- Jan 11, 2019
- 10
- 6
- New Zealand
- C?ID=353136
Would have taken my first scan at delivery before Christmas but only received my Dongle today.
This is the virgin scan before making some changes :-) Hope it helps others as others have helped me!
Monday,14,January,2019,11:21:14:03969
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
VIN: TMBKU7NE7K00 License Plate:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 32 36 3C 42 44 47 4B
52 5F 6C 6D A5 A9 BB BC D6 D7
VIN: TMBKU7NE7K00 Mileage: 1340km-832miles
BB-Door Rear Drv -- Status: Not registered 0001
Address 01: Engine (J623-DKTB) Labels: None
Part No SW: 5G0 906 259 S HW: 06K 907 425 J
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0C1940322444050B1000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TFS0205G0906259S 001003
ROD: EV_ECM20TFS0205G0906259S.rod
VCID: 3E253CCB60F74DE7AC7-806A
15183 - Unknown Error Code
P086B 00 [096] - -
Mileage: 518 km
Date: 2018.12.29
Time: 08:20:55
Engine speed: 2680.75 /min
Vehicle speed: 62 km/h
Coolant temperature: 101 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.609 V
Unlearning counter according OBD: 25
PV: 0.00 %
Engine: operating status: PUC
T_IGK: 655.35 s
Address 03: ABS Brakes (J104) Labels:* None
Part No SW: 5Q0 614 517 DF HW: 5Q0 614 517 AF
Component: ESC H62 0974
Revision: 00000000 Serial number: 62608000001067
Coding: 250793915426216E407B060260CA68A4C92A8402600616763443F0B1C0A9430B00000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
ROD: EV_Brake1UDSContiMK100ESP_037_SK37.rod
VCID: 78A9EAD30253B3D7A6B-802C
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0494442355
Coding: 032C0C0623
Shop #: WSC 73430 790 00063
VCID: 43D34D3F0B15200FC39-8016
Part No SW: 5E0 907 044 AQ HW: 5E0 907 044 AQ
Component: Climatronic H04 2002
Revision: 00001K00
Coding: 02110004000100011005000C0010102A
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ACClimaBHBVW37X 006147
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 74B1DEE31E3BD7B78A3-8020
Air quality sensor:
Part No SW: 5Q0 937 086 BR HW: 5Q0 937 086 BR
Revision: -------- Serial number: 865828091800T0
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 0B43A51F63C5A84FFB9-805E
Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 180817 051 0916
Serial number: 887253F0401822902086
Coding: 164DDD
Component: RLHS 052 0107
Serial number: SAY18M10D04H00M16S03
Coding: 00885D
Sun Roof:
Subsystem 3 - Part No SW: 5E9 959 591 B HW: 6R0 959 591 D
Component: J245 PS24.402 H04 0005
Serial number: 0000FST00263W4B00000
Coding: 991800
Roof Blind:
Subsystem 4 - Part No SW: 5E9 959 591 C HW: 8V3 959 591 A
Component: J394 PS24.402 H04 0005
Serial number: 0000FST00267U9I00000
Coding: 991800
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417618199
Coding: 0371167041
ASAM Dataset: EV_EPHVA2CAU3700000 009041
VCID: 51FF7777C169C29F415-8004
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 2B0060C141FFC428949C810510300600000000000000000004
VCID: 44D14E230E1B2737FA3-8010
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 18081841350097
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292AD342D373D766B-806C
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0712
Revision: -------- Serial number: 003W4PL3YSN1
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0557932745A1DE3FADD-8050
Subsystem 1 - Part No SW: ----------- HW: 454 001 309 18
Serial number: 3570000000053C8C423L
Subsystem 2 - Part No SW: ----------- HW: 454 001 509 18
Serial number: 3580000000080C4D423J
Subsystem 3 - Part No SW: ----------- HW: 454 802 209 18
Serial number: 35100F8BA7116000000P
Subsystem 4 - Part No SW: ----------- HW: 454 801 809 18
Serial number: 35200B0016516000000/
Subsystem 5 - Part No SW: ----------- HW: 454 802 808 18
Serial number: 355002D828F15000000O
Part No SW: 5Q0 953 521 LA HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0245
Revision: FF036036 Serial number: 20181004500795
Coding: 6404
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA1F6C3366B9FF7C23-8028
