Results 1 to 10 of 10
Thread: VW passat parking brake fault 2012
    Sep 2014
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
              65 72
    VIN: WVWZZZ3CZCP014439   Mileage: 387350km-240688miles
    08-Auto HVAC -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Malfunction 1010
    Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 BH    HW: 03L 907 309 N
       Component: R4 2.0l TDI   H24 9977
       Revision: 47H24---    Serial number: VWZCZ000000000
       Coding: 00190012042501080000
       Shop #: WSC 77019 210 00000
       ASAM Dataset: EV_ECM20TDI01103L906018BH 003005
       ROD: EV_ECM20TDI01103L906018BH.rod
       VCID: 71AA3C8DA0C6ACC229-8024
    7 Faults Found:
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [040] - -
                        Fault Frequency: 14
                        Mileage: 387261 km
                        Date: 2019.01.14
                        Time: 15:00:15
                        Engine speed: 2086.50 /min
                        Normed load value: 41.6 %
                        Vehicle speed: 18 km/h
                        Coolant temperature: 75 C
                        Intake air temperature: 17 C
                        Voltage terminal 30: 13.020 V
                        ACC target acceleration: 0.000 m/s
                        ACC control module received status-Bits 0-7: 4
                        Status of ACC/CCS acceleration interface-Bits 0-7: 0
                        Acceleration: 0.435 m/s
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    4984 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [109] - Electrical Fault
                        Mileage: 387198 km
                        Date: 2019.01.12
                        Time: 14:33:36
                        Engine speed: 858.00 /min
                        Normed load value: 65.5 %
                        Vehicle speed: 1 km/h
                        Coolant temperature: 27 C
                        Intake air temperature: 12 C
                        Voltage terminal 30: 14.840 V
                        Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                        Electric auxiliary heater: shut-off conditions-Bits 0-7: 20
                        Electric auxiliary heater: relay activation-Bits 0-7: 0
                        Preheat time: 0 ms
                        Glow status-Bits 0-7: 0
                        Glow status-Bits 0-7: 176
                        Glow cycles above temperature threshold-Bits 0-7: 10
                        Glow cycles above temperature threshold-Bits 0-7: 58
                        Glow cycles below temperature threshold-Bits 0-7: 0
                        Glow cycles below temperature threshold-Bits 0-7: 3
                        Outside air temperature: 9.0 C
    4986 - Cylinder 3 Glow Plug Circuit (Q12)
              P0673 00 [109] - Electrical Fault
                        Mileage: 387198 km
                        Date: 2019.01.12
                        Time: 14:33:36
                        Preheat time: 0 ms
    11841 - No Communications with HVAC Control Module (J301)
              U0164 00 [039] - -
                        Mileage: 387350 km
                        Date: 2019.01.17
                        Time: 14:08:27
                        Coolant temperature: 29 C
                        Intake air temperature: 11 C
                        Voltage terminal 30: 12.180 V
                        Limitation: accelerator pedal: 126.7 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 40
                        selected gear-Bits 0-7: 0
    4685 - Implausible Data Received from Parking Brake Control Module
              U0417 00 [032] - -
                        Mileage: 387276 km
                        Date: 2019.01.14
                        Time: 16:39:31
                        Engine speed: 2309.00 /min
                        Normed load value: 23.1 %
                        Vehicle speed: 37 km/h
                        Coolant temperature: 84 C
                        Intake air temperature: 13 C
                        Voltage terminal 30: 14.740 V
                        Limitation: accelerator pedal: 63.8 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 8
                        selected gear-Bits 0-7: 2
    4708 - No Communications with HVAC Control Module (J301)
              U0164 00 [039] - -
                        Mileage: 387350 km
                        Date: 2019.01.17
                        Time: 14:08:23
                        Coolant temperature: 28 C
                        Voltage terminal 30: 12.280 V
    4716 - No Communications with Parking Brake Control Module
              U0128 00 [046] - -
                        Fault Frequency: 248
                        Mileage: 387261 km
                        Date: 2019.01.14
                        Time: 15:00:14
                        Engine speed: 2013.50 /min
                        Normed load value: 43.1 %
                        Vehicle speed: 17 km/h
                        Limitation: accelerator pedal: 69.8 Nm
                        selected gear-Bits 0-7: 3
       Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
       Component: J104   C2 450M V465 0022
