Results 1 to 8 of 8
Thread: VW Multivan T5.1 2013 ABS coding required for bigger front brakes - code PR-2E4
    Jun 2016
    Croatia
    I have upgraded front brakes on my 2013 T5 Multivan from PR-2E3 (which was originally delivered with the van) to PR-2E4 (340 mm disc which was originally delivered with 180 HP Bi-TDI engine).
    Rear brakes remained the same.
    Can someone please help me with the coding of ABS for newly installed brakes. I have seen that one or two bytes have to be changed but not sure which and to what value.
    VCDS scan is attached.
    Thank you
    Brgds
    Ivan
    Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: Release 18.2.1(x64) Data version: 20180518 DS287.2
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Thursday,02,August,2018,17:43:26:53507
    VIN: WV2ZZZ7HZDH035488 License Plate:
    Mileage: 113920km-70786mi Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 2E 3C 55 56 69 77 78
     0B
    VIN: WV2ZZZ7HZDH035488 Mileage: 113920km-70786miles
    0D-Slide Door, Left -- Status: OK 0000
    2E-Media Player 3 -- Status: Malfunction 0010
    78-Slide Door, Right -- Status: OK 0000
    Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb
     Part No SW: 03L 906 019 FL HW: 03L 907 309 M
     Component: R4 2.0l TDI H44 9977
     Revision: 26H44--- Serial number: 00000000000000
     Coding: 0125401A233400080000
     Shop #: WSC 03038 425 00000
     ASAM Dataset: EV_ECM20TDI01103L906019FL 004005
     ROD: EV_ECM20TDI01103L906019FK_004.rod
     VCID: 7AAC049C6C5249E73F0-802E
    Self-Diagnosis Log
    Page 2
     Part No SW: 0BT 300 045 P HW: 0BH 927 711 C
     Component: DSG DQ500-7F H07 2552
     Revision: 00H07V01
     ROD: EV_TCMDQ500021_VW36.rod
     VCID: 42DCBC7C4402C127270-8016
    Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
     Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
     Component: ESP MK25A XT H43 0110
     Revision: 00H43001
     Coding: 108724AD09A7089A24A690797A6610
     Shop #: WSC 02756 790 49152
     VCID: 3A2CC49C2C5289E77F0-806E
    Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
     Part No SW: 7E5 907 040 AC HW: 7E5 907 040 AC
     Component: ClimatronicT5 H19 0406
     Revision: 00001003
     Coding: 0004000102
     Shop #: WSC 02756 790 50316
     ASAM Dataset: EV_ClimatronicT5 A01003
     ROD: EV_ClimaAutoT5Basis.rod
     VCID: 698E4BD019F4F27FC6A-803C
     Slave 1:
     Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
     Component: Heckbedienung H10 0202
     Serial number: BHB-0012108120015184
    Self-Diagnosis Log
    Page 3
    Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
     Part No SW: 7H0 937 089 F HW: 7H0 937 089
     Component: BCM T5GP Li4 H50 0254
     Revision: BS050001 Serial number: 0465 201121207
     Coding: A0A2393A0E21201301288E716EEB8FD5C280660F60853841300003000000
     Shop #: WSC 02756 790 00000
     VCID: 392EDB90295482FF76A-806C
     Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
     Component: RLS 170812 05 54 0403
     Coding: 02302E
     Subsystem 2 - Part No SW: 7E0 959 801 A HW: 7E0 959 801 A Labels: 7E0-959-80X-V1.CLB
     Component: J386__TSG_FT 003 3313
     Coding: 040000
     Subsystem 3 - Part No SW: 7E0 959 802 A HW: 7E0 959 802 A Labels: 7E0-959-80X-V1.CLB
     Component: J387__TSG_BT 003 3313
     Coding: 040000
     Subsystem 4 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
     Component: E221__MFL-TK6 H07 0022
     Serial number: 50000000000000591528
     Coding: E20000
    03431 - Activation of Left Parking Light
     Fault Status: 00101011
     Reset counter: 29
    Address 0D: Slide Door, Left Labels: Redir Fail!
