 171544
       Coding: 342402E000
       Coding: 00FD11
       Coding: 02005D
    H01 0031
    H01 0031
       Coding: 000037
       Coding: 80CF07FF00
    07:49:47
    Any help welcome.
    Thanks.
    Some info here is puzzling. Oil temp and coolant within 1 c question that. Also 69C is about 156F , no where near 190/195 I would want as a target for heat.
    Coolant fans don't normally come on until well above 195/90C but do excite for other various reasons such as AC, defrost ect but them coming on indicative of having hit some target but certainly no enough for stellar heat.
    Have a TDI which I seem to have to change stat every year which can make some serious hot heat. Noted last time in small amount of rust deposit, which IMO was the culprit, as unit would do what yours did. Even blocked off all air as JACK said but in 7C e
    Weather's should not need.
    Who changed the stat? And is it burped or evaced properly?
    Also my last STAT I specified OEM, and looked just like the other but would only use OEM that way you can say you did your best.
    The heat deliver in system _273, that is beyond my pay grade, maybe UWE could input.
    LARIMORE.
  8. Likes Jack@European_Parts liked this post
    Jul 2014
    Tallinn, Estonia
    The measuring blocks say the outside air temperature is +7C but is it really?
  11. #8
    These are all great posts aforementioned...........
    I can tell you if the system doesn't make adequate PSI and a leak at expansion tank or o-ring on filler cap can cause this etc. it will never run enough flow to remove hot air from convection of the heater core.
    If this condition exists it can indeed cause hot spots in engine and make radiator come on sooner as a sign of such issues & with no DTC's!, apparently?
    If the climate control sees a value of temp being adequate it may never open a blend door for cabin.......indeed should be investigated!
  12. Likes Larry Manton liked this post
  13. #9
    May 2016
    Jack, you hit what I missed and for sure. Have had my butT kicked more than once for not having a cap that would hole PSI, thanks for bringing it up, back to basics always,
    LARIMORE
  14. Likes Jack@European_Parts liked this post
  15. #10
    LARIMORE
    That's why JPPSG ...........The rules matter "BASICS"!
