Support for using VCDS after new Clock Spring Installation
Dear Support,
I have just recently purchased Hex Net and really looking forward to using it. I'm a newbie to VCDS and Diagnostics but have reasonable repair experience.
The Car in question is a SEAT Alhambra N7 chasis 2011
After the installation of a new clock spring I get the the various lights you would expect coming up on the Dashboard.
Previously, the horn and the steering wheel control bottons (left and right didnt work) and I had the airbag warning light on. After the new installation of a valeo clock spring the buttons and horn are now operational.
Ive done autoscan on the car and have the report. see below. (Is it ok to copy the code in the thread or are you supposed to upload it?)
Can I just clear the faults - if so how do I do that or do I need to code the new clock spring to the vehicle before clearing any faults and setting the SAS.
Many thanks in advance.
Dear Support,
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 25 2E 37 42 44 46 4F 52 53
56 61 62 6C 72
VIN: VSSZZZ7NZBVXXXXXX Mileage: 110180km-68462miles
18-Aux. Heat -- Status: Malfunction 1010
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HL HW: 03L 906 018 M
Component: R4 2,0L EDC H23 9959
Revision: 44H23--- Serial number:
Coding: 0019001A042501080000
Shop #: WSC 47696 696 92242
ASAM Dataset: EV_ECM20TDI01103L906018HL 003008
ROD: EV_ECM20TDI01103L906018F.rod
VCID: FBB6728772E3729203-80AE
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [175] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Mileage: 110083 km
Date: 2019.01.18
Time: 00:01:29
Coolant temperature: 46 °C
Intake air temperature: 13 °C
Voltage terminal 30: 11.760 V
ACC target acceleration: 0.000 m/s²
ACC control module received status-Bits 0-7: 6
Active brake system error status-Bits 0-7: 0
Status of ACC/CCS acceleration interface-Bits 0-7: 0
Acceleration: 0.000 m/s²
Engine status: COENG_READY
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 M HW: 7N0 614 109 H
Component: J104 C3 450M VDDF 0009
Revision: --H07--- Serial number: 00000003174862
Coding: 0024187
Shop #: WSC 47696 476 82776
VCID: B73EAEB7C64B96F2A7-80E2
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 219
Mileage: 106825 km
Date: 2013.03.06
Time: 11:00:32
Speed: 85.0 km/h
Hex Value: 0x0001
Bin. Bits: 00000000 00000000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Fault Frequency: 63
Reset counter: 223
Mileage: 110083 km
Date: 2013.06.10
Time: 00:01:39
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011110
Count: 191
Hex Value: 0x0000
008 - Implausible Signal
Fault Status: 01101000
Fault Frequency: 65
Reset counter: 219
Mileage: 110083 km
Date: 2013.06.10
Time: 00:03:58
Speed: 18.0 km/h
Hex Value: 0x0001
Voltage: 14.25 V
Bin. Bits: 00011110
Count: 245
Hex Value: 0x0001
Reset counter: 5
Mileage: 110117 km
Date: 2013.06.10
Time: 07:31:20
Hex Value: 0x0100
Voltage: 14.25 V
Bin. Bits: 00011110
Count: 277
Hex Value: 0x0000
Fault Frequency: 65
Reset counter: 219
Mileage: 110083 km
Date: 2013.06.10
Time: 00:03:58
Speed: 18.0 km/h
Hex Value: 0x0001
Voltage: 14.25 V
Bin. Bits: 00011110
Count: 245
Hex Value: 0x0001
Part No SW: 5K0 907 044 F HW: 5K0 907 044 F
Component: Clima-Sharan H11 0103
Coding: 0000000009
Shop #: WSC 00020 999 00000
VCID: AE108BD3F111573AF4-80FA
9601321 - Humidity sensor
B1281 29 [008] - Signal Implausible
Reset counter: 1
Mileage: 109815 km
Date: 2019.01.11
Time: 08:25:08
9485974 - Air Blower
B10BE 96 [008] - Component internal failure