     Part No: 7E0 959 243 D
     Component: Schiebetuer-SG 407 0328
     VCID: 3038E6B4F62E43B7C14-8064
    Self-Diagnosis Log
    Page 4
    Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
     Part No SW: 7E0 919 475 J HW: 7N0 919 475
     Component: PARKHILFE 8K H06 0105
     Revision: -------- Serial number: 28261219201644
     Coding: 118102
     ASAM Dataset: EV_VW75XParkAssis8K 001003
     ROD: EV_VW75XParkAssis8K_001_VN75.rod
     VCID: 392EDB9029D482FF76A-806C
     Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
     Component: VW10Airbag007 H07 0013
     Revision: -------- Serial number: 003HM002LJ64
     Coding: 000000000000000000000000000000003037
     Shop #: WSC 02754 790 50316
     VCID: 3634D0AC18CA6D879B8-8062
     Serial number: 3495ZRB40590QMN26H6%
     Serial number: 3505ZRB405B15A9SF0LN
    Self-Diagnosis Log
    Page 5
     Part No SW: 7E0 920 870 G HW: 7E0 920 870 G
     Component: KOMBI H06 0605
     Coding: 160F01
     VCID: 2D06FFC0ED9C2E5FEA2-8078
    12648448 - Function Restricted due to Missing Message(s)
     U1111 00 [008] - -
     [Steuergerät für Motor: keine Kommunikation]
     Reset counter: 27
     Mileage: 113807 km
     Date: 2018.05.02
     Time: 10:43:10
    12648704 - Function Restricted due to Missing Message(s)
     U1111 00 [008] - -
     [Steuergerät für Getriebe: keine Kommunikation]
     Reset counter: 27
     Mileage: 113807 km
     Date: 2018.05.02
     Time: 10:43:10
    12656896 - Function Restricted due to Missing Message(s)
     U1111 00 [008] - -
     [Steuergerät für Bremse: keine Kommunikation]
     Reset counter: 27
     Mileage: 113807 km
     Date: 2018.05.02
     Time: 10:43:10
    12669184 - Function Restricted due to Missing Message(s)
     U1111 00 [008] - -
    Self-Diagnosis Log
    Thursday,02,August,2018,17:43:27:53507
    Page 6
     [Steuergerät für Airbag: keine Kommunikation]
     Reset counter: 27
     Mileage: 113807 km
     Date: 2018.05.02
     Time: 10:43:10
    13639168 - Function Restricted due to Missing Message(s)
     U1111 00 [008] - -
     [Steuergerät für Leuchtweitenregelung: keine Kommunikation]
     Reset counter: 27
     Mileage: 113807 km
     Date: 2018.05.02
     Time: 10:43:10
    13649152 - Function Restricted due to Missing Message(s)
     U1111 00 [008] - -
     [Steuergerät für Spurwechselassistent: keine Kommunikation]
     Reset counter: 27
     Mileage: 113807 km
     Date: 2018.05.02
     Time: 10:43:10
    Address 18: Aux. Heat Labels: None
     Part No: 7E0 815 071 B
     Component: J737__Standheizung 0605
     Revision: 00085000 Serial number: 09019275F00000
     Coding: 0000031
     Shop #: WSC 02757 790 00000
     VCID: 24101AE4B2D6EF1735C-8070
    Self-Diagnosis Log
    Page 7
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
     Part No SW: 6N0 909 901 HW: 7H0 937 089
     Component: GW-K-CAN TP20 H50 0254
     Revision: BS050001
     Coding: 042200
     VCID: 70B826B43AAE03B7814-8024
     Component: IMMO H06 0605
     VCID: 6A8C34DC1CF2F967CF0-803E
     Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
     Component: SG EXT.PLAYER H18 0546
     Revision: A1001003 Serial number: 7663274097
     Coding: 010100
     VCID: 2A0CF4DCDCF239670F0-807E
    03138 - Input AUX IN
     Fault Status: 00101001
     Reset counter: 35
     Mileage: 107479 km
     Date: 2017.11.08
     Time: 15:59:44
    Self-Diagnosis Log
    Page 8
     Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
     Component: J0769 SWA MasterH13 0120
     Revision: 00H13000 Serial number: 6PZ 009 014-07
     Coding: 0010161
     VCID: 2F3AE5C8EB105C4FD8E-807A
     Subsystem 1 - Part No: 7E0 907 568 B
     Component: J0770 SWA Slave H10 0120
     Subsystem 2 - Serial number: 6PZ 009 014-27
     Subsystem 3 - Serial number: 5F25.06.1200H100003CH20172˙
     Subsystem 4 - Serial number: H20172˙
    Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
     Part No SW: 6R0 907 357 HW: 6R0 907 357
     Component: LWR-ECU H02 0070
     Coding: 0202000001000000
     Shop #: WSC 02757 790 50316
     ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
     ROD: EV_HeadlRegulVWLWRPt_VW25.rod
     VCID: 77AA1DA85F40548F40E-8022
     Part No SW: 7H0 035 186 D HW: 7H0 035 186 D
     Component: Radio RCD310 004 0119
     Revision: 01000001 Serial number: VWZ1Z2M8172356
     Coding: 01000400040014
     Shop #: WSC 02754 790 00000
    Unfortunately, I cannot find a good coding chart for this module. Best would be to find a scan from a van that came from the factory with the brakes that you have installed and compare them.
