- Joined
- Apr 17, 2015
- Messages
- 275
- Reaction score
- 86
- Location
- South Africa
- VCDS Serial number
- C?ID=133909
2x Extra fault codes also on cluster: Headlight range contr defective, Start system fault funtion unavailable. And these contr modules are not picked up on the scan?
Software fault?
ABS wiring was tested and sensor and in goog working order. This morning I started it up and drove it about 500m without any faults appearing on the cluster. Parked the Audi with engine running and busy checking aftermarket PDC that is fitted, when the fault codes appeared. On Friday I wa sbale to erase all and test drive with no faults. Today cannot erase any faults.
Any suggestions?
Software fault?
Any suggestions?
Monday,14,January,2019,11:08:48:48706
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: WAUZZZ8K4DA190907 License Plate: DSC756L
Mileage: 116920km-72650mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 62 72
VIN: WAUZZZ8K4DA190907 Mileage: 116920km-72650miles
Address 01: Engine (B8-PA-CDHA) Labels:. 06H-907-115-CAB.clb
Part No SW: 8K1 907 115 N HW: 8K1 907 115 N
Component: 1.8l R4/4V TF H04 0003
Revision: PBH04---
Coding: 0A190013040401022000
Shop #: WSC 02638 996 82379
ASAM Dataset: EV_ECM18TFS0118K1907115N 001005
ROD: EV_ECM18TFS0118K1907115N.rod
VCID: 393AC809B8E7D082D2-806C
Readiness: 1110 0001
Part No SW: 8K0 907 379 CH HW: 8K0 907 379 CH
Component: ESP8 front H09 0100
Coding: 01154C
Shop #: WSC 63801 002 1048576
VCID: 014A60E998B74842DA-8054
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11101100
Reset counter: 80
Mileage: 116927 km
Date: 2019.01.13
Time: 11:01:37
Hex Value: 0x0040
Hex Value: 0x0702
Hex Value: 0x0048
Hex Value: 0xB098
Hex Value: 0x0000
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H12 0633
Coding: 03B14000000000000000
Shop #: WSC 06325 000 00000
VCID: 79BA0809F067108292-802C
Subsystem 1 - Part No SW: 8K0 959 754 D HW: 8K0 959 754 D
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0813000056302011
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000280703015
Part No SW: 8K2 820 043 Q HW: 8K2 820 043 Q
Component: KLIMA 1 ZONE H02 0121
Revision: B0000000 Serial number: 01110120130068
Coding: 642402C000
VCID: 373ECE3186F3C6F224-8062
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 80
Mileage: 116927 km
Date: 2019.01.13
Time: 10:59:21
Voltage: 13.30 V
Temperature: 32.0°C
Temperature: 32.0°C
Count: 10000
Count: 9741
Bin. Bits: 01000000
Bin. Bits: 00000011
Time: 52.00 s
Part No SW: 8K0 907 063 DE HW: 8K0 907 063 DE
Component: BCM1 1.0 H16 0103
Revision: 05016001 Serial number: 00000524094301
Coding: 2600C010803400C00081400000001D0D0F1D030827090401000004000400020100000000000000
VCID: 75A20439DC7F74E2F6-8020
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110113 H06 0080
Serial number: SWF13010115875
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AR HW: 8K0 941 531 AR
Component: E1 - LDS H03 0031
Serial number: 00000000000301130652
Subsystem 3 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 97688466000000000001
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20243549
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 80
Mileage: 116927 km
Date: 2019.01.13
Time: 11:01:56
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD97GDGQ
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 28290 001 1048576
VCID: 48DCBDCDF30DB90A5D-801C
Serial number: 6334MSME7741795DQ
Serial number: 6344MSME76712863E
Serial number: 6352QSME1A290C52I
Serial number: 6362QSME2B2D195EZ
Serial number: 63732SME3728007C
Serial number: 63832SME18271362U
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130114001394
Coding: 000012
VCID: 4FEE96D11E636E321C-801A
Component: E221 - MFL H03 0004
Reset counter: 80
Mileage: 116927 km
Date: 2019.01.13
Time: 11:01:03
Part No SW: 8K0 920 901 C HW: 8K0 920 901 C
Component: KOMBIINSTR. H09 0556
Revision: 00200000 Serial number: UVB525ADD
Coding: 3384080002010008010000
VCID: 2B16E2414ABB721250-807E
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0055
Revision: 1V070026 Serial number: 2641V13104816A
Coding: 80CF07FF00
VCID: 48DCBDCDFB0DB90A5D-801C
Serial number: 9477138901
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 13004002362011200410
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C02204001410001
VCID: 56E063B521B91FFADF-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0022077790
Coding: 100000000001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3424F93D9F852DEA01-8060
3164944 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Fehlerwert "Radgeschwindigkeiten"]
Fault Frequency: 7
Reset counter: 80
Mileage: 116927 km
Date: 2019.01.13
Time: 10:56:23
Write only channel
Revision: 00002001 Serial number: 0300039001
Coding: 011A062200B900408130013680000000
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55E264B93CBF14E2D6-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 30000000002555
ROD: EV_ParkiBrake_AU48.rod
VCID: 383CCD0D83EDC98A2D-806C
459776 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[FC_SIGNAL_ESP_FR_RADGESCHW_ERROR_VALUE]
Reset counter: 80
Mileage: 116927 km
Date: 2019.01.13
Time: 10:56:49
Voltage terminal 30: 13.2 V
Internal Fault ID: 140
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: On
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R2 035 186 N HW: 8R2 035 186 N
Component: Concert3 H05 0470
Revision: 00000002 Serial number: AUZ5Z6M1837563
Coding: 0500048004010D000158071000
VCID: 41CAA0E9D83788429A-8014
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C02204001210001
VCID: 59FA688950A73082F2-800C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0304
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
