Results 1 to 10 of 11
Thread: Support for using VCDA after new Clock Spring Installation
    Jan 2019
    Support for using VCDS after new Clock Spring Installation
    Dear Support,
    I have just recently purchased Hex Net and really looking forward to using it. I'm a newbie to VCDS and Diagnostics but have reasonable repair experience.
    The Car in question is a SEAT Alhambra N7 chasis 2011
    After the installation of a new clock spring I get the the various lights you would expect coming up on the Dashboard.
    Previously, the horn and the steering wheel control bottons (left and right didnt work) and I had the airbag warning light on. After the new installation of a valeo clock spring the buttons and horn are now operational.
    Ive done autoscan on the car and have the report. see below. (Is it ok to copy the code in the thread or are you supposed to upload it?)
    Can I just clear the faults - if so how do I do that or do I need to code the new clock spring to the vehicle before clearing any faults and setting the SAS.
    Many thanks in advance.
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 18 19 20 25 2E 37 42 44 46 4F 52 53
              56 61 62 6C 72
    VIN: VSSZZZ7NZBVXXXXXX Mileage: 110180km-68462miles
    18-Aux. Heat -- Status: Malfunction 1010
       Part No SW: 03L 906 018 HL    HW: 03L 906 018 M
       Component: R4 2,0L EDC   H23 9959
       Revision: 44H23---    Serial number:
       Coding: 0019001A042501080000
       Shop #: WSC 47696 696 92242
       ASAM Dataset: EV_ECM20TDI01103L906018HL 003008
       ROD: EV_ECM20TDI01103L906018F.rod
       VCID: FBB6728772E3729203-80AE
    4332 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [175] - -
              [Checking coding/versions ofcontrol modules in drivetrain]
                        Mileage: 110083 km
                        Date: 2019.01.18
                        Time: 00:01:29
                        Coolant temperature: 46 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 11.760 V
                        ACC target acceleration: 0.000 m/s²
                        ACC control module received status-Bits 0-7: 6
                        Active brake system error status-Bits 0-7: 0
                        Status of ACC/CCS acceleration interface-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
                        Engine status: COENG_READY
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 M    HW: 7N0 614 109 H
       Component: J104   C3 450M VDDF 0009
       Revision: --H07---    Serial number: 00000003174862
       Coding: 0024187
       Shop #: WSC 47696 476 82776
       VCID: B73EAEB7C64B96F2A7-80E2
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 219
                        Mileage: 106825 km
                        Date: 2013.03.06
                        Time: 11:00:32
                        Speed: 85.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.25 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
                        Fault Frequency: 63
                        Reset counter: 223
                        Mileage: 110083 km
                        Date: 2013.06.10
                        Time: 00:01:39
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011110
                        Count: 191
                        Hex Value: 0x0000
                        Fault Frequency: 65
                        Reset counter: 219
                        Mileage: 110083 km
                        Date: 2013.06.10
                        Time: 00:03:58
                        Speed: 18.0 km/h
                        Hex Value: 0x0001
                        Voltage: 14.25 V
                        Bin. Bits: 00011110
                        Count: 245
                        Hex Value: 0x0001
                        Reset counter: 5
                        Mileage: 110117 km
                        Date: 2013.06.10
                        Time: 07:31:20
                        Hex Value: 0x0100
                        Voltage: 14.25 V
                        Bin. Bits: 00011110
                        Count: 277
                        Hex Value: 0x0000
                        Fault Frequency: 65
                        Reset counter: 219
                        Mileage: 110083 km
                        Date: 2013.06.10
                        Time: 00:03:58
                        Speed: 18.0 km/h
                        Hex Value: 0x0001
                        Voltage: 14.25 V
                        Bin. Bits: 00011110
                        Count: 245
