VCDS Mobile on Android - missing labels for measuring blocks
   #21
Moving this to HEX-NET Support.
Shaun
The DTC log I see from you for the 5f appears to be missing the ASAM id, which will make anything rod-related fail.
Is this car stock? Can you try posting the whole VCDS-Mobile autoscan so we can get a better sense of what is and isn't working. If you can't get it to upload to the cloud, you can also right click the file and "save as" from a PC and email to us, or you can copy-paste the text here in between [CODE] [/CODE] tags.
cruzbdg
C?ID=327228
Hi Shaun,
If you ask about VW Scirocco and 5F - Scirocco is generally stock except [5f, tempomat, navi and TPMS, RVC]. I had stock RCD310 on [56 radio]. Gateway doesn't have on list 5F. Gateway is stock. 5F (Discover Media) is added (retrofit).
Here are today photos from Golf V:
https://1drv.ms/f/s!AuwAeVEhNnQxgbQhw8e7OwlRXbF2vA
Missing labels are not related to stock or not stock modules I think. Both cars have stock engines. Golf has stock everything except tempomat and TPMS.
Golf V:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ9WXXXXXX   Mileage: 91570km-56898miles
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 AS    HW: 03C 906 024 AS
   Component:  MARELLI 4HV      G 2495
   Revision: --H12---    Serial number: VWX7Z0H83NI92W
   Coding: 0004071
   Shop #: WSC 00000 028 00001
   VCID: EFAEBDCDFEDB0F32B4-80BA
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0000257
   VCID: F6A088A981813EFA77-80A2
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: EC94AAC1CFCDF42A91-80B8
   Revision: 00H54000    Serial number: 00000008688928
   Coding: 758D0F2700041500471400001400000000297F074600010C000000000000
   VCID: B32671BDD2736BD290-80E6
   Component: Wischer 240908 021  0501
   Coding: 00038805
   Shop #: WSC 01357
   Component: RLS     021008 054  0402
   Coding: 00209069
   Shop #: WSC 01357
01259 - Fuel Pump Relay (J17)
                    Fault Status: 00101001
                    Reset counter: 85
                    Mileage: 80751 km
                    Voltage: 12.50 V
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD27RJU5
   Coding: 0013111
   VCID: BD325785E437ADA276-80E8
   Subsystem 1 - Serial number: 6332MSME423274171
   Subsystem 2 - Serial number: 6342MSME4035643DA
   Subsystem 3 - Serial number: 6352QSME4E0D0D0EZ
   Subsystem 4 - Serial number: 6362QSME2107141C6
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           757 0101
   Coding: 0000042
   VCID: FF4E6D8DAEBB7FB224-80AA
   Part No SW: 1K0 920 864     HW: 1K0 920 864
   Component: KOMBIINSTRUMENT VDD 1212
   Revision: V0002000    Serial number: VWX7Z0H83NI92W
   Coding: 0003103
   Shop #: WSC 00100 259 81089
   VCID: E99AD3D5C03FE102EA-80BC
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 040908F2001950
   Coding: E9807F060002020002
   VCID: B5224FA5DC0775E2BE-80E0
   Component: IMMO            VDD 1212
   Component: Tuer-SG         006 1219
   Coding: 0000180
   VCID: B83C4691CB15888AA5-80EC
00096 - Drivers Door Central Locking (Safe) Motor (V161)
            008 - Implausible Signal
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.068 H08 1901
   Coding: 809002005103087F2D04840560084F03E0FCA0
   VCID: 8346E17DC2531B5240-80D6
   Coding: 0000180
   VCID: B93A4395F01F91825A-80EC
   Part No SW: 1K0 035 156 A    HW: 1K0 035 156 A
   Component: Radio         018 0040
   Revision: R0018000    Serial number: VWZAZ1H7058144
   Coding: 0000020002
   VCID: A10A8BF5B88FE94272-80F4
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End----------(Elapsed Time: 01:25, VBatt start/end: 14.3V/14.3V)-----------
VCDS-Mobile autoscan Golf V:
VCDS-Mobile
Auto-Scan
Finished
Address 01: Engine	Labels: 03-01.clb
Part No SW: 03C 906 024 AS	HW: 03C906024AS
Revision: --H12---	Serial Number: VWX7Z0H83NI92W
Coding: 0004071
VCID: 6FA140BF05AF1CC9A578DE4-803A
No fault codes found.
