GPF Soot Loading
Chrispy
C?ID=124808
Not sure if this is in the right forum, as it may not actually be a problem...
2019MY SEAT Leon with GPF
Tuesday,15,January,2019,11:42:29:29302
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
VIN: VSSZZZ5FZKR028047   License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 42 44 4B 52 5F A9 BB
          BC D6 D7
VIN: VSSZZZ5FZKR028047   Mileage: 2354km-1462miles
BB-Door Rear Drv -- Status: Not registered 0001
Address 01: Engine (J623-DNUE)       Labels: None
   Part No SW: 8V0 906 259 R    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0B2540122426010B2000
   Shop #: WSC 00049 770 00174
   ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
   ROD: EV_ECM20TFS0208V0906259R.rod
   VCID: 4FF87B21D75A0B1F571-801A
   Part No SW: 0GC 300 012 M    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2305
   Revision: 00H06V07
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 2D0401A9BD96190F05D-8078
   Part No SW: 5Q0 614 517 DG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0654
   Revision: 00000000    Serial number: 62728000000312
   Coding: 19EE9392542221748777070460CA6998C92A84E1E0069677304250F4C206430100000012121212B835351919323200
   Shop #: WSC 00049 770 00201
   ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
   VCID: 79ACE5F9395E75AFD95-802C
   Part No SW: 5F0 907 044 AM    HW: 5F0 907 044 AM
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 02100204200114011005000000101020
   ROD: EV_ACClimaBHBVW37X_006_SE37.rod
   VCID: 71BCDDD9612E3DEF615-8024
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001828400758
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7DA4F1E92D76498FF5D-8028
   Subsystem 1 - Part No SW: 5F2 955 119 A    HW: 5F2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 180910  041 0574
   Serial number:         180919012754
   Coding: 0BC5FD
   Serial number: 21897850X81A955555A0
   Coding: 00005D
   Serial number: 000000000ZY181900HGW
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000213845
   Serial number: 000308418618277
   Coding: 0471051011
   VCID: 4CC26C2D264C3007323-8018
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Component: ACC BOSCH MQB H11 0682
   Coding: 3500008159FF8428949C814500300400000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D2440D0E1CF847FA3-8010
   Serial number: 19081841350334
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382A20FD42D4ACA766B-806C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W4PLXXQNS
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0554990945A6014FADD-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 000 310 18
   Serial number: 35700000000783842239
   Subsystem 2 - Part No SW: -----------    HW: 454 000 310 18
   Serial number: 358000000004D584223E
   Subsystem 3 - Part No SW: -----------    HW: 454 802 809 18
   Serial number: 3510099B46F16000000R
   Subsystem 4 - Part No SW: -----------    HW: 454 802 909 18
   Serial number: 35200C6F66416000000N
   Subsystem 5 - Part No SW: -----------    HW: 454 800 310 18
   Serial number: 3550083C72316000000C
   Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 03101820241039
   Coding: 1410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0A4EAA356CB86E37C0F-805E
   Part No SW: 5F0 920 790 A    HW: 5F0 920 790 A
   Component: KOMBI         609 1701
   Coding: 24AD3808BB800600018876011001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2708F3819F6A335FFF1-8072
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008645501
   Coding: 030100F42F085900FB0082689C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D2431E96DF6898FB5D-8068
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000I0365170918
   Coding: 012000
   Serial number: 75886002001810051C98
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00026.07.18
   Coding: 0001
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 0000346921447
   Coding: 00140220DC01020000001000
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000024084719
   Coding: 2D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C223CED76EC8087823-8068
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 03101810803813
   Coding: 000000070900095607000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353429C955C651CF7DD-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 0000347509768
   Coding: 00140020DE01020000001000
   VCID: 4EC66625D05002175C7-801A
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000024050442
   Coding: 350000
   Part No SW: 5F0 035 877     HW: 5F0 035 877
   Component: MU-S-ND-ER    H50 0512
   Serial number: SEZAZ2U0823349
   Coding: 04738201D70A00001111010100880A002F0202E601200400CE
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SK25.rod
   VCID: 698CB5B949FEC52F295-803C
   Subsystem 1 - Part No SW: 5F0 919 606 A    HW: 5F0 919 606 A
   Component: ABTm-2_8-BL  H41 1042
   Serial number: SEZ8Z9V6D001Y5
   Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
   Component: ECE1 2018/19  --- 1030
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 62
                    Mileage: 2098 km
                    Date: 2019.01.08
                    Time: 16:05:17
                    Voltage terminal 30: 12.1 V
                    Interface for external media: status-Status: Open circuit
   Part No SW: 5F0 907 159 D    HW: 4H0 907 159 A
   Serial number: 181004200298
   VCID: 2E0606A5B09062173C7-807A
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA6F6E520705297EC7-802A
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW37.rod
End----------(Elapsed Time: 01:48, VBatt start/end: 12.2V/12.2V)-----------
I'm trying to look at how the Gasoline Particulate Filter loads up with soot, and I'm seeing the following measured values:
IDE00434 Particle filter: soot mass calculated 0.01g
IDE13085 Particle filter: high level of soot buildup 9.6g
IDE13086 Particle filter: maximum soot build-up reached 16g
Is it possible the "soot mass calculated" is a factor of 10 or 100 out?
I've done some drives and it has peaked at 0.02g, and I've seen it drop off with a prolonged period of exhaust temp over 700 degC.
Which all seems logical, it's just that the soot load of 0.02 seems way too low, particularly if the high and maximum levels are 9.6 and 16.
NEtech
C?ID=56995
I think this is normal, Gasoline filter should last car lifetime.
I think IDE13085 has some other meaning/calculation.