                        Hex Value: 0x0001
       Part No SW: 5K0 907 044 F    HW: 5K0 907 044 F
       Component: Clima-Sharan  H11 0103
       Coding: 0000000009
       Shop #: WSC 00020 999 00000
       VCID: AE108BD3F111573AF4-80FA
    9601321 - Humidity sensor
              B1281 29 [008] - Signal Implausible
                        Reset counter: 1
                        Mileage: 109815 km
                        Date: 2019.01.11
                        Time: 08:25:08
    9485974 - Air Blower
              B10BE 96 [008] - Component internal failure
              [ZSB Gebläse/Regler vorne - Gebläsreglercode (Impuls) Nr.6 - Unterbrechung/ Kurschluss gegen Plus (+ Ltgs. Regler/Motor)]
                        Fault Frequency: 46
                        Reset counter: 8
                        Mileage: 109493 km
                        Date: 2018.12.24
                        Time: 18:15:40
       Part No SW: 5K0 937 086 F    HW: 5K0 937 086 F
       Component: BCM PQ35 M    011 0035
       Revision: BC011001
       Coding: 40180A3B8925F1C0400800C81400812443519288436DA1626480C70000C1
       Shop #: WSC 00020 790 00000
       VCID: B73EAEB7064B96F2A7-80E2
       Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    110628  31  0032
       Serial number:         110723030838
       Coding: 000D9D
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0022
       Serial number: Y10M09D11h12m21s03S1
       Coding: 0380DD
       Subsystem 3 - Part No: 7N0 951 171
       Component: DWA-Sensor 00  002 0205
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
    00834 - Signal for Activation of Heated Rear Window
                        Fault Status: 00101001
                        Reset counter: 0
                        Mileage: 109764 km
                        Date: 2013.05.31
                        Time: 15:05:48
                            Term 15 Off
                        Voltage: 12.00 V
                        Fault Status: 00101010
                        Fault Frequency: 7
                        Reset counter: 3
                        Mileage: 106017 km
                        Date: 2013.02.20
                        Time: 10:03:35
                        Voltage: 14.30 V
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 7N0 919 475     HW: 7N0 919 475
       Component: PARKHILFE 8K  H04 0010
       Revision: --------    Serial number: 80231024702540
       Coding: 308002
       ASAM Dataset: EV_EPHVA18VW4280000 001005
       ROD: EV_EPHVA18VW4280000.rod
       VCID: F8BC6D8B43D5598A6E-80AC
       Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
       Component: VW10Airbag01V H07 0013
       Serial number: 003GFPJSM2YZ
       Coding: 003156
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: BE30BB932171A7BA64-80EA
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60E792E012DD%
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS608C56EB129D/
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS60AC92E012DD-
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60176FEB12DD1
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS60C2F3D612DDV
              B1000 1B [136] - Resistance Too High
                        Mileage: 109738 km
                        Date: 2019.01.06
                        Time: 15:25:31
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20181106200829
       Coding: 7982A00000
       Shop #: WSC 01286 386 08256
       VCID: 82480F631509035A40-80D6
       Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H02 0102
       Serial number: 00000000000000160553
       Coding: E20000
    13 Faults Found:
    0516 - Databus
                        Reset counter: 223
                        Mileage: 110083 km
                        Date: 2019.01.18
                        Time: 00:01:29
    147462 - Terminal 15
              B1148 12 [009] - Short to Plus
    226827 - Turn Signal Switch
              B1144 13 [008] - Open Circuit
    226839 - Turn Signal Switch
              B1144 11 [009] - Short to Ground
                        Fault Frequency: 64
                        Reset counter: 223
    227339 - Windshield Wiper Switch
              B1145 13 [008] - Open Circuit
              B1149 13 [009] - Open Circuit
                        Reset counter: 223
    229127 - Cruise Control Switch
              B1154 11 [008] - Short to Ground
                        Reset counter: 4
    229147 - Cruise Control Switch
              B1154 13 [008] - Open Circuit
                        Reset counter: 4
    332660 - Databus
                        Reset counter: 4
