Had a look at this one a few times, it has 2 exhaust pressure sensors , the readings looked OK, but we swapped a new one in both positions have run a regen back to zero, lasts for a few days then code back in.
The dealer has told him that they would change the EGR and cooler, but couldn’t guarantee it would fix the issue.
Customer tells me noticed no drop in performance, just concerned about EML on. He is using good fuel and motorway driving in a regularly
I would have thought there is software upgrades for this year model? anyone had similar issues?
Wednesday,23,January,2019,12:35:51:32699
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
VIN: WAUZZZ4G1EN130370 License Plate: A6 GREY
Mileage: 146431km-90988mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62
6D 72 AC
VIN: WAUZZZ4G1EN130370 Mileage: 146431km-90988miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 BD HW: 04L 907 309
Component: R4 2,0L EDC H23 8244
Revision: 85H23---
Coding: 12254012242401080000
Shop #: WSC 54971 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021BD 002005
ROD: EV_ECM20TDI01104L906021BD_002.rod
VCID: E89CE2CA130CE00AF5-80BC
19226 - Particulate Trap Bank 1
P2002 00 [237] - Efficiency Below Threshold
Fault Frequency: 78
Mileage: 139807 km
Date: 2018.11.15
Time: 19:49:18
Engine speed: 1835.50 /min
Normed load value: 55.7 %
Vehicle speed: 72 km/h
Coolant temperature: 92 °C
Intake air temperature: 98 °C
Voltage terminal 30: 13.020 V
Exhaust mass flow of low-pressure EGR: calculated: 3.051
Differential pressure ratio: low-pressure EGR: 35.5 kg/h
Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 41.8 hPa
Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 39.0 hPa
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 71.47 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 63.78 %
Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 42.0 hPa
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G0 927 153 HW: 0CK 927 156 L
Component: 0CK 20TDI RdW H02 0002
Revision: --H02--- Serial number: 0000000019
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002009
ROD: EV_TCMDL382021_AU57.rod
VCID: E680ECF21918F67AC7-80B2
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 06A29F016045F980DB00
VCID: BA3868823D20A29A53-80EE
Part No SW: 4H0 907 064 EN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0521
Coding: 01B93046000000000000
VCID: F9BAB78E70A669821A-80AC
Serial number: 0214000033778006
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 BB HW: 4G0 820 043 BB
Component: KLIMA 2 ZONEN H14 0094
Serial number: 24021400111751
Coding: 3422090821
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: E08CFAEAFB3C984A3D-80B4
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001847898
Coding: 2600201040349FE00181008300001D0CCF9DC70827090201000004606100
VCID: EE9094D239E83E3ABF-80BA
Component: WWS57X 140210 H37 0080
Serial number: 140216231524
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22322651
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 24 02 2014 00000768
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 1AB88417000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Revision: 11001001 Serial number: 61061406400373
Coding: 08C308
VCID: F1AA8FAE20D621C2A2-80A4
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00GZBX4
Coding: 3032343631324E303235554A305234473053
VCID: B6207CB2093846FAB7-80E2
Serial number: 3575HRB405F2B68U8PN/
Serial number: 3585HRB405H2ATKKE97+
Serial number: 3515JRB401E50TT661D7
Serial number: 3525JRB400A50U80H12K
Serial number: 3554VRB400A50TIUMI8F
Serial number: 3564VRB400M50T8GGGUI
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140304000413
Coding: 000035
VCID: B02C4AAAE35C68CAED-80E4
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 984 H HW: 4G8 920 984 H
Component: TDieGb H58 0621
Revision: 29460235 Serial number: 658190214596018
Coding: 33A612000B412600010000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: BB366D86321A9B9248-80EE
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung / Adaption]
Reset counter: 168
Mileage: 139387 km
Date: 2018.11.12
Time: 15:01:29
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001294941
Coding: 00CD074400
VCID: F2A880A225D01ADA5B-80A6
Serial number: 0577592603
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 13122700000000000597
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 92
Mileage: 144210 km
Date: 2019.01.04
Time: 03:25:47
Voltage terminal 30: 12.4 V
Voltage terminal 15: 0.0 V
Control Module temperature: 0 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 1
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H03 0056
Revision: -------- Serial number: EJ1BPA7208T49A
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: B32645A61A4A53D290-80E6
Component: TSG FA H03 0507
Coding: 011F16004001620002080002
VCID: C7DE017676D2CF72DC-8092
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0018319686
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B22840A2E5505ADA9B-80E6
Revision: 00002001 Serial number: 0328489610
Coding: 013B0622A0B930008320090400010F470000000000000000000000000000
Component: DWA-Sensor H01 0010
Component: TSG BF H03 0507
VCID: C6C00C7271D8D67A27-8092
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001298884
ROD: EV_ParkiBrake_VW51.rod
VCID: AD1253DEFC6E0522C6-80F8
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 140228-0002-053
Coding: 112296101000A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
Component: RMC Nav Plus H55 0801
Coding: 0101010101C15B47082B060301010000000000
VCID: A71EA1F6D6922F723C-80F2
Subsystem 1 - Part No: 8X0 919 884 G
Component: P24-50-13.06 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464BS0E2650019
Subsystem 3 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349NC40006P
Component: TSG HL H03 0507
Coding: 010F14004001620002080002
VCID: C9DA074E60C63902CA-809C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 059400565
Coding: 097205C010
ROD: EV_HDSGAu571.rod
VCID: B5227BBE143E4DE2BE-80E0
Component: TSG HR H03 0507
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 140430064
ROD: EV_RDCMA00100_008.rod
VCID: AB165DC6C27A0B12D8-80FE
End----(Elapsed Time: 01:42, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
