Results 1 to 10 of 11
Thread: MY2019 Skoda Octavia - Traffic Sign Recognition - Error
    Jan 2019
    New Zealand
    Sooooooooo started off with small tweaks here and there that were perfectly tested. Decided to take on a bigger one which was TSR on my new Octavia.
    Followed instructions below and everything seemed to "take". However I get the error "Dynamic Road Sign Display currently restricted" as well as a fault in my Scan 5F; see below.
    Any ideas or any "slight change/tweak" that may be different from the coding instructions that have been made available. Vehicle comes with COLUMBUS radio and NAV. Is there something different from the from the guided coding that different between the type of radio?
    Followed these instructions:
    1. Module 5F
    Adaptations
    Car_Function_List_BAP_Gen2 traffic_sign_recognition_0x21
    Set to Active
    Car_Function_Adaptations_Gen2-menu menu_display_road_sign_identification
    Set to Enabled
    Then go to Coding
    Long Coding
    Byte 24, activate Bit 6
    2. Module A5
    Then go to Coding
    Long Coding
    Byte 16, activate Bit 4
    3. Module 17
    Then go to Coding
    Long Coding
    Byte 5, activate Bit 2
    Then you need to disable Road Sign Fusion.
    4. Module A5
    Adaptation
    Road sign detection fusion mode
    Change from Road sign fusion to Road sign detection
    Auto Scan
    Friday,18,January,2019,20:36:58:03969
    VIN: TMBKU7NE7K00XXXXX   License Plate:
    Chassis Type: NE-SK37 (3Q0)
    Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 32 36 3C 42 44 47 4B
              52 5F 6C 6D A5 A9 BB BC D6 D7
    VIN: TMBKU7NE7K00XXXXX   Mileage: 1432km-889miles
    BB-Door Rear Drv -- Status: Not registered 0001
    Address 01: Engine (J623-DKTB)       Labels: None
       Part No SW: 5G0 906 259 S    HW: 06K 907 425 J
       Component: 2.0l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 0C1940322444050B1000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM20TFS0205G0906259S 001003
       ROD: EV_ECM20TFS0205G0906259S.rod
       VCID: 3E253CCB60F74DE7AC1-806A
    15183 - Unknown Error Code
              P086B 00 [096] - -
                        Mileage: 518 km
                        Date: 2018.12.29
                        Time: 08:20:55
                        Engine speed: 2680.75 /min
                        Vehicle speed: 62 km/h
                        Coolant temperature: 101 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 14.609 V
                        Unlearning counter according OBD: 23
                        PV: 0.00 %
                        Engine: operating status: PUC
                        T_IGK: 655.35 s
    Address 03: ABS Brakes (J104)       Labels:* None
       Part No SW: 5Q0 614 517 DF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0974
       Revision: 00000000    Serial number: 62608000001067
       Coding: 250793915426216E407B060260CA68A4C92A8402600616763443F0B1C0A9430B00000012121212B835351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
       ROD: EV_Brake1UDSContiMK100ESP_037_SK37.rod
       VCID: 78A9EAD30253B3D7A6D-802C
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0494442355
       Coding: 032C0C0623
       Shop #: WSC 73430 790 00063
       VCID: 43D34D3F0B15200FC3F-8016
       Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
       Component: Climatronic   H04 2002
       Revision: 00001K00
       Coding: 02110004000100011005004C0010102A
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ACClimaBHBVW37X 006147
       ROD: EV_ACClimaBHBVW37X_006_SK37.rod
       VCID: 74B1DEE31E3BD7B78A5-8020
       Air quality sensor:
       Part No SW: 5Q0 937 086 BR    HW: 5Q0 937 086 BR
       Revision: --------    Serial number: 865828091800T0
       Shop #: WSC 73430 790 00000
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 0B43A51F63C5A84FFBF-805E
       Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 180817  051 0916
       Serial number: 887253F0401822902086
       Coding: 164DDD
       Component: RLHS  052 0107
       Serial number: SAY18M10D04H00M16S03
       Coding: 00885D
       Sun Roof:
       Subsystem 3 - Part No SW: 5E9 959 591 B    HW: 6R0 959 591 D
       Component: J245 PS24.402  H04 0005
       Serial number: 0000FST00263W4B00000
       Coding: 991800
       Roof Blind:
       Subsystem 4 - Part No SW: 5E9 959 591 C    HW: 8V3 959 591 A
       Component: J394 PS24.402  H04 0005
       Serial number: 0000FST00267U9I00000
       Coding: 991800
       Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0050
       Serial number: 000308417618199
       Coding: 0371167041
       ASAM Dataset: EV_EPHVA2CAU3700000 009041
       VCID: 51FF7777C169C29F413-8004
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Coding: 2B0060C141FFC428949C810510300600000000000000000004
       VCID: 44D14E230E1B2737FA5-8010
       Serial number: 18081841350097
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 38292AD342D373D766D-806C
       Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
       Component: Airbag VW21   006 0712
       Revision: --------    Serial number: 003W4PL3YSN1
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW21TS6VW48X_VW37.rod