    342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
              U0011 00 [008] - Performance
    365080 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
                        Reset counter: 5
    617736 - Selector Lever Park Position Lock Switch
              B1162 29 [008] - Signal Implausible
    1140738 - Steering angle sensor
                        UBat: 13.30 V
                        MC1 interner Fehlercode: 0
                        MC2 interner Fehlercode: 0
       Part No SW: 7N5 920 970 A    HW: 7N5 920 970 A
       Component: KOMBI         H17 0404
       Coding: 440B00
       VCID: B620A3B309416FFABC-80E2
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 5K0 963 271 C
       Component: Zuheizer        051 2606
       Revision: 00051000    Serial number: 09021535000000
       Coding: 0000041
       VCID: AF2E96D73E1B5E32FF-80FA
    00664 - Fuel gauge
                        Reset counter: 0
                        Mileage: 108478 km
                        Date: 2013.04.15
                        Time: 09:55:05
    01444 - Under-Voltage Shut-Off (Automatic)
                000 -  -  - Intermittent
                        Reset counter: 5
                        Mileage: 108500 km
                        Date: 2013.04.16
                        Time: 08:10:60
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H25 5603
       Revision:   H25       Serial number: 160910F2002035
       Coding: F9A07F06404A5304008203
       VCID: AE108BD33911573AF4-80FA
    01207 - Control Module for Auxiliary Heater (J364)
                        Fault Status: 00110100
                        Reset counter: 4
                        Mileage: 71198 km
                        Date: 2011.01.16
                        Time: 19:49:54
       Part No SW: 7N0 857 511 F    HW: 8P0 857 511 C
       Component: FLA           H04 0006
       Revision: AA001002
       Coding: 0102816B74745D545420363E00
       VCID: B620A3B301416FFABC-80E2
       Component: IMMO          H17 0404
       VCID: EA9847C30D79FB1AE8-80BE
       Revision: A1001003    Serial number: 7668593732
       Coding: 020000
       VCID: A71E7EF7D6EB067237-80F2
       Part No SW: 5P0 035 191 D    HW: 5P0 035 191 D
       Component: RNS315        H03 0007
       Serial number: SEZAZ2K9106199
       Coding: 040004110400000000021000
       ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
       ROD: EV_RNS315SeatEUV1UDS.rod
       VCID: AC1481DBC70D252ADA-80F8
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 C    HW: 7N0 959 793 A
       Component: TSG FA        H04 0360
       Revision:             Serial number: 0000108128591
       Coding: 01110620D001411011
       VCID: C2C8CF635D89C35A00-8096
       Part No: 7N0 909 144 L
       Component: EPS_ZFLS Kl. 260    3102
       Revision: 00H17000
       VCID: BC34B19BFF6DB5AA4A-80E8
                        Fault Status: 11101000
                        Reset counter: 219
                        Mileage: 110083 km
                        Date: 2013.06.10
                        Time: 00:01:31
                        Battery Volts: 11.8 V
                            DD
                        Temperature: 13.0°C
                        Count: 2
                        Steering Angle: 0.00°
                            SteerAng Init
    01312 - Powertrain Data Bus
                        Fault Status: 00101110
                        Fault Frequency: 7
                        Reset counter: 5
                        Mileage: 110117 km
                        Date: 2013.06.10
                        Time: 07:31:24
                        Voltage: 14.50 V
                            DU
                        Temperature: 24.0°C
                        RPM: 2458 /min
                        Speed: 43.0 km/h
                        Speed: 20.0 km/h
                        Count: 3
       Component: EZE_2         H25 5603
       Coding: 050B0500
       VCID: EFAE56D73E9B1E32BF-80BA
    02071 - Local Databus
                        Fault Status: 00101100
                        Fault Frequency: 151
                        Reset counter: 4
                        Mileage: 72187 km
                        Date: 2011.01.22
                        Time: 15:31:55
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 C    HW: 7N0 959 792 A
       Component: TSG BF        H04 0360
       Revision:             Serial number: 0000108132034
       Coding: 01110420DE01411011
       VCID: C1CAC06F588FD84219-8094
       Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
