Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: Update BCM 09 software version latest!
  1. #31
    Verified VCDS User sam1754's Avatar
    Mar 2019
    France
    I'll try this next wednesday. Thanks a lot!
    I might improve my german, VCDS help me do it!
    After a minute, I finally understand you meant "restlichen".
  2. #32
    May 2017
    Wiring is unfortunately missing if there’s no lights from factory.
    But there’s one option. There’s pin for interior door handle light on the door control module which you can enable through coding. The functionalirty is not exactly the same as from bcm but it’s easier.
    Can’t remember exactly which pin but I think I can find it.
  3. Likes PetrolDave liked this post
  4. #33
    Mar 2019
    France
    Yes, I tried this on pin 3 but it's linked to instrumental dimming. So I can't have a smooth ambient lightning with a bright instrument lightning. Do you know which pin is dedicated to ambient lightning on the 73 pin BCM J519?
    I know pin 72 is for floor lightning, pin 29 for dashboard ambient lightning, pin 62 for cupholder ambient lightning... Do you know how to do for door ambient light?
  5. #34
    May 2017
    I think the door control pin was infact 3 and yes that is connected to instrument dimming.
    Can’t remember the bcm pin. I can check it when I’m at the computer.
  6. #35
    Mar 2019
    France
    Wink
    Fabulous!!!
    Many thanks Barstanders!
    All is working! I didn’t put anything else as I had floorlights yet actives and I just wanted to add door panel’s lights. The allezonen menu is nice but it doesn’t allow me to adjust door/floor lights separatly (maybe not the exact word, sorry).
    I just put this:
    Elektronische Zentralelelektrik STG 09
    -> Anpassung -> Innenlicht Leuchtenkonfiguration -> Ambiente_Applikationsleisten_in_Tuertaflel active
    -> Innebeleuchtung Parameter
    -> p_addaption_kundenwunsch_tuer auf 0.60
    -> p_helligkeit_entriegelt_tueren auf 0%
    -> p_helligkeit_max_tueren auf 96%
    -> p_helligkeit_HD_auf_Zuendung_ein_tueren auf 126%
    -> p_helligkeit_HD_auf_zuendung_aus_tueren auf 127%
    -> p_helligkeit_dieseTuer_auf_zuendung_ein_tueren auf 96%
    -> p_helligkeit_andereTuer_auf_zuendung_ein_tueren auf 96%
    -> p_helligkeit_FZG_geschlolssen_zuendung_ein_tueren auf 126%
    -> p_helligkeit_dieseTuer_auf_zuendung_aus_tueren auf 96%
    -> p_helligkeit_andereTuer_auf_zuendung_aus_tueren auf 96%
    -> p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren auf 127%
    -> p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_au s_tueren auf 96%
    -> p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus _zueren auf 96%
    -> p_helligkeit_Tueren_geschlossen_schluessel_ab_tuer en auf 96%
    -> p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren auf 96%
    -> P_dimmfaktor_farbwechsel_auf auf 1
    -> P_dimmfaktor_farbwechsel_ab auf 1
    -> p_ambientelicht_verbauinformation_HMI auf 1
    Nächster Schritt
    STG 42 Türelektronik Fahrer
    -> lange Codierung
    -> front_field_light auf active setzen
    -> ambient_light auf active setzen
    -> door_exit_light auf active setzen
    -> inside_door_handle_ligtht auf active setzen
    If you want multicolor ambientlight, you have to wire it from pin 29 on the BCM. But I don't aprreciate those disco lights
  7. Likes barstanders, Dana liked this post
  8. #36
    Mar 2019
    France
    So,I noticed it's really interesting to adapt all dimming as you want it to be. As soon as you understand all functions, you can make your car more welcoming.
    Kundenwunsch value allow you to modify the amplitude of adjustment. For example, if you put 50% for foot lighting, you'll be able to adjust per 10% between 0 to 6V power.
    Now, I'd like to know what means "psd" and "miko" because I'd like to modify door handle lightning profil.
    Any idea?
    Sam
  9. #37
    Mar 2019
    France
    No one???
  10. #38
    Dec 2016
    DE
    PSD should be the Panoramaschiebedach, meaning panoramic sun-roof
    MiKo is short for Mittelkonsole meaning middle console (the part between the two front seats).
  11. Likes Uwe, jyoung8607 liked this post
  12. #39
    Mar 2019
    France
    Oh yes, it's clear!
    So it won't help me dimming inside door handles.
    Thank you!
  13. #40
    Mar 2019
    France
    Instead of using handle's lights, I'm triyng to use speaker's lights which are adjustable by 09 settings.
    I think it'll be possible but I don't know on which door module's pin I have to connect it?
    Any idea??? Thanks