       VCID: 0557932745A1DE3FADB-8050
       Subsystem 1 - Part No SW: -----------    HW: 454 001 309 18
       Serial number: 3570000000053C8C423L
       Subsystem 2 - Part No SW: -----------    HW: 454 001 509 18
       Serial number: 3580000000080C4D423J
       Subsystem 3 - Part No SW: -----------    HW: 454 802 209 18
       Serial number: 35100F8BA7116000000P
       Subsystem 4 - Part No SW: -----------    HW: 454 801 809 18
       Serial number: 35200B0016516000000/
       Subsystem 5 - Part No SW: -----------    HW: 454 802 808 18
       Serial number: 355002D828F15000000O
       Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0245
       Revision: FF036036    Serial number: 20181004500795
       Coding: 6404
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CA1F6C3366B9FF7C25-8028
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Reset counter: 62
                        Mileage: 10 km
                        Date: 2018.12.17
                        Time: 08:39:39
                        Ubat 30 Voltage: 14.40 V
                        Internal error state: 0
                        LIN_Temp: 254
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 239
                        Slope: 133
                        kp: 18
                        OUT: 50
                        Temperatur Statisch: 30
                        p_t_soll_0: 34.00 °C
                        p_t_soll_1: 39.00 °C
                        p_t_soll_2: 44.00 °C
       Part No SW: 5E0 920 756 F    HW: 5E0 920 756 F
       Component: KOMBI         312 2501
       Coding: 27AD09107D840008018A7B0B5001000080000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009066
       VCID: 2D070B87BD91C67F05B-8078
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   439 4344
       Revision: --------    Serial number: 0008603853
       Coding: 030100047F085900EB0002FB880F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW37.rod
       VCID: 3D273BC76DF156FFB5B-8068
       Subsystem 2 - Part No SW: 3V0 919 719 G    HW: 3V0 919 719 G
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000D1671310718
       Serial number: 758860020018100108E7
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H07 0021
       Serial number: 18000310569012
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 313F17F7A1A9A29F213-8064
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
       Component: Quersperre    H52 8043
       Serial number: HA1-00029.06.18
       Coding: 0201
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       VCID: 52FD787BC46FB987789-8006
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
       Component: Sitzmemory    H09 0024
       Serial number: Y0006RID28326
       Coding: 0014000000000500018280808080000000008181000000D400
       ASAM Dataset: EV_SeatMemorDriveSide 002022
       Component: HRE_Master    H12 0081
       Serial number: 0494258472
       Coding: 02011203
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H12 0081
       Serial number: 0494016392
       Coding: 020112
       Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
       Component: TSG FS        006 0246
       Serial number: 0000346798352
       Coding: 001D0920DE01020000001100
       VCID: 48C95A133233035716D-801C
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000024492932
       Coding: 1D0200
       Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5082
       Coding: 93170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3C2136C376EB5FF7825-8068
    Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1JJE05UKBU
       Coding: 0373020000AA002AAA0000000000
       ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
       ROD: EV_AMPMst16C4Gen2ALPI.rod
       VCID: 59EF8F5799998ADFB93-800C
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 04101810520845
       Coding: 000000070900046E06003D01010000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 353723E755C18EBF7DB-8060
       Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0246
       Serial number: 0000346744628
       Coding: 001D0120DE01020000001100
       VCID: 47CB592F3F2D0C2F1F7-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000024563100
       Coding: 050200
       Part No SW: 565 035 045 C    HW: 565 035 045
       Component: MU-H-N-RW     H55 1382
       Serial number: A858I0JS004953
       Coding: 037352080000000041510002000000002F0101E601200500FF
       VCID: 1471BE633EFB77B72A5-8040
       Subsystem 1 - Part No SW: 5E0 919 606 D    HW: 5E0 919 606 D
       Component: ABT_High-2  H52 9130
       Serial number: SKZ6ZHV2794967
       Subsystem 2 - Part No SW: V03 959 801 KE    HW: -----------
       Component: ROW 2018/2019  --- 0071
       Component: Gracenote2  --- 4013
    7201 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 62
                        Mileage: 1419 km
                        Date: 2019.01.18
                        Time: 17:45:19
                        Voltage terminal 30: 12.2 V
                        BAP-BAP_Function_ID: 02
       Component: RVC Compact   H15 0231
       Coding: 047302010600201F000040
       ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
