Results 1 to 6 of 6
Thread: 2013 Golf Intermittent Power loss
    Nov 2016
    Ireland
    Hi guys,
    Ive a 2013 golf, drives fine most of the time but every now and again it loses power and the glow plug light comes on. Cycle the ign once and it runs away again fine. This can happen at any time. twice in one day and it might not happen again for weeks.....
    Ive cleared all faults and drove the car again until it happened and ran autoscan below
    VIN: WVWZZZAUZEW001560
    Mileage: 187246km
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEW001560   Mileage: 187246km-116349miles
    Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   X22 5517
       Revision: 84X22---
       Coding: 01110012030511092000
       ASAM Dataset: EV_ECM16TDI01104L906021M 002009
       ROD: EV_ECM16TDI01104L997021.rod
       VCID: 2F6D759976CCDF3966-807A
    19225 - Boost Pressure Regulation
              P0299 00 [096] - Control Range Not Reached
                        Mileage: 186691 km
                        Date: 2019.01.12
                        Time: 21:47:51
                        Engine speed: 2227.00 /min
                        Normed load value: 78.0 %
                        Vehicle speed: 114 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 114 °C
                        Voltage terminal 30: 13.340 V
                        Unlearning counter according OBD: 34
                        Charge air pressure specified value: 2467 hPa
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2030.2 hPa
                        Mass airflow sensor 1 bank 1 airflow: raw value: 626.7 mg/stroke
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        Turbine actuator 1 bank 1: posit.feedback - Act.value: 82.81 %
                        Mean injection quantity: 30.63 mg/stroke
    20558 - Heater Support Pump
              P16C6 00 [032] - Running Dry
    Readiness: 0 0 0 0 X
       Revision: 00000000    Serial number: 61183000000582
       Coding: 01FA8AA12420096D037C060641C32580512490C06082A4F300400074C002
       VCID: 7BF591C9F234F3999A-802E
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       ROD: EV_ACManueBHBVW37X_SK48.rod
       VCID: 356147F19490E5E92C-8060
              P1719 00 [008] - -
                        Fault Frequency: 60
                        Reset counter: 60
                        Mileage: 172211 km
                        Date: 2018.09.03
                        Time: 06:35:01
                        Voltage terminal 30: 13.8 V
                        Auxiliary heater: in stages-Act.value: 3
       Part No SW: 5Q0 937 084 R    HW: 5Q0 937 084 R
       Component: BCM MQBAB B   H14 0111
       Serial number: 00011312200334
       Coding: 03000842C20100530BA44000000403081000000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: 479D3D39FE7C67794E-8012
       Component: WWS    130429  042 0551
       Serial number:         130503154715
       Coding: 0E4DD5
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                        Fault Frequency: 68
                        Reset counter: 14
                        Mileage: 179593 km
                        Date: 2018.11.10
                        Time: 08:44:09
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231311901968
       Coding: 0031051001
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       VCID: 3B7551C9B2B43399DA-806E
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R04XUSG
       VCID: 408F2625DB5250418F-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 705 13
       Serial number: 35767000000880DC2D0+
       Subsystem 2 - Part No SW: -----------    HW: 480 000 705 13
       Serial number: 358670000005DA940D0/
       Subsystem 3 - Part No SW: -----------    HW: 480 401 005 13
       Serial number: 3516502C71050653218T
       Subsystem 4 - Part No SW: -----------    HW: 480 401 005 13
       Serial number: 3526502AD1050650917.
       Subsystem 5 - Part No SW: -----------    HW: 480 400 205 13
       Serial number: 3556502C31050653F1F6
       Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
       Revision: --------    Serial number: 03051304401708
       Coding: 0600
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 76E380FDC916AEF1E5-8022
       Part No SW: 5G0 920 951 A    HW: 5G0 920 951 A
       Component: KOMBI         104 3350
       Coding: 27A41A002300260001080800000000
       ASAM Dataset: EV_DashBoardJCIMQBAB 008011
       ROD: EV_DashBoardJCIMQBAB_008.rod
       VCID: 275D9DB95E3C8779AE-8072
       Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
       Component: GW MQB Low    123 1144
       Revision: --------    Serial number: 0000545479
       Coding: 030000040B087300EF000048080E00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       VCID: 39794BC1B8880189C8-806C
       Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Serial number: 8597130403
       Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
       Component: TSG FS        012 0006
       Serial number: 26041304081010
       Coding: 003002208001040100001000
       VCID: 3D715FD1ACA03DA9E4-8068
       Coding: 01
       ROD: EV_SteerAssisMQB_008.rod
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 22041302090515
       Coding: 003000208E01040100801000
       VCID: 3E7358DDA1A626B1FD-806A
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
       Component: MU-S-D-ER     040 0407
       Serial number: V5C03004130831
       Coding: 02730000FF00000021111201002800001F0100060100010001
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 1F4D8559066C4FB9D6-804A
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H44 0020
       Serial number: VWZ8Z9N2402Z0K
    Any help appreciated....
    HQ
    http://wiki.ross-tech.com/wiki/index...3/P0299/000665
    Have you verified there are no leaks with the charge pipes? Looks like there is a "vacuum unit for turbocharger", if you manually pull vacuum with it, is the linear actuator movement smooth with applied vacuum? Is the engine generating a good supply vacuum and have proper control of it to the vacuum unit for turbocharger?
    Jef
  3. Likes Uwe, Larry Manton, RyMar liked this post
    Nov 2016
    Ireland
    Thanks Jef il get a look at it in yhe coming days and il report back 👍
    Jun 2014
    Quote Originally Posted by Jonesy View Post
    Thanks Jef il get a look at it in yhe coming days and il report back ��
    Hello
    Did you manage to fix this issue.
    I have same issue with Octavia VRS tdi. Car drives fine but light comes on intermittently.
    Same fault logged as above.
    The vacuum unit is working as it should.
    Nov 2016
    Ireland
    Quote Originally Posted by akersgarage View Post
    Hello
    Hi I'm waiting on the car to come back to me so I haven't got looking at it yet. Il post back when I get looking at it.
    If you get yours sorted in the mean time please share 👍
    Oct 2017
    Soot built up in variable geometry. Take the turbocharger out and clean it. You can find the procedure on youtube.
