Results 1 to 2 of 2
Thread: 2014 Audi S4 B8.5 - Dynamic Steering Failure
    Jan 2019
    Greetings! Was driving the other day and received “Dynamic Steering Issue - Ok to drive” on the MFD. a few miles later then it displayed “Dynamic Steering Failure - Do not drive” at which I completely lost power steering. I ran a VCDS scan. My Audi/VW shop thinks it’s a bad Dynamic Steering control module, however Audi does not sell this part separately and requires the whole steering rack to be replaced. Hoping someone has experience with this particular issue and can provide some insights or other steps that can be taken before replacing the whole rack.
    Sunday,06,January,2019,17:50:08:09684
    VCDS Version: 18.9.0.4 (x64)
    VIN: WAUBGAFL8EA055273   License Plate:
    Mileage: 86170km-53543mi   Repair Order:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 02 03 05 08 09 14 15 16 17 19 22 36 42 44 46 47 52 53 56
              5F 62 6C 72 A9
    VIN: WAUBGAFL8EA055273   Mileage: 86170km-53543miles
    Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0007
       Revision: --H07---
       Coding: 0A250034052600060000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
       ROD: EV_ECM30TFS0218K5907551G.rod
       VCID: 3A7BCA32BD7A4D9AD5-806E
       Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
       Component: 0B5 30TFSINAR H02 0002
       Revision: --H02---
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501021.rod
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Coding: 291D1A01
       VCID: 091965FEA01C96028C-805C
                000 -  -  - Intermittent
                        Fault Frequency: 145
                        Reset counter: 86
                        Mileage: 82656 km
                        Date: 2018.11.27
                        Time: 16:13:07
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0015
                        Hex Value: 0x1090
                        Hex Value: 0x0000
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 46
                        Mileage: 86177 km
                        Date: 2019.01.05
                        Time: 20:31:43
                        Hex Value: 0x0600
                        Hex Value: 0x4006
                        Hex Value: 0x120C
                        Hex Value: 0xC0B8
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 HM    HW: 8K0 907 064 GM
       Component: BCM2 2.0      H13 0641
       Coding: 0D814040000000000000
       VCID: 020B72D29D2AC55ACD-8056
       Serial number: 0213000310263010
       Revision: C1000000    Serial number: 01220920130980
       Coding: 6600228000
       VCID: 3979D53EB07C4682DC-806C
       Revision: 08016001    Serial number: 00000050428202
       Coding: 2600C811813CAFE0290048C300003D0D4F9CD308A2090221000008004000070100000030000000
       Shop #: WSC 06325 123 12345
       VCID: 78FF103ACBF69F8AE3-802C
       Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: MITSUBA270813  H18 0461
       Serial number: 1308220711576
       Coding: 004577
       Serial number: 21735060
       Coding: 03005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001109131195
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R7N3A03
       Serial number: 5FE88AC6000000000001
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8R0 907 364 C    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H09 0054
       Revision: 00000000    Serial number: 29081302140002
       Coding: 010181
       VCID: 3A7BCA32B57A4D9AD5-806E
       Serial number: 003KJDB0FX9.
       Coding: 303844354730303030304A55304C384B3053
       Shop #: WSC 45442 001 1048576
       VCID: 4A9B9AF2ED9ADD1A45-801E
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R130000ELSD
       Serial number: 6334MSME7F12241AF
       Serial number: 6344MSME7D614303B
       Serial number: 6352QSME7C372550I
       Serial number: 6362QSME38394360E
       Serial number: 63732SME24332F4C1
       Serial number: 63832SME52350F580
       Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
       Revision: --------    Serial number: 90372MIB0006M
       Coding: 000036
       VCID: 4487B4CAC7BE0B6ABF-8010
       Part No SW: 8K0 920 983     HW: 8K0 920 983
       Component: KOMBIINSTR.   H35 0563
       Revision: 00500000    Serial number: WWH555H9E
       Coding: 8BFF09009301D705020000
       VCID: 72EB2212AD8AF5DADD-8026
       Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0056
       Revision: 1Y070028    Serial number: 2841Y138300B01
       Coding: 80C303FF00
       VCID: 4A9B9AF2E59ADD1A45-801E
       Serial number: 3700401303
       Component: 4 Wheel Drive H14 0100
       Serial number: 001109130001300
       VCID: 2F6DEB667638983272-807A
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000073724842
       Coding: 00581B00000000000000
       VCID: 3B75CF36BA407492CE-806E
       Component: TSG FA        H09 0305
       Coding: 011C13204E00410001
       VCID: 56A37E82212289FAD1-8002
       Revision: 00001000    Serial number: 0009127957
       Coding: 000000010001
       Shop #: WSC 06324 123 12345
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3467E40A9F1EBBEA0F-8060
    7341600 - Position Sensor for Motor
              C10AD 29 [008] - Signal Implausible
                        Reset counter: 86
                        Mileage: 86151 km
                        Date: 2019.01.05
                        Time: 17:42:16
                        Write only channel
    1052420 - Internal Control Module Memory Check Sum Error
              B2000 49 [137] - Internal electronic failure
                        Mileage: 86177 km
                        Date: 2019.01.05
                        Time: 20:31:44
                        Write only channel
    7341570 - Position Sensor for Motor
              C10AD 29 [137] - Signal Implausible
                        Mileage: 86176 km
                        Date: 2019.01.05
                        Time: 20:30:40
                        Write only channel
       Revision: 00002001    Serial number: 0314961169
       Coding: 0106063A00FA400583B0013200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000727976
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
       Revision: 00005001    Serial number: 94813020034103
       VCID: 2D51F16E7434EA2240-8078
       Component: TSG BF        H09 0305
       VCID: 55A1798E3C2482E2D8-8000
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 20000000332229
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3979D53EB87C4682DC-806C
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156I60D7906845
       Coding: 020007010000000001
       VCID: 2541094E2CC4D26288-8070
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 G
       Component: H-BNT-NA      H44 1040
       Revision: --------    Serial number: 523E50H7625479
       Coding: 110200000206A1EF45028B4E00000403140000000000000000
       Shop #: WSC 65346 001 1048576
       VCID: 3F8DBB26AE5868B2E2-806A
       Subsystem 1 - Part No: 8R0 060 884 DQ
       Component: NAR 2016/2017  1402
       Component: DU7 High  H42 0104
       Serial number: A130IY0D2826149
       Serial number: 00000001620379
       Component: CD-Database  6890
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0305
       Coding: 010C13204000210001
       VCID: 59B975BE503CA682FC-800C
       Revision: --H08---    Serial number: 525PA8-J37955Q
       Coding: 1000006
       VCID: 387FD03A4B765F8A23-806C
       Component: TSG HR        H07 0305
       Component: SAS-GEN 2     H06 0005
       Serial number: 130910201986
       VCID: 72EB2212A58AF5DADD-8026
    End-------------------------(Elapsed Time: 04:09)--------------------------
    Component: RCEPS H37 0507 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Isn't there or wasn't there several firmware updates for this controller to address this error?
    Hey did you check all connections to the 0x44 rack & since a high load circuit or for fuse failures yet?