       Component: J540 EPB4  VW-53083 0006
       Revision:   H18       Serial number: 00000000087444
       Coding: 0024067
       VCID: B2289FA32D2973DA90-80E6
                        Fault Status: 00110010
                        Fault Frequency: 7
                        Reset counter: 250
                        Mileage: 106139 km
                        Date: 2013.02.22
                        Time: 09:08:50
                        Voltage: 9.30 V
                        Count: 52
                        Hex Value: 0x12E0
                        Hex Value: 0x0001
                        Hex Value: 0x0202
    03200 - Switch for Electric Parking Brake (E538)
                        Reset counter: 229
                        Mileage: 104563 km
                        Date: 2013.01.23
                        Time: 11:59:17
                        Voltage: 14.30 V
                        Count: 10
                        Hex Value: 0x12E1
                        Hex Value: 0x0001
                        Hex Value: 0x0808
       Component: Batt.regelung H25 5603
       Coding: 030B185A
       VCID: F1AA50AF28AF08C2A9-80A4
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370050045
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 C    HW: 7N0 959 795 A
       Component: TSG HL        H03 0360
       Revision:             Serial number: 0000107576468
       Coding: 010004200001411001
       VCID: C3C6CA674293CA520B-8096
                        Fault Frequency: 11
                        Reset counter: 1
                        Mileage: 108475 km
                        Date: 2013.04.15
                        Time: 09:16:12
       Part No SW: 7N0 907 441     HW: 7N0 907 441
       Component: J772__Rearview      0020
       Revision: 00H08000    Serial number: 525PA8-J080526
       Coding: 0020011
       VCID: EE904BD3F991173AB4-80BA
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H03 0360
       Revision:             Serial number: 0000108172843
    End----------(Elapsed Time: 02:08, VBatt start/end: 14.7V/14.8V)-----------
    Tartu, Estonia
    You need to copy coding from old module to new.
    The world is my oyster...
    Jan 2019
    Does the old code already exist in the Current scan? Can I copy the old code after the installation of the new module even if the old one has been removed?
    Quote Originally Posted by VDoubleYall View Post
    If you did a VCDS scan with the old module fitted then the scan will have been saved automatically by VCDS, so you can open that scan in any text editor and see the old coding.
  5. Likes Dana liked this post
    Jan 2019
    If I have already installed the new module is it possible to obtain the old code without putting the old module back in again? Model number for old module is 5K0.953.569.B the new one is 5K0.953.569.AL as you can see from the autoscan its picked this up and also there is a CODE value 7982A00000
    Is there anyway to get the code for the old module based on the part number?
    Jan 2019
    Thanks Dave, unfortunately I didn’t do an autoscan. I just purchased Hex net after installing the new module. So the only autoscan I’ve done is with the new module installed. It works as the horn and steering wheel buttons for radio etc function as normal. Question is if I need the old code what is the current code? Does it change at all when you install the new module.
    HQ
    Well, kind of makes it impossible for me to look up any real info to take a guess as to what coding should be.
    Often times the Steering Wheel Electronics module (J527) comes with some odd ball type coding in them right out of the box. I would suggest you plug the original J527 back up and scan it so you can get the original coding, then apply that to the new module.
    Jef
  9. Likes Dana, Uwe liked this post
  10. #8
    Nov 2014
    yes they would work..
    you could try coding from here and there, that would be trial and error,a hit and miss situation,
    to be certain about the correct coding i would copy from old module ..
  11. #9
    Jan 2019
    Update. So lucklily I remembered before agreeing to buy the car from a dealer 2 years ago I Asked they for a diagnostic report. This report has the original correct coding for the module. Changed the code in vcds, cleared all the faults, had to do a SAS basic settings procedure and voala! All sorted.
  12. Likes Dana, Uwe liked this post
  13. #10
    Oct 2014
    Can you post a new autoscan as it might help others with similar vehicles/circumstances
  14. Likes Dana, Uwe, Jef liked this post
