Results 21 to 30 of 40
Thread: VCDS Mobile on Android - missing labels for measuring blocks
  1. #21
    Moving this to HEX-NET Support.
  2. #22
    The DTC log I see from you for the 5f appears to be missing the ASAM id, which will make anything rod-related fail.
    Is this car stock? Can you try posting the whole VCDS-Mobile autoscan so we can get a better sense of what is and isn't working. If you can't get it to upload to the cloud, you can also right click the file and "save as" from a PC and email to us, or you can copy-paste the text here in between [CODE] [/CODE] tags.
  3. Likes Uwe liked this post
  4. #23
    Dec 2018
    Poland
    Hi Shaun,
    If you ask about VW Scirocco and 5F - Scirocco is generally stock except [5f, tempomat, navi and TPMS, RVC]. I had stock RCD310 on [56 radio]. Gateway doesn't have on list 5F. Gateway is stock. 5F (Discover Media) is added (retrofit).
    Here are today photos from Golf V:
    https://1drv.ms/f/s!AuwAeVEhNnQxgbQhw8e7OwlRXbF2vA
    Missing labels are not related to stock or not stock modules I think. Both cars have stock engines. Golf has stock everything except tempomat and TPMS.
    Golf V:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ9WXXXXXX   Mileage: 91570km-56898miles
    Address 01: Engine        Labels: 03C-906-024-BXW.lbl
       Part No SW: 03C 906 024 AS    HW: 03C 906 024 AS
       Component:  MARELLI 4HV      G 2495
       Revision: --H12---    Serial number: VWX7Z0H83NI92W
       Coding: 0004071
       Shop #: WSC 00000 028 00001
       VCID: EFAEBDCDFEDB0F32B4-80BA
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
       Component: MABS MK70M          0104
       Revision: 00H32001
       Coding: 0000257
       VCID: F6A088A981813EFA77-80A2
       Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: EC94AAC1CFCDF42A91-80B8
       Revision: 00H54000    Serial number: 00000008688928
       Coding: 758D0F2700041500471400001400000000297F074600010C000000000000
       VCID: B32671BDD2736BD290-80E6
       Component: Wischer 240908 021  0501
       Coding: 00038805
       Shop #: WSC 01357
       Component: RLS     021008 054  0402
       Coding: 00209069
       Shop #: WSC 01357
    01259 - Fuel Pump Relay (J17)
                        Fault Status: 00101001
                        Reset counter: 85
                        Mileage: 80751 km
                        Voltage: 12.50 V
       Component: 37 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD27RJU5
       Coding: 0013111
       VCID: BD325785E437ADA276-80E8
       Subsystem 1 - Serial number: 6332MSME423274171
       Subsystem 2 - Serial number: 6342MSME4035643DA
       Subsystem 3 - Serial number: 6352QSME4E0D0D0EZ
       Subsystem 4 - Serial number: 6362QSME2107141C6
       Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
       Component: J0527           757 0101
       Coding: 0000042
       VCID: FF4E6D8DAEBB7FB224-80AA
       Part No SW: 1K0 920 864     HW: 1K0 920 864
       Component: KOMBIINSTRUMENT VDD 1212
       Revision: V0002000    Serial number: VWX7Z0H83NI92W
       Coding: 0003103
       Shop #: WSC 00100 259 81089
       VCID: E99AD3D5C03FE102EA-80BC
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 040908F2001950
       Coding: E9807F060002020002
       VCID: B5224FA5DC0775E2BE-80E0
       Component: IMMO            VDD 1212
       Component: Tuer-SG         006 1219
       Coding: 0000180
       VCID: B83C4691CB15888AA5-80EC
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.068 H08 1901
       Coding: 809002005103087F2D04840560084F03E0FCA0
       VCID: 8346E17DC2531B5240-80D6
       Coding: 0000180
       VCID: B93A4395F01F91825A-80EC
    00110 - Right Mirror Turn Signal Lamp (L132)
       Part No SW: 1K0 035 156 A    HW: 1K0 035 156 A
       Component: Radio         018 0040
       Revision: R0018000    Serial number: VWZAZ1H7058144
       Coding: 0000020002
       VCID: A10A8BF5B88FE94272-80F4
       Component: Tuer-SG         006 1302
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Coding: 0000144
    End----------(Elapsed Time: 01:25, VBatt start/end: 14.3V/14.3V)-----------
    VCDS-Mobile autoscan Golf V:
    VCDS-Mobile
    Auto-Scan
    Finished
    Address 01: Engine	Labels: 03-01.clb
    Part No SW: 03C 906 024 AS	HW: 03C906024AS
    Revision: --H12---	Serial Number: VWX7Z0H83NI92W
    Coding: 0004071
    VCID: 6FA140BF05AF1CC9A578DE4-803A
    No fault codes found.