       Revision: --H07---    Serial number: 00000004522409
       Coding: 0003001
       Shop #: WSC 00028 028 00001
       VCID: 6D9220FD74FE48220D-8038
    6 Faults Found:
    02779 - Databus for Electric Parking Brake
                        Fault Status: 00101110
                        Fault Frequency: 10
                        Reset counter: 141
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:34
                        Speed: 38.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.75 V
                        Bin. Bits: 00010001
                        Count: 228
                        Hex Value: 0x0000
                        Fault Frequency: 10
                        Reset counter: 141
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:34
                        Speed: 38.0 km/h
                        Hex Value: 0x0001
                        Voltage: 14.75 V
                        Bin. Bits: 00010001
                        Count: 228
                        Hex Value: 0x0000
                        Reset counter: 136
                        Mileage: 387261 km
                        Date: 2013.06.06
                        Time: 15:03:14
                        Speed: 3.0 km/h
                        Hex Value: 0x0100
                        Voltage: 12.75 V
                        Bin. Bits: 00010001
                        Count: 246
                        Hex Value: 0x0000
                        Reset counter: 136
                        Mileage: 387261 km
                        Date: 2013.06.06
                        Time: 15:03:14
                        Speed: 3.0 km/h
                        Hex Value: 0x0100
                        Voltage: 12.75 V
                        Bin. Bits: 00010001
                        Count: 250
                        Hex Value: 0x0000
    01542 - Yaw Rate Sensor (G202)
                        Reset counter: 136
                        Mileage: 387261 km
                        Date: 2013.06.06
                        Time: 15:03:14
                        Speed: 4.0 km/h
                        Hex Value: 0x0100
                        Voltage: 12.75 V
                        Bin. Bits: 00010001
                        Count: 238
                        Hex Value: 0x0000
                013 - Check DTC Memory
                        Fault Status: 00101101
                        Fault Frequency: 23
                        Reset counter: 101
                        Mileage: 387294 km
                        Date: 2013.06.07
                        Time: 15:17:59
                        Hex Value: 0x0000
                        Voltage: 14.50 V
                        Bin. Bits: 00010001
                        Count: 254
                        Hex Value: 0x0000
    Address 08: Auto HVAC
       Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
       Component: BCM PQ47 H    413 0455
       Revision: BB413001
       Coding: 000000000000000000180080140081E403516488406C81606480C7200041
       VCID: 3B36DEA5BA0A1692C3-806E
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 06071  26  0612
       Coding: 00B795
       Component: RLS 190711 05  54  0403
       Coding: 0230ED
                        Fault Frequency: 115
                        Reset counter: 139
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:43
                        Voltage: 14.95 V
                        Reset counter: 101
                        Mileage: 387350 km
                        Date: 2013.06.09
                        Time: 13:44:13
                            Term 15 Off
                        Voltage: 12.35 V
                        Fault Status: 00101010
                        Reset counter: 138
                        Mileage: 387298 km
                        Date: 2013.06.07
                        Time: 16:42:47
                        Voltage: 10.25 V
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__102 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PDJU1SA
       Coding: 0012338
       VCID: 4CD48D792FA4A12A7A-8018
       Subsystem 1 - Serial number: 6332MTS654621811
       Subsystem 2 - Serial number: 6342MTS639381801
       Subsystem 3 - Serial number: 6351HTS6U1BV8AKR
       Subsystem 4 - Serial number: 6361HTS6K8ET8AKJ
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
                        Fault Status: 11101001
                        Mileage: 387350 km
                        Date: 2013.06.09
                        Time: 14:08:25
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010040    Serial number: 20110711200746
       Coding: 0182250000
       Shop #: WSC 00028 028 00021
       VCID: 72A83381A5C097DAD0-8026
       Coding: E20000
       Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
       Coding: 460F00
       VCID: 3522C89D942EC0E235-8060
    12658688 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergert fr elektrische Parkbremse: keine Kommunikation]
                        Fault Frequency: 240
                        Reset counter: 139
                        Mileage: 387206 km
                        Date: 2019.01.12
                        Time: 14:48:41
       Part No SW: 7N0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway H41 1620
