Results 1 to 10 of 10
Thread: OT: MK5 cluster hex addresses
    Nov 2014
    New Zealand
    Off Topic - not VCDS related at all, but I know some of you guys are as weird as meeeee! so I've posted this in general repair :
    Uwe: feel free to move, REmove etc, if you see fit
    Does anybody have the hex address map for the EEPROM binary (.bin) file from a MK5 instrument cluster of any kind? .OLS or .KP, map pack, etc?
    I'm specifically looking for the tables to adjust the speedo reading and the built in error; and the Distance impulse if required. My actual cluster is a 1K6 920 862 F
    I have slightly larger tyres than stock on the R32ran and have adjusted the impulse counter to the closest figure, but would like to make it accurate. Then I'd like to alter the speedometer "calibration" to a consistant and suitable "error" margin.
    Any help greatly appreciated... I got a speed camera ticket in the mail today... doing 85km/h in a 80km/h zone .... on Christmas Morning
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
    Jun 2014
    Newcastle, England
    If you're requesting a .ols file; I'm presuming you have access to WinOLS. I thought it had an 'Auto Map Search' function thingy? from screenshots I've seen (don't have WinOLS myself) it will even show a little block bar graph at the end of each page of the EEPROM if it thinks it's a progressive map.
    Nov 2014
    New Zealand
    Thanks - yeah... It doesn't find anything. I just have the demo, because I don't actully "tune" anything - I like it to be proper OEM-like... other than VW never made a fast enough Touran :-)
    The tables are quite "simple", but appear to have revesed bytes and don't stand out as tables. I'm looking through manully, but it's not something I'm familiar with. I was hoping I could compare mine with a known definition and work backwards a bit. It'll be a bit of a fun nerd-project , anyway :-)
    I'll keep playing though
    Thanks!!!
    Allan
    The R32ran Thread
    Quote Originally Posted by NZDubNurd View Post
    Got a yellow vest?
    https://www.bbc.com/news/world-europe-46822472
    Or an old tire and some fuel?
    http://english.controleradar.org/burning-gatso.php
    PS: Moving this to the Bar.
  5. Likes NZDubNurd liked this post
    Nov 2014
    New Zealand
    Got a yellow vest?
    Not yet...
    Allan
    The R32ran Thread
  7. Likes Uwe, PetrolDave, Jack@European_Parts liked this post
    Jun 2014
    Poland
    you can change impulse over coding
    when you not have enough value from coding, you can simple look what value is change in EPP and adjust itself .
    because most (it not all) Micronas RED display cluster are this same, you will not find a different cluster dump to compare
    OLS is file made by guys .
    for cluster is software VDO editor, also made by one guy, however is supporting mostly NEC cluster , you can import "curve speed" and adjust itself
    He made it from research and practices
  9. Likes jyoung8607, Jack@European_Parts liked this post
  10. #7
    Nov 2014
    New Zealand
    Quote Originally Posted by Spacewalker View Post
    Thanks Spacewalker :-)
    I adjusted the impulse to the best match, but it still reads slightly high. I'll change it, and compare the file ;-) I hadn't thought of that!!! Thank you!
    I'd like to correct the pulse, but also correct the needle movement - they are not very accurate!, especially as my cluster is the R32 version, the scale changes at 80km/h... so it has ... 50,60,70,80,100,120 and the difference from 80 to 85 is about the width of the needle!
    I can read the digital speed on the climate control, but it's a pain, and I can't see it if I'm wearing my polarised sunglasses!
    I saw the NEC cluster software - It looks great! Shame it doesn't work on mine :-( He's obviously very clever!
    Thanks for your help!
    Allan
    The R32ran Thread
  11. Likes jyoung8607, Jack@European_Parts liked this post
  12. #8
    Jun 2014
    Poland
    so install NEC cluster in your car and you can edit
    You expecting a help for 15 years old item
    old item just passing away.....
  13. Likes NZDubNurd, Jack@European_Parts liked this post
  14. #9
    Nov 2014
    New Zealand
    Haha! I should... but I like have Immo4A and MK60 without the silly VIN coding and crypto immo etc
    That's my excuse anyway
    Allan
    The R32ran Thread
  15. Likes Uwe liked this post
  16. #10
    Jun 2014
    Poland
    silly VIN...... wake up, is 2019 , not 2012 when that cluster become popular without proper coding tool
    and next , your ABS is MK60-AT because 4WD , not Mk60 (hope you know the different) .......so is fully support with NEC cluster , this same like your IMMO 4A ... if you know that of course
    I recommend you to talk with someone who know more than you about IMMo , cluster etc.
  17. Likes NZDubNurd, Jack@European_Parts liked this post