    Address 03: ABS Brakes	Labels: 1K-03.clb
    Part No SW: 1K0 907 379 AF	HW: 1K0907379AF
    Revision: 00H32001
    Coding: 0000257
    VCID: 76AF75DB7AF52D0166BE038-8023
    Part No SW: 1K0 907 044 DD	HW: 1K0907044DD
    Revision: 00130023	Serial Number: 00000000000000
    VCID: 6C9B57B334B9E7D1801AB10-8039
    Address 09: Cent. Elect.	Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E	HW: 3C8937049E
    Revision: 00H54000	Serial Number: 00000008688928
    Coding: 758D0F2700041500471400001400000000297F074600010C00 0000000000
    VCID: 33298CCF290778298120224-8066
    Subsystem 1 -  Part No SW: 1K1-955-119-E	Labels: 1Kx-955-119.clb
    Coding: 0038805
    Subsystem 2 -  Part No SW: 1K0-955-559-AH	Labels: 1K0-955-559-AG.clb
    Coding: 0209069
      Reset Counter: 89
      Mileage: 91622 km
      : OFF
      Voltage: 12.50 V
      : OFF
      : ON
      : OFF
      : OFF
      : OFF
    Part No SW: 1K0 909 605 T	HW: 1K0909605T
    Revision: 05020000	Serial Number: 0038PD27RJU5
    Coding: 0013111
    VCID: 3D3DAAF71F43BE596744B4C-8068
    Subsystem 1 -  Serial Number: 6332MSME423274171
    Subsystem 2 -  Serial Number: 6342MSME4035643DA
    Subsystem 3 -  Serial Number: 6352QSME4E0D0D0EZ
    Subsystem 4 -  Serial Number: 6362QSME2107141C6
    Part No SW: 1K0 953 549 BN	HW: 1K0953549BN
    Coding: 0000042
    VCID: 7F4190FF55CF6C4935D86E4-802A
    Part No SW: 1K0 920 864	HW: 1K0920864
    Revision: V0002000	Serial Number: VWX7Z0H83NI92W
    Coding: 0003103
    VCID: E995AEA7BB4B72F97B3C10C-80BC
    Address 19: CAN Gateway	Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q	HW: 1K0907951
    Revision:  H07 01	Serial Number: 040908F2001950
    VCID: 352DB2D727736619AF345CC-8060
    Address 42: Door Elect, Driver	Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M	HW: 1K0959701M
    Coding: 0000180
    VCID: 3833BBE330619B71B4127D0-806D
    Address 44: Steering Assist	Labels: 1Kx-909-14x-44.clb
    Part No SW: 1K1 909 144 M
    Address 46: Central Conv.	Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT	HW: 1K0959433BT
    Revision: 00020000	Serial Number: 00000000000000
    VCID: 83499C0FB92788A9D100B24-80D6
    Address 52: Door Elect, Pass.	Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 M	HW: 1K0959702M
    Coding: 0000180
    VCID: 3935BEE70B6B82794B1C60C-806C
    Address 56: Radio  (J503)	Labels: 5M0-035-1xx-56.clb
    Revision: R0018000
    Coding: 0000020002
    VCID: 2105768783FB7AB9636C78C-8074
    Address 62: Door, Rear Left	Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 K	HW: 1K0959703K
    Coding: 0000144
    Address 72: Door, Rear Right	Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 K	HW: 1K0959704K
    Coding: 0000144
    End--(Elapsed Time: 01:52, VBatt start/end: 14.4/14.4 Vign: 14.4)-
    Updated: I ran VCDS-Mobile on Edge browser on Windows 10 on laptop. Did autoscan and clicked save button. The popup displayed - it shows path but the file doesn't exist on VCDS-Cloud and in log directory in Ross-tech installation directory so where is this file?
    https://1drv.ms/i/s!AuwAeVEhNnQxgbQqndFrkQELMsbfHQ
    Last edited by cruzbdg; 01-30-2019 at 04:05 AM. Reason: Added vcds-mobile scan and new photo.
