I have occasionally been getting the ACC and Brake Guard Unavailable message when starting the car. It usually goes away if I turn off and start again.
No luck resetting today. I ran a scan and tried to clear all faults. It immediately throws a fault again. Car has not been in any accident and bumper has not been moved.
Any ideas?
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
Any ideas?
Monday,14,January,2019,15:32:29:57077
VCDS Version: 18.9.0.2 (x64)
VIN: WAUF2AFC2EN102192 License Plate:
Mileage: 100901km-62696mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
46 47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUF2AFC2EN102192 Mileage: 100901km-62696miles
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 E HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0006
Revision: NCH62---
Coding: 0A2500326546000E1000
Shop #: WSC 60542 002 1048576
ASAM Dataset: EV_ECM40TFS0114G0906014E 001004
ROD: EV_ECM40TFS0114G0906014E.rod
VCID: 2447AA2D2F050A6A91-8070
Readiness: 0110 0000
Part No SW: 4G9 927 156 C HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H02 0002
Revision: --H02---
Shop #: WSC 02391 785 00200
ROD: EV_TCMDL501021.rod
VCID: 35616769949F83E236-8060
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 65B65701A66DEA804B00
VCID: 3B757151B2BB5592C0-806E
Address 05: Acc/Start Auth. Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 ER HW: 4H0 907 064 ER
Component: BCM2 2.0 H36 0521
Coding: 0D882046000000000000
VCID: 7DF1BF49E42F9BA2BE-8028
Subsystem 2 - Part No: 4H0 905 852 C
Component: J764 ELV MLB
No Faults Found
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0093
Serial number: 04121300041899
Coding: 688120B84D
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6ADB84158DA11C1A6B-803E
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001669835
Coding: 09072091013C8FE2A90008C7A0003800CF9CD208A20802218001085C7B00
VCID: 6FED9501BE43F9323C-803A
Component: WWS57X 131203 H36 0080
Serial number: 131205122131
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22061213
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 05 12 2013 00000326
Component: USHL4.2 H30 0030
Serial number: 0000002274555R9BBV03
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000005121300010631
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000010121300010765
Coding: 110000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA106973000005335597
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 45294FD6000000000001
Revision: 11001001 Serial number: 61061335100727
Coding: A8E90A
VCID: 71E99379A077EFC22A-8024
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7601010102
VCID: 285FBE1D532DEE0ABD-807C
7 Faults Found:
31488 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 6
Reset counter: 110
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:04
Control Module temperature: 12 °C
Voltage terminal 15: 14.058 V
Velocity_vehicle_reference: -0.01 m/s
90880 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 6
Reset counter: 110
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:02
Control Module temperature: 11 °C
Voltage terminal 15: 12.737 V
32000 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 110
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:02
77824 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 6
Reset counter: 110
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:02
91392 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 6
Reset counter: 110
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:04
78592 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 6
Reset counter: 110
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:04
84224 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 11
Reset counter: 111
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:10
Voltage terminal 15: 13.997 V
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003TBP6
Coding: 303234373131303030324A55304C34473053
VCID: 336559719AEB9DD218-8066
Serial number: 6940000Y13000108PD0I
Serial number: 3575HRB401250L5CCOJ8
Serial number: 3585HRB401650L5C4117
Serial number: 3515JRB400Q50QDIL14H
Serial number: 3525JRB400G50PGAT14A
Serial number: 3554VRB400850R5KM8MZ
Serial number: 3564VRB401G50QLSE0RE
Revision: -------- Serial number: 90372MLB0003L
Coding: 0004FC
VCID: 387F6E5D8B8D7E8A2D-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 06 07 2013 11295807
Part No SW: 4G0 920 982 A HW: 4G0 920 982 A
Component: TBenUsaAccNv H58 0621
Revision: 29460235 Serial number: 658031213596018
Coding: 03CF09059F51D705020200
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 2A5B44154D21DC1AAB-807E
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001204039
