Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Update BCM 09 software version latest!
    Jun 2016
    Hello TBAx,
    That is not so nice to hear when you have an official VCDS cable. you think you can change everything because this is a CAN version, and I consciously bought this because I have a Golf 7.
    But can you tell me when I flash this with VCP, I can change the adapter channel with VCP.
    I would still like your help can you explain me how to flash this me and my friend are new to VCP.
    And see that you have done this more often.
    Which file should I use! ( FL_5Q0937084AJ_0137_S )
    Will this later build olso work
    FL_5Q0937084AP_0175_S
    FL_5Q0937084AQ_0175_S
    FL_5Q0937084AR_0175_S
    FL_5Q0937084AS_0175_S
    can you also tell me if I can flash the parkassist module to a newer version without problems.
    I hope you can give me an explanation. my friend has also postponed these questions at VCP, we are also waiting for a response.
  2. #12
    Dec 2016
    DE
    Hi barstanders,
    let’s move this discussion either to private message or the VCP forum. I‘m not sure Uwe likes to see in-detail discussion of a competitiors product publicly in the VCDS forum.
    But to answer your primary question: Using the AP or higher index versions could work. However I have not seen a car which came from factory with these mix of hardware and software.
    Even flashing to AJ 0137 could cause some unwanted side effects.
  3. Likes PetrolDave liked this post
  4. #13
    Jun 2016
    I have send you pm. Thanks
  5. #14
    Jun 2016
    Hello All,
    I have flash today the BMC to a newer version, i need to recode the Led Bar error, but i want to now what kind of fehler is the other ones.
    The footwel lights and inside door lights not burning.
    Tuesday,22,January,2019,15:47:23:42750
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZAUZDP010048   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZDP010048   Mileage: 63894km-39701miles
    Address 01: Engine (J623-CJZB)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 E    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 7695
       Revision: WAH08---
       Coding: 01110032232415082000
       Shop #: WSC 51969 000 1048576
       ASAM Dataset: EV_ECM12TFS01104E906016E 001011
       ROD: EV_ECM12TFS01104E906016H.rod
       VCID: 2468B6F82F7D016A99-8070
    Readiness: 1110 0001
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
       Shop #: WSC 56452 002 104857
       ROD: EV_Brake1UDSContiMK100IPB_008.rod
       VCID: 7DDEA39CEC5790A2B6-8028
       Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00020004200100011005000000101000
       Shop #: WSC 12345 123 123465
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 364C7CB089E183FA37-8062
       Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 L
       Component: BCM MQBAB H   H14 0137
       Serial number: 00011227800350
       Coding: 00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 0020DA689BA5FD4ADD-8054
       Component: WWS    120910  042 0551
       Serial number:         120924160900
       Coding: 0E4DD5
       Component: RLFS  024 0042
       Serial number: Y12M09D26H11M47S40S4
       Coding: 06A8DD
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY1306406H5
       Serial number: 00000000000056969920
    526359 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 204
                        Mileage: 63894 km
                        Date: 2019.01.22
                        Time: 15:43:24
    560405 - Databus
                        Reset counter: 204
                        Mileage: 63894 km
                        Date: 2019.01.22
                        Time: 15:43:24
    565764 - LED Light Bar
              B1664 31 [009] - No Signal
                        Reset counter: 204
                        Mileage: 63894 km
                        Date: 2019.01.22
                        Time: 15:43:24
       Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
       Component: PARKHILFE PLA 011 0029
       Revision: --------    Serial number: 61131226402555
       Coding: 0031161041
       ASAM Dataset: EV_EPHVA2CAU3700000 003014
       ROD: EV_EPHVA2CAU3700000_003.rod
       VCID: 3D5E639CACD750A2F6-8068
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R00E6ZJ
       Shop #: WSC 00028 028 00057
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 40A01A68DB253D4A9D-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 310 12
       Serial number: 35767000000E2845EB00
       Subsystem 2 - Part No SW: -----------    HW: 480 001 708 13
       Serial number: 35867000000ED2CC6D0F
       Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3516502A90D19C31C0EK
       Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3526502AD0CD5EB313CY
       Subsystem 5 - Part No SW: -----------    HW: 480 400 210 12
       Serial number: 3556502B30CD5EB4531M
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 1510120003004H
       Coding: 8400
       Shop #: WSC 51454 001 104857
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 75CEBBBCD467C8E2FE-8020
       Part No SW: 5G0 920 870     HW: 5G0 920 870
       Component: KOMBI         335 0555
       Coding: 07A501002390000800087A00040000
       Shop #: WSC 99179 211 12345
       VCID: 66ECECF099C1337A47-8032
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   122 1143
       Revision: --------    Serial number: 0000210963
       Coding: 030100042B086400EF000648080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       VCID: 3B5A6D84B2C35E92C8-806E
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H14 0035
       Serial number: 23130000529820100291
       Coding: 280000
       Serial number: 5430458201
       Serial number: 29051301100188
       Coding: 001F0220D000020000001000
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000243883
       Coding: 03
       ROD: EV_SteerAssisMQB_008.rod
       Component: TSG BFS       020 0023
       Serial number: 06031302090088
       Coding: 001F0020DE00020000801000
       VCID: 3FA21994A6DB42B2E4-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000247280
       Coding: 090000
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846
       Component: MU-S-N-ER     038 0486
       Serial number: V1F01510120522
       Coding: 02730001FF00000011110001000800001F0103940100010045
       Shop #: WSC 12345 666 54321
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 2772A1F45E4BEA72BC-8072
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9NJ902C5F
       Subsystem 2 - Part No SW: 5G0 919 866 AJ    HW: -----------
       Component:  ECE 2019  --- 0078
    End-------------------------(Elapsed Time: 02:49)--------------------------
  6. #15
    Jun 2016
    BCM
    Hello all,
    I want to give an explanation of what I did today and what kind of malfunctions occur as soon as I change a byte and bit.
