Thursday,17,January,2019,22:10:48:26482
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8U2ER100139 License Plate: CAR2
Mileage: 32840km-20405mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62
72
VIN: WAUZZZ8U2ER100139 Mileage: 32840km-20405miles
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 8U0 907 115 K HW: 8U0 907 115 B
Component: 2.0l R4/4V TFSI 04 0002
Revision: PDH03--- Serial number:
Coding: 4123000C244F0160
Shop #: WSC 00049 770 00008
VCID: 3F8DA50B6E1ACEB2E4-806A
050197 - Implausible Data Received from ABS Control Module
U0415 - 000 -
Fault Frequency: 11
Mileage: 32833 km
Date: 2019.01.07
Time: 00:29:21
Load: 0.0 %
Temperature: 68.0°C
Temperature: 37.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Mileage: 32833 km
Date: 2019.01.07
Time: 00:29:23
Load: 0.0 %
Temperature: 68.0°C
Temperature: 37.0°C
Voltage: 13.716 V
U1017 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 32833 km
Date: 2019.01.07
Time: 00:29:26
Load: 0.0 %
Temperature: 68.0°C
Temperature: 37.0°C
Voltage: 13.716 V
Readiness: 0010 0001
Part No SW: 0BH 300 012 B HW: 0BH 927 711 C
Component: DSG DQ500-7A H07 2233
Revision: 00H07V01
ROD: EV_TCMDQ500021.rod
VCID: 224B0C7F35A8835AEB-8076
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BA HW: 5N0 614 109 BA
Component: J104 C6 450M VD89 0160
Revision: --H07--- Serial number: 00000008067253
Coding: 0052341
Shop #: WSC 00049 770 00156
VCID: 6BD5215B4AE2821218-803E
01164 - ESP Operation
Reset counter: 177
Mileage: 32842 km
Date: 2019.01.15
Time: 07:18:02
Speed: 58.0 km/h
Hex Value: 0x0001
Bin. Bits: 00000000 00000000
Voltage: 13.50 V
Bin. Bits: 00000000
Count: 239
Hex Value: 0x0000
Reset counter: 177
Mileage: 32842 km
Date: 2019.01.15
Time: 07:18:02
Reset counter: 177
Mileage: 32842 km
Date: 2019.01.15
Time: 07:18:02
Reset counter: 177
Mileage: 32842 km
Date: 2019.01.15
Time: 07:18:02
Reset counter: 177
Mileage: 32842 km
Date: 2019.01.15
Time: 07:18:02
Reset counter: 177
Mileage: 32842 km
Date: 2019.01.15
Time: 07:18:02
Part No SW: 8U0 820 043 D HW: 8U0 820 043 D
Component: E87 Klimavoll 0100
Revision: 00H04000 Serial number: 8U0820043D
VCID: 326BFC3FAD4813DA1B-8066
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 R HW: 8X0 907 063 R
Component: BCM PQ35 M 113 0811
Revision: AD113811
Coding: 2E000A2CA8051AC0201840C00104094C43FF84AA206F912BE400878400C1
VCID: 4B9581DBEAA2621278-801E
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 140416 H37 0085
Serial number: 140419211050
Coding: 0047F7
Component: G397_RLFS H06 0002
Serial number: 22587996
Coding: 02006E
Fault Frequency: 33
Reset counter: 177
Mileage: 32834 km
Date: 2019.01.15
Time: 07:04:25
Term 15 On
Voltage: 14.10 V
Term 50 On
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Fault Status: 01100111
Reset counter: 137
Mileage: 32836 km
Date: 2019.01.15
Time: 07:09:50
Term 15 Off
Voltage: 12.95 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 Q HW: 8X0 919 475
Component: PARKHILFE 4K H03 0070
Revision: 11001001 Serial number: 37061412800810
Coding: 0C0104
Shop #: WSC 00049 770 00118
ASAM Dataset: EV_EPHVA14AU21X0000 003006
ROD: EV_EPHVA14AU21X0000_003.rod
VCID: 54A79AA73F9C3DEA29-8000
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
Component: AirbagVW-AU10 H09 0520
Serial number: 003LRR086DX9
Coding: 30413132313030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 4683B0EFF9C09F7AA7-8012
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME105C602DZZZZ
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME2738572DZZZZ
Serial number: 3516KSME4073602DZZZO
Serial number: 3526KSME2231492DZZZQ
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME7A71102CZZZ%
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 D HW: 5K0 953 569 AE
Revision: FF010018 Serial number: 20140507200962
Coding: 1884204000
ROD: EV_SMLSNGVOLWS.rod
VCID: 3D71DF03AC16DCA2F6-8068
Subsystem 1 - Part No SW: 8U0 951 528 E HW: 8U0 951 528 E
Component: E221 - MFL H09 0010
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 930 D HW: 8U0 920 930 D
Component: KOMBI_MEDIUM H01 0340
Coding: 72CF00
VCID: 387FCE178334F98A25-806C
Part No SW: 8U0 907 468 AC HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0072
Revision: 1P130039 Serial number: 3941P1442006A8
Coding: FBCF1A5A000100610353
VCID: 030569FB82726A52C0-8056
Subsystem 1 - Part No SW: 8U0 915 181 B HW: 8U0 915 181 B
Component: J367-BDM H08 0181
Serial number: 61098944556921065883
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 14123000784021200181
Part No SW: 0AY 907 554 F HW: 0AY 907 554 F
Component: Haldex4Motion H52 7521
Serial number: HA1-00005.04.14
Coding: 0001
VCID: 4E9388CF11B0573A1F-801A
Component: IMMO H01 0340
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 F HW: 8X0 959 793 F
Component: TSG FA H10 0415
Coding: 011802200101000000
VCID: 50AF96B7038441CA0D-8004
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501
Revision: 00H22000
VCID: 408FA6F713E4B14A9D-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 F HW: 8X0 959 792 F
Component: TSG BF H10 0415
VCID: 4FAD95CB1EBA5E3214-801A
Revision: H19 Serial number: 00000002231633
Coding: 0025166
VCID: 3663C02F41200FFA37-8062
02434 - Supply Voltage for Control Module for Left Channel
Fault Status: 00101001
Fault Frequency: 7
Reset counter: 177
Mileage: 32834 km
Date: 2019.01.15
Time: 07:04:45
Voltage: 11.20 V
Count: 15
Hex Value: 0x12F1
Hex Value: 0x0001
Hex Value: 0x0110
01316 - ABS Control Module
013 - Check DTC Memory
Fault Status: 01111101
Fault Frequency: 6
Reset counter: 137
Mileage: 32834 km
Date: 2019.01.14
Time: 06:05:05
Voltage: 12.00 V
Count: 69
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
02430 - Left Parking Brake Motor (V282) Resistance to Movement
Fault Status: 00110000
Reset counter: 177
Mileage: 32834 km
Date: 2019.01.15
Time: 07:05:35
Voltage: 12.10 V
Count: 23
Hex Value: 0x12F1
Hex Value: 0x0021
Hex Value: 0x0808
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 140430-0002-016
Coding: 1157A41010002500
ROD: EV_HeadlRegulBasic.rod
VCID: 428BACFFD5E8A35A8B-8016
Part No SW: 8U0 035 183 C HW: 8U0 035 183 A
Component: RMC Cnct H55 0801
Coding: 01010600020053070823020103010000000000
VCID: 3467FA27975C1DEA09-8060
Subsystem 1 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H42 0018
Serial number: AUZ8ZDEM50119T/
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010002200001000000
Component: TSG HR H07 0415
End-------------------------(Elapsed Time: 03:15)--------------------------