Address 03: ABS Brakes	Labels: 1K-03.clb
Part No SW: 1K0 907 379 AF	HW: 1K0907379AF
Revision: 00H32001
Coding: 0000257
VCID: 76AF75DB7AF52D0166BE038-8023
Part No SW: 1K0 907 044 DD	HW: 1K0907044DD
Revision: 00130023	Serial Number: 00000000000000
VCID: 6C9B57B334B9E7D1801AB10-8039
Address 09: Cent. Elect.	Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E	HW: 3C8937049E
Revision: 00H54000	Serial Number: 00000008688928
Coding: 758D0F2700041500471400001400000000297F074600010C00 0000000000
VCID: 33298CCF290778298120224-8066
Subsystem 1 -  Part No SW: 1K1-955-119-E	Labels: 1Kx-955-119.clb
Coding: 0038805
Subsystem 2 -  Part No SW: 1K0-955-559-AH	Labels: 1K0-955-559-AG.clb
Coding: 0209069
  Reset Counter: 89
  Mileage: 91622 km
  : OFF
  Voltage: 12.50 V
  : OFF
  : ON
  : OFF
  : OFF
  : OFF
Part No SW: 1K0 909 605 T	HW: 1K0909605T
Revision: 05020000	Serial Number: 0038PD27RJU5
Coding: 0013111
VCID: 3D3DAAF71F43BE596744B4C-8068
Subsystem 1 -  Serial Number: 6332MSME423274171
Subsystem 2 -  Serial Number: 6342MSME4035643DA
Subsystem 3 -  Serial Number: 6352QSME4E0D0D0EZ
Subsystem 4 -  Serial Number: 6362QSME2107141C6
Part No SW: 1K0 953 549 BN	HW: 1K0953549BN
Coding: 0000042
VCID: 7F4190FF55CF6C4935D86E4-802A
Part No SW: 1K0 920 864	HW: 1K0920864
Revision: V0002000	Serial Number: VWX7Z0H83NI92W
Coding: 0003103
VCID: E995AEA7BB4B72F97B3C10C-80BC
Address 19: CAN Gateway	Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q	HW: 1K0907951
Revision:  H07 01	Serial Number: 040908F2001950
VCID: 352DB2D727736619AF345CC-8060
Address 42: Door Elect, Driver	Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M	HW: 1K0959701M
Coding: 0000180
VCID: 3833BBE330619B71B4127D0-806D
Address 44: Steering Assist	Labels: 1Kx-909-14x-44.clb
Part No SW: 1K1 909 144 M
Address 46: Central Conv.	Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT	HW: 1K0959433BT
Revision: 00020000	Serial Number: 00000000000000
VCID: 83499C0FB92788A9D100B24-80D6
Address 52: Door Elect, Pass.	Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M	HW: 1K0959702M
Coding: 0000180
VCID: 3935BEE70B6B82794B1C60C-806C
Address 56: Radio  (J503)	Labels: 5M0-035-1xx-56.clb
Revision: R0018000
Coding: 0000020002
VCID: 2105768783FB7AB9636C78C-8074
Address 62: Door, Rear Left	Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K	HW: 1K0959703K
Coding: 0000144
Address 72: Door, Rear Right	Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K	HW: 1K0959704K
Coding: 0000144
End--(Elapsed Time: 01:52, VBatt start/end: 14.4/14.4 Vign: 14.4)-
Updated: I ran VCDS-Mobile on Edge browser on Windows 10 on laptop. Did autoscan and clicked save button. The popup displayed - it shows path but the file doesn't exist on VCDS-Cloud and in log directory in Ross-tech installation directory so where is this file?
s!AuwAeVEhNnQxgbQqndFrkQELMsbfHQ
https://1drv.ms/i/s!AuwAeVEhNnQxgbQqndFrkQELMsbfHQ
Shaun
Measuring blocks with VCDS should definitely work, so lets start with that.
Are the errors that you see there reproducible? If so, do you notice any event that seems to trigger it, like the wifi dropping? If you have a way to reproduce this, you can try making debug logs in VCDS by going [Options] -> Debug level = 1028 [Save] and then do whatever you need to reproduce. This will make a log in the VCDS\Debug folder. Also pay attention to the LEDs on the interface when this happens. Does it look like the interface reboots?
cruzbdg
C?ID=327228
Error in measuring blocks occurred once and on Golf so it will be hard to check if interface resets. The main problem for me is missing labels in vcds-mobile and problematic configuration HUD controls in vcds-mobile and connection to vcds cloud from vcds-mobile. Slow download data using vcds-mobile via 4G/LTE and how where to find saved logs on smartphone or laptop when saved from vcds-mobile if Cloud functionality doesn't work (vcds mobiel can't connect to vcds cloud.
I've updated my above post. Added vcds mobile scan and photo with path where shoudl be a file saved.
   #26
Access VCDS-Mobile with the device and browser of your choice. Click [View Saved Files]. Click on a file to open it; your browser will display it (they're all just plain text). Use your browser's SAVE AS (or equivalent functionality) to save the file to the local device the browser is running on.
Shaun
If the browser didn't ask you where to save it, it is probably set to save things in a default "Downloads" directory. It will be where ever your browser normally saves downloads.
As for the missing labels, can you make a debug log of opening your engine with VCDS-Mobile?