    I have flashed the BMC with multiple versions AD, AE, AF and AJ.
    But every time there is an error message see first reaction.
    When I turn off the byte footwell lights and then flas there is only one error, the LED bar will disappear. wrong coded.
    So iI have performed several tests and at version AE, after flashing, no error everything remains clean.
    so after flashing, he probably always gives a led bar of error, always untick footwell lights on the bmc before flashing.
    But I would like to see the next problem solved!
    As soon as I open the door the led door frames and handles, this also applies to the footwell lights tuns on.
    when I close the door, the lights do not light when I drive,
    Normally when the light sensor detects twilight, the automatic light turns on and these LED lights also turn on, ore when you switch the lights on!
    I have heard that my micro cable does not support this adaption channel to request ore change.
    but would like to know what these are so that I can do this with someone else!
    So when I activate footwell the ledbar and error coding message comes as a malfunction!
    Maybe i need to switch allf on the adaptations footwel lights,door ambient lights on the BMC and door 42 and 52, and the again flash!
    can someone tell me what to look at.
    BMC wit extensio AJ
    Wednesday,23,January,2019,16:21:07:42750
    VIN: WVWZZZAUZDP010048   Mileage: 63904km-39708miles
       Revision: WAH08---
    Readiness: 0110 0001
       Revision: 00001K06
       Coding: 00040846C24102FB0BA44080B11C0708100A000000000000000000000000
       Coding: 0E4DD5
       Coding: 06A8DD
              U1014 00 [009] - -
                        Reset counter: 206
                        Mileage: 63904 km
                        Date: 2019.01.23
                        Time: 16:18:03
       Coding: 0031161041
       Coding: 8400
       Coding: 280000
       Coding: 005F0220D000020000001000
       Coding: 03
       Coding: 090000
    BMC with extension AE,
    Wednesday,23,January,2019,17:51:41:42750
       Revision: WAH08---
       Revision: 00001K06
       Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 L
       Component: BCM MQBAB H   H14 0124
       ROD: EV_BCMBOSCH_012.rod
       VCID: 7BDAAD84F2439E9288-802E
       Coding: 0E4DD5
       Coding: 06A8DD
       Coding: 0031161041
       Coding: 8400
       Coding: 280000
       Coding: 03
       Coding: 090000
    End-------------------------(Elapsed Time: 02:54)--------------------------
  7. #16
    Jun 2016
    SW:5Q0-937-084-AA   HW:5Q0-937-084-L ---  Cent. Elect.
