Results 1 to 7 of 7
Thread: VW Passat 2008 TDI BKP engine
    Mar 2016
    I have the above none starter, I've been told to change the crankshaft sensor. After removing the water cooled oil filter housing I have gained access to the sensor, which is deeply recessed into the cylinder block. I have managed to put a 4 mm long Allen key into the bolt head and tried to turn it by hand but it seems to slip. Visual access with a mirror is limited and my eyesight focus ain't that good to make out exactly whether it is a torx or Allen key bolt head. I'm not even sure whether VW have a special tool designed for removing these sensors?
    Any help greatly appreciated.
    Every job is important, even the lowliest, and peoples lives very much depend on us all, so with this in mind, let no man delude himself that his work is more important than that of his colleagues.
    Jul 2017
    Kenya
    Quote Originally Posted by Trade Member View Post
    Hello,even though I haven't worked on this diesel motor,but most VW G28 senders are fastened by 5mm Allen keys,and you may need to remove debris that has settled inside the female screw head,and try VW T10058 or equivalent especially if it is at an angle ,I hope this helps
  3. Likes Trade Member, Uwe liked this post
    Mar 2016
    Quote Originally Posted by Fredrick Awuor View Post
    Thanks Frederick
    New User
    Lithuania
    From my experience, in most cases the gearbox needs to come off...
    Im sure it 4mm but the bolt sits at a funny angle, I had these before where they have been rounded off and gearbox removal was the only way to fix.
  7. Likes Fredrick Awuor liked this post
    May 2016
    Anwar, I don't always do what I'm told, I.E. meaning how have you validated the CPS is bad. If it was right in the open sure, but I would go upstream if I could, access the the signal with a scope and see if it is in fact, just my opinion, good luck.
    LARIMORE
  9. Likes Ashraf6119 liked this post
  10. #7
    Verified VCDS User Gremling's Avatar
    Dec 2017
    Norway, Nordland
    Did you figure this out yet?
    It is a 4mm Allen key, just a bit difficult to access, but fully doable, but the VW tool -T10370- will help.
    As far as I can recall, the oil filter bracket needs to be removed and oil cooler hoses needs to be removed, just remember to clamp off hoses.
    Found this video on Youtube for you, https://www.youtube.com/watch?v=mlWQBLROG0A see timestamp 1:07, and you can see the position for sensor.
    Sensor bolt to be tightened to 5Nm
    Hope this helps if issue still valid
    Regards
    Gremling
  11. Likes Uwe, Fredrick Awuor liked this post
