Results 1 to 5 of 5
Thread: Wanted: VW UP! RCD 215 Radio Long Coding String (Europan Car Please)
    Jan 2019
    New Zealand
    I'm moving a Car from Japan to New Zealand and need to change the FM frequency tuning range.
    Thanks!
    -Philip
    Magdeburg, Germany
    Start by posting an Auto-Scan from the vehicle in question. A minimum would be the VIN and/or the part number of the control module in question. In most cases, the units are region specific and a coding change isn't gonna help.
  3. Likes Bruce, PetrolDave liked this post
    Jan 2019
    New Zealand
    Thanks for the guidance - Auto-Scan follows:
    Friday,18,January,2019,12:13:29:49310
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZAAZGD107633   License Plate:
    Mileage: 680km-422mi   Repair Order:
    Chassis Type: AA-VW12 (1S0)
    Scan: 01 02 03 09 15 17 19 25 44 56 61 AD
    VIN: WVWZZZAAZGD107633   Mileage: 680km-422miles
    AD-Brake Sensors -- Status: OK 0000
    Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
       Part No SW: 04C 906 020 DR    HW: 04C 907 309 P
       Component: R3 1.0l MPI   H24 2561
       Revision: UNH24---
       Coding: 00140012020401000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM10MPI01104C906020DR 001004
       ROD: EV_ECM10MPI01104C906020DR.rod
       VCID: 6ED8307DB1579B3A3F-803A
    5603 - Park/Neutral Switch Input Circuit
              P0851 00 [096] - Short to Ground
                        Mileage: 498 km
                        Date: 2018.10.18
                        Time: 20:36:06
                        Engine speed: 1321.50 /min
                        Normed load value: 28.2 %
                        Coolant temperature: 17 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 11.355 V
                        Unlearning counter according OBD: 13
                        Adaptation status for transmission neutral position sensor-Bits 0-7: 0
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Address 02: Auto Trans (J514)       Labels:* None
       Part No SW: 0CT 927 750 F    HW: 0CT 927 750 C
       Component: SQ100         H12 0132
       Coding: 030120
       ASAM Dataset: EV_TCMSQ101011 005013
       ROD: EV_TCMSQ101011_005.rod
       VCID: 4B9E99E9E2058E1278-801E
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 L    HW: 1S0 614 517 L
       Component: EBC 460 ESP   H16 0023
       Serial number: A016NP8
       Coding: 11BF247129AD02F8880024F894AC409059B200
       ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
       ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
       VCID: 3874D6258393158A25-806C
       Part No SW: 1S0 937 090 E    HW: 1S0 937 090 E
       Component: PQ25 BCM      H59 0584
       Revision: -D------    Serial number: --------------
       Coding: 62B82B0000010000000001F42C2BACC07340424E7E031420200000460100
       VCID: 356ADF119C81E8E23E-8060
       Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
       Component: VW10Airbag01S H03 0006
       Revision: --------    Serial number: 003MY00K4J0G
       Coding: 000000000000000000000000000000003153
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       VCID: 3D7AC731ACB130A2F6-8068
       Serial number: 3497ARB405V41DQABPPB
       Serial number: 3507ARB405V41DQADPO4
       Serial number: 3557BRB405L3I0RMGHF2
    Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
       Part No SW: 1S0 920 861 G    HW: 1S0 920 861 G
       Component: KOMBI         H52 0405
       Revision: X0052001    Serial number: 00000000000000
       Coding: 1142000000
       ASAM Dataset: EV_KombiUDSMM9RM10 A05803
       ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
       VCID: 356ADF119481E8E23E-8060
       Part No SW: 1S0 909 901     HW: 1S0 937 090 E
       Component: GW-K-CAN TP20 H59 0584
       Revision: -D------
       Coding: 001300
       VCID: 70E42E05A3638DCA2D-8024
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 1S0 920 861 G
       Component: IMMO          H52 0405
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6AD03C6D8DBF771A63-803E
       Part No SW: 6R2 909 144 AJ    HW: 6R2 909 144 E
       Component: EPS_TRW_ALow  322 3132
       Serial number: CG5C1396
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016029
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 00047EC59BC39D4ADD-8054
    Address 56: Radio (J503)       Labels: None
       Part No SW: 1S0 035 156 M    HW: 1S0 035 156 M
       Component: Radio         H10 0022
       Revision: R0000000    Serial number: VWZAZ1R0891828
       Coding: 0000020001
       Part No SW: 1S0 907 534     HW: 1S0 937 090 E
       Component: Batt-regelung H59 0584
       Coding: 032B7864
       Subsystem 1 - Part No SW: 1S0 915 181 B    HW: 1S0 915 181 B
       Component: J367-BDM  H08 0210
    Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
       Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
       Component: CV-SENSOR     H07 0460
       ASAM Dataset: EV_CVSen 001001
       ROD: EV_CVSen.rod
       VCID: 285406655333850AB5-807C
    End-------------------------(Elapsed Time: 02:02)--------------------------
  5. Likes Sebastian, Dana liked this post
  6. #4
    Magdeburg, Germany
       Coding: 0000020001
    Definitely a special version for the Japanese market, so you'll likely need to replace it with the desired version for the market the car is heading to.
  7. Likes Dana, Uwe liked this post
  8. #5
    Jan 2019
    New Zealand
    Thanks, replacement unit has been sourced from the UK for 40£. Simple and easy solution!!
  9. Likes Uwe, Sebastian liked this post