       Revision:   H41       Serial number: 150711F2001221
       Coding: 461007
       VCID: 393AC4ADB0362482D1-806C
                        Reset counter: 101
                        Mileage: 387350 km
                        Date: 2013.06.09
                        Time: 13:44:11
                        Fault Status: 00110100
                        Fault Frequency: 247
                        Reset counter: 140
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:43
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       VCID: 76A00F9101A88BFAFC-8022
       Revision: A1001003    Serial number: 7660421655
       Coding: 020000
       VCID: 291A14ED40969402A1-807C
       Part No SW: 3C0 035 279 B    HW: 3C0 035 279 B
       Component: RNS315-EU   H33 0263
       Serial number: VWZAZ2L3385583
       Coding: 040004010400100000019002
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 220803C135A0475AE0-8076
       Component: EUR_W_0031  0031
    1048632 - Antenna 1 for Radio
              B1119 13 [008] - Open Circuit
                        Fault Frequency: 7
                        Reset counter: 140
                        Mileage: 387227 km
                        Date: 2019.01.13
                        Time: 15:50:31
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0003219597
       Coding: 0202B7
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0408
       Serial number: 00000002345468
       Coding: 000290
    66304 - Switch for Drivers Side Window Regulator
              B11F0 29 [008] - Signal Implausible
                        Reset counter: 136
                        Mileage: 387273 km
                        Date: 2019.01.14
                        Time: 15:25:00
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 196    3201
       Revision: 00H20000
       VCID: 3424F5995754D9EA02-8060
       Component:    KSG PQ47 ELV 043 0634
       Coding: 01910A0002860E76300494157C085FCE105C01
                        Reset counter: 101
                        Mileage: 387350 km
                        Date: 2013.06.09
                        Time: 13:56:59
       Component: EZE_2         H41 1620
       Coding: 00000008
       VCID: 6FAE3AF5BEF2BA323F-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0003212106
       Coding: 0202B6
       ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
       VCID: 3620CF918928CBFA3C-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0408
       Serial number: 00000002337091
       Coding: 000290
       Revision:   H19       Serial number: 00000000638861
       Coding: 0022167
       Shop #: WSC 05311 000 00000
       VCID: 3620CF914128CBFA3C-8062
                        Reset counter: 136
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:42
                        Voltage: 14.80 V
                        Count: 62
                        Hex Value: 0x1260
                        Hex Value: 0x0082
                        Hex Value: 0x0101
                        Fault Frequency: 9
                        Reset counter: 139
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:42
                        Voltage: 14.70 V
                        Count: 63
                        Hex Value: 0x1270
                        Hex Value: 0x0082
                        Hex Value: 0x0101
    00576 - Terminal 15
                        Fault Status: 01111000
                        Fault Frequency: 41
                        Reset counter: 101
                        Mileage: 387217 km
                        Date: 2013.06.04
                        Time: 15:14:40
                        Voltage: 10.60 V
                        Count: 52
                        Hex Value: 0x12E0
                        Hex Value: 0x0001
                        Hex Value: 0x0202
       Component: Batt.regelung H41 1620
       Coding: 030B185A
       VCID: 71AA3C8DA8C6ACC229-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900907523
       Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
       Component: RDKBERU30     H08 0008
       Serial number: 10000000049424
       ASAM Dataset: EV_RDKBERU30 003010
       ROD: EV_RDKBERU30_003.rod
       VCID: 3326F6859A5ADED21B-8066
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
    Saturday,19,January,2019,15:20:09:28598
    VCDS Version: 18.9.0.1  HEX-NET CB: 0.4436.4
    VIN: WVWZZZ3CZCP014439   License Plate:
    Mileage: 387350km-240688mi   Repair Order:
              65 72
    08-Auto HVAC -- Status: Malfunction 1010
    9 Faults Found:
    4815 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [032] - -
              [Software Incompatibility with Anti-Lockplease read DTC]
                        Mileage: 387350 km
                        Date: 2019.01.17
                        Time: 15:28:19
                        Engine speed: 975.50 /min
                        Normed load value: 40.4 %
                        Coolant temperature: 20 C
                        Intake air temperature: 8 C
                        Voltage terminal 30: 14.660 V
                        Requested transmission torque: 1000.0 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 10
                        Transmission torque intervention status-Bits 0-7: 0
