Results 1 to 4 of 4
Thread: Error 00149 - End of Line Programming not Completed - DCC Suspension
    Jan 2015
    Bosnia and Herzegovina
    For everyone with error 00149 - End of Line Programming not Completed, I have found a way to finally clear it. You will have this error if you bought a used unit (replaced) or flashed yours to newer version.
    To fix this you need to save your VIN in adaptation channel 30 by saving value 1
    Address 14: Susp. Elect. (J250), Login: 06865 Adaptation channell 30 save 1.
    After this I had to cycle key two times,or if this doesn't work remove power to electronic fuse 35 and error is gone after that automatically or clear faults.
    For basic setting you need to lift your car so that wheel are hung and sensors are reading values,
    Address 14: Susp. Elect. (J250) Login: 31564, Basic Settings: channell: 1 Go ON/OFF.
    I have flashed my unit from version 69 to 70 and finally to 71. I think that handling is better but could be just my imagination.
    hope this will help somebody
  2. Likes Uwe, Jef, colouny, DreamerCC, Dana, jyoung8607 liked this post
  3. #2
    HQ
    Could you post an Auto-Scan from the vehicle in question?
    Jef
    Jan 2015
    Tuesday,25,August,2015,18:46:04:03082
    VCDS Version: 15.7.0.1 (x64)
    Data version: 20150729
    VIN: WVWZZZ1KZBW145982   License Plate: GTD
    Mileage: 60110km-37350mi   Repair Order:
    Chassis Type: 1K (7N0)
    Scan: 01 02 03 08 09 14 15 16 17 19 25 37 42 44 46 52 55 56 77
    VIN: WVWZZZ1KZBW145982   Mileage: 60110km-37350miles
    Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 BC    HW: 03L 907 309 R
       Component: R4 2,0L EDC   X22 7819
       Revision: 42X22---    Serial number: 00000000000000
       Coding: 001D0012040400080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906018BC 003005
       ROD: EV_ECM20TDI01103L906018BC_VW36.rod
       VCID: 6CDD86F58787FD5E9A-8038
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 054 H    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2601
       Revision: 05351113    Serial number: 00001010130182
       VCID: 1B3F9529DAA9CAE6A3-804E
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Revision: 00H31001
       Coding: 143B600D092600FF281406EC901B0042310800
       VCID: 76E9A49DC1CB378E7C-8022
       Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00015 115 12345
       VCID: 6ED98CFDB19B0F4EB4-803A
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 66180A3AE8251A0000C80080300089EC47FD0088733D8520E48840240040
       VCID: 38756AA58B5F81FEAE-806C
       Component: Wischer 30101  26  0512
       Coding: 009F95
       Component: RLS 161010 05  54  0403
       Coding: 0730AD
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 3C0 907 376 A    HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0070
       Revision: 00000000    Serial number: 27101007080002
       Coding: 000180
       VCID: 2757B9D956E11E0637-8072
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRAEYNHY
       Coding: 00003132
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
       VCID: 3B7F75A9B269AAE643-806E
       Serial number: 3572MSME0527135AZZZQ
       Serial number: 3582MSME5F671057ZZZ/
       Serial number: 3512QSME18247539ZZZU
       Serial number: 3522QSME2C527547ZZZ-
       Part No SW: 5K0 953 507 AG    HW: 5K0 953 549 A
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JHO0019J
       Coding: 589A040000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 75EBA391D4CD3C9675-8020
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H05 0010
       Serial number: 0005278
       Coding: 830000
       Part No SW: 5K6 920 871 A    HW: 5K6 920 871 A
       Coding: 170D00
       VCID: 3261588D65236BAE90-8066
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 061110F2000242
       Coding: 350000
       VCID: 30655285632F59BEE6-8064
       VCID: 6AD180ED8D73E36EE8-803E
       Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
       Component: RNS-MID       H42 5238
       Revision: AB001001    Serial number: VWZ6Z7K4333018
       Coding: 04000002040000A00000
       Shop #: WSC 05314 123 12345
       VCID: 3777699986418E86A7-8062
       Subsystem 1 - Part No: 1T0 919 859 C
       Component: EU East V12  8196
                        Fault Status: 01101011
                        Fault Frequency: 78
                        Reset counter: 240
                        Mileage: 59748 km
                        Date: 2015.08.17
                        Time: 22:01:04
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
       Component: Tuer-SG         009 2117
       Coding: 0004214
       VCID: 3261588DAD236BAE90-8066
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 179    3001
       Revision: 00H17000
       VCID: 31635781A82550B6E9-8064
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
       Coding: 0004470
       VCID: 336F5D89523962A69B-8066
       Coding: 1444956
       VCID: 346D5E955737659E82-8060
       Coding: 00000022
       Coding: 00000022
                        Fault Frequency: 78
                        Reset counter: 240
                        Mileage: 59748 km
                        Date: 2015.08.17
                        Time: 22:01:04
    Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000A07957277
       Coding: 410120
       Shop #: WSC 00028 028 00001
       VCID: 2A5140ED45F3236E28-807E
    End-------------------------(Elapsed Time: 02:28)--------------------------
  5. Likes Jef, Uwe liked this post
    United States
    This is long overdue but I just linked this from the 00149 DTC page.
    I believe this has also fixed Golf 5/6 platform Audi Magnetic Ride modules as well (perhaps 8P A3, 8J TT and 42 R8) but I wasn't confident enough to list those chassis types. If that sounds correct we can expand on the Wiki notes in the future.
  7. Likes Uwe, m87a, Jef liked this post
