Results 1 to 8 of 8
Thread: 2014 Audi C7 S6 Fault ACC - 8B-Adaptive Cruise 2
    Mar 2017
    I have occasionally been getting the ACC and Brake Guard Unavailable message when starting the car. It usually goes away if I turn off and start again.
    No luck resetting today. I ran a scan and tried to clear all faults. It immediately throws a fault again. Car has not been in any accident and bumper has not been moved.
    Any ideas?
    8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
    Monday,14,January,2019,15:32:29:57077
    VCDS Version: 18.9.0.2 (x64)
    VIN: WAUF2AFC2EN102192   License Plate:
    Mileage: 100901km-62696mi   Repair Order:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
              46 47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
    VIN: WAUF2AFC2EN102192   Mileage: 100901km-62696miles
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 014 E    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0006
       Revision: NCH62---
       Coding: 0A2500326546000E1000
       Shop #: WSC 60542 002 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906014E 001004
       ROD: EV_ECM40TFS0114G0906014E.rod
       VCID: 2447AA2D2F050A6A91-8070
    Readiness: 0110 0000
       Part No SW: 4G9 927 156 C    HW: 0B5 927 156 K
       Component: 0B5 40TFSINAR H02 0002
       Revision: --H02---
       Coding: 000001
       ROD: EV_TCMDL501021.rod
       VCID: 35616769949F83E236-8060
       Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
       Coding: 65B65701A66DEA804B00
       VCID: 3B757151B2BB5592C0-806E
    Address 05: Acc/Start Auth.        Labels: 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 ER    HW: 4H0 907 064 ER
       Component: BCM2 2.0      H36 0521
       Coding: 0D882046000000000000
       VCID: 7DF1BF49E42F9BA2BE-8028
       Subsystem 2 - Part No: 4H0 905 852 C
       Component: J764 ELV MLB
    No Faults Found
       Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
       Component: KLIMA 4 ZONEN H14 0093
       Serial number: 04121300041899
       Coding: 688120B84D
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: 6ADB84158DA11C1A6B-803E
       Revision: 11012002    Serial number: 00000001669835
       Coding: 09072091013C8FE2A90008C7A0003800CF9CD208A20802218001085C7B00
       VCID: 6FED9501BE43F9323C-803A
       Component: WWS57X 131203  H36 0080
       Serial number:         131205122131
       Coding: 0045F7
       Serial number: 22061213
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 05 12 2013  00000326
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R9BBV03
       Serial number: 00000005121300010631
       Coding: 110000
       Serial number: 00000010121300010765
       Coding: 110000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA106973000005335597
       Coding: 020300
       Serial number: 45294FD6000000000001
       Revision: 11001001    Serial number: 61061335100727
       Coding: A8E90A
       VCID: 71E99379A077EFC22A-8024
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Coding: 7601010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 285FBE1D532DEE0ABD-807C
    7 Faults Found:
    31488 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 110
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:04
                        Control Module temperature: 12 °C
                        Voltage terminal 15: 14.058 V
                        Velocity_vehicle_reference: -0.01 m/s
    90880 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 110
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:02
                        Control Module temperature: 11 °C
                        Voltage terminal 15: 12.737 V
    32000 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 110
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:02
    77824 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 110
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:02
    91392 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 110
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:04
    78592 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 110
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:04
    84224 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 11
                        Reset counter: 111
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:10
                        Voltage terminal 15: 13.997 V
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H33 0033
       Revision: --------    Serial number: 003D8003TBP6
       Coding: 303234373131303030324A55304C34473053
       VCID: 336559719AEB9DD218-8066
       Serial number: 6940000Y13000108PD0I
       Serial number: 3575HRB401250L5CCOJ8
       Serial number: 3585HRB401650L5C4117
       Serial number: 3515JRB400Q50QDIL14H
       Serial number: 3525JRB400G50PGAT14A
       Serial number: 3554VRB400850R5KM8MZ
       Serial number: 3564VRB401G50QLSE0RE
       Revision: --------    Serial number: 90372MLB0003L
       Coding: 0004FC
       VCID: 387F6E5D8B8D7E8A2D-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 06 07 2013  11295807
       Part No SW: 4G0 920 982 A    HW: 4G0 920 982 A
       Component: TBenUsaAccNv  H58 0621
       Revision: 29460235    Serial number: 658031213596018
       Coding: 03CF09059F51D705020200
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K.rod
       VCID: 2A5B44154D21DC1AAB-807E
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001204039
       Coding: 00E1034800
       VCID: 72EB9C75A571D4DAD3-8026
       Serial number: 3250152003
    6654 - Automatic distance regulation 2
              U1071 00 [009] - No communication
                        Reset counter: 110
                        Mileage: 99900 km
                        Date: 2018.12.24
                        Time: 17:39:01
                        Voltage terminal 30: 11.9 V
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 18 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    12290 - Quiescent Current
              U1406 00 [008] - Too High
                        Fault Frequency: 92
                        Reset counter: 148
                        Mileage: 96809 km
                        Date: 2018.10.01
                        Time: 15:58:55
                        Voltage terminal 30: 12.6 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 32 °C