                        Calculated reducing transmission intervention torque: 1000.0 Nm
    14413 - Implausible Data Received from ABS Control Module
              U0415 00 [032] - -
              [Invalid Data Received FromAnti-Lock Brake System Control Module]
                        Mileage: 387350 km
                        Date: 2019.01.17
                        Time: 15:28:14
                        Engine speed: 905.00 /min
                        Normed load value: 43.5 %
                        Voltage terminal 30: 14.780 V
              U1113 00 [047] - -
                        Fault Frequency: 19
                        Mileage: 387261 km
                        Date: 2019.01.14
                        Time: 15:00:15
              P0671 00 [047] - Electrical Fault
                        Mileage: 387198 km
                        Date: 2019.01.12
                        Time: 14:33:36
                        Preheat time: 0 ms
              P0673 00 [047] - Electrical Fault
                        Mileage: 387198 km
                        Date: 2019.01.12
                        Time: 14:33:36
                        Preheat time: 0 ms
              U0164 00 [038] - -
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 14:19:04
                        Engine speed: 1302.50 /min
                        Coolant temperature: 2 C
                        Intake air temperature: 3 C
              U0417 00 [032] - -
                        Mileage: 387276 km
                        Date: 2019.01.14
                        Time: 16:39:31
              U0164 00 [038] - -
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 14:18:56
                        Intake air temperature: 2 C
                        Voltage terminal 30: 11.640 V
              U0128 00 [046] - -
                        Fault Frequency: 252
                        Mileage: 387261 km
                        Date: 2019.01.14
                        Time: 15:00:14
       Coding: 0003001
                        Reset counter: 141
                        Mileage: 387356 km
                        Date: 2013.06.09
                        Time: 16:51:41
                        Speed: 25.0 km/h
                        Hex Value: 0x0001
                        Voltage: 14.75 V
                        Bin. Bits: 00010001
                        Count: 228
                        Hex Value: 0x0000
                        Reset counter: 141
                        Mileage: 387356 km
                        Date: 2013.06.09
                        Time: 16:51:41
                        Speed: 25.0 km/h
                        Hex Value: 0x0001
                        Voltage: 14.75 V
                        Bin. Bits: 00010001
                        Count: 228
                        Hex Value: 0x0000
                        Fault Frequency: 9
                        Reset counter: 101
                        Mileage: 387357 km
                        Date: 2013.06.10
                        Time: 13:48:29
                        Hex Value: 0x0000
                        Voltage: 12.50 V
                        Bin. Bits: 00010001
                        Count: 254
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revision: 00001003
       Coding: 0004001803
       VCID: 7F4EEAB5E692CAB2AF-802A
    9 Faults Found:
    9475093 - Position Sensor for Left Temperature Flap Motor
              B1094 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:16
    9475349 - Position Sensor for Right Temperature Flap Motor
              B1095 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:16
    9476117 - Position Sensor for Defrost Flap Motor
              B1098 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:16
    9476373 - Position Sensor for Front Air Distribution Flap Motor
              B1099 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:16
    9476885 - Position Sensor for Fresh/Recirculated Flap Motor
              B109B 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:16
    9470741 - Temperature Sensor for Left Footwell Vent
              B1083 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:08
    9470997 - Temperature Sensor for Right Footwell Vent
              B1084 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:08
    9472533 - Temperature Sensor for Evaporator Vent
              B108A 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:08
    9478421 - Diagnostic Line for Front Air Blower
              B10A1 15 [008] - Open or Short to Plus
                        Reset counter: 141
                        Mileage: 387357 km
                        Date: 2019.01.19
                        Time: 15:14:29
       Revision: BB413001
       Coding: 00B795
       Coding: 0230ED
                        Fault Frequency: 119
                        Reset counter: 141
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:43
                        Voltage: 14.95 V
                        Reset counter: 141
                        Mileage: 387350 km
                        Date: 2013.06.09
                        Time: 13:44:13
                            Term 15 Off
                        Voltage: 12.35 V
                        Reset counter: 141