    	Component:BCM MQBAB H   H14 0112, Coding:00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
    	EV_BCMCONTI,011001,EV_BCMBOSCH_011.rod
    	Tuesday,22,January,2019,06:27:28:42750
    	VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    	VCID: 77D2B1B4CE6BBAF2EC-8022
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,9
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,9
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,9
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,9
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms,9
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,320 ms,9
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,320 ms,9
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,9
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,9
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,9
    IDE01550-Service position,170.494336 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,Yes ,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,2
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,2
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,Yes ,2
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,2
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
    IDE02488-DWA Interior monitoring,100 %,1
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,3
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,3
    IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,4
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,4
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,4
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled ,4
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,13
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,13
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,13
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,13
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separate ,3
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,3
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,4 ,3
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,3
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,3
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,3
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,3
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.100 %,3
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,3
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
    IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,not active ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,5
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,116 ,5
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,2 ,5
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,5
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,5
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,20 seconds ,5
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,5
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,5
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
    IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
    IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
    IDE04928-ENG148904-Anti-theft device-Überwachung Innenentriegelungshebel,not active ,1
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,4
    IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,4
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,4
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,4
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,4
    IDE05142-ENG115758-Access control-Valet Parking,not active ,4
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,4
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,4
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00 ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,0 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,0 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,89 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,28 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,28 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,31 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,31 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00 ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00 ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00 ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44 ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,not active ,560
    IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,43 - allgemeine LED ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,not active ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,0 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,0 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,22 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,23 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,6 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,7 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,31 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,31 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE05822-DWA Vehicle inclination sensor,100 %,1
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 ,172
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,14
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,14
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,14
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,14
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,14
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,14
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,14
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,14
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,14
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,14
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,14
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,14
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,14
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,14
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
    IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,active ,6
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,2
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
    IDE07007-ENG148891-A/C heater function via remote control-Anzahl zulaessiger Remotestarts,0 ,2
    IDE07007-ENG148876-A/C heater function via remote control-RemoteStart Betrieb Dauer,0 min,2
    IDE07356-Position during interval mode,31.494474 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
    IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,6
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,6
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,Yes ,6
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,No ,6
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,6
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,6
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,6
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,6
    IDE08542-ENG115671-Access control 2-Regenschließen,Permanent ,6
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,6
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,6
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,6
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,6
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,6
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,6
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,4
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,4
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,4
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,non sensitive ,4
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,1
    IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner,not active ,1
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,1
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,1
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,1
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE10298-Alternating park position 1,7.494498 °,2
    IDE10299-Alternating park position 2,29.494476 °,2
    MAS01490-Energy management,active ,1
    MAS05055-lower turn position,31.494474 °,2
    MAS05056-upper turn position,170.494336 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,3
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,3
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,3
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,3
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,3
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,3
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,3
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,3
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,3
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,3
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,3
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,3
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,3
    ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 lx,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 %,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 %,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 %,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 %,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 %,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 %,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 %,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 %,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 %,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 %,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.0 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.0 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.0 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.0 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.0 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 %,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 %,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 %,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 %,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 %,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 %,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 %,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 %,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 %,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 %,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 %,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 %,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.0 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0 ,10
    ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0,0 lx,8
    ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1,8 lx,8
    ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2,50 lx,8
    ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3,500 lx,8
    ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0,6.0 %,8
    ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1,6.0 %,8
    ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2,100.0 %,8
    ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3,100.0 %,8
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,28 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,28 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,33 - LED-Modul Blinkleuchten ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,33 - LED-Modul Blinkleuchten ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,31 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,31 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44 ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
  8. #17
    Jun 2016
    SW:5Q0-937-084-AJ   HW:5Q0-937-084-L ---  Cent. Elect.
    	Component:BCM MQBAB H   H14 0137, Coding:00040846C24102FB0BA44080B11C0708101E000000000000000000000000
    	EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
    	Wednesday,23,January,2019,16:13:01:42750
    	VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    	VCID: 0020DA689BA5FD4ADD-8054
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms,12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,320 ms,12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,320 ms,12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
    IDE01550-Service position,170.49 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
    IDE02488-DWA Interior monitoring,100 %,1
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled ,8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,4 ,8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,20 seconds ,8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
    IDE04927-ENG126845-Window heater-FSH Automatik,not active ,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,8
    IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
    IDE05142-ENG115758-Access control-Valet Parking,not active ,8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00 ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,0 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,0 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,89 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,28 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,28 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,31 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,31 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00 ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00 ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00 ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44 ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,not active ,560
    IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,43 - allgemeine LED ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,not active ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,0 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,0 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,22 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,23 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,6 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,7 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,31 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,31 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE05822-DWA Vehicle inclination sensor,100 %,1
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 ,172
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
    IDE07356-Position during interval mode,31.49 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
    IDE08542-IDE02022-Access control 2-Comfort opening,active ,8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active ,8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
    IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,non sensitive ,8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
    IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
    IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
    IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
    IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
    IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
    IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
    IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
    IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
    IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
    IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
    IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
    IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
    IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
    IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
    IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
    IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
    IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
    IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
    IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
    IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
    IDE10298-Alternating park position 1,7.49 °,2
    IDE10299-Alternating park position 2,29.49 °,2
    MAS05055-lower turn position,31.49 °,2
    MAS05056-upper turn position,170.49 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,28 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,28 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,33 - LED-Modul Blinkleuchten ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,33 - LED-Modul Blinkleuchten ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,31 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,31 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44 ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
    ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
    ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
    ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
  9. #18
    Jun 2016
    SW:5Q0-937-084-AE   HW:5Q0-937-084-L ---  Cent. Elect.