Coding: 00E1034800
VCID: 72EB9C75A571D4DAD3-8026
Serial number: 3250152003
6654 - Automatic distance regulation 2
U1071 00 [009] - No communication
Fault Frequency: 6
Reset counter: 110
Mileage: 99900 km
Date: 2018.12.24
Time: 17:39:01
Voltage terminal 30: 11.9 V
Voltage terminal 15: 12.0 V
Control Module temperature: 18 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
12290 - Quiescent Current
U1406 00 [008] - Too High
Fault Frequency: 92
Reset counter: 148
Mileage: 96809 km
Date: 2018.10.01
Time: 15:58:55
Voltage terminal 30: 12.6 V
Voltage terminal 15: 0.0 V
Control Module temperature: 32 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
U140B 00 [008] - -
Fault Frequency: 72
Reset counter: 148
Mileage: 96839 km
Date: 2018.10.04
Time: 00:46:28
Voltage terminal 30: 12.3 V
Control Module temperature: 26 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 000712130001281
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 275DBD215E33E172B4-8072
Part No SW: 4G0 919 158 N HW: 4G0 919 158 N
Component: KLIMA FOND H08 0093
Serial number: 03121300041361
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
VCID: 3A7B7455BD816C9ADB-806E
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008002
ROD: EV_AirSuspe_VW51.rod
VCID: 2E53480571C9B03A77-807A
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000083614522
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77FDAD61C613B1F2E4-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7E00SJ2L
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 377D6D618E9371F224-8062
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 306F567DA3FDA6CA65-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F13.12.1300H03000AMS16087ÿ
Subsystem 4 - Serial number: S16087ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F17005E00628002000013
VCID: 458117A9CC7F1362A6-8010
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0002109131
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326B5C7565F194DA13-8066
Revision: 00002001 Serial number: 0321528254
Coding: 0106063A00FA408583B0088002070E000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000197573
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO25864234
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00005577913
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93113808
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000005221
Coding: 030000
VCID: 1C3792CD1F7532AA29-8048
03405 - Bass Loudspeaker
Fault Status: 00111011
Reset counter: 151
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 468310A5F179187AAF-8012
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000912448
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C57420D47D5C22A59-8078
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 131211-0002-034
Coding: 12216F601002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2D514F097CCFCB224E-8078
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156LA0D7948570
Coding: 020007010000000001
VCID: 2541B7292C3FF36286-8070
Part No SW: 4G0 035 746 J HW: 4G0 035 746 E
Component: H-BNT-NA H41 1038
Revision: -------- Serial number: 194LA0D7598243
Coding: 060200000203F9EF7D12CB1E00000003100001000000000000
VCID: 2E53480579C9B03A77-807A
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD003CP5U
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Serial number: 90349ML2000Z6
Component: CD-Database 5571
Reset counter: 110
Mileage: 100890 km
Date: 2019.01.14
Time: 15:05:56
Bin. Bits: 00000000 00100000
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
Component: TSG HL H03 0507
VCID: 49991B99E067F70242-801C
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0120057
Coding: 0201000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007.rod
Component: TSG HR H03 0507
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2643B0255939F87A8F-8072
Address 8B: Adaptive Cruise 2
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000120512137
Coding: 04C19A1A0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169537960F7AFC26A-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 131119200620
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H07 0008
Revision: 00001001 Serial number: 97812002967700
ROD: EV_AEMLearAU64X_AU57.rod
End-------------------------(Elapsed Time: 06:45)--------------------------
Gateway Installation List: 4G0 907 468 AD
Adding data from previous scan before the fault appeared.
Monday,01,October,2018,11:20:13:57077
VCDS Version: 18.2.1.5 (x64)
Mileage: 96783km-60138mi Repair Order:
VIN: WAUF2AFC2EN102192 Mileage: 96783km-60138miles
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7601010102
VCID: 2643B0255939F8747E-8072