                        Mileage: 387298 km
                        Date: 2013.06.07
                        Time: 16:42:47
                        Voltage: 10.25 V
       Coding: 0012338
                        Mileage: 387357 km
                        Date: 2013.06.11
                        Time: 14:18:58
       Coding: 0182250000
       Coding: E20000
       Coding: 460F00
              U1111 00 [008] - -
                        Fault Frequency: 241
                        Reset counter: 141
                        Mileage: 387206 km
                        Date: 2019.01.12
                        Time: 14:48:41
       Coding: 461007
                        Reset counter: 141
                        Mileage: 387350 km
                        Date: 2013.06.09
                        Time: 13:44:11
                        Fault Frequency: 251
                        Reset counter: 141
                        Mileage: 387206 km
                        Date: 2013.06.04
                        Time: 14:48:43
       Coding: 020000
              B1119 13 [009] - Open Circuit
                        Fault Frequency: 10
                        Reset counter: 101
                        Mileage: 387227 km
                        Date: 2019.01.13
                        Time: 15:50:31
       Coding: 0202B7
       Slave Driver:
       Coding: 000290
                        Reset counter: 136
                        Mileage: 387273 km
                        Date: 2019.01.14
                        Time: 15:25:00
       Revision: 00H20000
                        Reset counter: 141
                        Mileage: 387350 km
                        Date: 2013.06.09
                        Time: 13:56:59
       Coding: 00000008
       Coding: 0202B6
       Slave Passenger:
       Coding: 000290
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000575378
       Coding: 0022167
       VCID: 383CC1A94B3C3D8A2E-806C
    00576 - Terminal 15
                        Fault Frequency: 9
                        Reset counter: 141
                        Mileage: 387356 km
                        Date: 2013.06.09
                        Time: 16:43:08
                        Voltage: 12.80 V
                        Count: 52
                        Hex Value: 0x1263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 141
                        Mileage: 387356 km
                        Date: 2013.06.09
                        Time: 16:51:41
                        Voltage: 14.60 V
                        Count: 63
                        Hex Value: 0x1260
                        Hex Value: 0x0082
                        Hex Value: 0x0101
                        Reset counter: 141
                        Mileage: 387356 km
                        Date: 2013.06.09
                        Time: 16:51:41
                        Voltage: 14.60 V
                        Count: 62
                        Hex Value: 0x1270
                        Hex Value: 0x0082
                        Hex Value: 0x0101
       Coding: 030B185A
    End----------(Elapsed Time: 01:32, VBatt start/end: 14.6V/14.6V)-----------
    any ideas on this we have changed the parking brake module also but fault comes back possible it can be ABS pump?
    Last edited by Uwe; 01-19-2019 at 03:07 PM. Reason: QUOTE -> CODE & split sections
    Sep 2014
    anyone had this issue?
    16.4905 S, 151.7375 W
    Have you checked the basics? I would start with checking fuses for the J540-Parking Brake controller, then check the J540's powers and grounds.
    With VCDS you can check the Measuring Value Block group [038], field (3) for the 15-Power voltage as reported by the J540. This needs to be actual battery voltage!
    We have a Ross-Tech wiki page for the 00576 - Terminal 15: Implausible fault, if an A4 J519 controller sets this code because of a missing fuse, maybe the J540 could do the same?
    Hope this helps,
    drpeter
  4. Likes Uwe, jimmyq, Jack@European_Parts liked this post
    Aug 2014
    Now permanent in Maryland, USA.
    Jimmyq
    DrPeter is right..try checking power and grounds, your issue looks like supply issue. If all connections and fuses check out, measure voltages Term.30 and Term.15 voltage directly on the J540 socket/connector you should have 12V.
  6. Likes jimmyq liked this post
    No it needs to be actual Voltage + Amperage or actual deliverable Current!
    123 load lights .............
    Sep 2014
    the J540 has 2 permanent lives both ok all fuses ok also none missing or blown grounds ok too measuring blocks shows terminal 30 12v and terminal 15 shows on and off when key is in and out but also shows error at times going to follow the wire back for terminal 15 will update soon
    Did you load it & if you did, how?
  10. Likes DrPeter, jimmyq liked this post
  11. #8
    Sep 2014
    hi sorted the problem did a continuity test for the terminal 15 wire which had 7v same wire goes to parking brake switch and auto hold on them it was 12v chased it up behind the dash was chaffed there behind middle of dash against some metal bracket all sorted now thanks guys appreciated
  12. #9
    Aug 2014
    Great Job! You owe all of us beer!
  13. Likes jimmyq liked this post
  14. #10
