Results 1 to 9 of 9
Thread: "Data type not supported for adaptation" error message
    Nov 2018
    Hello!
    I'm trying to change the value of the following adaptation channel in the "09 Cent. Elect." block:
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3
    its current value is 00000000 and I want to restore it to 00001000. I've used 31347 security code.
    It's supposed to bring back separate sunroof led brightness controls to head unit menu. But VCDS doesn't allow me to do it and shows the following error message:
    Is it something that can only be fixed by the new release?
    Regards!
    Please provide an autoscan so we can see which ROD data is being used and then simulate this here. Thanks!
  3. Likes Uwe liked this post
    Nov 2018
    Autoscan for only 09 block is enough, right?
       Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 034 0246
       Revision: --------    Serial number: C86417051800A6
       Shop #: WSC 00066 790 00453
       ROD: EV_BCMBOSCH_018.rod
       VCID: 065595BA78A6AD27A41-8052
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 180427  034 0373
       Serial number: 18042322104430
       Component: RLHS  050 0107
       Serial number: SBY18M05D30H23M20S35
       Coding: 00A8DD
       Serial number: 000000000ZY180741RER
       Serial number: 00000000000010249811
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 172
                        Mileage: 6768 km
                        Date: 2019.01.16
                        Time: 00:00:21
  5. Likes Uwe, Dana liked this post
    Implemented in source, thankfully Andy's e-tron had the same channel:
    VCDS wasn't equipped to handle bit-fields in adaptation sub-channels.
    I'm waiting on a new UDS dataset and then we can push this in the next beta!
    Nov 2018
    Thank you! Waiting for that beta then.
    Jun 2017
    I have my problems to believe this was a bug as I remember numerous people changing these channels for retrofitting ambient light.
    Only thing I can remember about these channels is that you have to use the S12345 login for the engineer session.
    That particular (sub-)one is being displayed as a bitfield, that's (was) the issue here. It's possible previous UDS data called for it to be displayed in another format, like hex or decimal?
    I was able to change it back and forth using 31347 on the e-tron.
  10. Likes Uwe, Dana, PetrolDave liked this post
  11. #8
    Jun 2016
    Hello All and hadez16,
    See this reaction from Uwe, #28.
    https://forums.ross-tech.com/showthr...diculous/page3
    Maybe he also has an old cable that may be the reason why you can not change it!, because i cant olso and the reason is down written!
    I don't remember exactly when we discovered the problem with a few Adaption channels that were too large for the older cables to handle, but I think it was right around that time. In any case the problem was not obvious at first, until some people made changes to such channels, which had unforeseen consequences and they were unable to revert them. We then put checks in the software to look for that, and block those channels from being accessed with older cables, in order to prevent the contents of those channels from getting messed up.
  12. #9
    Quote Originally Posted by barstanders View Post
    Those are two different issues.
