Results 1 to 2 of 2
Thread: Troubleshooting V10 TDI Cam Sensor
    Jun 2014
    Here is the intermittent 012295 that's showing up occasionally while driving. After a trip to the carwash recently there was no signal at all for awhile. Would there be a MVB for this EDC16 where I could watch and do some wiggle tests?
    Sunday,16,December,2018,12:01:36:34689
    VCDS Version: 18.9.0.1
    VIN: WVGPT77L46D062013   License Plate:
    Mileage: 200360km-124497mi   Repair Order:
    Chassis Type: 7L (LG1 - My VW Touareg)
    Scan: 01 02 03 05 06 08 09 11 15 16 17 18 19 1C 22 29 34 36 37 39
              46 47 56 68 69 6C 6E 76
    VIN: WVGPT77L46D062013   Mileage: 200360km-124497miles
       Part No SW: 070 906 016 CQ    HW: 028 101 196 2
       Component: V10 5,0L EDCG000AGMª8472
       Revision: --H02---    Serial number: VWZ3Z0F6455356
       Coding: 0060575
       Shop #: WSC 31414 000 00000
       VCID: 61C2339FBBCE2B42B9-5102
    012295 - Camshaft Position Sensor (G40)
                   P3007 - 000 - No Signal - Intermittent
                        Fault Status: 00110000
                        Mileage: 197722 km
                        RPM: 1764 /min
                        Speed: 103.5 km/h
                        Load: 32.5 %
                        Voltage: 13.60 V
                        Bin. Bits: 00101000
                        Idle Stabilization: 0.0°KW
                        (no units): 48.0
       Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
       Component: AL 750 6A           0856
       Revision: 00H37000    Serial number:
       Coding: 0004200
       VCID: 7F0695E72D7AFDB2AF-5120
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D7AAFEF67F62FA2FD-5102
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 137 A    HW: 5WK 485 02
       Component: 29 Kessy            6700
       Revision: 67005915    Serial number: VWZ3Z0F6455356
       Coding: 0147688
       VCID: 316283DFABAEDBC269-5120
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77F67DC7054AC5F2E7-5120
       Part No: 7L6 907 044 T
       Component: CLIMAtronic 2+2     4222
       Coding: 0020030
       VCID: 458AC70F0F266762A5-5120
       Subsystem 1 - Part No: 7L6 907 049 E
       Component: CLIMAtronic FOND    0400
    02600 - Rear Right Temperature Flap Motor (V314)
                000 -  -  - Intermittent
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3002
       Coding: 0111836
       VCID: 4796CD07352A757257-5120
    Address 11: Engine II        Labels: Redir Fail!
       Component: V10 5,0L EDCG000AGSª8472
       Coding: 0060575
       VCID: 61C2339FBBCE2B42B9-5120
       Part No: 3D0 909 601 H
       Component: 05 Airbag 8.4E++H01 0562
       Revision: BB38727     Serial number: 0007379>
       Coding: 0012341
       VCID: 28546EBB98749A0ABE-5120
       Subsystem 1 - Part No: 7L0 959 339 C
       Component: BF-Gewichtsens. 006 0008
       Part No: 7L6 953 549 H
       Component: Lenksäulenmodul     3401
       Coding: 0010032
       VCID: 448CDA0B041C5E6AB2-5120
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 R
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0005231
       VCID: 4894CE3B38347A0A5E-5102
    Address 18: Aux. Heat        Labels: 7L6-819-008.clb
       Part No: 7L6 819 008 G
       Component: Standheizung E1MAC
       VCID: 3A70A4F376D8189AD8-5120
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70E446DB602492CA26-5120
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       Part No: 0AD 927 755 AT
       Component: TRANSFERCASE        0114
       VCID: 0D1A3F2F17D6DF22AD-5120
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       Coding: 0000003
       VCID: 66C8208352E04C7A4C-513C
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       VCID: 3668B0C342C0FCFA3C-5102
       Component: Sitzverstellung     0703
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 M
       Component:      Navigation     0047
       Coding: 0000101
       VCID: 50A4E65BC064B2CA06-5120
       Part No: 3D0 909 158
       Coding: 0000003
       VCID: 67D62D8755EA557277-5120
       Part No: 7L0 959 933 J
       Component:    HSG              5115
       Coding: 0000085
       VCID: 438ED917011259528B-4AE6
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    6 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    01134 - Alarm Horn (H12)
    01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 7L6 035 456
       Component: 08K Audioverst.     0105
       Subsystem 1 - Part No: 7L6 035 456
    No Faults Found
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 E
       Component:        Radio        0047
       Coding: 0014042
       VCID: 356AB7CF5FC6F7E235-5120
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000341
       Shop #: WSC 31414 000 376832
       VCID: 3C7CA2EB7CEC26AACA-5120
       Component: RLS     010510 054  0403
       Coding: 00133665
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       VCID: 3874BEFB48D40A8A2E-5120
       Part No SW: 7L6 907 441     HW: 7L6 907 441
       Component: J772__Rearview      0051
       Revision: 00H07000    Serial number:    PA8 J620685
       Coding: 0000101
       VCID: 72E04CD36E28A0DAD0-5120
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 J
       Component: DACHDISPLAY         0538
       Revision: 00700538    Serial number: 2009266.06
       VCID: 3E78A8E36AF034BAE4-5120
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 3972BBFF73DE1382D1-5120
    End-------------------------(Elapsed Time: 06:19)--------------------------
    Address 01: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 46: DTCs cleared
    While engine is running, the camshaft RPM should be in Group 051.2. This should be half the engine speed.