[ZSB Gebläse/Regler vorne - Gebläsreglercode (Impuls) Nr.6 - Unterbrechung/ Kurschluss gegen Plus (+ Ltgs. Regler/Motor)]
Fault Frequency: 46
Reset counter: 8
Mileage: 109493 km
Date: 2018.12.24
Time: 18:15:40
Part No SW: 5K0 937 086 F HW: 5K0 937 086 F
Component: BCM PQ35 M 011 0035
Revision: BC011001
Coding: 40180A3B8925F1C0400800C81400812443519288436DA1626480C70000C1
Shop #: WSC 00020 790 00000
VCID: B73EAEB7064B96F2A7-80E2
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110628 31 0032
Serial number: 110723030838
Coding: 000D9D
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559 Labels: 7N0-955-559.CLB
Component: RLFS 021 0022
Serial number: Y10M09D11h12m21s03S1
Coding: 0380DD
Subsystem 3 - Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
00834 - Signal for Activation of Heated Rear Window
Fault Status: 00101001
Reset counter: 0
Mileage: 109764 km
Date: 2013.05.31
Time: 15:05:48
Term 15 Off
Voltage: 12.00 V
Fault Status: 00101010
Fault Frequency: 7
Reset counter: 3
Mileage: 106017 km
Date: 2013.02.20
Time: 10:03:35
Term 15 On
Voltage: 14.30 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0010
Revision: -------- Serial number: 80231024702540
Coding: 308002
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: F8BC6D8B43D5598A6E-80AC
Part No SW: 7N0 959 655 B HW: 7N0 959 655 B
Component: VW10Airbag01V H07 0013
Serial number: 003GFPJSM2YZ
Coding: 003156
ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
ROD: EV_AirbaVW10TS6VW428.rod
VCID: BE30BB932171A7BA64-80EA
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60E792E012DD%
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS608C56EB129D/
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60AC92E012DD-
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60176FEB12DD1
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60C2F3D612DDV
9437211 - Igniter for Driver's Airbag
B1000 1B [136] - Resistance Too High
Mileage: 109738 km
Date: 2019.01.06
Time: 15:25:31
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20181106200829
Coding: 7982A00000
Shop #: WSC 01286 386 08256
VCID: 82480F631509035A40-80D6
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Serial number: 00000000000000160553
Coding: E20000
13 Faults Found:
0516 - Databus
Fault Frequency: 8
Reset counter: 223
Mileage: 110083 km
Date: 2019.01.18
Time: 00:01:29
147462 - Terminal 15
B1148 12 [009] - Short to Plus
226827 - Turn Signal Switch
B1144 13 [008] - Open Circuit
Fault Frequency: 6
226839 - Turn Signal Switch
B1144 11 [009] - Short to Ground
Fault Frequency: 64
Reset counter: 223
227339 - Windshield Wiper Switch
B1145 13 [008] - Open Circuit
227355 - Windshield Wiper/Washer Switch
B1149 13 [009] - Open Circuit
Reset counter: 223
229127 - Cruise Control Switch
B1154 11 [008] - Short to Ground
Reset counter: 4
229147 - Cruise Control Switch
B1154 13 [008] - Open Circuit
Reset counter: 4
332660 - Databus
Reset counter: 4
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
365080 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Reset counter: 5
617736 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
1140738 - Steering angle sensor
UBat: 13.30 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Part No SW: 7N5 920 970 A HW: 7N5 920 970 A
Component: KOMBI H17 0404
Coding: 440B00
VCID: B620A3B309416FFABC-80E2
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 5K0 963 271 C
Component: Zuheizer 051 2606
Revision: 00051000 Serial number: 09021535000000
Coding: 0000041
VCID: AF2E96D73E1B5E32FF-80FA
00664 - Fuel gauge
Reset counter: 0
Mileage: 108478 km
Date: 2013.04.15
