Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Something for everyone...
    Jul 2014
    Tallinn, Estonia
    In my Golf 7 there is a fuse in box C under dash which is supposed to supply power only to external lights. well, if I take it out the instrument cluster also powers off. that is written nowhere.
    Its pretty apparent in Elsa - fuse SC17 provides battery voltage to the instrument cluster.
  2. #12
    Apr 2018
    ITALY
    I am talking about SC23 or SC31, which should power the two headlights only. I do not remember specifically what happens, but when I pull one of those, either the cluster goes off or the ignition does not turn on anymore.
    car user manual, all schematics, Elsa and all the gods say those two fuses are for the headlights only.
    needless to say, this has always happened since the car was stock.
    I took another look at the WD and those two fuses go straight to BCM for left/right lights supply. it may be the BCM, maybe the internal wiring allows ignition only when those supplies are present.
  3. #13
    Jul 2014
    Tallinn, Estonia
    Oh, I see.
    Both these are 40A fuses with heavy gauge 4,0mm2 wiring - quite hefty for only running headlights. I'm guessing they are a more general voltage supply for the BCM.
  4. Likes Fredrick Awuor liked this post
  5. #14
    HQ
    Yep. There tends to be a left side and right side fuse. If there is a poor mechanical connection at the fuse, you can end up with this:
    http://wiki.ross-tech.com/wiki/index...nal_30_(Right)
    Jef
  6. Likes Uwe, jyoung8607 liked this post
  7. #15
    May 2014
    ^^^ From my reading of the WD (which I fully acknowledge could be incorrect) the BCM on the mk7 has 6 x separately fused T30 supply points. SC23 (pin#66A) and SC31 (pin #1C) are indeed for the right and left headlight Leuchte-sets (I believe). SC42 (pin #73A) is used by the BCM for the central locking function which leaves 3 x "general" T30 supplies:SC43 (pin #73C), SC4 (pin #4C) and SC26 (pin #1A).
    The BCM also produces (or, rather appears to produce) 4 x T15 supplies which I assume are generated through one, or more of the "general" T30 fuses: pin #13A for the main T15 voltage supply relay (J329), pin#14A for the dash panel wiring harness (T15a) and the two Ignition/Starter switch (-D-) connections on pin #44A and pin #47A (although I'm not sure whether these latter 2 x supplies come from, or to the module @ hex 44)
    But if anyone knows how the supply from the "general" T30 pins are distributed - I'm all ears!!!
    EDIT: For those that have an interest - here is a picture of the PCB from a BCM for MQB platform vehicle - it's quite a sophisticated control processor!!
  8. Likes Boki Ar liked this post
