Results 11 to 20 of 40
Thread: VCDS Mobile on Android - missing labels for measuring blocks
    Dec 2018
    Poland
    Laptop connected via wi-fi to Lumia Hotspot:
    Internet works.
    HEX-NET connected via USB cable to Laptop. In PC VCDS->Program Options Port USB selected.
    In VCDS Interface Config on 1st tab I see SSID of my Lumia hotspot. Mode Infrastructure. IP 192.168.137.XXX Security WPA/2 and MAC address. Wi-fi tab shows available networks on which is my Lumia Hotspot and this has blue colour label, so is connected to it.
    VINs stored: Unknown
    When i go to http://<ip>/ I se error message: Cannot connect to site. Error code: INET_E_RESOURCE_NOT_FOUND.
    At home I have router so 2nd test:
    Laptop and Hex-Net connected to home infrastrukture/router.
    IP: 192.168.1.X
    VINs Stored shows correct number.
    VCDS-Mobile opens.
    So I see a problem but I do not know if this is my WP 8.1 hotspot problem or some other problem. From Laptop I can use Internet without problem being connected to Lumia hotspot.
    New Question is: How to open VCDS-Mobile when Hex-net is in AP mode without VCDS-Mobile application installed. How to get address.
  2. #12
    Dec 2018
    Poland
    Auto-scan from PC version:
    Chassis Type: 13-VW36 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 77
    VIN: WVWZZZ13ZAVXXXXXX   Mileage: 169440km-105285miles
    Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
       Part No SW: 03C 906 027 BS    HW: 03C 907 309 B
       Component: MED17.5.5       G   1676
       Revision: LAH07---    Serial number:
       Coding: 0000072
       Shop #: WSC 27333 001 1048576
       VCID: 73A631BD12F3ABD2D6-8026
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 743B60F5492500FE2E1006EC921C0040340000
       Shop #: WSC 00020 790 12345
       VCID: 78BC0691CB95C88AE3-802C
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00020 999 00000
       VCID: 7DB21785ECB7EDA2B0-8028
       Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
       Component: BCM PQ35 H    011 0028
       Revision: BE011001
       Coding: 48100A389025E300C0080080100049E647850A88734D8960648000000040
       VCID: 3620C8A98101FEFA31-8062
       Subsystem 1 - Part No: 1K8 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 27110  22  0614
       Coding: 009795
       Subsystem 2 - Part No: 1K8 951 171
       Subsystem 3 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
    01134 - Alarm Horn (H12)
                000 -  -  - Intermittent
                        Fault Frequency: 15
                        Reset counter: 131
                        Mileage: 168985 km
                        Date: 2013.06.03
                        Time: 19:08:23
                            Term 15 Off
                        Voltage: 12.80 V
    Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
       Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
       Component: PARKHILFE     005 1706
       Revision: 00005000    Serial number: 0 263 004 388
       Coding: 300001
       VCID: 3A38DC99B5191A9AD5-806E
       Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
       Component: 0G AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 003D1D021MBN
       Coding: 0012359
       Shop #: WSC 00020 790 00000
       VCID: 6FAE3DCD7EDB8F3232-803A
       Subsystem 1 - Serial number: 6332MSME4F042B53F
       Subsystem 2 - Serial number: 6342MSME4E632970H
       Subsystem 3 - Serial number: 6352QSME274B1816H
       Subsystem 4 - Serial number: 6362QSME4F4A0426N
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20150629201004
       Coding: 1082140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 024864799549925ACD-8056
       Serial number: 0008541
       Coding: 820000
       Part No SW: 1K8 920 871 B    HW: 1K8 920 871 B
       Component: KOMBI         H05 0305
       Coding: 170F00
       Shop #: WSC 00020 999 12345
       VCID: 312AFBB5606FD9C264-8064
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0233
       Revision:   H16       Serial number: 4520K102030947
       Coding: E9A11F06400602004000
       VCID: 699A53D5403F61026C-803C
       Component: IMMO          H05 0305
       VCID: 6A982CD98D396A1A65-803E
    Address 37: Navigation
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2123
       Coding: 0016437
       VCID: 393AC395701F1182DC-806C
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 312AFBB5A86FD9C264-8064
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0016436
       VCID: 3A38DC9975191A9AD5-806E
       Part No: 8P0 907 357 K
       Coding: 0000015
       VCID: 42C8A4791DC9525A8D-8016
    Address 56: Radio
    Address 77: Telephone
    End----------(Elapsed Time: 01:13, VBatt start/end: 14.6V/14.6V)-----------
  3. #13
    Jun 2014
    Swansea, UK
    Quote Originally Posted by cruzbdg View Post
    When in AP mode the IP is always the same - 192.168.0.1
    (or possibly 192.168.1.1 - I forget which, but if you connect to the network in android then check the WiFi settings for that network, the Gateway IP is the one to connect to)
  4. Likes Uwe liked this post
  5. #14
    Isn't there something on your phone that can show you what devices are connected to its hotspot?