291104 - Temperature Sensor for Heated Steering Wheel
B1455 01 [008] - Electrical Failure
Reset counter: 60
Mileage: 10 km
Date: 2018.12.17
Time: 08:39:39
Ubat 30 Voltage: 14.40 V
Internal error state: 0
LIN_Temp: 254
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 239
Slope: 133
kp: 18
OUT: 50
Temperatur Statisch: 30
p_t_soll_0: 34.00 °C
p_t_soll_1: 39.00 °C
p_t_soll_2: 44.00 °C
Part No SW: 5E0 920 756 F HW: 5E0 920 756 F
Component: KOMBI 312 2501
Coding: 27AD09107D800008018A6B0B5001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009066
VCID: 2D070B87BD91C67F05D-8078
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 439 4344
Revision: -------- Serial number: 0008603853
Coding: 030100047F085900EB0002FB880F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3D273BC76DF156FFB5D-8068
Subsystem 2 - Part No SW: 3V0 919 719 G HW: 3V0 919 719 G
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000D1671310718
Serial number: 758860020018100108E7
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H07 0021
Serial number: 18000310569012
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F17F7A1A9A29F215-8064
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
Component: Quersperre H52 8043
Serial number: HA1-00029.06.18
Coding: 0201
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 52FD787BC46FB98778F-8006
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RID28326
Coding: 0014000000000500018280808080000000008181000000D400
ASAM Dataset: EV_SeatMemorDriveSide 002022
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0494258472
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0494016392
Coding: 020112
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000346798352
Coding: 001D0920DE01020000001100
VCID: 48C95A133233035716B-801C
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000024492932
Coding: 1D0200
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 93170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C2136C376EB5FF7823-8068
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1JJE05UKBU
Coding: 0373020000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: 59EF8F5799998ADFB95-800C
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 04101810520845
Coding: 000000070900046E06003D01010000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 353723E755C18EBF7DD-8060
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000346744628
Coding: 001D0120DE01020000001100
VCID: 47CB592F3F2D0C2F1F1-8012
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000024563100
Coding: 050200
Part No SW: 565 035 045 C HW: 565 035 045
Component: MU-H-N-RW H55 1382
Serial number: A858I0JS004953
Coding: 037352080000000041510002000000002F0101E601200500FF
VCID: 1471BE633EFB77B72A3-8040
Subsystem 1 - Part No SW: 5E0 919 606 D HW: 5E0 919 606 D
Component: ABT_High-2 H52 9130
Serial number: SKZ6ZHV2794967
Subsystem 2 - Part No SW: V03 959 801 KE HW: -----------
Component: ROW 2018/2019 --- 0071
Component: Gracenote2 --- 4013
Component: RVC Compact H15 0231
Coding: 047302010600201F000040
ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
VCID: 392F2FD779D96ADF995-806C
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 5E0 959 107 B HW: 5E0 959 107
Component: HDSG-Modul H01 0747
Revision: 42001003 Serial number: 251801282
Coding: 1233074002
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK37.rod
VCID: 2B03059F8385C84F1B9-807E
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 1272
Serial number: 27081841K23041
Coding: 020307020000010100022354C150A90084000E200000
VCID: 08499A1372B3C357D6B-805C
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0002
Serial number: 180904200061
VCID: 698FBF9749F91A5F295-803C
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416_SK26.rod
VCID: 7EA5FCCB20778DE7EC7-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LED_PLUS_R_KEBODAVW416_SK26.rod
End----------(Elapsed Time: 02:05, VBatt start/end: 12.1V/12.1V)-----------
