Results 1 to 4 of 4
Thread: Passat CC Headlight adaption help
    Morning all,
    Did a service on this car and when I did a scan I found the message in headlight controller (55).
    Car must have been used on other side of road, so the customer asked me to set it back for UK driving.
    When I went in to adapt, I entered the security number but got message that it didn't accept it (or something relation to seed key!) sorry I should have taken a screen shot..
    Here is the scan.
    Some advice on this would be appreciated. In the meantime I'll ask customer to go through his handbook to see if there is an option somewere for him to do it manually.
    Monday,14,January,2019,09:33:34:02944
    VCDS Version: 18.9.0.1 (x64)  HEX-NET CB: 0.4441.4
    VIN: WVWZZZ3CZFE802744   License Plate: N444SBY
    Mileage: 173920km-108068mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 55 56
              61 62 72
    VIN: WVWZZZ3CZFE802744   Mileage: 173920km-108068miles
       Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9979
       Revision: 41H28---    Serial number: VWZCZ000000000
       Coding: 00190012040501080000
       Shop #: WSC 42628 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
       ROD: EV_ECM20TDI01103L906018PR.rod
       VCID: 895AC0E52832420201-80DC
       Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
       Component: J104   C2 450M VD38 0040
       Revision: --H07---    Serial number: 00000008211971
       Coding: 0004016
       Shop #: WSC 00015 115 00170
       VCID: F9BAB025B0D2528211-80AC
    02214 - Tire Pressure Warning
                        Reset counter: 84
                        Mileage: 172185 km
                        Date: 2018.12.15
                        Time: 09:49:56
                        Speed: 113.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.75 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
       Part No SW: 3AA 907 044 BP    HW: 3AA 907 044 BP
       Component: Climatronic   H05 0607
       Revision: 00001K02
       Coding: 071400C849
       Shop #: WSC 00015 115 00001
       VCID: FF4E5E3D66F67CB22F-80AA
       Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
       Component: BCM PQ47 H++  422 0475
       Revision: BD422001
       Coding: 000800000000000000880080940028642355028860220120E484C72000C1
       Shop #: WSC 05311 000 00001
       VCID: C9DA00E560B20202C1-809C
       Subsystem 1 - Part No SW: 3C8 955 119 J    HW: 3C8 955 119 J
       Component: WWS464 060314  024 0644
       Serial number: 14030307010560
       Coding: 044D9D
       Component: RLFS  024 0042
       Serial number: Y14M06D12H05M29S43S9
       Coding: 0228DD
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__70J VW10 HI   2518
       Revision: 28020000    Serial number: 003L7PBPXL1I
       Coding: 0012362
       VCID: FCB4A931BFE067AA0A-80A8
       Subsystem 1 - Serial number: 6332MTS634761424
       Subsystem 2 - Serial number: 6342MTS607091464
       Subsystem 3 - Serial number: 6351HTS6GA8LSCKR
       Subsystem 4 - Serial number: 6361HTS6RD0LSCKJ
       Part No SW: 3C5 953 501 CM    HW: 5K0 953 569 AR
       Revision: FF010042    Serial number: 20140531200883
       Coding: 0182070000
       VCID: F2A8870925A421DA50-80A6
       Coding: E20000
       Part No SW: 3C8 920 971 G    HW: 3C8 920 971 G
       Component: KOMBI         H03 0905
       Coding: 440F01
       Shop #: WSC 05314 115 00001
       VCID: B12A4805E0225AC2E9-80E4
       Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1653
       Revision:   H56       Serial number: 260514F2000271
       Coding: 469007
       Shop #: WSC 05314 000 00001
       VCID: 814AD8C518020A4259-80D4
       Part No SW: 3AA 959 433 E    HW: 3AA 959 433 E
       Component:    IMMO         048 0407
       Revision: 00048000    Serial number: VWZCZ000000000
       VCID: BB366A2DFA6EA09243-80EE
       Revision: A1001003    Serial number: 7666294491
       Coding: 020100
       VCID: AB165A6DCA0E3012D3-80FE
       Part No SW: 3C8 035 279 S    HW: 3C8 035 279 S
       Component: RNS315-EU   H80 0500
       Serial number: VWZAZ2P0323007
       Coding: 0400040104000F0000019002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: BB366A2D326EA09243-80EE
       Component: EUR_W_V6  0062
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0556
       Revision: 12110009    Serial number: 0008652649
       Coding: 0202B7
       Shop #: WSC 05311 115 00001
       VCID: ED9294753C9AFE228D-80B8
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  005 0501
       Serial number: 00000004001973
       Coding: 010090
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 207    3501
       Revision: 00H22000
       VCID: B93A7025F052928251-80EC
       Component:    KSG PQ47 ELV 048 0700
       Coding: 01910A0001860E763604941570085FCE105C04
       Component: EZE_2         H56 1653
       Coding: 00000008
       VCID: EFAE8E7D3E960C32BF-80BA
       Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0004
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0556
       Revision: 14110009    Serial number: 0008662341
       Coding: 0202B6
       ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
       VCID: EE909379319C053AB4-80BA
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  005 0501
       Serial number: 00000004015645
       Coding: 010090
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000077432
       Coding: 0022167
       VCID: B83C7521CB588B8AAE-80EC
    Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
       Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
       Component: LWR-ECU       005 0030
       Coding: 078E000001000000
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
       ROD: EV_HeadlRegulVWLWRCC.rod
       VCID: B93A70253852928251-80EC
    5275648 - Left/Right Driving Switch-Over Active
              C1080 00 [009] -  -
                        Reset counter: 252
                        Mileage: 151695 km
                        Date: 2017.07.20
                        Time: 06:41:20
       Component: Batt.regelung H56 1653
       Coding: 030F1859
       VCID: F1AA880528A21AC2A9-80A4
       Component: J367-BDM  H07 0180
       Serial number: 41154432001491343555
    End----------(Elapsed Time: 01:33, VBatt start/end: 14.8V/14.8V)-----------
    Is IDE03787-IDE03632 currently set to 'Active' or 'Not Active'?
    I doubt that channel would need a Security Access to change.
    It must be set to 'Active' (but can get car back in to check) and when I tried to change it, it did require security access. So choose the one VCDS showed when I moved mouse over to box for entering the security code.
    Just an update, the customer found a way manually throught the settings in car/lighting/
  5. Likes Uwe, DrPeter liked this post