Time: 09:55:05
01444 - Under-Voltage Shut-Off (Automatic)
Reset counter: 5
Mileage: 108500 km
Date: 2013.04.16
Time: 08:10:60
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 160910F2002035
Coding: F9A07F06404A5304008203
VCID: AE108BD33911573AF4-80FA
Fault Status: 00110100
Reset counter: 4
Mileage: 71198 km
Date: 2011.01.16
Time: 19:49:54
Part No SW: 7N0 857 511 F HW: 8P0 857 511 C
Component: FLA H04 0006
Revision: AA001002
Coding: 0102816B74745D545420363E00
VCID: B620A3B301416FFABC-80E2
Component: IMMO H17 0404
VCID: EA9847C30D79FB1AE8-80BE
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668593732
Coding: 020000
VCID: A71E7EF7D6EB067237-80F2
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5P0 035 191 D HW: 5P0 035 191 D
Component: RNS315 H03 0007
Serial number: SEZAZ2K9106199
Coding: 040004110400000000021000
ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
ROD: EV_RNS315SeatEUV1UDS.rod
VCID: AC1481DBC70D252ADA-80F8
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 C HW: 7N0 959 793 A
Component: TSG FA H04 0360
Revision: Serial number: 0000108128591
Coding: 01110620D001411011
VCID: C2C8CF635D89C35A00-8096
Part No: 7N0 909 144 L
Component: EPS_ZFLS Kl. 260 3102
Revision: 00H17000
VCID: BC34B19BFF6DB5AA4A-80E8
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 219
Mileage: 110083 km
Date: 2013.06.10
Time: 00:01:31
Battery Volts: 11.8 V
DD
Temperature: 13.0°C
Count: 2
Steering Angle: 0.00°
SteerAng Init
01312 - Powertrain Data Bus
Fault Status: 00101110
Fault Frequency: 7
Reset counter: 5
Mileage: 110117 km
Date: 2013.06.10
Time: 07:31:24
Voltage: 14.50 V
DU
Temperature: 24.0°C
RPM: 2458 /min
Speed: 43.0 km/h
Speed: 20.0 km/h
Count: 3
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: EFAE56D73E9B1E32BF-80BA
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
02071 - Local Databus
Fault Status: 00101100
Fault Frequency: 151
Reset counter: 4
Mileage: 72187 km
Date: 2011.01.22
Time: 15:31:55
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 C HW: 7N0 959 792 A
Component: TSG BF H04 0360
Revision: Serial number: 0000108132034
Coding: 01110420DE01411011
VCID: C1CAC06F588FD84219-8094
Part No SW: 3AA 907 801 D HW: 3AA 907 801 D
Component: J540 EPB4 VW-53083 0006
Revision: H18 Serial number: 00000000087444
Coding: 0024067
VCID: B2289FA32D2973DA90-80E6
Fault Status: 00110010
Fault Frequency: 7
Reset counter: 250
Mileage: 106139 km
Date: 2013.02.22
Time: 09:08:50
Voltage: 9.30 V
Count: 52
Hex Value: 0x12E0
Hex Value: 0x0001
Hex Value: 0x0202
03200 - Switch for Electric Parking Brake (E538)
Fault Frequency: 8
Reset counter: 229
Mileage: 104563 km
Date: 2013.01.23
Time: 11:59:17
Voltage: 14.30 V
Count: 10
Hex Value: 0x12E1
Hex Value: 0x0001
Hex Value: 0x0808
Component: Batt.regelung H25 5603
Coding: 030B185A
VCID: F1AA50AF28AF08C2A9-80A4
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370050045
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 C HW: 7N0 959 795 A
Component: TSG HL H03 0360
Revision: Serial number: 0000107576468
Coding: 010004200001411001
VCID: C3C6CA674293CA520B-8096
Fault Frequency: 11
Reset counter: 1
Mileage: 108475 km
Date: 2013.04.15
Time: 09:16:12
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7N0 907 441 HW: 7N0 907 441
Component: J772__Rearview 0020
Revision: 00H08000 Serial number: 525PA8-J080526
Coding: 0020011
VCID: EE904BD3F991173AB4-80BA
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0360
Revision: Serial number: 0000108172843
End----------(Elapsed Time: 02:08, VBatt start/end: 14.7V/14.8V)-----------