VCDS-Mobile: [Options] -> Debug Level = 0027 -> [Submit] -> [Done, Go Back] -> [Select] -> [01 - Engine]
Let it load up, retrieve faultcodes, then go back and send us the file, it will be called like debuglog-XX.edl
cruzbdg
C?ID=327228
Hi. Today I generated debug file and sent it via email to Support at Ross-Tech.com (subject the same as this thread). In vcds-mobile I went into saved files. I see files I saved earlier. On my list 6 logs and 1 debug. Synced with cloud were only 2. One I uploaded today (7.2kB) and took much time. I tried upload debug file (22.4kB) and was uploading very, very slow, I canceled it. In VCDS-Mobile pings to server are ~168ms and "quality poor". I use LTE and sites browsed via smartphone loads normally except vcds-cloud and vcds-mobile.
I can add also this info. Yesterday I connected in infrastructure mode hex-net via hotspot on android and I went into engine[01] and advanced measuring, without looking into any intermediate places in vcds-mobile. I saw labels the same as you can see in my phoneo from OBD II advances measuring values. I was looking for location 15 and 16 (missfires) and I had to go back, and go into adv meas values again to see 15 and 16 groups (loc.). Summarizing - sometime I see on list with locations a set of labels like 03 fuel system 1/2 status, 04 calculated load value, 05 engine cooland temperature, etc. Normaly in controles->functions->adv meas values I see a list with lables like loc 1.1, loc 1.2, ... loc 15.1,... , 115.1, 115.2, ..., etc. If I know/remember locations numer, I can select it without problem, but if I don't know meaning or don't remember it, then I see labels without readable meaning descriptions.
Also I have feeling, that something is wrong with displaying measured values if more than 3 selected. Here I can describe easy a problem with showing labels (for some measures show RPM, count, and no label at all in 1st column).
If you need more informations for investiagtion and don't want write everything on forum (some info or data could be not releveant for other users), then please feel free to write/ask/reply via email.
This behaviour exists on different browsers (Wp 8.1 IE, Win10 PC IE11 and Edge, Smartphone with android and default web browser (Chrome?)).
   #29
Shaun
If you see measuring values you suspect are wrong, feel free to make a debug log with level = 001f and send it to us to investigate. If possible, a description of what value is showing and what you think it should be would be helpful.
I'll look into your first debug log in a bit.
Shaun
Alright I reproduced your label issue here. I will try to get you a fix to test sometime next week. If you haven't heard from me by next Wednesday, feel free to bump this tread and make sure I didn't forget.
   #31
Shaun
cruzbdg I put your HEX-NET on the alpha channel. If you check with VCIConfig, you should see a couple of updates that will bring you up to CB V0.4501
Please give that a try and then see if it finds more labels in VCDS-Mobile.
cruzbdg
C?ID=327228
Hi. I could give reply after some time, beacuse tomorrow I will give a car to workshop, so I will not be able to test on car. Earlier I will check if this CB version is available for me.
   #33
Shaun
You should do the updates now even if you don't have the car at the moment, because access to the alpha updates will expire eventually.
   #34
cruzbdg
C?ID=327228
Hi. Ok, I downloaded updates. Detected FW 0.255 and CB 0.4501
I have some comments to Information displayed in VCDS Interface Config.
  1. Something is wrong with radio buttons on Advanced tab. I have Beta channel selected but NO DOT (empty white circle) is displayed for both radios so I can't see what I have set. I expect black dot (checked) one radio by default or selected by me.
  2. Please take a look at screenshot https://1drv.ms/u/s!AuwAeVEhNnQxgbQwV6NX3af8lkCPkg .
    I see some things to correct. First - label above progress bar says "Checking rods…" but progress is full and on the right list panel the latest status is "Update completed successfully". If progress bar is full, then I would expect the same or similar sentence there. Second - what is "Wifi status:0" at the bottom status bar? Maybe the status could be more self-explanatory. Third - right list shows steps but could be more precise. I know that 2 updates were ready to download (CB and FW), but during Update process, looking at right list, I don't know which step is for what kind of update. More details I saw in label above progress bar, but on right list I think it will be better to display for example "Preparing Update - CB" or "Preparing Update - FW", generally "Preparing Update - <whichPart>". 4th - remove the char | from the last line when done. 5th - We have button "Check for Updates" and button "Download Update". In my opinion, it could be "Check for Update" and "Download Update" or "Check for Updates" and "Download Updates".
   #35
Shaun
Don't mess with the update channel buttons right now. I've set you to a not publicly accessible alpha channel (public channels are only beta and release). If you change to one of those with the utility it will override my changes and take you off of the alpha channel.
   #36
cruzbdg
C?ID=327228
I have set some time ago radio button but I don't remember on which value. Yesterday I didn't touch radio buttons and any other configuration so I think I have downloaded your changes.
   #37
Shaun
Yes you look fine.
   #38
cruzbdg
C?ID=327228
Hi. I've checked. Now labels in advanced measuring values are displayed :).
Will this post delivered to official download?
I saw next problem with labels in address [10] when use Adaptation or Coding 07 via cloud functions. On PC Version is OK.
cruzbdg
C?ID=327228
Will your change added to official release? When can I update interface to get official version of this fix?
   #40
Shaun
Yes, eventually. An even more recent 0.4502 is on the alpha and beta channel now. But I can't give you an exact time frame when it will be on release, it will be when we're satisfied that it is thoroughly tested.