    	Component:BCM MQBAB H   H14 0124, Coding:00040846C24102FB0BA44080B11C0708100A000000000000000000000000
    	EV_BCMCONTI,012001,EV_BCMBOSCH_012.rod
    	Wednesday,23,January,2019,17:45:14:42750
    	VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    	VCID: 7BDAAD84F2439E9288-802E
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,9
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,9
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,9
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,9
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms,9
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,320 ms,9
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,320 ms,9
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,9
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,9
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,9
    IDE01550-Service position,170.494336 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,Yes ,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,2
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,2
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,Yes ,2
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,2
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
    IDE02488-DWA Interior monitoring,100 %,1
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,3
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,3
    IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,4
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,4
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,4
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled ,4
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,13
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,13
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,13
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,13
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separate ,3
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,3
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,4 ,3
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,3
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,3
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,3
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,3
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.100 %,3
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,3
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
    IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,not active ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,5
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,116 ,5
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,2 ,5
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,5
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,5
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,20 seconds ,5
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,5
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,5
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
    IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
    IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
    IDE04928-ENG148904-Anti-theft device-Überwachung Innenentriegelungshebel,not active ,1
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,4
    IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,4
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,4
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,4
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,4
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,4
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,4
    IDE05142-ENG148954-Access control-Softtouch-Betätigung senden,Always ,4
    IDE05142-ENG115758-Access control-Valet Parking,not active ,4
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,4
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,4
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00 ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,0 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,0 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,89 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,28 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,28 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,31 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,31 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00 ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00 ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00 ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44 ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,not active ,560
    IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,33 - LED-Modul Blinkleuchten ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,43 - allgemeine LED ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,32 - allgemeine LED bis 12W ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,not active ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,0 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,0 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,22 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,23 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,6 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,7 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,31 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,31 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE05822-DWA Vehicle inclination sensor,100 %,1
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 ,172
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,14
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,14
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,14
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,14
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,14
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,14
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,14
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,14
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,14
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,14
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,14
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,14
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,14
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,14
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
    IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,active ,6
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,2
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
    IDE07007-ENG148891-A/C heater function via remote control-Anzahl zulaessiger Remotestarts,2 ,2
    IDE07007-ENG148876-A/C heater function via remote control-RemoteStart Betrieb Dauer,10 min,2
    IDE07356-Position during interval mode,31.494474 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
    IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,6
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,6
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,Yes ,6
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,No ,6
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,6
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,6
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,6
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,6
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,6
    IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,6
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active ,6
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active ,6
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,6
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,6
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,6
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,6
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,6
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,6
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,6
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,6
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,6
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,4
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,4
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,4
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,non sensitive ,4
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,1
    IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner,not active ,1
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,1
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,1
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,1
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
    IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
    IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
    IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
    IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
    IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
    IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
    IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
    IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
    IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
    IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
    IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
    IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,10
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,10
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,10
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,10
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,10
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,10
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,10
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,10
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,10
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,10
    IDE09731-ENG148953-Int. light: 2nd generation-Helligkeit Türtafelbeleuchtung nicht berechnen,not active ,10
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,10
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,10
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,10
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,10
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,10
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,10
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,10
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
    IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
    IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
    IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
    IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
    IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 W/m²,10
    IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
    IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
    IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
    IDE10298-Alternating park position 1,7.494498 °,2
    IDE10299-Alternating park position 2,29.494476 °,2
    MAS01490-Energy management,active ,1
    MAS05055-lower turn position,31.494474 °,2
    MAS05056-upper turn position,170.494336 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,3
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,3
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,3
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,3
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,3
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,3
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,3
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,3
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,3
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,3
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,3
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,3
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,3
    ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 lx,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 %,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 %,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 %,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 %,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 %,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 %,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 %,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 %,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 %,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 %,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.0 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.0 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.0 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.0 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.0 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 %,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 %,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 %,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 %,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 %,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 %,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 %,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 %,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 %,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 %,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 %,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 %,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.0 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0 ,10
    ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0,0 lx,8
    ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1,8 lx,8
    ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2,50 lx,8
    ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3,500 lx,8
    ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0,6.0 %,8
    ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1,6.0 %,8
    ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2,100.0 %,8
    ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3,100.0 %,8
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,28 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,28 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,33 - LED-Modul Blinkleuchten ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,33 - LED-Modul Blinkleuchten ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,31 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,31 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44 ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 %,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 %,12
  10. #19
    Jun 2016
    Hello All,
    I stil need help.
    Wit AE index no fehler, only the door ambiant lights and footwell burns when i open the doors.
    Please i must not be so diffucult voor expert vcds users here.
    I only want that the ambient lights stays on when the lights go on!!!
  11. #20
    Quote Originally Posted by barstanders View Post
    Are you sure this is possible with the modules fitted to your car?
    VCDS can only enable features/functions that VAG have built-in to their firmware; if VAG haven't included it VCDS can't enable it
  12. Likes Uwe liked this post