       VCID: 392F2FD779D96ADF993-806C
       Part No SW: 5E0 959 107 B    HW: 5E0 959 107
       Component: HDSG-Modul    H01 0747
       Revision: 42001003    Serial number: 251801282
       Coding: 1233074002
       ASAM Dataset: EV_HDSGSk462 301136
       ROD: EV_HDSGSk462_SK37.rod
       VCID: 2B03059F8385C84F1BF-807E
       Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H09 1272
       Serial number: 27081841K23041
       Coding: 020307020000010100022354C150A90094000E200000
       Shop #: WSC 73430 790 12345
       VCID: 08499A1372B3C357D6D-805C
       Part No SW: 5E0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0002
       Serial number: 180904200061
       VCID: 698FBF9749F91A5F293-803C
    Address BB: Door Rear Drv
    Address BC: Door Rear Pass
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
       Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
       Component: LED1L         H06 0005
       ROD: EV_LED_PLUS_L_KEBODAVW416_SK26.rod
       VCID: 7EA5FCCB20778DE7EC1-802A
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
       Component: LED1R         H06 0005
       ROD: EV_LED_PLUS_R_KEBODAVW416_SK26.rod
    End----------(Elapsed Time: 02:12, VBatt start/end: 12.3V/12.3V)-----------
    Changes Debug
    Address A5	3QD 980 654 	recoded (Long Coding)	from	020307020000010100022354C150A90084000E200000	to	020307020000010100022354C150A90094000E200000
    Address 17	5E0 920 756 F	recoded (Long Coding)	from	27AD09107D800008018A7B0B5001000080000000	to	27AD09107D840008018A7B0B5001000080000000
    Address 5F	565 035 045 C	channel ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	adapted from	not activated 	to	activated
    Address A5	3QD 980 654 	channel IDE04733-Road sign detection fusion mode	adapted from	Road sign fusion 	to	Road sign detection
    Jun 2017
    Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high
    This channel has to be activated also.
    What brought you to the point changing the fusion channel?
    Jan 2019
    New Zealand
    Will enable that channel too. In A5 or 5F? What does the adaption fix?
    Was just following the steps from the forum guide which was done on a 2017 Octavia and a Golf Mk7.5. Does the fusion channel make a difference?
    Jan 2019
    New Zealand
    https://www.briskoda.net/forums/topi...n-recognition/
    Jun 2017
    Have a look at the date of this thread.
    This applies to the old 5Q0 camera.
    Your camera is different.
    Try setting the channel to fusion and activate the mentioned channel above.
  6. Likes Uwe liked this post
    Jan 2019
    New Zealand
    Yes was the starting point and then followed the one in the original post from another forum dated May 2018 so went with it :-)
    Ill go code this in now; check and post an Auto Scan. If that was for the old 5Q0 camera; which one do I have?
    Thank you!
    Jan 2019
    New Zealand
    Was already activated so left as is.
    Switched back to Fusion Mode and cleared Fault Code. Seems to have fixed it....... new Auto Scan no Fault code present
    Will test it out tomorrow and see if it behaves. Am I right to think then that Fusion Mode blends the Nav System and the Camera?
    Friday,18,January,2019,23:36:26:03969
       Revision: --H13---
              P086B 00 [096] - -
                        Mileage: 518 km
                        Date: 2018.12.29
                        Time: 08:20:55
                        PV: 0.00 %
                        T_IGK: 655.35 s
       Coding: 032C0C0623
       Revision: 00001K00
       Air quality sensor:
       Coding: 164DDD
       Coding: 00885D
       Sun Roof:
       Coding: 991800
       Roof Blind:
       Coding: 991800
       Coding: 0371167041
       Coding: 6404
                        Reset counter: 62
                        Mileage: 10 km
                        Date: 2018.12.17
                        Time: 08:39:39
                        LIN_Temp: 254
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 239
                        Slope: 133
                        kp: 18
                        OUT: 50
       Coding: 0201
       Coding: 02011203
       Coding: 020112
       Coding: 1D0200
       Coding: 93170000
       Coding: 050200
       Coding: 1233074002
    End----(Elapsed Time: 02:12, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
  9. Likes Uwe liked this post
  10. #8
    Quote Originally Posted by SkodaNZ View Post
    That's as I understand it.
  11. #9
    Jun 2017
    Fusion mode combines predictive route data (PSD) from your navigation software with the camera-based recognitation of traffic signs along the road.
    This is the normal way the system should work.
  12. Likes PetrolDave, SkodaNZ, Uwe liked this post
  13. #10
    Mar 2019
    I'm having an issue with the traffic signs too. I finally got it to show up in the MMI although it is disabled. And i'm not getting any error (was getting the dreaded recognition currently restricted).
    For this adaptation, what is your value for the msg bus? Is it not active? You didn't mention you changed it i thought it may be already filled in.
    Traffic sign recognition 0x21 msg bus ???