    PS -- Admin Note: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is good for a sheet-fed printer, but is much harder to read here than the native .txt format that VCDS gives you when you use [Copy] or [Save]. Whenever you do a full Auto-Scan such as the one above, the original text format is automatically saved in your Scans sub-folder.
    Jul 2014
    Tallinn, Estonia
    There are some scans on the forum with the 2.0 BiTDI engine. Just search "CFCA", which is the engine code.
    This one seems close https://forums.ross-tech.com/showthr...highlight=cfca
    Nov 2014
    New Zealand
    This is my work van, if it helps... it is 4motion though. BiTDI, LWB, High roof, manual trans. Pretty standard, options wise.
    I don't have the PR codes here (or possibly at all!)
    Wednesday,22,August,2018,07:34:25:42165
    VCDS Version: 18.2.1.5 (x64)
    VIN: WV1ZZZ7HZEH010274   License Plate:
    Scan: 01 03 04 08 09 10 15 17 19 22 25 56 77
    VIN: WV1ZZZ7HZEH010274   Mileage: 60300km-37468miles
    Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 906 022 JC    HW: 03L 907 309 H
       Component: R4 2,0L EDC   H36 9109
       Revision: 22H36---    Serial number: 00000000000000
       Coding: 01190012230600080000
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_ECM20BTD01103L906022JC 002007
       ROD: EV_ECM20BTD01103L906022JC.rod
       VCID: 6FEDFC86B639B93CCD-803A
       Revision: 00H43001
       Coding: 908724AD91A5099524A48978A96210
       Shop #: WSC 02736 790 49152
       VCID: 3A7B1DD2B5FB2C942A-806E
       Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
       Component: Climatic-T5   H20 0505
       Revision: 00001011
       Coding: 0000000002
       ROD: EV_ClimaT5Basis.rod
       VCID: 7BF5D8D6F241D59C71-802E
    9473905 - Motor for Temperature Flap
              B108F 71 [008] - Actuator stuck
                        Reset counter: 77
                        Mileage: 59384 km
                        Date: 2018.07.31
                        Time: 07:15:52
       Part No SW: 7H0 937 086 M    HW: 7H0 937 086
       Component: BCM T5GPM++4  H34 0411
       Revision: BM034001    Serial number: 0572 154130063
       Coding: E0A0303A0A212031002808102C2B8CD40000432F60064000320000000000
       Shop #: WSC 02736 790 00000
       VCID: 3D7116CEA4D51BAC0F-8068
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3313
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3313
       Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0106
       Revision: --------    Serial number: 32931312600429
       Coding: 108001
       ASAM Dataset: EV_VW75XParkAssis4K 001004
       ROD: EV_VW75XParkAssis4K_001.rod
       VCID: 3A7B1DD2BDFB2C942A-806E
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H07 0013
       Revision: --------    Serial number: 003HL00J07TA
       Coding: 000000000000000000000000000000003039
       Shop #: WSC 02734 790 50316
       VCID: 35610EEE94E5C3ECC7-8060
       Part No SW: 7E0 920 870 J    HW: 7E0 920 870 J
       Component: KOMBI         H04 0710
       Coding: 160A01
       VCID: 306F3FFA6B87E6C494-8064
       Part No SW: 6N0 909 901     HW: 7H0 937 086
       Component: GW-K-CAN TP20 H34 0411
       Revision: BM034001
       Coding: 042300
       VCID: 70EFFFFAA307A6C4D4-8024
       Part No SW: 09N 907 554 B    HW: 09N 907 554 B
       Component: Haldex 4Motion      6008
       Coding: 0000009
       VCID: 377D04E646E931FCD5-8062
       Component: IMMO          H04 0710
       VCID: 6ADBED928DDB5C149A-803E
       Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
       Component: Radio RCD310  042 0082
       Revision: 01000001    Serial number: VWZ1Z2N1584588
       Coding: 05000200020014
       Shop #: WSC 02734 790 00000
       VCID: 336530F69291DDDCE9-8066
       Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007664889793
       Coding: 0A01010000010101
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 397902DEB8FD278C23-806C
    9458195 - Control Module for Cellular Telephone
              B1052 13 [008] - Open Circuit
                        Fault Frequency: 250
                        Reset counter: 88
    End-------------------------(Elapsed Time: 02:28)--------------------------
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  5. Likes Uwe liked this post
    Mar 2015
    Australia
    PR code for your VIN NZDubNerb shows 2E3 for brakes same as the OP.