                        System status: LIN_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
                        Fault Frequency: 72
                        Reset counter: 148
                        Mileage: 96839 km
                        Date: 2018.10.04
                        Time: 00:46:28
                        Voltage terminal 30: 12.3 V
                        Control Module temperature: 26 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0013
       Serial number: 000712130001281
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       VCID: 275DBD215E33E172B4-8072
       Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
       Component: KLIMA FOND    H08 0093
       Serial number: 03121300041361
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: 3A7B7455BD816C9ADB-806E
       Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H18 0782
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E53480571C9B03A77-807A
       Revision: AA000000    Serial number: 00000083614522
       Coding: 00581B0000002001000001010101102030303232203232
       VCID: 77FDAD61C613B1F2E4-8022
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7E00SJ2L
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 377D6D618E9371F224-8062
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH03 0060
       Revision: 00H03000    Serial number: 6PZ 010 287-03
       VCID: 306F567DA3FDA6CA65-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H03 0060
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F13.12.1300H03000AMS16087˙
       Subsystem 4 - Serial number: S16087˙
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F17005E00628002000013
       VCID: 458117A9CC7F1362A6-8010
       Component: RCEPS         H39 0010
       Revision: 00001000    Serial number: 0002109131
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 326B5C7565F194DA13-8066
       Revision: 00002001    Serial number: 0321528254
       Coding: 0106063A00FA408583B0088002070E000000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000197573
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO25864234
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00005577913
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93113808
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000005221
       Coding: 030000
       VCID: 1C3792CD1F7532AA29-8048
    03405 - Bass Loudspeaker
                        Fault Status: 00111011
                        Reset counter: 151
       Coding: 011F17005E00628002000002
       VCID: 468310A5F179187AAF-8012
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000912448
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C57420D47D5C22A59-8078
       Serial number: 131211-0002-034
       Coding: 12216F601002A400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D514F097CCFCB224E-8078
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156LA0D7948570
       Coding: 020007010000000001
       VCID: 2541B7292C3FF36286-8070
       Part No SW: 4G0 035 746 J    HW: 4G0 035 746 E
       Component: H-BNT-NA      H41 1038
       Revision: --------    Serial number: 194LA0D7598243
       Coding: 060200000203F9EF7D12CB1E00000003100001000000000000
       VCID: 2E53480579C9B03A77-807A
       Subsystem 1 - Part No: 8R0 060 884 BL
       Component: NAR 2014  0902
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD003CP5U
       Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
       Serial number: 90349ML2000Z6
       Component: CD-Database  5571
                        Reset counter: 110
                        Mileage: 100890 km
                        Date: 2019.01.14
                        Time: 15:05:56
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
       VCID: 49991B99E067F70242-801C
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0120057
       Coding: 0201000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007.rod
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2643B0255939F87A8F-8072
    Address 8B: Adaptive Cruise 2
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000120512137
       Coding: 04C19A1A0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 3169537960F7AFC26A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 131119200620
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H07 0008
       Revision: 00001001    Serial number: 97812002967700
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X_AU57.rod
    End-------------------------(Elapsed Time: 06:45)--------------------------
    Gateway Installation List:  4G0 907 468 AD
    Adding data from previous scan before the fault appeared.
    Monday,01,October,2018,11:20:13:57077
    VCDS Version: 18.2.1.5 (x64)
    Mileage: 96783km-60138mi   Repair Order:
    VIN: WAUF2AFC2EN102192   Mileage: 96783km-60138miles
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7601010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 2643B0255939F8747E-8072
    "Cannot be reached" by both the Gateway and VCDS means the radar module is off-line.
    Of course there is some possibility that the radar module has an intermittent, internal failure, but check external causes like wiring and voltage supply first, before condemning it.
    Mar 2017
    So this is the radar module itself and neither of the the two front globes?
    Quote Originally Posted by gadgetman View Post
    Your car has two radar modules:
    13-Auto Dist. Reg and 8B-Adaptive Cruise 2. The second on is the one that's playing dead.
    Mar 2017
    Thanks Uwe. I'll check it when I get the car back home in the garage, traveling at the moment.
    Mar 2017
    Got back to hotel yesterday. Then went out for dinner, after starting the car the ACC was operational again. Warning light went away - no errors since the last 3 starts. Weird.
  7. #7
    Mar 2017
    Well this problem has come back intermittently. I have a service appointment with the dealer next week and will let you all know the outcome.
  8. #8
    Mar 2017
    It took the dealer a week to pinpoint the problem. It was a faulty globe (left one). That part is around $2k USD. I think they also replaced the cruise control module. They had to calibrate everything which takes about 5 hours. Fortunately this was all covered on existing CPO warranty.
  9. Likes Uwe, raf0468 liked this post
