Results 1 to 6 of 6
Thread: O2 Sensor Fault Code
    Sep 2018
    Sweden
    Hello
    I've an Allroad 2.7t -04 and I've fault code "P0131 - Oxygen (Lambda) Sensor B1 S1: Signal too Low". Is it a bad sensor? I've checked the resistance at the sensor connector and it's 10 ohms so that's fine. The wires from the ECU to the sensor seems fine.
    I logged this in VCDS. Don't know if that tells you something. Yes, this was last year but it's still the same:
    Saturday,22,September,2018,17:02:37:02198
                    Address 01: Engine  (4Z7 907 551 N)
    17:02:25 Group 031: Lambda Control
      0.010 V  Bank 1 Sensor 1 (actual)
      0.450 V  Bank 1 Sensor 1 (specified)
      0.680 V  Bank 2 Sensor 1 (actual)
      0.455 V  Bank 2 Sensor 1 (specified)
    17:02:25 Group 032: Lambda Control (Mixture Adaptation)
      9.9 %  Adaptation (Idle) Bank 1 Sensor 1
      -0.8 %  Adaptation (Partial) Bank 1 Sensor 1
      -0.8 %  Adaptation (Idle) Bank 2 Sensor 1
      -2.3 %  Adaptation (Partial) Bank 2 Sensor 1
    17:02:25 Group 033: Lambda Control
      25.0 %  Lambda Control Bank 1 Sensor 1
      0.010 V  Sensor Voltage Bank 1 Sensor 1
      -16.4 %  Lambda Control Bank 2 Sensor 1
      0.630 V  Sensor Voltage Bank 2 Sensor 1
    HQ
    Hey hey!
    Please include a full Auto-Scan when asking for help:
    https://forums.ross-tech.com/showthr...t-an-Auto-Scan
    Quote Originally Posted by classexa View Post
    [/CODE]
    Looking very lean there. Check out our page on fuel trim:
    http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
    Post the full Auto-Scan!
    Jef
  3. Likes Uwe liked this post
    Sep 2018
    Sweden
    Sorry about that. Here you go:
    Saturday,12,January,2019,11:44:59:02198
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WAUZZZ4B44N041931   License Plate:
    Chassis Type: 4B (01 - Allroad)
    Scan: 01 02 03 08 15 17 25 34 35 55 56
    VIN: WAUZZZ4B44N041931   Mileage: 269080km-167198miles
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 4Z7 907 551 N
       Component: 2.7L V6/5VT     G   0003
       Coding: 11755
       Shop #: WSC 01120
       VCID: 4EC592D8E9C7AC175C7-5160
       WAUZZZ4B44N041931     AUZ7Z0C2464255
    16515 - Oxygen (Lambda) Sensor B1 S1
                P0131 - 35-10 - Signal too Low - Intermittent
       Part No: 4Z7 927 156 L
       Component: AG5 01V 2.7l5VT RdW 2122
       Coding: 00001
       VCID: 4FFB8FDCEECDA51F571-5184
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389 A
       Component: ABS/ESP allrad      D56
       Coding: 06497
       Shop #: WSC 40967
       VCID: 4ACD9EC815AF803700F-5184
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AP
       Component: A6-Klimavollautomat 0208
       Coding: 00000
       VCID: 688944406B53522736B-258E
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 H
       Component: Airbag 8.4EP        3000
       Coding: 0001706
       Shop #: WSC 02334 785 00200
       VCID: 54F180B0C2EBC6C76A3-5184
       Part No: 4B0 920 933 P
       Component: KOMBI+WEGFAHRS. VDO D14
       Coding: 04164
       Shop #: WSC 01120
       VCID: 3039EC209333DAE72EB-5160
    01304 - Radio
                49-00 - No Communications
    Address 34: Level Control        Labels: 4Z7-907-553.lbl
       Part No: 4Z7 907 553 F
       Component:  - 2C1A1          X060
       Coding: 25500
       Shop #: WSC 02334
       VCID: 48C9A4C00BA3722716B-5160
    01772 - Signal from Level Control Pressure Sensor (G291)
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 L
       Component: Zentralverriegelung D38
       Coding: 06721
       Shop #: WSC 02334
       VCID: 323DE6289D0FE8F758F-4F0C
    01561 - Rear left door
                59-10 - Can't Unlock - Intermittent
    01562 - Rear right door
                61-00 - Won't De-Safe
                61-10 - Won't De-Safe - Intermittent
       Part No: 4Z7 907 357
       Coding: 00030
       Shop #: WSC 02334
       VCID: 045170F0773B9647BA3-4B5C
    End----------(Elapsed Time: 01:50, VBatt start/end: 13.8V/13.7V)-----------
    So reading that link you gave me and looking at the numbers, I might have a vakuum leak somewhere? But is that related to the fault code? I also have misfires on Cyl 4 but the plug and ignition coil are fine. I've swithced them around and checked. There's no code on this. I checked the measuring blocks in VCDS. It also appears that it's only noticable when idling, not when driving. Could these 2 things be related?
    May 2016
       Coding: 11755
       Shop #: WSC 01120
       Coding: 00001
       Coding: 06497
       Shop #: WSC 40967
       Coding: 00000
       Coding: 0001706
       Coding: 04164
       Shop #: WSC 01120
    01304 - Radio
       Coding: 25500
       Shop #: WSC 02334
       Coding: 06721
       Shop #: WSC 02334
       Coding: 00030
       Shop #: WSC 02334
    At idle usually indicative of smaller intake leak as under larger throttle opening small leak is insignificant at speeds.
    Could swap sensors as a test if they are the same but would spray intake in all areas while at idle and see if numbers change on bank 1. What to use there are various opinions such as WD40.
    LARIMORE
  6. Likes classexa liked this post
    The miss is either from a small isolated multiplicative vacuum leak, carbon build up, weak cylinder ( check compression ), burned valve, bad injector spray pattern at idle ( most likely ), bad ground to coil pack or trigger or B+ connectivity issue.
    OXS sensor might just be plain contaminated with carbon deposits or bad.
  8. Likes Uwe, classexa liked this post
  9. #6
    Sep 2018
    Sweden
    Thanks for all the answers. Looks like there could be many things. I'll start by doing a compression test tomorrow and go from there