  5. #24
    Measuring blocks with VCDS should definitely work, so lets start with that.
    Are the errors that you see there reproducible? If so, do you notice any event that seems to trigger it, like the wifi dropping? If you have a way to reproduce this, you can try making debug logs in VCDS by going [Options] -> Debug level = 1028 [Save] and then do whatever you need to reproduce. This will make a log in the VCDS\Debug folder. Also pay attention to the LEDs on the interface when this happens. Does it look like the interface reboots?
  6. Likes Uwe liked this post
  7. #25
    Dec 2018
    Poland
    Error in measuring blocks occurred once and on Golf so it will be hard to check if interface resets. The main problem for me is missing labels in vcds-mobile and problematic configuration HUD controls in vcds-mobile and connection to vcds cloud from vcds-mobile. Slow download data using vcds-mobile via 4G/LTE and how where to find saved logs on smartphone or laptop when saved from vcds-mobile if Cloud functionality doesn't work (vcds mobiel can't connect to vcds cloud.
    I've updated my above post. Added vcds mobile scan and photo with path where shoudl be a file saved.
  8. #26
    Quote Originally Posted by cruzbdg View Post
    Access VCDS-Mobile with the device and browser of your choice. Click [View Saved Files]. Click on a file to open it; your browser will display it (they're all just plain text). Use your browser's SAVE AS (or equivalent functionality) to save the file to the local device the browser is running on.
  9. #27
    If the browser didn't ask you where to save it, it is probably set to save things in a default "Downloads" directory. It will be where ever your browser normally saves downloads.
    As for the missing labels, can you make a debug log of opening your engine with VCDS-Mobile?
    VCDS-Mobile: [Options] -> Debug Level = 0027 -> [Submit] -> [Done, Go Back] -> [Select] -> [01 - Engine]
    Let it load up, retrieve faultcodes, then go back and send us the file, it will be called like debuglog-XX.edl
  10. Likes Uwe liked this post
  11. #28
    Dec 2018
    Poland
    Hi. Today I generated debug file and sent it via email to Support at Ross-Tech.com (subject the same as this thread). In vcds-mobile I went into saved files. I see files I saved earlier. On my list 6 logs and 1 debug. Synced with cloud were only 2. One I uploaded today (7.2kB) and took much time. I tried upload debug file (22.4kB) and was uploading very, very slow, I canceled it. In VCDS-Mobile pings to server are ~168ms and "quality poor". I use LTE and sites browsed via smartphone loads normally except vcds-cloud and vcds-mobile.
    I can add also this info. Yesterday I connected in infrastructure mode hex-net via hotspot on android and I went into engine[01] and advanced measuring, without looking into any intermediate places in vcds-mobile. I saw labels the same as you can see in my phoneo from OBD II advances measuring values. I was looking for location 15 and 16 (missfires) and I had to go back, and go into adv meas values again to see 15 and 16 groups (loc.). Summarizing - sometime I see on list with locations a set of labels like 03 fuel system 1/2 status, 04 calculated load value, 05 engine cooland temperature, etc. Normaly in controles->functions->adv meas values I see a list with lables like loc 1.1, loc 1.2, ... loc 15.1,... , 115.1, 115.2, ..., etc. If I know/remember locations numer, I can select it without problem, but if I don't know meaning or don't remember it, then I see labels without readable meaning descriptions.
    Also I have feeling, that something is wrong with displaying measured values if more than 3 selected. Here I can describe easy a problem with showing labels (for some measures show RPM, count, and no label at all in 1st column).
    If you need more informations for investiagtion and don't want write everything on forum (some info or data could be not releveant for other users), then please feel free to write/ask/reply via email.
    This behaviour exists on different browsers (Wp 8.1 IE, Win10 PC IE11 and Edge, Smartphone with android and default web browser (Chrome?)).
  12. #29
    If you see measuring values you suspect are wrong, feel free to make a debug log with level = 001f and send it to us to investigate. If possible, a description of what value is showing and what you think it should be would be helpful.
    I'll look into your first debug log in a bit.
  13. Likes Uwe liked this post
  14. #30
    Alright I reproduced your label issue here. I will try to get you a fix to test sometime next week. If you haven't heard from me by next Wednesday, feel free to bump this tread and make sure I didn't forget.
  15. Likes Uwe, cruzbdg liked this post