    I honestly don't know; I've never used a Windows phone, but I'm confident there are network scanner apps for Windows phones that can give you a list of IP addresses on the current network.
  6. #15
    Quote Originally Posted by Mike@Gendan View Post
    Bah, you're right. I missed the fact that this question was with regard to AP mode. If the HEX-NET is in AP mode and the phone is connected to the HEX-NET's AP, then yes, the HEX-NET's IP is always 192.168.0.1.
    Now if the HEX-NET is in infrastructure mode, and is connecting to the AP created by the phone's hotspot, then things are more complicated, and without an app, one needs to know the IP address that the HEX-NET has gotten from the phone via DHCP somehow.
  7. #16
    Not sure how reliable this source is, but according to this: https://ugetfix.com/ask/how-to-fix-i...on-windows-10/
    Error code: INET_E_RESOURCE_NOT_FOUND might be a bug with Windows Creators Update. Maybe try the TCP fast open fix or try a different web browser.
  8. Likes Uwe liked this post
  9. #17
    Dec 2018
    Poland
    I can check IP, Gateway, Mask on Lumia when I am connected to some Wi-Fi, but when I share connection (tehterning) I only see a number of connected devices which means I don't know IP address without using Laptop and checking in VCDS Interface Config Editor. The number of connected devices is increased. WP is dying OS, but I like it very much especially Metro UI so It would be good for me to be able to use VCDS Mobile on WP OS too .
    Ok I will check if works VCDS Mobile on Windows Phone when interface is in AP mode using this address 192.168.0.1.
    @Shaun - I would not apply quick fix oneself. On the same browser I was able to open VCDS Mobile with 1 difference - > being connected to different AP,Network (Lumia Tethering vs Home Router with AP).
  10. #18
    It sounds to me like it is a bug with the browser related to trying to do a DNS resolve on the local IP address, which doesn't work when the device is on a "captive portal" type isolated network. I would try a different browser, like chrome or firefox.
  11. #19
    Aug 2018
    I have given away my Lumia a while ago, so I can't check. But since I randomly have a similar problem, I'd say the phone's tethering WiFi hotspot uses 5 GHz, or 2.4 GHz and channels 12 or 13. In each case, the HexNet will not be able to connect to this WiFi network. Make sure the hotspot is using 2.4 GHz and disable/enable the hotspot a couple of times so that it chooses a channel in the 1-11 range.
    I'd love to learn that there will be a new HexNet generation with 5 GHz WiFi (or Bluetooth ) support, but I doubt that apart from enthusiasts there is much of a professional demand for it.
  12. Likes PetrolDave liked this post
  13. #20
    Dec 2018
    Poland
    Hi. I have Android smartfone for a few days. THis smartfone is LG K4 LTE and has Android 5.1.1 with Kernell 3.10.65, compilation number LMY47V. I enabled hotspot and connected to it HEX-Net and Windows 10 laptop. I have access to Internet from both devices (smartphone and laptop). I did autoscan from VCDS mobile on smartphone and on laptop on Golf 5.
    Using tethering on lumia I was able to use cloud functions on vcds mobile on connected android smartphone, but on Android smartphone with enabled hotspot I am not able to connect to your server. VCDS Cloud time out. Autoscan stored but I don't see log file in Explorer and I don't see this scan on VCDS Cloud. Also once time I saw labels in advanced measuring values on android, but go back and again go into adv meas values and I don't see labels - laebl file not found and each item on list has locXX, but... in OBD II - read data I see labels.
    On WIndows 10 vcds mobile I also didn't see labels in adv meas values. I did screen shots. In free time I will upload to OneDrive and share link.
    So don't focus on Lumia. Scirocco 5F vs Golf 5 01(engine). Lumia vs old android. The same issues. Also when I was driving and watching meas values on VCDS PC for group 15 and 16 in engine module via wi-fi in infrastructure mode I got errors for all watching groups. Probably lost connection with interface. Go back, and read again fixes it.