    Note this is from a 3rd party not direct from VW, so I can't vouch for it's accuracy...should show on your PR codes sticker though?
    Will PM you the rest of the PR codes for your reference.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  7. Likes Uwe liked this post
    Nov 2014
    New Zealand
    Bummer... apparently we didn't get big brakes
    We got the biggest T5, but with the lowest payload, so that probably makes sense!
    Thanks - Will reply to your PM now too
    Allan
    The R32ran Thread
    Jun 2016
    Croatia
    Thank you for helping out...
    I have done some research with different VIN's and compared the PR numbers with partslink24.
    These are my findings:
    CARS WITH PR-2E3 brakes
    10 87 24 AD 09 A7 08 9A 24 A6 90 79 7A 66 10 - multivan, dsg gearbox, trailer hitch, fwd, 140 hp 2013, PR-2E3 MY CAR
    50 87 24 AD 89 A8 0A 98 24 A8 91 74 A9 63 10 - transporter, manual gearbox, trailer hitch, fwd, 140 hp 2010, WV1ZZZ7HZAH243635, PR-2E3
    90 87 24 AD 91 A5 09 95 24 A4 89 78 A9 62 10 - transporter, manual gearbox,no trailer hitch, awd, 180 hp 2014 WV1ZZZ7HZEH010274, PR-2E3 this car has CFCA engine but PR-2E3 brakes as per partslink24
    70 87 24 AD 89 AB 0E 9C 24 A3 91 76 A9 64 10 – transporter, manual gearbox, no trailer hitch, fwd, 180 hp 2013, WV1ZZZ7HZDH077156, PR-2E3 this car has CFCA engine but PR-2E3 brakes as per partslink24
    70 87 24 AD 89 A4 0E 97 24 A2 91 73 A9 67 10 - transporter,manual gearbox, no trailer hitch, fwd, 180hp, 2013, WV1ZZZ7HZDH102029, PR-2E3, this car has CFCA engine but PR-2E3 brakes as per partslink24
    Above you can see that BYTE 02 (24) and BYTE 08 (24) are same for all the cars with factory option PR-2E3 which is standard brakes.
    CARS WITH PR-2E4 brakes
    10 87 64 AD 19 AB 08 9C 26 A8 98 73 BA 65 16 – transporter, dsg gearbox, trailer hitch, awd, 180 hp, 2011, WV2ZZZ7HZBH077627, PR-2E4
    10 87 64 AD 09 A5 08 9D 26 A3 90 71 AA 62 16 - multivan, dsg gearbox, no trailer hitch,fwd, 180 hp 2011, PR-2E4 WV2ZZZ7HZBH118104
    10 87 64 AD 11 A7 08 9C 26 A2 88 78 7A 61 16 - multivan, dsg gearbox, trailer hitch, awd, 180 hp, 2010, PR-2E4 WV2ZZZ7HZAH237073
    10 87 64 AD 09 A6 08 9D 26 A6 90 76 AA 63 90 - multivan, dsg gearbox, trailer hitch, fwd, 180 hp, 2014, PR-2E4 WV2ZZZ7HZEH028455
    90 87 64 AD 89 A6 09 98 26 A7 91 72 B9 61 10 - transporter, manual gearbox, no trailer hitch,fwd,180 hp 2014, PR-2E4, WV1ZZZ7HZEH023513
    Above you can see that BYTE 02 (64) and BYTE 08 (26) are same for all the cars with factory option PR-2E4 which are bigger brakes.
    Bytes 5, 7, 9, 11 and 13 should be related to VIN number of each car.
    Byte 6 should be related to gear box.
    I think that for PR-2E4 coding has to be changed on BYTE 02 to 64 and BYTE 08 to 26.
    Please let me know your toughts and corret me if I am wrong.
    Thanks
  10. Likes AIB Wolfgang, Uwe, dnoermann liked this post
  11. #8
    Quote Originally Posted by ivan081185 View Post
    Yes I would think that is right.
  12. Likes Uwe liked this post
